[PATCH 017/111] LEON3: new Console driver, APBUART driver using Driver Manager
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:19 UTC 2015
This patch reimplements the console driver of the LEON3 BSP, it
has split up the console driver in two parts: Console driver and
UART driver. Before the only UART supported was APBUART and only
on-chip APBUARTs found during startup. However splitting the
driver in two allows any UART interface to reuse the termios
attach code of the console driver, pratically this has always
been a problem when discovering APBUARTs after startup for
example the PCI board GR-RASTA-IO has APBUARTs and must wait
until after PCI has been setup.
Since the only current driver that supports the new console
driver uses the Driver Manager, the new console driver is
only enabled when Driver Manager is initialized during startup.
The new APBUART driver supports:
 * polling mode
 * interrupt mode
 * task-driven mode
 * set UART attributes
 * read UART attributes (system console inherit settings from
   boot loader)
 * Driver manager for finding/initialization of the hardware
 c/src/lib/libbsp/sparc/Makefile.am                 |    5 +-
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    3 +
 c/src/lib/libbsp/sparc/leon3/include/bsp.h         |    1 +
 c/src/lib/libbsp/sparc/leon3/include/leon.h        |   37 ++
 c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 +
 c/src/lib/libbsp/sparc/shared/include/cons.h       |   42 ++
 .../sparc/shared/include/drvmgr/ambapp_bus.h       |    1 +
 c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c  |  677 ++++++++++++++++++++
 c/src/lib/libbsp/sparc/shared/uart/cons.c          |  189 ++++++
 9 files changed, 958 insertions(+), 1 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/cons.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/uart/cons.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 67b62ca..d733ca1 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -49,7 +49,10 @@ EXTRA_DIST += shared/include/grspw.h
 EXTRA_DIST += shared/include/grspw_pci.h
 EXTRA_DIST += shared/include/grspw_rasta.h
-# UART  (APBUART)
+# UART
+EXTRA_DIST += shared/uart/cons.c
+EXTRA_DIST += shared/uart/apbuart_cons.c
+EXTRA_DIST += shared/include/cons.h
 EXTRA_DIST += shared/uart/apbuart.c
 EXTRA_DIST += shared/uart/apbuart_pci.c
 EXTRA_DIST += shared/uart/apbuart_rasta.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index f57b245..f263ab6 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -79,6 +79,9 @@ libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
 # console
 libbsp_a_SOURCES += ../../shared/console-termios.c
 libbsp_a_SOURCES += console/console.c
+libbsp_a_SOURCES += ../../sparc/shared/uart/cons.c
+libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart_cons.c
+include_HEADERS += ../../sparc/shared/include/cons.h
 # debugio
 libbsp_a_SOURCES += console/printk_support.c
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 37dfedb..d302418 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -255,6 +255,7 @@ extern const unsigned char LEON3_irq_to_cpu[32];
  * image bigger.
 #define AMBAPPBUS_INFO_AVAIL          /* AMBAPP Bus driver */
+#define APBUART_INFO_AVAIL            /* APBUART Console driver */
 #define GPTIMER_INFO_AVAIL            /* GPTIMER Timer driver */
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index 6057c42..8d7a03a 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -87,6 +87,43 @@ extern "C" {
                                               /* 0 = no function */
+ *  The following defines the bits in the UART Control Registers.
+#define LEON_REG_UART_CONTROL_RTD  0x000000FF /* RX/TX data */
+ *  The following defines the bits in the LEON UART Status Register.
+#define LEON_REG_UART_STATUS_DR   0x00000001 /* Data Ready */
+#define LEON_REG_UART_STATUS_TSE  0x00000002 /* TX Send Register Empty */
+#define LEON_REG_UART_STATUS_THE  0x00000004 /* TX Hold Register Empty */
+#define LEON_REG_UART_STATUS_BR   0x00000008 /* Break Error */
+#define LEON_REG_UART_STATUS_OE   0x00000010 /* RX Overrun Error */
+#define LEON_REG_UART_STATUS_PE   0x00000020 /* RX Parity Error */
+#define LEON_REG_UART_STATUS_FE   0x00000040 /* RX Framing Error */
+#define LEON_REG_UART_STATUS_TF   0x00000200 /* FIFO Full */
+#define LEON_REG_UART_STATUS_ERR  0x00000078 /* Error Mask */
+ *  The following defines the bits in the LEON UART Control Register.
+#define LEON_REG_UART_CTRL_RE     0x00000001 /* Receiver enable */
+#define LEON_REG_UART_CTRL_TE     0x00000002 /* Transmitter enable */
+#define LEON_REG_UART_CTRL_RI     0x00000004 /* Receiver interrupt enable */
+#define LEON_REG_UART_CTRL_TI     0x00000008 /* Transmitter interrupt enable */
+#define LEON_REG_UART_CTRL_PS     0x00000010 /* Parity select */
+#define LEON_REG_UART_CTRL_PE     0x00000020 /* Parity enable */
+#define LEON_REG_UART_CTRL_FL     0x00000040 /* Flow control enable */
+#define LEON_REG_UART_CTRL_LB     0x00000080 /* Loop Back enable */
+#define LEON_REG_UART_CTRL_DB     0x00000800 /* Debug FIFO enable */
+#define LEON_REG_UART_CTRL_SI     0x00004000 /* TX shift register empty IRQ enable */
+#define LEON_REG_UART_CTRL_FA     0x80000000 /* FIFO Available */
+#define LEON_REG_UART_CTRL_FA_BIT 31
  *  The following defines the bits in the LEON Cache Control Register.
 #define LEON3_REG_CACHE_CTRL_FI      0x00200000 /* Flush instruction cache */
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 99c8b22..a45fc31 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -109,6 +109,10 @@ $(PROJECT_INCLUDE)/tlib.h: ../../sparc/shared/include/tlib.h $(PROJECT_INCLUDE)/
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tlib.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/tlib.h
+$(PROJECT_INCLUDE)/cons.h: ../../sparc/shared/include/cons.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/cons.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/cons.h
 $(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
diff --git a/c/src/lib/libbsp/sparc/shared/include/cons.h b/c/src/lib/libbsp/sparc/shared/include/cons.h
new file mode 100644
index 0000000..2f1e517
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/cons.h
@@ -0,0 +1,42 @@
+/*  Console driver interface to UART drivers
+ *  - First console device that has System Console flag set will be
+ *    system console.
+ *  - If none of the registered console devices has system console set,
+ *    the first is registered device is used, unless it has
+ *  COPYRIGHT (c) 2010.
+ *  Cobham Gaisler AB.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef __CONS_H__
+#define __CONS_H__
+struct console_dev;
+#define CONSOLE_FLAG_SYSCON      0x01
+struct console_cons_ops {
+	void (*get_uart_attrs)(struct console_dev *, struct termios *t);
+struct console_dev {
+	/* Set to non-zero if this UART should be system console and/or
+	 * debug console.
+	int flags;
+	char *fsname; /* File system prefix */
+	const struct rtems_termios_callbacks *callbacks; /* TERMIOS Callbacks */
+	struct console_cons_ops ops;
+extern void console_dev_register(struct console_dev *dev);
+#if 0
+extern void console_dev_unregister(struct console_dev *dev);
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
index 23e8cbd..c8fca24 100644
--- a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
+++ b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
@@ -28,6 +28,7 @@ extern "C" {
 	DRIVER_ID(DRVMGR_BUS_TYPE_AMBAPP, ((((vendor) & 0xff) << 16) | ((device) & 0xfff)))
 /*** Gaisler Hardware Device Driver IDs ***/
+#define DRIVER_AMBAPP_GAISLER_APBUART_ID       DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_APBUART)
 #define DRIVER_AMBAPP_GAISLER_GPTIMER_ID       DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GPTIMER)
 struct amba_dev_id {
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index 0000000..2785286
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -0,0 +1,677 @@
+/*  This file contains the driver for the GRLIB APBUART serial port. The driver
+ *  is implemented by using the cons.c console layer. Interrupt/Polling/Task
+ *  driven mode can be configured using driver resources:
+ *  - mode   (0=Polling, 1=Interrupt, 2=Task-Driven-Interrupt Mode)
+ *  - syscon (0=Force not Ssystem Console, 1=Suggest System Console)
+ *  The BSP define APBUART_INFO_AVAIL in order to add the info routine
+ *  used for debugging.
+/******************* Driver manager interface ***********************/
+#include <bsp.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <assert.h>
+#include <rtems/bspIo.h>
+#include <string.h>
+#include <stdio.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/ambapp_bus.h>
+#include <apbuart.h>
+#include <ambapp.h>
+#include <grlib.h>
+#include <cons.h>
+#include <rtems/termiostypes.h>
+/*#define DEBUG 1  */
+#ifdef DEBUG
+#define DBG(x...) printk(x)
+#else
+#define DBG(x...)
+#endif
+/* LEON3 Low level transmit/receive functions provided by debug-uart code */
+extern void apbuart_outbyte_polled(
+  struct apbuart_regs *regs,
+  unsigned char ch,
+  int do_cr_on_newline,
+  int wait_sent);
+extern int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
+extern struct apbuart_regs *dbg_uart; /* The debug UART */
+struct apbuart_priv {
+	struct console_dev condev;
+	struct drvmgr_dev *dev;
+	struct apbuart_regs *regs;
+	char devName[32];
+	void *cookie;
+	int sending;
+	int mode;
+/* TERMIOS Layer Callback functions */
+void apbuart_get_attributes(struct console_dev *condev, struct termios *t);
+int apbuart_set_attributes(int minor, const struct termios *t);
+ssize_t apbuart_write_polled(int minor, const char *buf, size_t len);
+int apbuart_pollRead(int minor);
+ssize_t apbuart_write_intr(int minor, const char *buf, size_t len);
+int apbuart_pollRead_task(int minor);
+int apbuart_firstOpen(int major, int minor, void *arg);
+int apbuart_lastClose(int major, int minor, void *arg);
+void apbuart_isr(void *arg);
+int apbuart_get_baud(struct apbuart_priv *uart);
+int apbuart_init1(struct drvmgr_dev *dev);
+#ifdef APBUART_INFO_AVAIL
+static int apbuart_info(
+	struct drvmgr_dev *dev,
+	void (*print_line)(void *p, char *str),
+	void *p, int, char *argv[]);
+#define APBUART_INFO_FUNC apbuart_info
+#else
+#define APBUART_INFO_FUNC NULL
+#endif
+struct drvmgr_drv_ops apbuart_ops =
+	.init = {apbuart_init1, NULL, NULL, NULL},
+	.remove = NULL,
+	.info = APBUART_INFO_FUNC
+static struct amba_dev_id apbuart_ids[] =
+	{VENDOR_GAISLER, GAISLER_APBUART},
+	{0, 0}		/* Mark end of table */
+static struct amba_drv_info apbuart_drv_info =
+		DRVMGR_OBJ_DRV,				/* Driver */
+		NULL,					/* Next driver */
+		NULL,					/* Device list */
+		DRIVER_AMBAPP_GAISLER_APBUART_ID,	/* Driver ID */
+		"APBUART_DRV",				/* Driver Name */
+		DRVMGR_BUS_TYPE_AMBAPP,			/* Bus Type */
+		&apbuart_ops,
+		NULL,					/* Funcs */
+		0,					/* No devices yet */
+		sizeof(struct apbuart_priv),		/*DrvMgr alloc private*/
+	&apbuart_ids[0]
+void apbuart_cons_register_drv (void)
+	DBG("Registering APBUART Console driver\n");
+	drvmgr_drv_register(&apbuart_drv_info.general);
+/* Interrupt mode routines */
+static const rtems_termios_callbacks Callbacks_intr = {
+    apbuart_firstOpen,           /* firstOpen */
+    apbuart_lastClose,           /* lastClose */
+    NULL,                        /* pollRead */
+    apbuart_write_intr,          /* write */
+    apbuart_set_attributes,      /* setAttributes */
+    NULL,                        /* stopRemoteTx */
+    NULL,                        /* startRemoteTx */
+    TERMIOS_IRQ_DRIVEN           /* outputUsesInterrupts */
+/* Polling mode routines */
+static const rtems_termios_callbacks Callbacks_task = {
+    apbuart_pollRead_task,       /* pollRead */
+    TERMIOS_TASK_DRIVEN          /* outputUsesInterrupts */
+static const rtems_termios_callbacks Callbacks_poll = {
+    apbuart_pollRead,            /* pollRead */
+    apbuart_write_polled,        /* write */
+    TERMIOS_POLLED               /* outputUsesInterrupts */
+	struct apbuart_priv *priv;
+	struct amba_dev_info *ambadev;
+	struct ambapp_core *pnpinfo;
+	union drvmgr_key_value *value;
+	char prefix[32];
+	unsigned int db;
+	static int first_uart = 1;
+	/* The default operation in AMP is to use APBUART[0] for CPU[0],
+	 * APBUART[1] for CPU[1] and so on. The remaining UARTs is not used
+	 * since we don't know how many CPU-cores there are. Note this only
+	 * affects the on-chip amba bus (the root bus). The user can override
+	 * the default resource sharing by defining driver resources for the
+	 * APBUART devices on each AMP OS instance.
+#if defined(RTEMS_MULTIPROCESSING) && defined(LEON3)
+	if (drvmgr_on_rootbus(dev) && dev->minor_drv != LEON3_Cpu_Index &&
+	    drvmgr_keys_get(dev, NULL) != 0) {
+		/* User hasn't configured on-chip APBUART, leave it untouched */
+		return DRVMGR_EBUSY;
+#endif
+	DBG("APBUART[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
+	/* Private data was allocated and zeroed by driver manager */
+	priv = dev->priv;
+	if (!priv)
+		return DRVMGR_NOMEM;
+	priv->dev = dev;
+	/* Get device information from AMBA PnP information */
+	ambadev = (struct amba_dev_info *)priv->dev->businfo;
+	if (ambadev == NULL)
+		return -1;
+	pnpinfo = &ambadev->info;
+	priv->regs = (struct apbuart_regs *)pnpinfo->apb_slv->start;
+	/* Clear HW regs, leave baudrate register as it is */
+	priv->regs->status = 0;
+	/* leave debug bit, and Transmitter/receiver if this is the debug UART */
+#ifdef LEON3
+	if (priv->regs == dbg_uart) {
+		db = priv->regs->ctrl & (LEON_REG_UART_CTRL_DB |
+					LEON_REG_UART_CTRL_RE |
+					LEON_REG_UART_CTRL_TE |
+					LEON_REG_UART_CTRL_FL |
+					LEON_REG_UART_CTRL_PE |
+					LEON_REG_UART_CTRL_PS);
+	} else
+#endif
+		db = priv->regs->ctrl & LEON_REG_UART_CTRL_DB;
+	priv->regs->ctrl = db;
+	/* The system console and Debug console may depend on this device, so
+	 * initialize it straight away.
+	 * We default to have System Console on first APBUART, user may override
+	 * this behaviour by setting the syscon option to 0.
+	if (drvmgr_on_rootbus(dev) && first_uart) {
+		priv->condev.flags = CONSOLE_FLAG_SYSCON;
+		first_uart = 0;
+	} else {
+		priv->condev.flags = 0;
+	value = drvmgr_dev_key_get(priv->dev, "syscon", KEY_TYPE_INT);
+	if (value) {
+		if (value->i)
+			priv->condev.flags |= CONSOLE_FLAG_SYSCON;
+		else
+			priv->condev.flags &= ~CONSOLE_FLAG_SYSCON;
+	priv->condev.fsname = NULL;
+	priv->condev.ops.get_uart_attrs = apbuart_get_attributes;
+	/* Select 0=Polled, 1=IRQ, 2=Task-Driven UART Mode */
+	value = drvmgr_dev_key_get(priv->dev, "mode", KEY_TYPE_INT);
+	if (value)
+		priv->mode = value->i;
+	else
+		priv->mode = TERMIOS_POLLED;
+	if (priv->mode == TERMIOS_IRQ_DRIVEN) {
+		priv->condev.callbacks = &Callbacks_intr;
+	} else if (priv->mode == TERMIOS_TASK_DRIVEN) {
+		priv->condev.callbacks = &Callbacks_task;
+	} else {
+		priv->condev.callbacks = &Callbacks_poll;
+	/* Get Filesystem name prefix */
+	prefix[0] = '\0';
+	if (drvmgr_get_dev_prefix(dev, prefix)) {
+		/* Got special prefix, this means we have a bus prefix
+		 * And we should use our "bus minor"
+		sprintf(priv->devName, "/dev/%sapbuart%d", prefix, dev->minor_bus);
+		priv->condev.fsname = priv->devName;
+	/* Register it as a console device, the console driver will register
+	 * a termios device as well
+	console_dev_register(&priv->condev);
+	return DRVMGR_OK;
+	void *p, int argc, char *argv[])
+	struct apbuart_priv *priv = dev->priv;
+	char *str1;
+	char buf[64];
+	if (dev->priv == NULL)
+		return -DRVMGR_EINVAL;
+	if (priv->mode == TERMIOS_POLLED)
+		str1 = "TERMIOS_POLLED";
+	else if (priv->mode == TERMIOS_TASK_DRIVEN)
+		str1 = "TERMIOS_TASK_DRIVEN";
+	else
+		str1 = "BAD MODE";
+	sprintf(buf, "UART Mode:   %s", str1);
+	print_line(p, buf);
+	if (priv->condev.fsname) {
+		sprintf(buf, "FS Name:     %s", priv->condev.fsname);
+	sprintf(buf, "STATUS REG:  0x%x", priv->regs->status);
+	sprintf(buf, "CTRL REG:    0x%x", priv->regs->ctrl);
+	sprintf(buf, "SCALER REG:  0x%x  baud rate %d",
+				priv->regs->scaler, apbuart_get_baud(priv));
+	return DRVMGR_OK;
+#endif
+#ifndef LEON3
+/* This routine transmits a character, it will busy-wait until on character
+ * fits in the APBUART Transmit FIFO
+void apbuart_outbyte_polled(
+  unsigned char ch,
+  int wait_sent)
+send:
+	while ((regs->status & LEON_REG_UART_STATUS_THE) == 0) {
+		/* Lower bus utilization while waiting for UART */
+		asm volatile ("nop"::);	asm volatile ("nop"::);
+	regs->data = (unsigned int) ch;
+	if ((ch == '\n') && do_cr_on_newline) {
+		ch = '\r';
+		goto send;
+	/* Wait until the character has been sent? */
+	if (wait_sent) {
+/* This routine polls for one character, return EOF if no character is available */
+int apbuart_inbyte_nonblocking(struct apbuart_regs *regs)
+	if (regs->status & LEON_REG_UART_STATUS_ERR) {
+		regs->status = ~LEON_REG_UART_STATUS_ERR;
+	if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
+		return EOF;
+	return (int)regs->data;
+#endif
+	struct apbuart_priv *uart = (struct apbuart_priv *)minor;
+	rtems_libio_open_close_args_t *ioarg = arg;
+	if ( ioarg && ioarg->iop )
+		uart->cookie = ioarg->iop->data1;
+	else
+		uart->cookie = NULL;
+	/* Enable TX/RX */
+	uart->regs->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
+	if (uart->mode != TERMIOS_POLLED) {
+		/* Register interrupt and enable it */
+		drvmgr_interrupt_register(uart->dev, 0, "apbuart",
+						apbuart_isr, uart);
+		uart->sending = 0;
+		/* Turn on RX interrupts */
+		uart->regs->ctrl |= LEON_REG_UART_CTRL_RI;
+	return 0;
+		/* Turn off RX interrupts */
+		uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RI);
+		/**** Flush device ****/
+		while (uart->sending) {
+			/* Wait until all data has been sent */
+		/* Disable and unregister interrupt handler */
+		drvmgr_interrupt_unregister(uart->dev, 0, apbuart_isr, uart);
+#ifdef LEON3
+	/* Disable TX/RX if not used for DEBUG */
+	if (uart->regs != dbg_uart)
+		uart->regs->ctrl &= ~(LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE);
+#endif
+	return 0;
+	return apbuart_inbyte_nonblocking(uart->regs);
+	int c, tot;
+	char buf[32];
+	tot = 0;
+	while ((c=apbuart_inbyte_nonblocking(uart->regs)) != EOF) {
+		buf[tot] = c;
+		tot++;
+		if (tot > 31) {
+			rtems_termios_enqueue_raw_characters(uart->cookie, buf, tot);
+			tot = 0;
+	if (tot > 0)
+	return EOF;
+struct apbuart_baud {
+	unsigned int num;
+	unsigned int baud;
+struct apbuart_baud apbuart_baud_table[] = {
+	{B50, 50},
+	{B75, 75},
+	{B110, 110},
+	{B134, 134},
+	{B150, 150},
+	{B200, 200},
+	{B300, 300},
+	{B600, 600},
+	{B1200, 1200},
+	{B1800, 1800},
+	{B2400, 2400},
+	{B4800, 4800},
+	{B9600, 9600},
+	{B19200, 19200},
+	{B38400, 38400},
+	{B57600, 57600},
+	{B115200, 115200},
+	{B230400, 230400},
+	{B460800, 460800},
+#define BAUD_NUM (sizeof(apbuart_baud_table)/sizeof(struct apbuart_baud))
+int apbuart_baud_num2baud(unsigned int num)
+	int i;
+	for(i=0; i<BAUD_NUM; i++)
+		if (apbuart_baud_table[i].num == num)
+			return apbuart_baud_table[i].baud;
+	return -1;
+struct apbuart_baud *apbuart_baud_find_closest(unsigned int baud)
+	int i, diff;
+	for(i=0; i<BAUD_NUM-1; i++) {
+		diff = apbuart_baud_table[i+1].baud -
+			apbuart_baud_table[i].baud;
+		if (baud < (apbuart_baud_table[i].baud + diff/2))
+			return &apbuart_baud_table[i];
+	return &apbuart_baud_table[BAUD_NUM-1];
+	unsigned int core_clk_hz;
+	unsigned int scaler;
+	/* Get current scaler setting */
+	scaler = uart->regs->scaler;
+	/* Get APBUART core frequency */
+	drvmgr_freq_get(uart->dev, DEV_APB_SLV, &core_clk_hz);
+	/* Calculate baud rate from generator "scaler" number */
+	return core_clk_hz / ((scaler + 1) * 8);
+struct apbuart_baud *apbuart_get_baud_closest(struct apbuart_priv *uart)
+	return apbuart_baud_find_closest(apbuart_get_baud(uart));
+	unsigned int ctrl;
+	int baud;
+	switch(t->c_cflag & CSIZE) {
+		default:
+		case CS5:
+		case CS6:
+		case CS7:
+			/* Hardware doesn't support other than CS8 */
+			return -1;
+		case CS8:
+			break;
+	/* Read out current value */
+	ctrl = uart->regs->ctrl;
+	switch(t->c_cflag & (PARENB|PARODD)){
+		case (PARENB|PARODD):
+			/* Odd parity */
+			ctrl |= LEON_REG_UART_CTRL_PE|LEON_REG_UART_CTRL_PS;
+			break;
+		case PARENB:
+			/* Even parity */
+			ctrl &= ~LEON_REG_UART_CTRL_PS;
+			ctrl |= LEON_REG_UART_CTRL_PE;
+			break;
+		default:
+		case 0:
+		case PARODD:
+			/* No Parity */
+			ctrl &= ~(LEON_REG_UART_CTRL_PS|LEON_REG_UART_CTRL_PE);
+	if (!(t->c_cflag & CLOCAL))
+		ctrl |= LEON_REG_UART_CTRL_FL;
+	else
+		ctrl &= ~LEON_REG_UART_CTRL_FL;
+	/* Update new settings */
+	uart->regs->ctrl = ctrl;
+	/* Baud rate */
+	baud = apbuart_baud_num2baud(t->c_cflag & CBAUD);
+	if (baud > 0){
+		/* Calculate Baud rate generator "scaler" number */
+		scaler = (((core_clk_hz*10)/(baud*8))-5)/10;
+		/* Set new baud rate by setting scaler */
+		uart->regs->scaler = scaler;
+	return 0;
+	struct apbuart_priv *uart = (struct apbuart_priv *)condev;
+	struct apbuart_baud *baud;
+	t->c_cflag = t->c_cflag & ~(CSIZE|PARENB|PARODD|CLOCAL|CBAUD);
+	/* Hardware support only CS8 */
+	t->c_cflag |= CS8;
+	/* Read out current parity */
+	if (ctrl & LEON_REG_UART_CTRL_PE) {
+		if (ctrl & LEON_REG_UART_CTRL_PS)
+			t->c_cflag |= PARENB|PARODD; /* Odd parity */
+		else
+			t->c_cflag |= PARENB; /* Even parity */
+	if ((ctrl & LEON_REG_UART_CTRL_FL) == 0)
+		t->c_cflag |= CLOCAL;
+	baud = apbuart_get_baud_closest(uart);
+	t->c_cflag |= baud->num;
+	int nwrite = 0;
+	while (nwrite < len) {
+		apbuart_outbyte_polled(uart->regs, *buf++, 0, 0);
+		nwrite++;
+	return nwrite;
+	unsigned int oldLevel;
+	rtems_interrupt_disable(oldLevel);
+	/* Enable TX interrupt */
+	uart->regs->ctrl = ctrl | LEON_REG_UART_CTRL_TI;
+	if (ctrl & LEON_REG_UART_CTRL_FA) {
+		/* APBUART with FIFO.. Fill as many as FIFO allows */
+		while (((uart->regs->status & LEON_REG_UART_STATUS_TF) == 0) &&
+		       (uart->sending < len)) {
+			uart->regs->data = *buf;
+			buf++;
+			uart->sending++;
+	} else {
+		/* start UART TX, this will result in an interrupt when done */
+		uart->sending = 1;
+	rtems_interrupt_enable(oldLevel);
+	return 0;
+/* Handle UART interrupts */
+	struct apbuart_priv *uart = arg;
+	unsigned int status;
+	char data;
+	int cnt;
+	/* Get all received characters */
+	if (uart->mode == TERMIOS_TASK_DRIVEN) {
+		if ((status=uart->regs->status) & LEON_REG_UART_STATUS_DR)
+			rtems_termios_rxirq_occured(uart->cookie);
+	} else {
+		while ((status=uart->regs->status) & LEON_REG_UART_STATUS_DR) {
+			/* Data has arrived, get new data */
+			data = uart->regs->data;
+			/* Tell termios layer about new character */
+			rtems_termios_enqueue_raw_characters(uart->cookie, &data, 1);
+	if (uart->sending && (status & LEON_REG_UART_STATUS_THE)) {
+		/* Sent the one char, we disable TX interrupts */
+		uart->regs->ctrl &= ~LEON_REG_UART_CTRL_TI;
+		/* Tell close that we sent everything */
+		cnt = uart->sending;
+		/* apbuart_write_intr() will get called from this function */
+		rtems_termios_dequeue_characters(uart->cookie, cnt);
diff --git a/c/src/lib/libbsp/sparc/shared/uart/cons.c b/c/src/lib/libbsp/sparc/shared/uart/cons.c
index 0000000..3de9f54
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/uart/cons.c
@@ -0,0 +1,189 @@
+/*  This file contains the TTY driver for the serial ports. The driver
+ *  is layered so that different UART hardware can be used. It is implemented
+ *  using the Driver Manager.
+ *  This driver uses the termios pseudo driver.
+#include <bsp.h>
+#include <cons.h>
+#ifdef RTEMS_DRVMGR_STARTUP
+/* Note that it is not possible to use the interrupt mode of the driver
+ * together with the "old" APBUART and -u to GRMON. However the new
+ * APBUART core (from 1.0.17-b2710) has the GRMON debug bit and can
+ * handle interrupts.
+int console_initialized = 0;
+rtems_device_major_number console_major = 0;
+#define FLAG_SYSCON 0x01
+struct console_priv {
+	unsigned char flags; /* 0x1=SystemConsole */
+	unsigned char minor;
+	struct console_dev *dev;
+#define CONSOLE_MAX BSP_NUMBER_OF_TERMIOS_PORTS
+struct console_priv cons[CONSOLE_MAX] = {{0,0},};
+/* Register Console to TERMIOS layer and initialize it */
+void console_dev_init(struct console_priv *con, int minor)
+	char name[16], *fsname;
+	rtems_status_code status;
+	if (!con->dev->fsname) {
+		strcpy(name, "/dev/console_a");
+		/* Special console name and MINOR for SYSTEM CONSOLE */
+		if (minor == 0)
+			name[12] = '\0'; /* /dev/console */
+		name[13] += minor; /* when minor=0, this has no effect... */
+		fsname = name;
+	} else {
+		fsname = con->dev->fsname;
+	status = rtems_io_register_name(fsname, console_major, minor);
+	if ((minor == 0) && (status != RTEMS_SUCCESSFUL))
+		rtems_fatal_error_occurred(status);
+void console_dev_register(struct console_dev *dev)
+	int i, minor = 0;
+	struct console_priv *con = NULL;
+	if ((dev->flags & CONSOLE_FLAG_SYSCON) && !cons[0].dev) {
+		con = &cons[0];
+		con->flags = FLAG_SYSCON;
+	} else {
+		for (i=1; i<CONSOLE_MAX; i++) {
+			if (!cons[i].dev) {
+				con = &cons[i];
+				con->flags = 0;
+				minor = i;
+				break;
+	if (con == NULL) {
+		/* Not enough console structures */
+		return;
+	/* Assign Console */
+	con->dev = dev;
+	con->minor = minor;
+	/* Console layer is already initialized, that means that we can
+	 * register termios interface directly.
+	if (console_initialized)
+		console_dev_init(con, minor);
+#if 0
+void console_dev_unregister(struct console_dev *dev)
+#endif
+rtems_device_driver console_initialize(
+	rtems_device_major_number	major,
+	rtems_device_minor_number	minor,
+	void				*arg)
+	int i;
+	console_major = major;
+	rtems_termios_initialize();
+	/* Register all Console a file system device node */
+	for (i=0; i<CONSOLE_MAX; i++) {
+		if (cons[i].dev)
+			console_dev_init(&cons[i], i);
+	console_initialized = 1;
+	return RTEMS_SUCCESSFUL;
+rtems_device_driver console_open(
+	void				*arg)
+	struct termios term;
+	if ((minor >= CONSOLE_MAX) || !cons[minor].dev)
+		return RTEMS_INVALID_NUMBER;
+	status = rtems_termios_open(
+			major,
+			(int)cons[minor].dev,
+			arg,
+			cons[minor].dev->callbacks);
+	/* Inherit UART hardware parameters from bootloader on system console */
+	if ((status == RTEMS_SUCCESSFUL) && (cons[minor].flags & FLAG_SYSCON) &&
+	    (cons[minor].dev->ops.get_uart_attrs != NULL)) {
+		if (tcgetattr(STDIN_FILENO, &term) >= 0) {
+			cons[minor].dev->ops.get_uart_attrs(cons[minor].dev,
+								&term);
+			term.c_oflag |= ONLCR;
+			tcsetattr(STDIN_FILENO, TCSANOW, &term);
+	return status;
+rtems_device_driver console_close(
+	void				*arg)
+	return rtems_termios_close(arg);
+rtems_device_driver console_read(
+	void				*arg)
+	return rtems_termios_read(arg);
+rtems_device_driver console_write(
+	void				*arg)
+	return rtems_termios_write(arg);
+rtems_device_driver console_control(
+	void				*arg)
+	return rtems_termios_ioctl(arg);
+#endif
1.7.0.4
