[PATCH 020/111] LEON: updated and added PCI peripherals for LEON BSPs
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:22 UTC 2015
The CCHIP driver is replaced with the GR_701 driver. The
RASTA driver is replaced by the GR-RASTA-IO driver.
All drivers are now compatible with both LEON2 and LEON3,
drivers were initialized directly by the PCI-board drivers
are now initialized by the driver manager and therefore
does not require the double code created by including for
example grcan.c into grcan_rasta.c. The other drivers needs
to be updated to the driver manager framework however.
Added support for:
 * GR-701 (only LEON2 before)
 * GR-RASTA-IO (only LEON2 before)
 * GR-RASTA-ADCDAC
 * GR-RASTA-TMTC
 * GR-RASTA-SPW-ROUTER
 * GR-TMTC-1553
 c/src/lib/libbsp/sparc/Makefile.am                 |   29 +-
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |   55 +-
 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c         |  375 -----------
 c/src/lib/libbsp/sparc/leon2/include/cchip.h       |   42 --
 c/src/lib/libbsp/sparc/leon2/include/rasta.h       |  132 ----
 c/src/lib/libbsp/sparc/leon2/preinstall.am         |  100 ++--
 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c         |  386 -----------
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |   31 +-
 c/src/lib/libbsp/sparc/leon3/preinstall.am         |   36 +-
 c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c  |  135 ----
 .../lib/libbsp/sparc/shared/1553/b1553brm_rasta.c  |  117 ----
 c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c    |  100 ---
 c/src/lib/libbsp/sparc/shared/can/occan_pci.c      |   65 --
 .../lib/libbsp/sparc/shared/include/apbuart_pci.h  |   47 --
 .../libbsp/sparc/shared/include/apbuart_rasta.h    |   47 --
 .../lib/libbsp/sparc/shared/include/b1553brm_pci.h |   61 --
 .../libbsp/sparc/shared/include/b1553brm_rasta.h   |   61 --
 c/src/lib/libbsp/sparc/shared/include/gr_701.h     |   48 ++
 .../libbsp/sparc/shared/include/gr_rasta_adcdac.h  |   49 ++
 .../lib/libbsp/sparc/shared/include/gr_rasta_io.h  |   49 ++
 .../libbsp/sparc/shared/include/gr_rasta_tmtc.h    |   99 +++
 .../lib/libbsp/sparc/shared/include/gr_tmtc_1553.h |   49 ++
 .../lib/libbsp/sparc/shared/include/grcan_rasta.h  |   29 -
 c/src/lib/libbsp/sparc/shared/include/grspw_pci.h  |   53 --
 .../lib/libbsp/sparc/shared/include/grspw_rasta.h  |   53 --
 c/src/lib/libbsp/sparc/shared/include/occan_pci.h  |   46 --
 c/src/lib/libbsp/sparc/shared/pci/gr_701.c         |  592 +++++++++++++++++
 .../lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c  |  661 +++++++++++++++++++
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c    |  678 +++++++++++++++++++
 .../libbsp/sparc/shared/pci/gr_rasta_spw_router.c  |  675 +++++++++++++++++++
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c  |  684 ++++++++++++++++++++
 c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c   |  571 ++++++++++++++++
 c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c      |  132 ----
 c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c    |  158 -----
 c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c   |   44 --
 c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c |   43 --
 36 files changed, 4272 insertions(+), 2260 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
 delete mode 100644 c/src/lib/libbsp/sparc/leon2/include/cchip.h
 delete mode 100644 c/src/lib/libbsp/sparc/leon2/include/rasta.h
 delete mode 100644 c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/can/occan_pci.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_701.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_rasta_io.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
 delete mode 100644 c/src/lib/libbsp/sparc/shared/include/occan_pci.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_701.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
 delete mode 100644 c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 3f0854e..719feba 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -42,45 +42,42 @@ EXTRA_DIST += shared/pci/pcif.c
 EXTRA_DIST += shared/pci/pci_memreg_sparc_le.c
 EXTRA_DIST += shared/pci/pci_memreg_sparc_be.c
+# PCI target boards
+EXTRA_DIST += shared/include/gr_701.h
+EXTRA_DIST += shared/include/gr_rasta_adcdac.h
+EXTRA_DIST += shared/include/gr_rasta_io.h
+EXTRA_DIST += shared/include/gr_rasta_tmtc.h
+EXTRA_DIST += shared/include/gr_tmtc_1553.h
+EXTRA_DIST += shared/pci/gr_701.c
+EXTRA_DIST += shared/pci/gr_rasta_adcdac.c
+EXTRA_DIST += shared/pci/gr_rasta_io.c
+EXTRA_DIST += shared/pci/gr_rasta_spw_router.c
+EXTRA_DIST += shared/pci/gr_rasta_tmtc.c
+EXTRA_DIST += shared/pci/gr_tmtc_1553.c
 # DEBUG
 EXTRA_DIST += shared/include/debug_defs.h
 # SpaceWire (GRSPW)
 EXTRA_DIST += shared/spw/grspw.c
-EXTRA_DIST += shared/spw/grspw_pci.c
-EXTRA_DIST += shared/spw/grspw_rasta.c
 EXTRA_DIST += shared/include/grspw.h
-EXTRA_DIST += shared/include/grspw_pci.h
-EXTRA_DIST += shared/include/grspw_rasta.h
 # UART
 EXTRA_DIST += shared/uart/cons.c
 EXTRA_DIST += shared/uart/apbuart_cons.c
 EXTRA_DIST += shared/include/cons.h
 EXTRA_DIST += shared/uart/apbuart.c
-EXTRA_DIST += shared/uart/apbuart_pci.c
-EXTRA_DIST += shared/uart/apbuart_rasta.c
 EXTRA_DIST += shared/include/apbuart.h
-EXTRA_DIST += shared/include/apbuart_pci.h
-EXTRA_DIST += shared/include/apbuart_rasta.h
 # CAN (OC_CAN, GRCAN)
 EXTRA_DIST += shared/can/occan.c
-EXTRA_DIST += shared/can/occan_pci.c
 EXTRA_DIST += shared/can/grcan.c
-EXTRA_DIST += shared/can/grcan_rasta.c
 EXTRA_DIST += shared/include/occan.h
-EXTRA_DIST += shared/include/occan_pci.h
 EXTRA_DIST += shared/include/grcan.h
-EXTRA_DIST += shared/include/grcan_rasta.h
 # MIL-STD-B1553 (Core1553BRM)
 EXTRA_DIST += shared/1553/b1553brm.c
-EXTRA_DIST += shared/1553/b1553brm_pci.c
-EXTRA_DIST += shared/1553/b1553brm_rasta.c
 EXTRA_DIST += shared/include/b1553brm.h
-EXTRA_DIST += shared/include/b1553brm_pci.h
-EXTRA_DIST += shared/include/b1553brm_rasta.h
 # I2C-master (I2CMST)
 EXTRA_DIST += shared/i2c/i2cmst.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index e923025..008e203 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -8,21 +8,6 @@ dist_project_lib_DATA = bsp_specs
 include_HEADERS = include/bsp.h
 include_HEADERS += include/tm27.h
-include_HEADERS += include/rasta.h
-include_HEADERS += include/cchip.h
-include_HEADERS += ../../sparc/shared/include/grspw.h
-include_HEADERS += ../../sparc/shared/include/grspw_pci.h
-include_HEADERS += ../../sparc/shared/include/grspw_rasta.h
-include_HEADERS += ../../sparc/shared/include/occan.h
-include_HEADERS += ../../sparc/shared/include/occan_pci.h
-include_HEADERS += ../../sparc/shared/include/grcan.h
-include_HEADERS += ../../sparc/shared/include/grcan_rasta.h
-include_HEADERS += ../../sparc/shared/include/apbuart.h
-include_HEADERS += ../../sparc/shared/include/apbuart_pci.h
-include_HEADERS += ../../sparc/shared/include/apbuart_rasta.h
-include_HEADERS += ../../sparc/shared/include/b1553brm.h
-include_HEADERS += ../../sparc/shared/include/b1553brm_pci.h
-include_HEADERS += ../../sparc/shared/include/b1553brm_rasta.h
 include_HEADERS += ../../sparc/shared/include/debug_defs.h
 nodist_include_HEADERS = include/bspopts.h
@@ -111,30 +96,40 @@ libbsp_a_SOURCES += ../../sparc/shared/timer/tlib.c
 include_HEADERS += ../../sparc/shared/include/grpci2.h
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci2.c
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci.c
+libbsp_a_SOURCES += ../../sparc/shared/pci/pcif.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/pci_memreg_sparc_le.c
 libbsp_a_SOURCES +=  ../../sparc/shared/pci/pci_memreg_sparc_be.c
 libbsp_a_SOURCES +=  pci/at697_pci.c
-# RASTA Kit
-libbsp_a_SOURCES += rasta/rasta.c
-# Companion Chip Kit
-libbsp_a_SOURCES += cchip/cchip.c
+# PCI target devices
+include_HEADERS += ../../sparc/shared/include/gr_701.h
+include_HEADERS += ../../sparc/shared/include/gr_rasta_adcdac.h
+include_HEADERS += ../../sparc/shared/include/gr_rasta_io.h
+include_HEADERS += ../../sparc/shared/include/gr_rasta_tmtc.h
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_701.c
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_adcdac.c
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_io.c
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_spw_router.c
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_rasta_tmtc.c
 # B1553BRM
-libbsp_a_SOURCES += ../../sparc/shared/1553/b1553brm.c \
-    ../../sparc/shared/1553/b1553brm_pci.c \
-    ../../sparc/shared/1553/b1553brm_rasta.c
+include_HEADERS += ../../sparc/shared/include/b1553brm.h
+libbsp_a_SOURCES += ../../sparc/shared/1553/b1553brm.c
 # CAN
+include_HEADERS += ../../sparc/shared/include/occan.h
+include_HEADERS += ../../sparc/shared/include/grcan.h
 libbsp_a_SOURCES += ../../sparc/shared/can/occan.c \
-    ../../sparc/shared/can/occan_pci.c \
-    ../../sparc/shared/can/grcan.c \
-    ../../sparc/shared/can/grcan_rasta.c
+    ../../sparc/shared/can/grcan.c
 # SpaceWire
-libbsp_a_SOURCES += ../../sparc/shared/spw/grspw.c \
-    ../../sparc/shared/spw/grspw_pci.c ../../sparc/shared/spw/grspw_rasta.c
+include_HEADERS += ../../sparc/shared/include/grspw.h
+libbsp_a_SOURCES += ../../sparc/shared/spw/grspw.c
 # UART (RAW)
-libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart.c \
-    ../../sparc/shared/uart/apbuart_pci.c \
-    ../../sparc/shared/uart/apbuart_rasta.c
+include_HEADERS += ../../sparc/shared/include/apbuart.h
+libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart.c
 # I2CMST
 include_HEADERS += ../../sparc/shared/include/i2cmst.h
 libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
diff --git a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c b/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
deleted file mode 100644
index 72419d5..0000000
--- a/c/src/lib/libbsp/sparc/leon2/cchip/cchip.c
+++ /dev/null
@@ -1,375 +0,0 @@
- * @file
- * @ingroup cchip
- * @brief GR-701 (Companion Chip) PCI board driver
- *  COPYRIGHT (c) 2007.
- *  Aeroflex Gaisler AB.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <rtems/bspIo.h>
-#include <rtems.h>
-#include <string.h>
-#include <rtems.h>
-#include <leon.h>
-#include <ambapp.h>
-#include <pci.h>
-#include <b1553brm_pci.h>
-#include <occan_pci.h>
-#include <grspw_pci.h>
-#include <apbuart_pci.h>
-#include <cchip.h>
-#define DEBUG
-#define DEBUG_IRQS
-#define BOARD_INFO
-/*#define PRINT_SPURIOUS*/
-/* AT697 Register MAP */
-static LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
-/* initializes interrupt management for companionship board */
-void cchip1_irq_init(void);
-/* register interrupt handler (called from drivers) */
-void cchip1_set_isr(void *handler, int irqno, void *arg);
-#define READ_REG(address) _READ_REG((unsigned int)address)
-static __inline__ unsigned int _READ_REG(unsigned int addr) {
-  unsigned int tmp;
-  __asm__ ("lda [%1]1, %0 "
-    : "=r"(tmp)
-    : "r"(addr)
-  return tmp;
-/* PCI bride reg layout on AMBA side */
-typedef struct {
-  unsigned int bar0;
-  unsigned int bar1;
-  unsigned int bar2;
-  unsigned int bar3;
-  unsigned int bar4;/* 0x10 */
-  unsigned int unused[4*3-1];
-  unsigned int ambabars[1]; /* 0x40 */
-} amba_bridge_regs;
-/* PCI bride reg layout on PCI side */
-typedef struct {
-  unsigned int bar4; /* 0x10 */
-  unsigned int ilevel;
-  unsigned int ipend;
-  unsigned int iforce;
-  unsigned int istatus;
-  unsigned int iclear;
-  unsigned int imask;
-} pci_bridge_regs;
-typedef struct {
-  pci_bridge_regs  *pcib;
-  amba_bridge_regs *ambab;
-  /* AT697 PCI */
-  uint32_t bars[5];
-  int bus, dev, fun;
-  /* AMBA bus */
-  struct ambapp_bus amba_bus;
-  struct ambapp_mmap amba_maps[2];
-  /* FT AHB SRAM */
-  int ftsram_size; /* kb */
-  unsigned int ftsram_start;
-  unsigned int ftsram_end;
-} cchip1;
-cchip1 cc1;
-static int init_pcif(void)
-  uint32_t com1;
-  int i,bus,dev,fun;
-  struct ambapp_bus *abus;
-  if ( BSP_pciFindDevice(0x1AC8, 0x0701, 0, &bus, &dev, &fun) == 0 ) {
-  }else if (BSP_pciFindDevice(0x16E3, 0x0210, 0, &bus, &dev, &fun) == 0) {
-  } else {
-    /* didn't find any Companionship board on the PCI bus. */
-    return -1;
-  /* found Companionship PCI board, Set it up: */
-  pci_read_config_dword(bus, dev, fun, 0x10, &cc1.bars[0]);
-  pci_read_config_dword(bus, dev, fun, 0x14, &cc1.bars[1]);
-  pci_read_config_dword(bus, dev, fun, 0x18, &cc1.bars[2]);
-  pci_read_config_dword(bus, dev, fun, 0x1c, &cc1.bars[3]);
-  pci_read_config_dword(bus, dev, fun, 0x20, &cc1.bars[4]);
-#ifdef DEBUG
-  for(i=0; i<5; i++){
-    printk("PCI: BAR%d: 0x%x\n\r",i,cc1.bars[i]);
-#endif
-  /* Set up PCI ==> AMBA */
-  pcib = (void *)cc1.bars[0];
-  pcib->bar0 = 0xfc000000;
-  /*  pcib->bar1 = 0xff000000;*/
-#ifdef BOARD_INFO
-  printk("Found CCHIP1 Board at 0x%lx\n\r",(unsigned int)pcib);
-#endif
-  /* AMBA MAP cc1.bars[1] (in CPU) ==> 0xf0000000(remote amba address) */
-  cc1.amba_maps[0].size = 0x04000000;
-  cc1.amba_maps[0].local_adr = cc1.bars[1];
-  cc1.amba_maps[0].remote_adr = 0xfc000000;
-  /* Mark end of table */
-  cc1.amba_maps[1].size=0;
-  cc1.amba_maps[1].local_adr = 0;
-  cc1.amba_maps[1].remote_adr = 0;
-  /* Enable I/O and Mem accesses */
-  pci_read_config_dword(bus, dev, fun, 0x4, &com1);
-  com1 |= 0x3;
-  pci_write_config_dword(bus, dev, fun, 0x4, com1);
-  /* Set up AMBA Masters ==> PCI */
-  ambab = (void *)(cc1.bars[1]+0x400);
-#ifdef DEBUG
-  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",0,ambab->bar0,pcib->bar0);
-  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",1,ambab->bar1,pcib->bar1);
-  printk("AMBA: PCIBAR[%d]: 0x%x, 0x%x\n\r",2,ambab->bar2,pcib->bar2);
-#endif
-  /* 0xe0000000(AMBA) ==> 0x40000000(PCI) ==> 0x40000000(AT697 AMBA) */
-  ambab->ambabars[0] = 0x40000000;
-  /* Scan bus for AMBA devices */
-  abus = &cc1.amba_bus;
-  memset(abus,0,sizeof(*abus));
-  ambapp_scan(abus, cc1.bars[1]+0x3f00000, NULL, &cc1.amba_maps[0]);
-  /* Init all msters, max 16 */
-  for(i=1; i<16; i++) {
-    ambab->ambabars[i] = 0x40000000;
-    if (READ_REG(&ambab->ambabars[i]) != 0x40000000)
-      break;
-  /* Enable PCI Master */
-   com1 |= 0x4;
-  cc1.pcib  = pcib;
-  cc1.ambab = ambab;
-  cc1.bus = bus;
-  cc1.dev = dev;
-  cc1.fun = fun;
-  return 0;
-#ifndef GAISLER_FTAHBRAM
- #define GAISLER_FTAHBRAM 0x50
-#endif
-static int init_onboard_sram(void)
-  struct ambapp_ahb_info ahb;
-  struct ambapp_apb_info apb;
-  unsigned int conf, size;
-  /* Find SRAM controller
-   * 1. AHB slave interface
-   * 2. APB slave interface
-  if ( ambapp_find_apbslv(&cc1.amba_bus, VENDOR_GAISLER,
-      GAISLER_FTAHBRAM, &apb) != 1 ){
-    printk("On Board FT SRAM not found (APB)\n");
-    return -1;
-  if ( ambapp_find_ahbslv(&cc1.amba_bus, VENDOR_GAISLER,
-      GAISLER_FTAHBRAM, &ahb) != 1 ){
-    printk("On Board FT SRAM not found (AHB)\n");
-    return -1;
-  /* We have found the controller.
-   * Get it going.
-   * Get size of SRAM
-  conf = *(unsigned int *)apb.start;
-  size = (conf >>10) & 0x7;
-  /* 2^x kb */
-  cc1.ftsram_size = 1<<size;
-  cc1.ftsram_start = ahb.start[0];
-  cc1.ftsram_end = size*1024 + cc1.ftsram_start;
-#ifdef BOARD_INFO
-  printk("Found FT AHB SRAM %dkb at 0x%lx\n",cc1.ftsram_size,cc1.ftsram_start);
-#endif
-  return 0;
-int cchip1_register(void)
-  /* Init AT697 PCI Controller */
-  init_pci();
-  /* Find & init CChip board .
-   * Also scan AMBA Plug&Play info for us.
-  if ( init_pcif() ){
-    printk("Failed to initialize CCHIP board\n\r");
-    return -1;
-  /* Set interrupt common board stuff */
-  cchip1_irq_init();
-  /* Find on board SRAM */
-  if ( init_onboard_sram() ){
-    printk("Failed to register On Board SRAM. It is needed by b1553BRM\n");
-    return -1;
-  /* Register interrupt install functions */
-  b1553brm_pci_int_reg = cchip1_set_isr;
-  occan_pci_int_reg = cchip1_set_isr;
-  grspw_pci_int_reg = cchip1_set_isr;
-  apbuart_pci_int_reg = cchip1_set_isr;
-  /* register the BRM PCI driver, use 16k FTSRAM... */
-  if ( b1553brm_pci_register(&cc1.amba_bus,0,0,3,cc1.ftsram_start,0xffa00000) ){
-    printk("Failed to register BRM PCI driver\n");
-    return -1;
-  /* register the BRM PCI driver, no DMA memory... */
-  if ( occan_pci_register(&cc1.amba_bus) ){
-    printk("Failed to register OC_CAN PCI driver\n");
-    return -1;
-  /* register the GRSPW PCI driver, use malloc... */
-  if ( grspw_pci_register(&cc1.amba_bus,0,0xe0000000) ){
-    printk("Failed to register GRSPW PCI driver\n");
-    return -1;
-  /* register the APBUART PCI driver, no DMA memory */
-  if ( apbuart_pci_register(&cc1.amba_bus) ){
-    printk("Failed to register APBUART PCI driver\n");
-    return -1;
-  return 0;
-static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v);
-static unsigned int cchip1_spurious_cnt;
-typedef struct {
-  unsigned int (*handler)(int irqno, void *arg);
-  void *arg;
-} int_handler;
-static int_handler int_handlers[16];
-void cchip1_irq_init(void){
-  /* Configure AT697 ioport bit 7 to input pci irq */
-  regs->PIO_Direction &= ~(1<<7);
-  regs->PIO_Interrupt  = 0x87;          /* level sensitive */
-  /* Set up irq controller (mask all IRQs) */
-  cc1.pcib->imask = 0x0000;
-  cc1.pcib->ipend = 0;
-  cc1.pcib->iclear = 0xffff;
-  cc1.pcib->iforce = 0;
-  cc1.pcib->ilevel = 0x0;
-  memset(int_handlers,0,sizeof(int_handlers));
-  /* Reset spurious counter */
-  cchip1_spurious_cnt = 0;
-  /* Register interrupt handler */
-  set_vector(cchip1_interrupt_dispatcher,LEON_TRAP_TYPE(CCHIP_IRQ),1);
-void cchip1_set_isr(void *handler, int irqno, void *arg){
-  int_handlers[irqno].handler = handler;
-  int_handlers[irqno].arg = arg;
-#ifdef DEBUG
-  printk("Registering IRQ %d to 0x%lx(%d,0x%lx)\n\r",
-      irqno,(unsigned int)handler,irqno,(unsigned int)arg);
-#endif
-  cc1.pcib->imask |= 1<<irqno; /* Enable the registered IRQ */
-static rtems_isr cchip1_interrupt_dispatcher(rtems_vector_number v){
-  unsigned int pending = READ_REG(&cc1.pcib->ipend);
-  unsigned int clr = pending;
-  int irq=1;
-  if ( !pending ){
-#ifdef PRINT_SPURIOUS
-    printk("Spurious IRQ %d: %d\n",v,cchip1_spurious_cnt);
-#endif
-    cchip1_spurious_cnt++;
-    return;
-#ifdef DEBUG_IRQS
-  printk("CCIRQ: 0x%x\n",(unsigned int)pending);
-#endif
-  /* IRQ 0 doesn't exist */
-  irq=1;
-  pending = pending>>1;
-  while ( pending ){
-    if ( (pending & 1) && (handler=int_handlers[irq].handler) ){
-      handler(irq,int_handlers[irq].arg);
-    irq++;
-  cc1.pcib->iclear = clr;
-  /*LEON_Clear_interrupt( brd->irq );*/
diff --git a/c/src/lib/libbsp/sparc/leon2/include/cchip.h b/c/src/lib/libbsp/sparc/leon2/include/cchip.h
index d8d1e46..0000000
--- a/c/src/lib/libbsp/sparc/leon2/include/cchip.h
+++ /dev/null
@@ -1,42 +0,0 @@
- * @defgroup cchip Companion Chip handler
- * @ingroup sparc_leon2
- * @file
- * @ingroup cchip
- * @brief Register all drivers supported by the Companion Chip board
-#ifndef __CCHIP_H__
-#define __CCHIP_H__
-#ifdef __cplusplus
-extern "C" {
-#endif
-#define CCHIP_IRQ 4
-/* Register all drivers supported by the Companion Chip board */
-int cchip_register(void);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/sparc/leon2/include/rasta.h b/c/src/lib/libbsp/sparc/leon2/include/rasta.h
index b7eccb4..0000000
--- a/c/src/lib/libbsp/sparc/leon2/include/rasta.h
+++ /dev/null
@@ -1,132 +0,0 @@
- * @defgroup leon2_rasta Rasta Handler
- * @file
- * @ingroup leon2_rasta
- * @brief Handles Rasta
-#ifndef __RASTA_H__
-#define __RASTA_H__
-#include <bsp.h>
-#include <grcan.h>
-#include <b1553brm_rasta.h>
-#include <grspw.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-extern int rasta_register(void);
-/* Address of PCI bus on RASTA local AMBA bus */
-#define RASTA_PCI_BASE             0xe0000000
-/* Address of SRAM on RASTA local AMBA bus */
-#define RASTA_LOCAL_SRAM           0x40000000
-#define UART0_IRQNO  2
-#define UART1_IRQNO  3
-#define GRCAN_IRQNO  7
-#define SPW0_IRQNO   10
-#define SPW1_IRQNO   11
-#define SPW2_IRQNO   12
-#define BRM_IRQNO    13
-#define GRCAN_IRQ   (3<<GRCAN_IRQNO)
-#define SPW0_IRQ    (1<<SPW0_IRQNO)
-#define SPW1_IRQ    (1<<SPW1_IRQNO)
-#define SPW2_IRQ    (1<<SPW2_IRQNO)
-#define SPW_IRQ     (7<<SPW0_IRQNO)
-#define BRM_IRQ     (1<<BRM_IRQNO)
-#define UART0_IRQ   (1<<UART0_IRQNO)
-#define UART1_IRQ   (1<<UART1_IRQNO)
- *  The following defines the bits in the UART Control Registers.
-#define LEON_REG_UART_CONTROL_RTD  0x000000FF /* RX/TX data */
- *  The following defines the bits in the LEON UART Status Registers.
-#define LEON_REG_UART_STATUS_DR   0x00000001 /* Data Ready */
-#define LEON_REG_UART_STATUS_TSE  0x00000002 /* TX Send Register Empty */
-#define LEON_REG_UART_STATUS_THE  0x00000004 /* TX Hold Register Empty */
-#define LEON_REG_UART_STATUS_BR   0x00000008 /* Break Error */
-#define LEON_REG_UART_STATUS_OE   0x00000010 /* RX Overrun Error */
-#define LEON_REG_UART_STATUS_PE   0x00000020 /* RX Parity Error */
-#define LEON_REG_UART_STATUS_FE   0x00000040 /* RX Framing Error */
-#define LEON_REG_UART_STATUS_ERR  0x00000078 /* Error Mask */
-#define LEON_REG_UART_CTRL_RE     0x00000001 /* Receiver enable */
-#define LEON_REG_UART_CTRL_TE     0x00000002 /* Transmitter enable */
-#define LEON_REG_UART_CTRL_RI     0x00000004 /* Receiver interrupt enable */
-#define LEON_REG_UART_CTRL_TI     0x00000008 /* Transmitter interrupt enable */
-#define LEON_REG_UART_CTRL_PS     0x00000010 /* Parity select */
-#define LEON_REG_UART_CTRL_PE     0x00000020 /* Parity enable */
-#define LEON_REG_UART_CTRL_FL     0x00000040 /* Flow control enable */
-#define LEON_REG_UART_CTRL_LB     0x00000080 /* Loop Back enable */
-#define UART_SET_SCALER 0
-#define UART_SET_CTRL   1
-#define UART_GET_STAT   2
-#define UART_CLR_STAT   3
-struct uart_reg {
-    volatile unsigned int data;              /* 0x00 */
-    volatile unsigned int status;            /* 0x04 */
-    volatile unsigned int ctrl;              /* 0x08 */
-    volatile unsigned int scaler;            /* 0x0C */
-void uart_register(unsigned int baseaddr);
-rtems_device_driver uart_initialize(rtems_device_major_number major,
-    rtems_device_minor_number  minor, void *arg);
-rtems_device_driver uart_open(rtems_device_major_number major,
-rtems_device_driver uart_close(rtems_device_major_number major,
-rtems_device_driver uart_read(rtems_device_major_number major,
-rtems_device_driver uart_write(rtems_device_major_number major,
-rtems_device_driver uart_control(rtems_device_major_number major,
-struct gpio_reg {
-    volatile unsigned int in_data;          /* 0x00 */
-    volatile unsigned int out_data;         /* 0x04 */
-    volatile unsigned int dir;              /* 0x08 */
-    volatile unsigned int imask;            /* 0x0C */
-    volatile unsigned int ipol;             /* 0x10 */
-    volatile unsigned int iedge;            /* 0x14 */
-extern struct gpio_reg *gpio0, *gpio1;
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index 01b2ab9..ab2498d 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -45,66 +45,6 @@ $(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/rasta.h: include/rasta.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rasta.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rasta.h
-$(PROJECT_INCLUDE)/cchip.h: include/cchip.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/cchip.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/cchip.h
-$(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw.h
-$(PROJECT_INCLUDE)/grspw_pci.h: ../../sparc/shared/include/grspw_pci.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw_pci.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw_pci.h
-$(PROJECT_INCLUDE)/grspw_rasta.h: ../../sparc/shared/include/grspw_rasta.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw_rasta.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw_rasta.h
-$(PROJECT_INCLUDE)/occan.h: ../../sparc/shared/include/occan.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/occan.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/occan.h
-$(PROJECT_INCLUDE)/occan_pci.h: ../../sparc/shared/include/occan_pci.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/occan_pci.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/occan_pci.h
-$(PROJECT_INCLUDE)/grcan.h: ../../sparc/shared/include/grcan.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grcan.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/grcan.h
-$(PROJECT_INCLUDE)/grcan_rasta.h: ../../sparc/shared/include/grcan_rasta.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grcan_rasta.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/grcan_rasta.h
-$(PROJECT_INCLUDE)/apbuart.h: ../../sparc/shared/include/apbuart.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart.h
-$(PROJECT_INCLUDE)/apbuart_pci.h: ../../sparc/shared/include/apbuart_pci.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart_pci.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart_pci.h
-$(PROJECT_INCLUDE)/apbuart_rasta.h: ../../sparc/shared/include/apbuart_rasta.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart_rasta.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart_rasta.h
-$(PROJECT_INCLUDE)/b1553brm.h: ../../sparc/shared/include/b1553brm.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/b1553brm.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/b1553brm.h
-$(PROJECT_INCLUDE)/b1553brm_pci.h: ../../sparc/shared/include/b1553brm_pci.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/b1553brm_pci.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/b1553brm_pci.h
-$(PROJECT_INCLUDE)/b1553brm_rasta.h: ../../sparc/shared/include/b1553brm_rasta.h $(PROJECT_INCLUDE)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/b1553brm_rasta.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/b1553brm_rasta.h
 $(PROJECT_INCLUDE)/debug_defs.h: ../../sparc/shared/include/debug_defs.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/debug_defs.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/debug_defs.h
@@ -169,6 +109,46 @@ $(PROJECT_INCLUDE)/tlib.h: ../../sparc/shared/include/tlib.h $(PROJECT_INCLUDE)/
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tlib.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/tlib.h
+$(PROJECT_INCLUDE)/grpci2.h: ../../sparc/shared/include/grpci2.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grpci2.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grpci2.h
+$(PROJECT_INCLUDE)/gr_701.h: ../../sparc/shared/include/gr_701.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_701.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_701.h
+$(PROJECT_INCLUDE)/gr_rasta_adcdac.h: ../../sparc/shared/include/gr_rasta_adcdac.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_rasta_adcdac.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_rasta_adcdac.h
+$(PROJECT_INCLUDE)/gr_rasta_io.h: ../../sparc/shared/include/gr_rasta_io.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_rasta_io.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_rasta_io.h
+$(PROJECT_INCLUDE)/gr_rasta_tmtc.h: ../../sparc/shared/include/gr_rasta_tmtc.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_rasta_tmtc.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_rasta_tmtc.h
+$(PROJECT_INCLUDE)/b1553brm.h: ../../sparc/shared/include/b1553brm.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/b1553brm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/b1553brm.h
+$(PROJECT_INCLUDE)/occan.h: ../../sparc/shared/include/occan.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/occan.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/occan.h
+$(PROJECT_INCLUDE)/grcan.h: ../../sparc/shared/include/grcan.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grcan.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grcan.h
+$(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw.h
+$(PROJECT_INCLUDE)/apbuart.h: ../../sparc/shared/include/apbuart.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart.h
 $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
diff --git a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c b/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
index bfd9e31..0000000
--- a/c/src/lib/libbsp/sparc/leon2/rasta/rasta.c
+++ /dev/null
@@ -1,386 +0,0 @@
- * @file
- * @brief GR-RASTA-IO PCI board driver
- *  GR-RASTA-IO PCI board driver
-#include <pci.h>
-#include <rasta.h>
-#include <grlib.h>
-#include <grcan_rasta.h>
-#include <grspw_rasta.h>
-#include <apbuart_rasta.h>
-/* If RASTA_SRAM is defined SRAM will be used, else SDRAM */
-/*#define RASTA_SRAM 1*/
-#define RASTA_IRQ  5
-/* Offset from 0x80000000 (dual bus version) */
-#define AHB1_IOAREA_BASE_ADDR 0x80100000
-#define APB2_OFFSET    0x200000
-#define IRQ_OFFSET     0x200500
-#define GRHCAN_OFFSET  0x201000
-#define BRM_OFFSET     0x100000
-#define SPW_OFFSET     0xa00
-#define UART_OFFSET    0x200200
-#define GPIO0_OFF      0x200600
-#define GPIO1_OFF      0x200700
-/* #define DEBUG 1 */
-#ifdef DEBUG
-#define DBG(x...) printk(x)
-#else
-#define DBG(x...)
-#endif
-static int bus, dev, fun;
-struct irqmp_regs *irq = NULL;
-LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
-struct gpio_reg *gpio0, *gpio1;
-/* static rtems_isr pci_interrupt_handler (rtems_vector_number v) { */
-/*     volatile unsigned int *pci_int = (volatile unsigned int *) 0x80000168;*/
-/*     volatile unsigned int *pci_mem = (volatile unsigned int *) 0xb0400000;*/
-/*     if (*pci_int & 0x20) { */
-/*         *pci_int = 0x20; */
-/*         *pci_mem = 0; */
-/*         printk("pci died\n"); */
-void *uart0_int_arg, *uart1_int_arg;
-void *spw0_int_arg, *spw1_int_arg, *spw2_int_arg;
-void *grcan_int_arg;
-void *brm_int_arg;
-void (*uart0_int_handler)(int irq, void *arg) = NULL;
-void (*uart1_int_handler)(int irq, void *arg) = NULL;
-void (*spw0_int_handler)(int irq, void *arg) = NULL;
-void (*spw1_int_handler)(int irq, void *arg) = NULL;
-void (*spw2_int_handler)(int irq, void *arg) = NULL;
-void (*grcan_int_handler)(int irq, void *arg) = NULL;
-void (*brm_int_handler)(int irq, void *arg) = NULL;
-static rtems_isr rasta_interrupt_handler (rtems_vector_number v)
-    unsigned int status;
-    status = irq->ipend;
-    if ( (status & GRCAN_IRQ) && grcan_int_handler ) {
-      grcan_int_handler(GRCAN_IRQNO,grcan_int_arg);
-    if (status & SPW_IRQ) {
-      if ( (status & SPW0_IRQ) && spw0_int_handler ){
-        spw0_int_handler(SPW0_IRQNO,spw0_int_arg);
-      if ( (status & SPW1_IRQ) && spw1_int_handler ){
-        spw1_int_handler(SPW1_IRQNO,spw1_int_arg);
-      if ( (status & SPW2_IRQ) && spw2_int_handler ){
-        spw2_int_handler(SPW2_IRQNO,spw2_int_arg);
-    if ((status & BRM_IRQ) && brm_int_handler ){
-        brm_int_handler(BRM_IRQNO,brm_int_arg);
-    if ( (status & UART0_IRQ) && uart0_int_handler ) {
-      uart0_int_handler(UART0_IRQNO,uart0_int_arg);
-    if ( (status & UART1_IRQ) && uart1_int_handler) {
-      uart1_int_handler(UART1_IRQNO,uart1_int_arg);
-    DBG("RASTA-IRQ: 0x%x\n",status);
-    irq->iclear = status;
-static void rasta_interrrupt_register(void *handler, int irqno, void *arg)
-  DBG("RASTA: Registering irq %d\n",irqno);
-  if ( irqno == UART0_IRQNO ){
-    DBG("RASTA: Registering uart0 handler: 0x%x, arg: 0x%x\n",handler,arg);
-    uart0_int_handler = handler;
-    uart0_int_arg = arg;
-    /* unmask interrupt source */
-    irq->iclear = UART0_IRQ;
-    irq->mask[0] |= UART0_IRQ;
-  if ( irqno == UART1_IRQNO ){
-    DBG("RASTA: Registering uart1 handler: 0x%x, arg: 0x%x\n",handler,arg);
-    uart1_int_handler = handler;
-    uart1_int_arg = arg;
-    irq->iclear = UART1_IRQ;
-    irq->mask[0] |= UART1_IRQ;
-  if ( irqno == SPW0_IRQNO ){
-    DBG("RASTA: Registering spw0 handler: 0x%x, arg: 0x%x\n",handler,arg);
-    spw0_int_handler = handler;
-    spw0_int_arg = arg;
-    irq->iclear = SPW0_IRQ;
-    irq->mask[0] |= SPW0_IRQ;
-  if ( irqno == SPW1_IRQNO ){
-    DBG("RASTA: Registering spw1 handler: 0x%x, arg: 0x%x\n",handler,arg);
-    spw1_int_handler = handler;
-    spw1_int_arg = arg;
-    irq->iclear = SPW1_IRQ;
-    irq->mask[0] |= SPW1_IRQ;
-  if ( irqno == SPW2_IRQNO ){
-    DBG("RASTA: Registering spw2 handler: 0x%x, arg: 0x%x\n",handler,arg);
-    spw2_int_handler = handler;
-    spw2_int_arg = arg;
-    irq->iclear = SPW2_IRQ;
-    irq->mask[0] |= SPW2_IRQ;
-  if ( irqno == GRCAN_IRQNO ){
-    DBG("RASTA: Registering GRCAN handler: 0x%x, arg: 0x%x\n",handler,arg);
-    grcan_int_handler = handler;
-    grcan_int_arg = arg;
-    irq->iclear = GRCAN_IRQ;
-    irq->mask[0] |= GRCAN_IRQ;
-  if ( irqno == BRM_IRQNO ){
-    DBG("RASTA: Registering BRM handler: 0x%x, arg: 0x%x\n",handler,arg);
-    brm_int_handler = handler;
-    brm_int_arg = arg;
-    irq->iclear = BRM_IRQ;
-    irq->mask[0] |= BRM_IRQ;
-static int rasta_get_gpio(
-  struct ambapp_bus *abus, int index, struct gpio_reg **regs,
-  int *irq)
-  struct ambapp_apb_info dev;
-  int cores;
-  if ( !abus )
-    return -1;
-  /* Scan PnP info for GPIO port number 'index' */
-  cores = ambapp_find_apbslv_next(abus, VENDOR_GAISLER, GAISLER_GPIO, &dev,
-                                  index);
-  if ( cores < 1 )
-    return -1;
-  if ( regs )
-    *regs = (struct gpio_reg *)dev.start;
-  if ( irq )
-    *irq = dev.irq;
-  return 0;
-/* AMBA Plug&Play information */
-static struct ambapp_bus abus;
-static struct ambapp_mmap amba_maps[3];
-int rasta_register(void)
-    uint32_t bar0, bar1, data;
-    unsigned int *page0 = NULL;
-    unsigned int *apb_base = NULL;
-    int found=0;
-    DBG("Searching for RASTA board ...");
-    /* Search PCI vendor/device id. */
-    if (BSP_pciFindDevice(0x1AC8, 0x0010, 0, &bus, &dev, &fun) == 0) {
-      found = 1;
-    /* Search old PCI vendor/device id. */
-    if ( (!found) &&
-            (BSP_pciFindDevice(0x16E3, 0x0210, 0, &bus, &dev, &fun) == 0) ) {
-      found = 1;
-    /* Did we find a RASTA board? */
-    if ( !found )
-      return -1;
-    DBG(" found it (dev/fun: %d/%d).\n", dev, fun);
-    pci_read_config_dword(bus, dev, fun, 0x10, &bar0);
-    pci_read_config_dword(bus, dev, fun, 0x14, &bar1);
-    page0 = (unsigned int *)(bar0 + 0x400000);
-    *page0 = 0x80000000;                  /* Point PAGE0 to start of APB     */
-    apb_base = (unsigned int *)(bar0+APB2_OFFSET);
-/*  apb_base[0] = 0x000002ff;
-    apb_base[1] = 0x8a205260;
-    apb_base[2] = 0x00184000; */
-    /* Configure memory controller */
-#ifdef RASTA_SRAM
-    apb_base[0] = 0x000002ff;
-    apb_base[1] = 0x00001260;
-    apb_base[2] = 0x000e8000;
-#else
-    apb_base[1] = 0x82206000;
-#endif
-    /* Set up rasta irq controller */
-    irq = (struct irqmp_regs *) (bar0+IRQ_OFFSET);
-    irq->iclear = 0xffff;
-    irq->ilevel = 0;
-    irq->mask[0] = 0xffff &
-           ~(UART0_IRQ|UART1_IRQ|SPW0_IRQ|SPW1_IRQ|SPW2_IRQ|GRCAN_IRQ|BRM_IRQ);
-    regs->PIO_Interrupt  |= (0x87<<8);    /* level sensitive */
-    apb_base[0x100] |= 0x40000000;        /* Set GRPCI mmap 0x4 */
-    apb_base[0x104] =  0x40000000;        /* 0xA0000000;  Point PAGE1 to RAM */
-    /* set parity error response */
-    pci_read_config_dword(bus, dev, fun, 0x4, &data);
-    pci_write_config_dword(bus, dev, fun, 0x4, data|0x40);
-    pci_master_enable(bus, dev, fun);
-    /* install PCI interrupt vector */
-    /*    set_vector(pci_interrupt_handler,14+0x10, 1); */
-    /* install interrupt vector */
-    set_vector(rasta_interrupt_handler, RASTA_IRQ+0x10, 1);
-    /* Scan AMBA Plug&Play */
-    /* AMBA MAP bar0 (in CPU) ==> 0x80000000(remote amba address) */
-    amba_maps[0].size = 0x10000000;
-    amba_maps[0].local_adr = bar0;
-    amba_maps[0].remote_adr = 0x80000000;
-    /* AMBA MAP bar1 (in CPU) ==> 0x40000000(remote amba address) */
-    amba_maps[1].size = 0x10000000;
-    amba_maps[1].local_adr = bar1;
-    amba_maps[1].remote_adr = 0x40000000;
-    amba_maps[2].size=0;
-    amba_maps[2].local_adr = 0;
-    amba_maps[2].remote_adr = 0;
-    memset(&abus,0,sizeof(abus));
-    /* Start AMBA PnP scan at first AHB bus */
-    ambapp_scan(&abus, bar0 + (AHB1_IOAREA_BASE_ADDR & ~0xf0000000), NULL,
-                &amba_maps[0]);
-    printk("Registering RASTA GRCAN driver\n\r");
-    /*grhcan_register(bar0 + GRHCAN_OFFSET, bar1);*/
-    grcan_rasta_int_reg=rasta_interrrupt_register;
-    if ( grcan_rasta_ram_register(&abus,bar1+0x20000) ){
-      printk("Failed to register RASTA GRCAN driver\n\r");
-      return -1;
-    printk("Registering RASTA BRM driver\n\r");
-    /*brm_register(bar0   +  BRM_OFFSET, bar1);*/
-    /* register the BRM RASTA driver, use 128k on RASTA SRAM... */
-    b1553brm_rasta_int_reg=rasta_interrrupt_register;
-    if ( b1553brm_rasta_register(&abus,2,0,3,bar1,0x40000000) ){
-      printk("Failed to register BRM RASTA driver\n");
-      return -1;
-    /* provide the spacewire driver with AMBA Plug&Play
-     * info so that it can find the GRSPW cores.
-    grspw_rasta_int_reg=rasta_interrrupt_register;
-    if ( grspw_rasta_register(&abus,bar1) ){
-      printk("Failed to register RASTA GRSPW driver\n\r");
-      return -1;
-    apbuart_rasta_int_reg=rasta_interrrupt_register;
-    if ( apbuart_rasta_register(&abus) ){
-      printk("Failed to register RASTA APBUART driver\n\r");
-      return -1;
-    /* Find GPIO0 address */
-    if ( rasta_get_gpio(&abus,0,&gpio0,NULL) ){
-      printk("Failed to get address for RASTA GPIO0\n\r");
-      return -1;
-    /* Find GPIO1 address */
-    if ( rasta_get_gpio(&abus,1,&gpio1,NULL) ){
-      printk("Failed to get address for RASTA GPIO1\n\r");
-      return -1;
-    /* Successfully registered the RASTA board */
-    return 0;
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index a451208..dee5d57 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -109,30 +109,37 @@ libbsp_a_SOURCES +=  ../../sparc/shared/pci/pcif.c
+include_HEADERS += ../../sparc/shared/include/gr_tmtc_1553.h
+libbsp_a_SOURCES +=  ../../sparc/shared/pci/gr_tmtc_1553.c
 # B1553BRM
-include_HEADERS += ../../sparc/shared/include/b1553brm.h \
-    ../../sparc/shared/include/b1553brm_pci.h
 # CAN
 include_HEADERS += ../../sparc/shared/include/occan.h \
-    ../../sparc/shared/include/occan_pci.h ../../sparc/shared/include/grcan.h
+    ../../sparc/shared/include/grcan.h
-    ../../sparc/shared/can/occan_pci.c  ../../sparc/shared/can/grcan.c
 # SpaceWire
-include_HEADERS += ../../sparc/shared/include/grspw.h \
-    ../../sparc/shared/include/grspw_pci.h
 # UART
 include_HEADERS += ../../sparc/shared/include/apbuart.h \
-    ../../sparc/shared/include/apbuart_pci.h \
     ../../sparc/shared/include/apbuart_termios.h
     ../../sparc/shared/uart/apbuart_termios.c
 # I2CMST
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index a12563a..631a7f0 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -129,22 +129,34 @@ $(PROJECT_INCLUDE)/grpci2.h: ../../sparc/shared/include/grpci2.h $(PROJECT_INCLU
+$(PROJECT_INCLUDE)/gr_tmtc_1553.h: ../../sparc/shared/include/gr_tmtc_1553.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_tmtc_1553.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_tmtc_1553.h
@@ -153,18 +165,10 @@ $(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE
 $(PROJECT_INCLUDE)/apbuart_termios.h: ../../sparc/shared/include/apbuart_termios.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/apbuart_termios.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/apbuart_termios.h
diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
index 2ae4af5..0000000
--- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_pci.c
+++ /dev/null
@@ -1,135 +0,0 @@
-/* Select PCI driver */
-#define B1553BRM_NO_AMBA
-#define B1553BRM_PCI
-#undef B1553BRM_MAXDEVS
-/* Use only 16K memory */
-#define DMA_MEM_16K
-/* Malloced memory or
- * Card local memory
-#define B1553BRM_LOCAL_MEM
-#define DONT_DEF_RAMON
-/* memory must be aligned to a 128k boundary */
-unsigned int brmpci_memarea_address;
-#define B1553BRM_LOCAL_MEM_ADR brmpci_memarea_address
-/* We have custom address tranlation for HW addresses */
-#define B1553BRM_ADR_TO
-/* No custom MEMAREA=>CPU used since BRM Core work with offsets
- * in it's descriptors.
-#undef B1553BRM_ADR_FROM
-/* Set registered device name */
-#define B1553BRM_DEVNAME "/dev/brmpci0"
-#define B1553BRM_DEVNAME_NO(devstr,no) ((devstr)[11]='0'+(no))
-/* Any non-static function will begin with */
-#define B1553BRM_PREFIX(name) b1553brmpci##name
-/* do nothing, assume that the interrupt handler is called
- * setup externally calling b1553_interrupt_handler.
-#define B1553BRM_REG_INT(handler,irq,arg) \
- if ( b1553brm_pci_int_reg ) \
-   b1553brm_pci_int_reg(handler,irq,arg);
-#ifdef B1553BRM_ADR_TO
-/* Translate a address within the Memory Region (memarea) into an Hardware
- * device address. This address is put into hardware registers or descriptors
- * so that the hardware can access the Memory Region.
- * Example:
- * An local AMBA access at 0xe0000000 will translate into PCI address 0x40000000,
- * the PCI address 0x40000000 will translate into CPU-AMBA address 0x40000000.
-unsigned int brmpci_hw_address;
-static inline unsigned int memarea_to_hw(unsigned int addr) {
-		/* don't translate? */
-		if ( brmpci_hw_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x000fffff) | brmpci_hw_address);
-#endif
-/* not used since BRM Core work with offsets */
-#ifdef B1553BRM_ADR_FROM
-unsigned int brmpci_cpu_access_address;
-static inline unsigned int hw_to_cpu(unsigned int addr) {
-		if ( brmpci_cpu_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x0fffffff) | brmpci_cpu_address);
-#endif
-void (*b1553brm_pci_int_reg)(void *handler, int irq, void *arg) = 0;
-static void b1553brmpci_interrupt_handler(int irq, void *arg);
-#include "b1553brm.c"
- * memarea     = preallocated memory somewhere, pointer to start of memory.
- * hw_address  = how to translate a memarea address into an HW device AMBA address.
-int b1553brm_pci_register(
- struct ambapp_bus *bus,
- unsigned int clksel,
- unsigned int clkdiv,
- unsigned int brm_freq,
- unsigned int memarea,
- unsigned int hw_address
-	/* Setup configuration */
-	/* if zero malloc will be used */
-	brmpci_memarea_address = memarea;
-	brmpci_hw_address = hw_address;
-	brmpci_cpu_address = memarea & 0xf0000000;
-#endif
-	/* Register the driver */
-	return B1553BRM_PREFIX(_register)(bus,clksel,clkdiv,brm_freq);
-/* Call this from PCI interrupt handler
- * irq = the irq number of the HW device local to that IRQMP controller
-static void b1553brmpci_interrupt_handler(int irq, void *arg){
-	brm_interrupt(arg);
-#if 0
-int b1553brm_pci_interrupt_handler(int irqmask){
-	int i;
-	unsigned int mask=0;
-	/* find minor */
-	for(i=0; i<brm_cores; i++){
-		if ( (1<<brms[i].irqno) & irqmask ){
-			mask |= 1<<brms[i].irqno;
-			brm_interrupt(&brms[i]);
-			/* more interrupts to scan for? */
-			if ( irqmask & ~mask )
-				return mask; /* handled */
-	return mask;
-#endif
diff --git a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c b/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
index d15881e..0000000
--- a/c/src/lib/libbsp/sparc/shared/1553/b1553brm_rasta.c
+++ /dev/null
@@ -1,117 +0,0 @@
-#define DMA_MEM_128K
-unsigned int brmrasta_memarea_address;
-#define B1553BRM_LOCAL_MEM_ADR brmrasta_memarea_address
-#define B1553BRM_DEVNAME "/dev/brmrasta0"
-#define B1553BRM_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
-#define B1553BRM_PREFIX(name) b1553brmrasta##name
- if ( b1553brm_rasta_int_reg ) \
-   b1553brm_rasta_int_reg(handler,irq,arg);
- * Example:
-unsigned int brmrasta_hw_address;
-		if ( brmrasta_hw_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x0fffffff) | brmrasta_hw_address);
-#endif
-unsigned int brmrasta_cpu_access_address;
-		if ( brmrasta_cpu_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x0fffffff) | brmrasta_cpu_address);
-#endif
-void (*b1553brm_rasta_int_reg)(void *handler, int irq, void *arg) = 0;
-static void b1553brmrasta_interrupt_handler(int irq, void *arg);
-int b1553brm_rasta_register(
-	/* if zero the malloc will be used */
-	brmrasta_memarea_address = memarea;
-	brmrasta_hw_address = hw_address;
-	brmrasta_cpu_address = memarea & 0xf0000000;
-#endif
-/* Call this from RASTA interrupt handler
-static void b1553brmrasta_interrupt_handler(int irq, void *arg){
diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c b/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
index 8832e09..0000000
--- a/c/src/lib/libbsp/sparc/shared/can/grcan_rasta.c
+++ /dev/null
@@ -1,100 +0,0 @@
-#include <rasta.h>
-/* PCI frequency */
-#define SYS_FREQ_HZ 30000000
-/*#define USE_AT697_RAM              1      */
-/* memarea_to_hw(x)
- * x: address in AT697 address space
- * returns the address in the RASTA address space that can be used to access x with dma.
-#ifdef USE_AT697_RAM
-    return ((addr & 0x0fffffff) | RASTA_PCI_BASE);
-#else
-    return ((addr & 0x0fffffff) | RASTA_LOCAL_SRAM);
-#endif
-#define MEMAREA_TO_HW(x) memarea_to_hw(x)
-#define IRQ_CLEAR_PENDING(irqno)
-#define IRQ_UNMASK(irqno)
-#define IRQ_MASK(irqno)
-#define IRQ_GLOBAL_PREPARE(level) rtems_interrupt_level level
-#define IRQ_GLOBAL_DISABLE(level) rtems_interrupt_disable(level)
-#define IRQ_GLOBAL_ENABLE(level) rtems_interrupt_enable(level)
-#define GRCAN_REG_INT(handler,irqno,arg) \
-  if ( grcan_rasta_int_reg ) \
-    grcan_rasta_int_reg(handler,irqno,arg);
-void (*grcan_rasta_int_reg)(void *handler, int irq, void *arg) = 0;
-#define GRCAN_PREFIX(name) grcan_rasta##name
-/* We provide our own handler */
-#define GRCAN_DONT_DECLARE_IRQ_HANDLER
-#define GRCAN_REG_BYPASS_CACHE
-#define GRCAN_DMA_BYPASS_CACHE
-#define GRCAN_MAX_CORES 1
-/* Custom Statically allocated memory */
-#undef STATICALLY_ALLOCATED_TX_BUFFER
-#undef STATICALLY_ALLOCATED_RX_BUFFER
-#define STATIC_TX_BUF_SIZE 4096
-#define STATIC_RX_BUF_SIZE 4096
-#define TX_BUF_SIZE 4096
-#define RX_BUF_SIZE 4096
-#define STATIC_TX_BUF_ADDR(core) \
-	((unsigned int *)\
-  (grcan_rasta_rambase+(core)*(STATIC_TX_BUF_SIZE+STATIC_RX_BUF_SIZE)))
-#define STATIC_RX_BUF_ADDR(core) \
-  ((unsigned int *) \
-	(grcan_rasta_rambase+(core)*(STATIC_TX_BUF_SIZE+STATIC_RX_BUF_SIZE)+STATIC_RX_BUF_SIZE))
-#define GRCAN_DEVNAME "/dev/grcan0"
-#define GRCAN_DEVNAME_NO(devstr,no) ((devstr)[10]='0'+(no))
-void grcan_rasta_interrupt_handler(int irq, void *pDev);
-unsigned int grcan_rasta_rambase;
-#include "grcan.c"
-int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase)
-  grcan_rasta_rambase = rambase;
-  return GRCAN_PREFIX(_register)(abus);
-#if 0
-static void grcan_rasta_interrupt_handler(int v)
-  /* We know there is always only one GRCAN core in a RASTA chip... */
-  grcan_interrupt(&grcans[0]);
-	struct grcan_priv *pDev = arg;
-	grcan_interrupt(pDev);
-#endif
-void GRCAN_PREFIX(_interrupt_handler)(int irq, void *pDev)
diff --git a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c b/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
index 12273c9..0000000
--- a/c/src/lib/libbsp/sparc/shared/can/occan_pci.c
+++ /dev/null
@@ -1,65 +0,0 @@
-/* PCI cannot do byte accesses to addresses aligned byte wise
- * Use alternative reg map.
-#define OCCAN_WORD_REGS
-#define OCCAN_DEVNAME "/dev/occanpci0"
-#define OCCAN_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
-#define OCCAN_PREFIX(name) occanpci##name
-#define OCCAN_REG_INT(handler,irq,arg) \
- if ( occan_pci_int_reg ) \
-   occan_pci_int_reg(handler,irq,arg);
-void (*occan_pci_int_reg)(void *handler, int irq, void *arg) = 0;
-void occanpci_interrupt_handler(int irq, void *arg);
-/* AMBA Bus is clocked using the PCI clock (33.3MHz) */
-#define SYS_FREQ_HZ 33333333
-/* Enable two redundant channels */
-#define REDUNDANT_CHANNELS 2
-#define OCCAN_SET_CHANNEL(priv,channel) occanpci_set_channel(priv,channel)
-#include "occan.c"
-/* Define method that sets redundant channel
- * The channel select register:
- *  0x00 = byte regs
- *  0x40 = channel select
- *  0x80 = word regs
-static void inline occanpci_set_channel(occan_priv *priv, int channel){
-	unsigned int *chan_sel = (unsigned int *)(((unsigned int)priv->regs & ~0xff)+0x40);
-	if ( channel == 0 )
-	  *chan_sel = 0;
-	else
-		*chan_sel = 0xffffffff;
-int occan_pci_register(struct ambapp_bus *bus)
-	return OCCAN_PREFIX(_register)(bus);
-void occanpci_interrupt_handler(int irq, void *arg){
-	occan_interrupt(arg);
diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
index d2d8bf0..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/apbuart_pci.h
+++ /dev/null
@@ -1,47 +0,0 @@
- * @file
- * @ingroup uart
- * @brief APBUART via PCI - driver interface
- *  Gaisler Research
-#ifndef __APBUART_PCI_H__
-#define __APBUART_PCI_H__
-#include <apbuart.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Register APBUART driver, if APBUART devices are found.
- * bus = pointer to AMBA bus description used to search for APBUART(s).
-int apbuart_pci_register (struct ambapp_bus * bus);
-/* This function must be called on APBUART interrupt. Called from the
- * PCI interrupt handler.
- * irq = AMBA IRQ assigned to the APBUART device, is found by reading
- *       pending register on IRQMP connected to the APBUART device.
-void apbuartpci_interrupt_handler (int irq, void *arg);
-extern void (*apbuart_pci_int_reg) (void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __APBUART_PCI_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h b/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
index d502970..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/apbuart_rasta.h
+++ /dev/null
@@ -1,47 +0,0 @@
- * @file
- * @ingroup uart
- * @brief APBUART RASTA via PCI - driver interface
-#ifndef __APBUART_RASTA_H__
-#define __APBUART_RASTA_H__
-#ifdef __cplusplus
-extern "C" {
-#endif
-int apbuart_rasta_register(struct ambapp_bus *bus);
- * RASTA interrupt handler.
-void apbuartrasta_interrupt_handler(int irq, void *arg);
-extern void (*apbuart_rasta_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __APBUART_RASTA_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
index e7ed277..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_pci.h
+++ /dev/null
@@ -1,61 +0,0 @@
- * @file
- * @ingroup 1553
- * @brief Macros used for brm controller via PCI
- *  COPYRIGHT (c) 2006.
-#ifndef __B1553BRM_PCI_H__
-#define __B1553BRM_PCI_H__
-#include <b1553brm.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Register BRM driver
- * See (struct brm_reg).w_ctrl for clksel and clkdiv.
- * See Enhanced register (the least signinficant 2 bits) in BRM Core for brm_freq
- * bus = &ambapp_plb for LEON3. (LEON2 not yet supported for this driver)
- * Memory setup:
- * memarea = 128k aligned pointer to memory (if zero malloc will be used) (as the CPU sees it)
- * hw_address = address that HW must use to access memarea. (used in the translation process)
-/* This function must be called on BRM interrupt. Called from the
- * PCI interrupt handler. irq = AMBA IRQ MASK assigned to the BRM device,
- * is found by reading pending register on IRQMP connected to BRM
- * device.
- * Return 0=not handled. nono-zero=handled
-int b1553brm_pci_interrupt_handler(int irq, void *arg);
-extern void (*b1553brm_pci_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __B1553BRM_PCI_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h b/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
index bc19644..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/b1553brm_rasta.h
+++ /dev/null
@@ -1,61 +0,0 @@
- * @file
- * @ingroup 1553
- * @brief Macros used for brm RASTA controller
-#ifndef __B1553BRM_RASTA_H__
-#define __B1553BRM_RASTA_H__
-#ifdef __cplusplus
-extern "C" {
-#endif
- * Memory setup:
- * device.
-int b1553brm_rasta_interrupt_handler(int irq, void *arg);
-extern void (*b1553brm_rasta_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __B1553BRM_RASTA_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_701.h b/c/src/lib/libbsp/sparc/shared/include/gr_701.h
new file mode 100644
index 0000000..0ff75cc
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_701.h
@@ -0,0 +1,48 @@
+/*  GR-701 PCI Target driver.
+ *  COPYRIGHT (c) 2008.
+ *  Cobham Gaisler AB.
+ *  Configures the GR-701 interface PCI board.
+ *  This driver provides a AMBA PnP bus by using the general part
+ *  of the AMBA PnP bus driver (ambapp_bus.c).
+ *  Driver resources for the AMBA PnP bus provided can be set using
+ *  gr701_set_resources().
+ *  The license and distribution terms for this file may be
+ *  found in found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef __GR_701_H__
+#define __GR_701_H__
+#include <drvmgr/drvmgr.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* An array of pointers to GR-701 resources. The resources will be
+ * used by the drivers controlling the cores on the GR-701 target AMBA bus.
+ * The gr_rasta_io_resources is declared weak so that the user can override the
+ * default configuration.
+extern struct drvmgr_bus_res *gr701_resources[];
+#define GR701_OPTIONS_AMBA   0x01
+#define GR701_OPTIONS_IRQ    0x02
+/* Print information about GR-RASTA-IO PCI board */
+void gr701_print(int options);
+/* Register GR-701 driver */
+void gr701_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
index 0000000..42c7c56
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h
@@ -0,0 +1,49 @@
+/*  GR-RASTA-ADCDAC PCI Target driver.
+ *  Configures the GR-RASTA-ADCDAC interface PCI board.
+ *  gr_rasta_adcdac_set_resources().
+#ifndef __GR_RASTA_ADCDAC_H__
+#define __GR_RASTA_ADCDAC_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* An array of pointers to GR-RASTA-ADCDAC resources. The resources will be
+ * used by the drivers controlling the cores on the GR-RASTA-ADCDAC target AMBA bus.
+extern struct drvmgr_bus_res *gr_rasta_adcdac_resources[];
+/* Options to gr_rasta_io_print function */
+#define RASTA_ADCDAC_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
+#define RASTA_ADCDAC_OPTIONS_IRQ    0x02 /* Print current IRQ setup */
+void gr_rasta_adcdac_print(int options);
+/* Register GR-RASTA-IO driver */
+void gr_rasta_adcdac_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_io.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_io.h
index 0000000..0aea86d
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_io.h
@@ -0,0 +1,49 @@
+/*  GR-RASTA-IO PCI Target driver.
+ *  Configures the GR-RASTA-IO interface PCI board.
+ *  gr_rasta_io_set_resources().
+#ifndef __GR_RASTA_IO_H__
+#define __GR_RASTA_IO_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* An array of pointers to GR-RASTA-IO resources. The resources will be
+ * used by the drivers controlling the cores on the GR-RASTA-IO target AMBA bus.
+extern struct drvmgr_bus_res *gr_rasta_io_resources[];
+#define RASTA_IO_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
+#define RASTA_IO_OPTIONS_IRQ    0x02 /* Print current IRQ setup */
+void gr_rasta_io_print(int options);
+void gr_rasta_io_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
index 0000000..28b6ea0
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
@@ -0,0 +1,99 @@
+/*  GR-RASTA-TMTC PCI Target driver.
+ *  Configures the GR-RASTA-TMTC interface PCI board.
+ *  gr_rasta_tmtc_set_resources().
+#ifndef __GR_RASTA_TMTC_H__
+#define __GR_RASTA_TMTC_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* GPIO TM/TC configuration pin definitions
+ * --31         PWRX                (1=PW2APB,     0=TM VC3/4)
+ * --30         PWTC                (1=APB2PW,     0=TC MAP1/2)
+ * --29         Redundant TM        (1=enable,     0=disable)
+ * --28         Redundant TC        (1=enable,     0=disable)
+ * --27         Select TM output    (1=GRTM,       0=PTME)
+ * --26         Loop back PW        (1=enable,     0=disable)
+ * --25         Transponder clock   (1=PLL,        0=PLL bypass)
+ * --24         PWTX-SELECT         (0=TX0-0,      1=TX0-1)
+ * --23         PDEC Map Switch     (1=on,         0=off)
+ * --22         PDEC Ext CPDU       (1=on,         0=off)
+ * --21         PDEC Super User     (1=on,         0=off)
+ * --20         PDEC RM On          (1=on,         0=off)
+ * --19         PDEC AU Enable      (1=on,         0=off)
+ * --18         PDEC Dynamic Mode   (1=on,         0=off)
+ * --17         PDEC Priority       (1=on,         0=off)
+ * --16         TC PSS Support      (1=on,         0=off)
+ * --15         TC Mark             (1=on,         0=off)
+ * --14         TC Pseudo           (1=on,         0=off)
+ * --13         TC Rising Clock     (1=rise,       0=fall)
+ * --12         TC Active High      (1=high,       0=low)
+ * --11         Bit Lock Positive   (1=high,       0=low)
+ * --10         RF Avail Positive   (1=high,       0=low)
+ * -- 9 : 0     SpaceCraft ID
+#define GR_TMTC_GPIO_PWRX		(1<<31)
+#define GR_TMTC_GPIO_PWTC		(1<<30)
+#define GR_TMTC_GPIO_RED_TM		(1<<29)
+#define GR_TMTC_GPIO_RED_TC		(1<<28)
+#define GR_TMTC_GPIO_GRTM_SEL		(1<<27)
+#define GR_TMTC_GPIO_LB_PW		(1<<26)
+#define GR_TMTC_GPIO_TRANSP_CLK		(1<<25)
+#define GR_TMTC_GPIO_PWTX_SEL		(1<<24)
+#define GR_TMTC_GPIO_PDEC_MAP		(1<<23)
+#define GR_TMTC_GPIO_PDEC_CPDU		(1<<22)
+#define GR_TMTC_GPIO_PDEC_SU		(1<<21)
+#define GR_TMTC_GPIO_PDEC_RM		(1<<20)
+#define GR_TMTC_GPIO_PDEC_AU		(1<<19)
+#define GR_TMTC_GPIO_PDEC_DYN_MODE	(1<<18)
+#define GR_TMTC_GPIO_PDEC_PRIO		(1<<17)
+#define GR_TMTC_GPIO_TC_PSS		(1<<16)
+#define GR_TMTC_GPIO_TC_MARK		(1<<15)
+#define GR_TMTC_GPIO_TC_PSEUDO		(1<<14)
+#define GR_TMTC_GPIO_TC_RISING_CLK	(1<<13)
+#define GR_TMTC_GPIO_TC_ACTIVE_HIGH	(1<<12)
+#define GR_TMTC_GPIO_TC_BIT_LOCK	(1<<11)
+#define GR_TMTC_GPIO_TC_RF_AVAIL	(1<<10)
+#define GR_TMTC_GPIO_SCID		(0x000003ff)
+/* An array of pointers to GR-RASTA-TMTC bus resources. The resources will be
+ * used by the device drivers controlling the cores on the GR-RASTA-IO target
+ * AMBA bus.
+ * The array is defined weak, and defualts to no resources.
+extern struct drvmgr_bus_res *gr_rasta_tmtc_resources[];
+#define RASTA_TMTC_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
+#define RASTA_TMTC_OPTIONS_IRQ    0x02 /* Print current IRQ setup */
+/* Print information about GR-RASTA-TMTC PCI board */
+void gr_rasta_tmtc_print(int options);
+/* Register GR-RASTA-TMTC driver */
+void gr_rasta_tmtc_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h b/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
index 0000000..4df89f7
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
@@ -0,0 +1,49 @@
+/*  GR-TMTC-1553 PCI Target driver.
+ *  COPYRIGHT (c) 2010.
+ *  Configures the GR-TMTC-1553 interface PCI board.
+ *  gr_tmtc_1553_set_resources().
+#ifndef __GR_TMTC_1553_H__
+#define __GR_TMTC_1553_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* An array of pointers to GR-TMTC-1553 resources. The resources will be
+ * used by the drivers controlling the cores on the GR-TMTC-1553 target AMBA bus.
+extern struct drvmgr_bus_res *gr_tmtc_1553_resources[];
+#define TMTC_1553_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
+#define TMTC_1553_OPTIONS_IRQ    0x02 /* Print current IRQ setup */
+void gr_tmtc_1553_print(int options);
+void gr_tmtc_1553_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
index dd5ef95..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/grcan_rasta.h
+++ /dev/null
@@ -1,29 +0,0 @@
- * @file
- * @ingroup can
- * @brief Registers the GRCAN for RASTA
-#ifndef __GRCAN_RASTA_H__
-#define __GRCAN_RASTA_H__
-#include <grcan.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Registers the GRCAN for RASTA
- * rambase is address of the first GRCAN core has it's TX buffer, followed by
- * it's RX buffer
-int grcan_rasta_ram_register(struct ambapp_bus *abus, int rambase);
-extern void (*grcan_rasta_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
index 0e1c6f9..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_pci.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * @file
- * @ingroup spw
- * @brief Macros used for GRSPW controller via PCI
-#ifndef __GRSPW_PCI_H__
-#define __GRSPW_PCI_H__
-#include <grspw.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Register GRSPW Driver
- * Memory setup:
-int grspw_pci_register (struct ambapp_bus *bus,
-                        unsigned int memarea, unsigned int hw_address);
- * device.
-unsigned int grspw_pci_interrupt_handler (int irq, void *arg);
-extern void (*grspw_pci_int_reg) (void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __GRSPW_PCI_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h b/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
index 1d33603..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_rasta.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * @file
- * @ingroup spw
- * @brief Macros used for RASTA PCI GRSPW controller
-#ifndef __GRSPW_RASTA_H__
-#define __GRSPW_RASTA_H__
-#include <grspw.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * Memory setup:
- * ram_base = 128k aligned pointer to memory (as the CPU sees it)
-int grspw_rasta_register(
- unsigned int ram_base
-/* This function must be called on GRSPW interrupt. Called from the
- * PCI interrupt handler. irq = AMBA IRQ MASK assigned to the GRSPW device,
- * is found by reading pending register on IRQMP connected to GRSPW
- * device.
-void grspw_rasta_interrupt_handler(unsigned int status);
-/* callback to register interrupt handler */
-extern void (*grspw_rasta_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __GRSPW_RASTA_PCI_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h b/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
index d3c6d1b..0000000
--- a/c/src/lib/libbsp/sparc/shared/include/occan_pci.h
+++ /dev/null
@@ -1,46 +0,0 @@
- * @file
- * @ingroup can
- * @brief OC_CAN controller via PCI - driver interface
-#ifndef __OCCAN_PCI_H__
-#define __OCCAN_PCI_H__
-#include <occan.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
-/* Register OC_CAN driver
- * bus = pointer to AMBA bus description used to search for OC_CAN contrller(s).
-int occan_pci_register(struct ambapp_bus *bus);
-/* This function must be called on OC_CAN interrupt. Called from the
- * PCI interrupt handler. irq = AMBA IRQ assigned to the OC_CAN device,
- * is found by reading pending register on IRQMP connected to the OC_CAN
- * device.
-extern void (*occan_pci_int_reg)(void *handler, int irq, void *arg);
-#ifdef __cplusplus
-#endif
-#endif /* __OCCAN_PCI_H__ */
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_701.c b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
index 0000000..1483008
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_701.c
@@ -0,0 +1,592 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <bsp.h>
+#include <rtems/bspIo.h>
+#include <pci.h>
+#include <pci/access.h>
+#include <ambapp.h>
+#include <drvmgr/ambapp_bus.h>
+#include <drvmgr/pci_bus.h>
+#include <genirq.h>
+#include <gr_701.h>
+/* Offset from 0x80000000 (dual bus version) */
+#define AHB1_BASE_ADDR 0x80000000
+#define AHB1_IOAREA_BASE_ADDR 0x80100000
+/* #define DEBUG 1 */
+#ifdef DEBUG
+#define DBG(x...) printk(x)
+#else
+#define DBG(x...)
+#endif
+int gr701_init1(struct drvmgr_dev *dev);
+int gr701_init2(struct drvmgr_dev *dev);
+#define READ_REG(address) (*(volatile unsigned int *)address)
+/* PCI bride reg layout on AMBA side */
+struct amba_bridge_regs {
+	volatile unsigned int bar0;
+	volatile unsigned int bar1;
+	volatile unsigned int bar2;
+	volatile unsigned int bar3;
+	volatile unsigned int bar4;/* 0x10 */
+	volatile unsigned int unused[4*3-1];
+	volatile unsigned int ambabars[1]; /* 0x40 */
+/* PCI bride reg layout on PCI side */
+struct pci_bridge_regs {
+	volatile unsigned int bar4; /* 0x10 */
+	volatile unsigned int ilevel;
+	volatile unsigned int ipend;
+	volatile unsigned int iforce;
+	volatile unsigned int istatus;
+	volatile unsigned int iclear;
+	volatile unsigned int imask;
+/* Private data structure for driver */
+struct gr701_priv {
+	/* Driver management */
+	struct drvmgr_dev	*dev;
+	char				prefix[16];
+	struct pci_bridge_regs		*pcib;
+	struct amba_bridge_regs		*ambab;
+	/* PCI */
+	pci_dev_t			pcidev;
+	struct pci_dev_info		*devinfo;
+	/* IRQ */
+	genirq_t			genirq;
+	int				interrupt_cnt;
+	/* GR-701 Address translation */
+	struct drvmgr_map_entry		bus_maps_up[2];
+	struct drvmgr_map_entry		bus_maps_down[2];
+	/* AMBA Plug&Play information on GR-701 */
+	struct ambapp_bus		abus;
+	struct ambapp_mmap		amba_maps[3];
+        struct ambapp_config		config;
+int ambapp_gr701_int_register(
+	struct drvmgr_dev *dev,
+	int irq,
+	const char *info,
+	drvmgr_isr handler,
+	void *arg);
+int ambapp_gr701_int_unregister(
+	int irq,
+	drvmgr_isr isr,
+	void *arg);
+int ambapp_gr701_int_unmask(
+	int irq);
+int ambapp_gr701_int_mask(
+	int irq);
+int ambapp_gr701_int_clear(
+	int irq);
+int ambapp_gr701_get_params(
+	struct drvmgr_bus_params *params);
+struct ambapp_ops ambapp_gr701_ops = {
+	.int_register = ambapp_gr701_int_register,
+	.int_unregister = ambapp_gr701_int_unregister,
+	.int_unmask = ambapp_gr701_int_unmask,
+	.int_mask = ambapp_gr701_int_mask,
+	.int_clear = ambapp_gr701_int_clear,
+	.get_params = ambapp_gr701_get_params
+struct drvmgr_drv_ops gr701_ops =
+	.init = {gr701_init1, gr701_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct pci_dev_id_match gr701_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_701),
+	PCIID_END_TABLE /* Mark end of table */
+struct pci_drv_info gr701_info =
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_PCI_GAISLER_GR701_ID,	/* Driver ID */
+		"GR-701_DRV",			/* Driver Name */
+		DRVMGR_BUS_TYPE_PCI,		/* Bus Type */
+		&gr701_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		0,
+	&gr701_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-701 board.
+ * It is declared weak so that the user may override it from the project file,
+ * if the default settings are not enough.
+ * The configuration consists of an array of configuration pointers, each
+ * pointer determine the configuration of one GR-701 board. Pointer
+ * zero is for board0, pointer 1 for board1 and so on.
+ * The array must end with a NULL pointer.
+struct drvmgr_bus_res *gr701_resources[] __attribute__((weak)) =
+	NULL
+int gr701_resources_cnt = 0;
+	DBG("Registering GR-701 PCI driver\n");
+	drvmgr_drv_register(&gr701_info.general);
+void gr701_interrupt(void *arg)
+	struct gr701_priv *priv = arg;
+	unsigned int status;
+	int irq = 0;
+	while ( (status=priv->pcib->istatus) != 0 ) {
+		priv->interrupt_cnt++;	/* An interrupt was generated */
+		irq = status;
+		genirq_doirq(priv->genirq, irq);
+		/* ACK interrupt */
+		priv->pcib->istatus = 0;
+	/* ACK interrupt, this is because PCI is Level, so the IRQ Controller still drives the IRQ. */
+	if ( irq )
+		drvmgr_interrupt_clear(priv->dev, 0);
+int gr701_hw_init(struct gr701_priv *priv)
+	uint32_t com1;
+	int mst;
+	unsigned int pci_freq_hz;
+	pci_dev_t pcidev = priv->pcidev;
+	struct pci_dev_info *devinfo = priv->devinfo;
+	/* Set up PCI ==> AMBA */
+	priv->pcib = pcib = (void *)devinfo->resources[0].address;
+	pcib->bar0 = 0xfc000000;
+	/* Set up GR701 AMBA Masters connection to PCI */
+	priv->ambab = ambab = (struct amba_bridge_regs *)(
+		devinfo->resources[1].address + 0x400);
+	/* Init all msters, max 16 */
+	for (mst=0; mst<16; mst++) {
+		ambab->ambabars[mst] = 0x40000000;
+		if (READ_REG(&ambab->ambabars[mst]) != 0x40000000)
+			break;
+	/* Setup Address translation for AMBA bus, assume that PCI BAR
+	 * are mapped 1:1 to CPU.
+	priv->amba_maps[0].size = 0x04000000;
+	priv->amba_maps[0].local_adr = devinfo->resources[1].address;
+	priv->amba_maps[0].remote_adr = 0xfc000000;
+	/* Mark end of table */
+	priv->amba_maps[1].size=0;
+	priv->amba_maps[1].local_adr = 0;
+	priv->amba_maps[1].remote_adr = 0;
+	/* Setup DOWN-streams address translation */
+	priv->bus_maps_down[0].name = "PCI BAR1 -> AMBA";
+	priv->bus_maps_down[0].size = priv->amba_maps[0].size;
+	priv->bus_maps_down[0].from_adr = (void *)devinfo->resources[1].address;
+	priv->bus_maps_down[0].to_adr = (void *)0xfc000000;
+	/* Setup UP-streams address translation */
+	priv->bus_maps_up[0].name = "AMBA PCIF Window";
+	priv->bus_maps_up[0].size = 0x10000000;
+	priv->bus_maps_up[0].from_adr = (void *)0xe0000000;
+	priv->bus_maps_up[0].to_adr = (void *)0x40000000;
+	/* Mark end of translation tables */
+	priv->bus_maps_down[1].size = 0;
+	priv->bus_maps_up[1].size = 0;
+	/* Enable I/O and Mem accesses */
+	pci_cfg_r32(pcidev, PCI_COMMAND, &com1);
+	com1 |= PCI_COMMAND_IO | PCI_COMMAND_MEMORY;
+	pci_cfg_w32(pcidev, PCI_COMMAND, com1);
+	/* Start AMBA PnP scan at first AHB bus */
+	ambapp_scan(&priv->abus, devinfo->resources[1].address + 0x3f00000,
+			NULL, &priv->amba_maps[0]);
+	/* Frequency is the same as the PCI bus frequency */
+	drvmgr_freq_get(priv->dev, NULL, &pci_freq_hz);
+	/* Initialize Frequency of AMBA bus */
+	ambapp_freq_init(&priv->abus, NULL, pci_freq_hz);
+	/* Init IRQ controller (avoid IRQ generation) */
+	pcib->imask = 0x0000;
+	pcib->ipend = 0;
+	pcib->iclear = 0xffff;
+	pcib->iforce = 0;
+	pcib->ilevel = 0x0;
+	/* Successfully registered the GR-701 board */
+	return 0;
+void gr701_hw_init2(struct gr701_priv *priv)
+	/* Enable PCI Master (for DMA) */
+	pci_master_enable(priv->pcidev);
+/* Called when a PCI target is found with the PCI device and vendor ID
+ * given in gr701_ids[].
+	struct gr701_priv *priv;
+	uint32_t bar0, bar1, bar0_size, bar1_size;
+	priv = malloc(sizeof(struct gr701_priv));
+	if ( !priv )
+		return DRVMGR_NOMEM;
+	memset(priv, 0, sizeof(*priv));
+	dev->priv = priv;
+	priv->dev = dev;
+	/* Determine number of configurations */
+	if ( gr701_resources_cnt == 0 ) {
+		while ( gr701_resources[gr701_resources_cnt] )
+			gr701_resources_cnt++;
+	/* Generate Device prefix */
+	strcpy(priv->prefix, "/dev/gr701_0");
+	priv->prefix[11] += dev->minor_drv;
+	mkdir(priv->prefix, S_IRWXU | S_IRWXG | S_IRWXO);
+	priv->prefix[12] = '/';
+	priv->prefix[13] = '\0';
+	priv->devinfo = devinfo = (struct pci_dev_info *)dev->businfo;
+	priv->pcidev = devinfo->pcidev;
+	bar0 = devinfo->resources[0].address;
+	bar0_size = devinfo->resources[0].size;
+	bar1 = devinfo->resources[1].address;
+	bar1_size = devinfo->resources[1].size;
+	printf("\n\n--- GR-701[%d] ---\n", dev->minor_drv);
+	printf(" PCI BUS: 0x%x, SLOT: 0x%x, FUNCTION: 0x%x\n",
+		PCI_DEV_EXPAND(priv->pcidev));
+	printf(" PCI VENDOR: 0x%04x, DEVICE: 0x%04x\n\n\n",
+		devinfo->id.vendor, devinfo->id.device);
+	printf(" PCI BAR[0]: 0x%lx - 0x%lx\n", bar0, bar0 + bar0_size - 1);
+	printf(" PCI BAR[1]: 0x%lx - 0x%lx\n", bar1, bar1 + bar1_size - 1);
+	printf(" IRQ: %d\n\n\n", devinfo->irq);
+	/* all neccessary space assigned to GR-701 target? */
+	if ((bar0_size == 0) || (bar1_size == 0))
+		return DRVMGR_ENORES;
+	priv->genirq = genirq_init(16);
+	if ( priv->genirq == NULL ) {
+		free(priv);
+		dev->priv = NULL;
+		return DRVMGR_FAIL;
+	if ( gr701_hw_init(priv) ) {
+		genirq_destroy(priv->genirq);
+		free(priv);
+		dev->priv = NULL;
+		printf(" Failed to initialize GR-701 HW\n");
+	/* Init amba bus */
+	priv->config.abus = &priv->abus;
+	priv->config.ops = &ambapp_gr701_ops;
+	priv->config.maps_up = &priv->bus_maps_up[0];
+	priv->config.maps_down = &priv->bus_maps_down[0];
+	if ( priv->dev->minor_drv < gr701_resources_cnt ) {
+		priv->config.resources = gr701_resources[priv->dev->minor_drv];
+	} else {
+		priv->config.resources = NULL;
+	/* Create and register AMBA PnP bus. */
+	return ambapp_bus_register(dev, &priv->config);
+	struct gr701_priv *priv = dev->priv;
+	/* Clear any old interrupt requests */
+	drvmgr_interrupt_clear(dev, 0);
+	/* Enable System IRQ so that GR-701 PCI target interrupt goes through.
+	 * It is important to enable it in stage init2. If interrupts were
+	 * enabled in init1 this might hang the system when more than one PCI
+	 * board is connected, this is because PCI interrupts might be shared
+	 * and PCI target 2 have not initialized and might therefore drive
+	 * interrupt already when entering init1().
+	drvmgr_interrupt_register(dev, 0, "gr701", gr701_interrupt, priv);
+	gr701_hw_init2(priv);
+	return DRVMGR_OK;
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr701_priv *priv = dev->parent->dev->priv;
+	rtems_interrupt_level level;
+	int status;
+	rtems_interrupt_disable(level);
+	status = genirq_register(priv->genirq, irq, handler, arg);
+	if ( status == 0 ) {
+		/* Clear IRQ for first registered handler */
+		priv->pcib->iclear = (1<<irq);
+	} else if ( status == 1 )
+		status = 0;
+	if (status != 0) {
+		rtems_interrupt_enable(level);
+	status = genirq_enable(priv->genirq, irq, handler, arg);
+		/* Enable IRQ for first enabled handler only */
+		priv->pcib->imask |= (1<<irq); /* unmask interrupt source */
+		status = DRVMGR_OK;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+	status = genirq_disable(priv->genirq, irq, isr, arg);
+		/* Disable IRQ only when no enabled handler exists */
+		priv->pcib->imask &= ~(1<<irq); /* mask interrupt source */
+	status = genirq_unregister(priv->genirq, irq, isr, arg);
+	if ( status != 0 )
+		status = DRVMGR_FAIL;
+	return status;
+	int irq)
+	DBG("GR-701 IRQ %d: enable\n", irq);
+	if ( genirq_check(priv->genirq, irq) )
+	/* Enable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	DBG("GR-701 IRQ %d: disable\n", irq);
+	/* Disable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_gr701_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	/* Device name prefix pointer, skip /dev */
+	params->dev_prefix = &priv->prefix[5];
+	return 0;
+void gr701_print_dev(struct drvmgr_dev *dev, int options)
+	unsigned int freq_hz;
+	/* Print */
+	printf("--- GR-701 [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	printf(" IRQ:             %d\n", devinfo->irq);
+	drvmgr_freq_get(dev, 0, &freq_hz);
+	printf(" FREQ:            %u Hz\n", freq_hz);
+	printf(" IMASK:           0x%08x\n", priv->pcib->imask);
+	printf(" IPEND:           0x%08x\n", priv->pcib->ipend);
+	/* Print amba config */
+	if ( options & GR701_OPTIONS_AMBA ) {
+		ambapp_print(&priv->abus, 10);
+#if 0
+	/* Print IRQ handlers and their arguments */
+	if ( options & GR701_OPTIONS_IRQ ) {
+		int i;
+		for(i=0; i<16; i++) {
+			printf(" IRQ[%02d]:         0x%x, arg: 0x%x\n",
+				i, (unsigned int)priv->isrs[i].handler, (unsigned int)priv->isrs[i].arg);
+#endif
+	struct pci_drv_info *drv = &gr701_info;
+	dev = drv->general.dev;
+	while(dev) {
+		gr701_print_dev(dev, options);
+		dev = dev->next_in_drv;
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
index 0000000..21ca52c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
@@ -0,0 +1,661 @@
+#include <stdio.h>
+#include <bsp.h>
+#include <pci.h>
+#include <grlib.h>
+#include <gr_rasta_adcdac.h>
+/*#define DEBUG 1*/
+#ifdef DEBUG
+#else
+#define DBG(x...)
+#endif
+/* Determines which PCI address the AHB masters will access, it should be
+ * set so that the masters can access the CPU RAM. Default is base of CPU RAM,
+ * CPU RAM is mapped 1:1 to PCI space.
+extern unsigned int _RAM_START;
+#define AHBMST2PCIADR (((unsigned int)&_RAM_START) & 0xf0000000)
+/* PCI ID */
+#define PCIID_VENDOR_GAISLER		0x1AC8
+#define PCIID_DEVICE_GR_RASTA_ADCDAC	0x0014
+int gr_rasta_adcdac_init1(struct drvmgr_dev *dev);
+int gr_rasta_adcdac_init2(struct drvmgr_dev *dev);
+struct grpci_regs {
+	volatile unsigned int cfg_stat;
+	volatile unsigned int page0;
+	volatile unsigned int page1;
+	volatile unsigned int iomap;
+	volatile unsigned int stat_cmd;
+struct gr_rasta_adcdac_ver {
+	const unsigned int	amba_freq_hz;	/* The frequency */
+	const unsigned int	amba_ioarea;	/* The address where the PnP IOAREA starts at */
+struct gr_rasta_adcdac_priv {
+	char				prefix[20];
+	/* PCI */
+	pci_dev_t			pcidev;
+	uint32_t			ahbmst2pci_map;
+	/* IRQ */
+	genirq_t			genirq;
+	/* GR-RASTA-ADCDAC */
+	struct gr_rasta_adcdac_ver	*version;
+	struct irqmp_regs		*irq;
+	struct grpci_regs		*grpci;
+	struct drvmgr_map_entry		bus_maps_down[3];
+	/* AMBA Plug&Play information on GR-RASTA-ADCDAC */
+	struct ambapp_mmap		amba_maps[4];
+struct gr_rasta_adcdac_ver gr_rasta_adcdac_ver0 = {
+	.amba_freq_hz		= 50000000,
+	.amba_ioarea		= 0x80100000,
+int ambapp_rasta_adcdac_int_register(
+	int irq,
+	const char *info,
+	void *arg);
+int ambapp_rasta_adcdac_int_unregister(
+	int irq,
+	drvmgr_isr isr,
+	void *arg);
+int ambapp_rasta_adcdac_int_unmask(
+	int irq);
+int ambapp_rasta_adcdac_int_mask(
+	int irq);
+int ambapp_rasta_adcdac_int_clear(
+	int irq);
+int ambapp_rasta_adcdac_get_params(
+struct ambapp_ops ambapp_rasta_adcdac_ops = {
+	.int_register = ambapp_rasta_adcdac_int_register,
+	.int_unregister = ambapp_rasta_adcdac_int_unregister,
+	.int_unmask = ambapp_rasta_adcdac_int_unmask,
+	.int_mask = ambapp_rasta_adcdac_int_mask,
+	.int_clear = ambapp_rasta_adcdac_int_clear,
+	.get_params = ambapp_rasta_adcdac_get_params
+struct drvmgr_drv_ops gr_rasta_adcdac_ops =
+{	.init = {gr_rasta_adcdac_init1, gr_rasta_adcdac_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct pci_dev_id_match gr_rasta_adcdac_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_ADCDAC),
+struct pci_drv_info gr_rasta_adcdac_info =
+		DRIVER_PCI_GAISLER_RASTAADCDAC_ID,/* Driver ID */
+		"GR-RASTA-ADCDAC_DRV",		/* Driver Name */
+		&gr_rasta_adcdac_ops,
+		NULL,				/* Funcs */
+		0,
+	&gr_rasta_adcdac_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-RASTA-ADCDAC board.
+ * pointer determine the configuration of one GR-RASTA-ADCDAC board. Pointer
+struct drvmgr_bus_res *gr_rasta_adcdac_resources[] __attribute__((weak)) =
+	NULL
+int gr_rasta_adcdac_resources_cnt = 0;
+	DBG("Registering GR-RASTA-ADCDAC PCI driver\n");
+	drvmgr_drv_register(&gr_rasta_adcdac_info.general);
+void gr_rasta_adcdac_isr (void *arg)
+	struct gr_rasta_adcdac_priv *priv = arg;
+	unsigned int status, tmp;
+	int irq;
+	tmp = status = priv->irq->ipend;
+	/* DBG("GR-RASTA-ADCDAC: IRQ 0x%x\n",status); */
+	for(irq=0; irq<16; irq++) {
+		if ( status & (1<<irq) ) {
+			priv->irq->iclear = (1<<irq);
+			status &= ~(1<<irq);
+				break;
+	if ( tmp )
+	DBG("RASTA-ADCDAC-IRQ: 0x%x\n", tmp);
+int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
+	uint32_t data;
+	unsigned int *page0 = NULL;
+	struct ambapp_dev *tmp;
+	int status;
+	struct ambapp_ahb_info *ahb;
+	uint32_t bar0, bar0_size;
+	/* Select version of GR-RASTA-ADCDAC board */
+	switch (devinfo->rev) {
+		case 0:
+			priv->version = &gr_rasta_adcdac_ver0;
+			break;
+		default:
+			return -2;
+	page0 = (unsigned int *)(bar0 + bar0_size/2);
+	/* Point PAGE0 to start of Plug and Play information */
+	*page0 = priv->version->amba_ioarea & 0xf0000000;
+	/* set parity error response */
+	pci_cfg_r32(priv->pcidev, PCI_COMMAND, &data);
+	pci_cfg_w32(priv->pcidev, PCI_COMMAND, (data|PCI_COMMAND_PARITY));
+	/* Scan AMBA Plug&Play */
+	/* AMBA MAP bar0 (in CPU) ==> 0x80000000(remote amba address) */
+	priv->amba_maps[0].size = bar0_size/2;
+	priv->amba_maps[0].local_adr = bar0;
+	priv->amba_maps[0].remote_adr = 0x80000000;
+	/* AMBA MAP bar1 (in CPU) ==> 0x40000000(remote amba address) */
+	priv->amba_maps[1].size = devinfo->resources[1].size;
+	priv->amba_maps[1].local_adr = devinfo->resources[1].address;
+	priv->amba_maps[1].remote_adr = 0x40000000;
+	/* Addresses not matching with map be untouched */
+	priv->amba_maps[2].size = 0xfffffff0;
+	priv->amba_maps[2].local_adr = 0;
+	priv->amba_maps[2].remote_adr = 0;
+	priv->amba_maps[3].size=0;
+	priv->amba_maps[3].local_adr = 0;
+	priv->amba_maps[3].remote_adr = 0;
+	/*ambapp_scan(priv->bar0 + (priv->version->amba_ioarea & ~0xf0000000),
+		NULL, &priv->amba_maps[0], NULL, &priv->abus.root, NULL);*/
+		bar0 + (priv->version->amba_ioarea & ~0xf0000000),
+	ambapp_freq_init(&priv->abus, NULL, priv->version->amba_freq_hz);
+	/* Point PAGE0 to start of APB area */
+	*page0 = 0x80000000;
+	/* Find GRPCI controller */
+	tmp = (void *)ambapp_for_each(&priv->abus,
+					(OPTIONS_ALL|OPTIONS_APB_SLVS),
+					VENDOR_GAISLER, GAISLER_PCIFBRG,
+					ambapp_find_by_idx, NULL);
+	if ( !tmp ) {
+		return -3;
+	priv->grpci = (struct grpci_regs *)((struct ambapp_apb_info *)tmp->devinfo)->start;
+	/* Set GRPCI mmap so that AMBA masters can access CPU-RAM over
+	 * the PCI window.
+	priv->grpci->cfg_stat = (priv->grpci->cfg_stat & 0x0fffffff) |
+				(priv->ahbmst2pci_map & 0xf0000000);
+	priv->grpci->page1 = 0x40000000;
+	/* Find IRQ controller */
+					VENDOR_GAISLER, GAISLER_IRQMP,
+	if ( !tmp ) {
+		return -4;
+	priv->irq = (struct irqmp_regs *)DEV_TO_APB(tmp)->start;
+	/* Set up GR-RASTA-ADCDAC irq controller */
+	priv->irq->iclear = 0xffff;
+	priv->irq->ilevel = 0;
+	priv->irq->mask[0] = 0;
+	/* DOWN streams translation table */
+	priv->bus_maps_down[0].name = "PCI BAR0 -> AMBA";
+	priv->bus_maps_down[0].from_adr = (void *)priv->amba_maps[0].local_adr;
+	priv->bus_maps_down[0].to_adr = (void *)priv->amba_maps[0].remote_adr;
+	priv->bus_maps_down[1].name = "PCI BAR1 -> AMBA";
+	priv->bus_maps_down[1].size = priv->amba_maps[1].size;
+	priv->bus_maps_down[1].from_adr = (void *)priv->amba_maps[1].local_adr;
+	priv->bus_maps_down[1].to_adr = (void *)priv->amba_maps[1].remote_adr;
+	/* Mark end of translation table */
+	priv->bus_maps_down[2].size = 0;
+	/* Find GRPCI controller AHB Slave interface */
+					(OPTIONS_ALL|OPTIONS_AHB_SLVS),
+	if ( !tmp ) {
+		return -5;
+	ahb = (struct ambapp_ahb_info *)tmp->devinfo;
+	/* UP streams translation table */
+	priv->bus_maps_up[0].name = "AMBA GRPCI Window";
+	priv->bus_maps_up[0].size = ahb->mask[0]; /* AMBA->PCI Window on GR-RASTA-ADCDAC board */
+	priv->bus_maps_up[0].from_adr = (void *)ahb->start[0];
+	/* Successfully registered the RASTA board */
+	return 0;
+int gr_rasta_adcdac_hw_init2(struct gr_rasta_adcdac_priv *priv)
+	/* Enable DMA by enabling PCI target as master */
+	return DRVMGR_OK;
+ * given in gr_rasta_adcdac_ids[].
+	struct gr_rasta_adcdac_priv *priv;
+	int status;
+	union drvmgr_key_value *value;
+	priv = malloc(sizeof(struct gr_rasta_adcdac_priv));
+	if ( !priv )
+	dev->priv = priv;
+	priv->dev = dev;
+	if ( gr_rasta_adcdac_resources_cnt == 0 ) {
+		while ( gr_rasta_adcdac_resources[gr_rasta_adcdac_resources_cnt] )
+			gr_rasta_adcdac_resources_cnt++;
+	strcpy(priv->prefix, "/dev/rastaadcdac0");
+	priv->prefix[16] += dev->minor_drv;
+	priv->prefix[17] = '/';
+	priv->prefix[18] = '\0';
+	printf("\n\n--- GR-RASTA-ADCDAC[%d] ---\n", dev->minor_drv);
+	printf(" PCI VENDOR: 0x%04x, DEVICE: 0x%04x\n",
+	/* all neccessary space assigned to GR-RASTA-ADCDAC target? */
+	/* Let user override which PCI address the AHB masters of the
+	 * RASTA-ADCDAC board access when doing DMA to CPU RAM. The AHB masters
+	 * access the PCI Window of the AMBA bus, the MSB 4-bits of that address
+	 * is translated according this config option before the address
+	 * goes out on the PCI bus.
+	 * Only the 4 MSB bits have an effect;
+	value = drvmgr_dev_key_get(priv->dev, "ahbmst2pci", KEY_TYPE_INT);
+	if (value)
+		priv->ahbmst2pci_map = value->i;
+	else
+		priv->ahbmst2pci_map = AHBMST2PCIADR; /* default */
+		free(priv);
+		dev->priv = NULL;
+	if ( (status = gr_rasta_adcdac_hw_init1(priv)) != 0 ) {
+		free(priv);
+		dev->priv = NULL;
+		printf(" Failed to initialize GR-RASTA-ADCDAC HW: %d\n", status);
+	priv->config.ops = &ambapp_rasta_adcdac_ops;
+	if ( priv->dev->minor_drv < gr_rasta_adcdac_resources_cnt ) {
+		priv->config.resources = gr_rasta_adcdac_resources[priv->dev->minor_drv];
+	} else {
+	struct gr_rasta_adcdac_priv *priv = dev->priv;
+	/* Enable System IRQ so that GR-RASTA-ADCDAC PCI target interrupt
+	 * goes through.
+	 * PCI board is connected, this is because PCI interrupts might
+	 * be shared and PCI board 2 have not initialized and might
+	 * therefore drive interrupt already when entering init1().
+		dev,
+		0,
+		"gr_rasta_adcdac",
+		gr_rasta_adcdac_isr,
+		(void *)priv);
+	return gr_rasta_adcdac_hw_init2(priv);
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_rasta_adcdac_priv *priv = dev->parent->dev->priv;
+	int status;
+		status = 0;
+		priv->irq->mask[0] |= (1<<irq); /* unmask interrupt source */
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+		priv->irq->mask[0] &= ~(1<<irq); /* mask interrupt source */
+	return status;
+	int irq)
+	DBG("RASTA-ADCDAC IRQ %d: unmask\n", irq);
+		return DRVMGR_EINVAL;
+	return DRVMGR_OK;
+	int irq)
+	DBG("RASTA-ADCDAC IRQ %d: mask\n", irq);
+	/* Disable/mask IRQ */
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_rasta_adcdac_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	return 0;
+void gr_rasta_adcdac_print_dev(struct drvmgr_dev *dev, int options)
+	/* Print */
+	printf("--- GR-RASTA-ADCDAC [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	printf(" IRQ REGS:        0x%x\n", (unsigned int)priv->irq);
+	printf(" PCI REVISION:    %d\n", devinfo->rev);
+	printf(" FREQ:            %d Hz\n", priv->version->amba_freq_hz);
+	printf(" IMASK:           0x%08x\n", priv->irq->mask[0]);
+	printf(" IPEND:           0x%08x\n", priv->irq->ipend);
+	if ( options & RASTA_ADCDAC_OPTIONS_AMBA ) {
+#if 0
+	if ( options & RASTA_ADCDAC_OPTIONS_IRQ ) {
+		int i;
+#endif
+	struct pci_drv_info *drv = &gr_rasta_adcdac_info;
+	while(dev) {
+		gr_rasta_adcdac_print_dev(dev, options);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
index 0000000..f96676d
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
@@ -0,0 +1,678 @@
+#include <stdio.h>
+#include <bsp.h>
+#include <pci.h>
+#include <grlib.h>
+#include <gr_rasta_io.h>
+#ifdef DEBUG
+#else
+#define DBG(x...)
+#endif
+/* PCI ID */
+int gr_rasta_io_init1(struct drvmgr_dev *dev);
+int gr_rasta_io_init2(struct drvmgr_dev *dev);
+struct gr_rasta_io_ver {
+struct gr_rasta_io_priv {
+	char				prefix[16];
+	/* PCI */
+	pci_dev_t			pcidev;
+	/* IRQ */
+	genirq_t			genirq;
+	/* GR-RASTA-IO */
+	struct gr_rasta_io_ver		*version;
+	/* AMBA Plug&Play information on GR-RASTA-IO */
+struct gr_rasta_io_ver gr_rasta_io_ver0 = {
+	.amba_freq_hz		= 30000000,
+struct gr_rasta_io_ver gr_rasta_io_ver1 = {
+int ambapp_rasta_io_int_register(
+	int irq,
+	const char *info,
+	void *arg);
+int ambapp_rasta_io_int_unregister(
+	int irq,
+	void *arg);
+int ambapp_rasta_io_int_unmask(
+	int irq);
+int ambapp_rasta_io_int_mask(
+	int irq);
+int ambapp_rasta_io_int_clear(
+	int irq);
+int ambapp_rasta_io_get_params(
+struct ambapp_ops ambapp_rasta_io_ops = {
+	.int_register = ambapp_rasta_io_int_register,
+	.int_unregister = ambapp_rasta_io_int_unregister,
+	.int_unmask = ambapp_rasta_io_int_unmask,
+	.int_mask = ambapp_rasta_io_int_mask,
+	.int_clear = ambapp_rasta_io_int_clear,
+	.get_params = ambapp_rasta_io_get_params
+struct drvmgr_drv_ops gr_rasta_io_ops =
+	.init = {gr_rasta_io_init1, gr_rasta_io_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct pci_dev_id_match gr_rasta_io_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_IO),
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER_OLD, PCIID_DEVICE_GR_RASTA_IO_OLD),
+struct pci_drv_info gr_rasta_io_info =
+		DRIVER_PCI_GAISLER_RASTAIO_ID,	/* Driver ID */
+		"GR-RASTA-IO_DRV",		/* Driver Name */
+		&gr_rasta_io_ops,
+		NULL,				/* Funcs */
+		0,
+	&gr_rasta_io_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-RASTA-IO board.
+ * pointer determine the configuration of one GR-RASTA-IO board. Pointer
+struct drvmgr_bus_res *gr_rasta_io_resources[] __attribute__((weak)) =
+	NULL
+int gr_rasta_io_resources_cnt = 0;
+	DBG("Registering GR-RASTA-IO PCI driver\n");
+	drvmgr_drv_register(&gr_rasta_io_info.general);
+void gr_rasta_io_isr (void *arg)
+	struct gr_rasta_io_priv *priv = arg;
+	int irq;
+	/* DBG("GR-RASTA-IO: IRQ 0x%x\n",status); */
+				break;
+	if ( tmp )
+	DBG("RASTA-IO-IRQ: 0x%x\n", tmp);
+int gr_rasta_io_hw_init(struct gr_rasta_io_priv *priv)
+	int status;
+	/* Select version of GR-RASTA-IO board */
+		case 0:
+			priv->version = &gr_rasta_io_ver0;
+			break;
+		case 1:
+			priv->version = &gr_rasta_io_ver1;
+			break;
+		default:
+			return -2;
+#if 0
+		uint32_t data;
+#endif
+	if ( !tmp ) {
+		return -3;
+	 * the PCI window.
+	/* Find IRQ controller, Clear all current IRQs */
+	if ( !tmp ) {
+		return -4;
+	/* Set up GR-RASTA-IO irq controller */
+	if ( !tmp ) {
+		return -5;
+	priv->bus_maps_up[0].size = ahb->mask[0]; /* AMBA->PCI Window on GR-RASTA-IO board */
+	return 0;
+int gr_rasta_io_hw_init2(struct gr_rasta_io_priv *priv)
+	return DRVMGR_OK;
+ * given in gr_rasta_io_ids[].
+	struct gr_rasta_io_priv *priv;
+	int status;
+	priv = malloc(sizeof(struct gr_rasta_io_priv));
+	if ( !priv )
+	dev->priv = priv;
+	priv->dev = dev;
+	if ( gr_rasta_io_resources_cnt == 0 ) {
+		while ( gr_rasta_io_resources[gr_rasta_io_resources_cnt] )
+			gr_rasta_io_resources_cnt++;
+	strcpy(priv->prefix, "/dev/rastaio0");
+	priv->prefix[12] += dev->minor_drv;
+	priv->prefix[13] = '/';
+	priv->prefix[14] = '\0';
+	printf("\n\n--- GR-RASTA-IO[%d] ---\n", dev->minor_drv);
+	/* all neccessary space assigned to GR-RASTA-IO target? */
+	 * GR-RASTA-IO board access when doing DMA to CPU RAM. The AHB masters
+	if (value)
+	else
+		free(priv);
+		dev->priv = NULL;
+	status = gr_rasta_io_hw_init(priv);
+	if ( status != 0 ) {
+		free(priv);
+		dev->priv = NULL;
+		printf(" Failed to initialize GR-RASTA-IO HW: %d\n", status);
+	priv->config.ops = &ambapp_rasta_io_ops;
+	if ( priv->dev->minor_drv < gr_rasta_io_resources_cnt ) {
+		priv->config.resources = gr_rasta_io_resources[priv->dev->minor_drv];
+	} else {
+	struct gr_rasta_io_priv *priv = dev->priv;
+	/* Enable System IRQ so that GR-RASTA-IO PCI target interrupt goes
+	 * through.
+	 * might therefore drive interrupt already when entering init1().
+		dev,
+		0,
+		"gr_rasta_io",
+		gr_rasta_io_isr,
+		(void *)priv);
+	return gr_rasta_io_hw_init2(priv);
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_rasta_io_priv *priv = dev->parent->dev->priv;
+	int status;
+		status = 0;
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+	return status;
+	int irq)
+	DBG("RASTA-IO IRQ %d: unmask\n", irq);
+	return DRVMGR_OK;
+	int irq)
+	DBG("RASTA-IO IRQ %d: mask\n", irq);
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_rasta_io_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	return 0;
+void gr_rasta_io_print_dev(struct drvmgr_dev *dev, int options)
+	/* Print */
+	printf("--- GR-RASTA-IO [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	if ( options & RASTA_IO_OPTIONS_AMBA ) {
+#if 0
+	if ( options & RASTA_IO_OPTIONS_IRQ ) {
+		int i;
+#endif
+	struct pci_drv_info *drv = &gr_rasta_io_info;
+	while(dev) {
+		gr_rasta_io_print_dev(dev, options);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
index 0000000..027c1d4
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
@@ -0,0 +1,675 @@
+/*  GR-RASTA-SPW-ROUTER PCI Target driver.
+ *  COPYRIGHT (c) 2011.
+ *  Configures the GR-RASTA-SPW-ROUTER interface PCI board.
+ *  of the AMBA PnP bus driver (ambapp_bus.c). Based on the
+ *  GR-RASTA-IO driver.
+#include <stdio.h>
+#include <bsp.h>
+#include <pci.h>
+#include <grlib.h>
+/*#include <gr_rasta_spw_router.h> */
+#define GRPCI2_BAR0_TO_AHB_MAP 0x04  /* Fixme */
+#define GRPCI2_PCI_CONFIG      0x20  /* Fixme */
+#define RASTA_SPW_ROUTER_OPTIONS_AMBA  0x01 /* Print AMBA bus devices */  /* Fixme */
+#define RASTA_SPW_ROUTER_OPTIONS_IRQ   0x02 /* Print current IRQ setup */ /* Fixme */
+#ifdef DEBUG
+#else
+#define DBG(x...)
+#endif
+/* PCI ID */
+int gr_rasta_spw_router_init1(struct drvmgr_dev *dev);
+int gr_rasta_spw_router_init2(struct drvmgr_dev *dev);
+struct grpci2_regs {
+	volatile unsigned int ctrl;
+	volatile unsigned int statcap;
+	volatile unsigned int pcimstprefetch;
+	volatile unsigned int ahbtopciiomap;
+	volatile unsigned int dmactrl;
+	volatile unsigned int dmadesc;
+	volatile unsigned int dmachanact;
+	volatile unsigned int reserved;
+	volatile unsigned int pcibartoahb[6];
+	volatile unsigned int reserved2[2];
+	volatile unsigned int ahbtopcimemmap[16];
+	volatile unsigned int trcctrl;
+	volatile unsigned int trccntmode;
+	volatile unsigned int trcadpat;
+	volatile unsigned int trcadmask;
+	volatile unsigned int trcctrlsigpat;
+	volatile unsigned int trcctrlsigmask;
+	volatile unsigned int trcadstate;
+	volatile unsigned int trcctrlsigstate;
+struct gr_rasta_spw_router_ver {
+struct gr_rasta_spw_router_priv {
+	char			prefix[20];
+	/* PCI */
+	pci_dev_t		pcidev;
+	/* IRQ */
+	genirq_t		genirq;
+	/* GR-RASTA-SPW-ROUTER */
+	struct gr_rasta_spw_router_ver	*version;
+	struct grpci2_regs	*grpci2;
+	/* AMBA Plug&Play information on GR-RASTA-SPW-ROUTER */
+struct gr_rasta_spw_router_ver gr_rasta_spw_router_ver0 = {
+	.amba_ioarea		= 0xfff00000,
+int ambapp_rasta_spw_router_int_register(
+	int irq,
+	const char *info,
+	void *arg);
+int ambapp_rasta_spw_router_int_unregister(
+	int irq,
+	void *arg);
+int ambapp_rasta_spw_router_int_unmask(
+	int irq);
+int ambapp_rasta_spw_router_int_mask(
+	int irq);
+int ambapp_rasta_spw_router_int_clear(
+	int irq);
+int ambapp_rasta_spw_router_get_params(
+struct ambapp_ops ambapp_rasta_spw_router_ops = {
+	.int_register = ambapp_rasta_spw_router_int_register,
+	.int_unregister = ambapp_rasta_spw_router_int_unregister,
+	.int_unmask = ambapp_rasta_spw_router_int_unmask,
+	.int_mask = ambapp_rasta_spw_router_int_mask,
+	.int_clear = ambapp_rasta_spw_router_int_clear,
+	.get_params = ambapp_rasta_spw_router_get_params
+struct drvmgr_drv_ops gr_rasta_spw_router_ops =
+	.init = {gr_rasta_spw_router_init1, gr_rasta_spw_router_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL
+struct pci_dev_id_match gr_rasta_spw_router_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR),
+struct pci_drv_info gr_rasta_spw_router_info =
+		DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID,	/* Driver ID */
+		"GR-RASTA-SPW_ROUTER_DRV",	/* Driver Name */
+		&gr_rasta_spw_router_ops,
+		NULL,				/* Funcs */
+		sizeof(struct gr_rasta_spw_router_priv),
+	&gr_rasta_spw_router_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-RASTA-SPW-ROUTER board.
+ * pointer determine the configuration of one GR-RASTA-SPW-ROUTER board. Pointer
+struct drvmgr_bus_res *gr_rasta_spw_router_resources[] __attribute__((weak)) =
+	NULL
+int gr_rasta_spw_router_resources_cnt = 0;
+void gr_rasta_spw_router_register_drv(void)
+	DBG("Registering GR-RASTA-SPW-ROUTER PCI driver\n");
+	drvmgr_drv_register(&gr_rasta_spw_router_info.general);
+void gr_rasta_spw_router_isr(void *arg)
+	struct gr_rasta_spw_router_priv *priv = arg;
+	int irq;
+	/* DBG("GR-RASTA-SPW-ROUTER: IRQ 0x%x\n",status); */
+				break;
+	 * still drives the IRQ
+	if ( tmp )
+	DBG("RASTA-SPW_ROUTER-IRQ: 0x%x\n", tmp);
+int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
+	int i;
+	uint32_t data;
+	unsigned int ctrl;
+	uint8_t tmp2;
+	int status;
+	uint8_t cap_ptr;
+	/* Select version of GR-RASTA-SPW-ROUTER board. Currently only one
+	 * version
+		case 0:
+			priv->version = &gr_rasta_spw_router_ver0;
+			break;
+		default:
+			return -2;
+	/* Check capabilities list bit */
+	pci_cfg_r8(pcidev, PCI_STATUS, &tmp2);
+	if (!((tmp2 >> 4) & 1)) {
+		/* Capabilities list not available which it should be in the GRPCI2 */
+		return -3;
+	/* Read capabilities pointer */
+	pci_cfg_r8(pcidev, PCI_CAP_PTR, &cap_ptr);
+	/* Set AHB address mappings for target PCI bars */
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_BAR0_TO_AHB_MAP, 0xffe00000);  /* APB bus, AHB I/O bus 2 MB */
+	/* Set PCI bus to be big endian */
+	pci_cfg_r32(pcidev, cap_ptr+GRPCI2_PCI_CONFIG, &data);
+	data = data & 0xFFFFFFFE;
+	pci_cfg_w32(pcidev, cap_ptr+GRPCI2_PCI_CONFIG, data);
+#if 0
+	pci_cfg_r32(pcidev, PCI_COMMAND, &data);
+	pci_cfg_w32(pcidev, PCI_COMMAND, (data|PCI_COMMAND_PARITY));
+#endif
+	/* AMBA MAP bar0 (in router) ==> 0xffe00000(remote amba address) */
+	priv->amba_maps[0].size = devinfo->resources[0].size;
+	priv->amba_maps[0].local_adr = devinfo->resources[0].address;
+	priv->amba_maps[0].remote_adr = 0xffe00000;
+	priv->amba_maps[1].size = 0xfffffff0;
+	priv->amba_maps[2].size=0;
+	ambapp_scan(
+		&priv->abus,
+		devinfo->resources[0].address + 0x100000,
+		NULL,
+		&priv->amba_maps[0]);
+	tmp = ambapp_for_each(&priv->abus,
+	if ( !tmp ) {
+		return -4;
+	/* Set up GR-RASTA-SPW-ROUTER irq controller */
+	/* Find GRPCI2 controller AHB Slave interface */
+					VENDOR_GAISLER, GAISLER_GRPCI2,
+	if ( !tmp ) {
+		return -5;
+	priv->bus_maps_up[0].name = "AMBA GRPCI2 Window";
+	priv->bus_maps_up[0].size = ahb->mask[0]; /* AMBA->PCI Window on GR-RASTA-SPW-ROUTER board */
+				(priv->ahbmst2pci_map & ~(ahb->mask[0]-1));
+	/* Find GRPCI2 controller APB Slave interface */
+	if ( !tmp ) {
+		return -6;
+	priv->grpci2 = (struct grpci2_regs *)
+		((struct ambapp_apb_info *)tmp->devinfo)->start;
+	/* Set AHB to PCI mapping for all AMBA AHB masters */
+	for(i = 0; i < 16; i++) {
+		priv->grpci2->ahbtopcimemmap[i] = priv->ahbmst2pci_map &
+							~(ahb->mask[0]-1);
+	/* Make sure dirq(0) sampling is enabled */
+	ctrl = priv->grpci2->ctrl;
+	ctrl = (ctrl & 0xFFFFFF0F) | (1 << 4);
+	printf("data: 0x%x\n", ctrl);
+	priv->grpci2->ctrl = ctrl;
+	/* Successfully registered the RASTA-SPW-ROUTER board */
+	return 0;
+int gr_rasta_spw_router_hw_init2(struct gr_rasta_spw_router_priv *priv)
+	return DRVMGR_OK;
+ * given in gr_rasta_spw_router_ids[].
+	struct gr_rasta_spw_router_priv *priv;
+	int status;
+	priv = dev->priv;
+	if (!priv)
+	dev->priv = priv;
+	priv->dev = dev;
+	if ( gr_rasta_spw_router_resources_cnt == 0 ) {
+		while ( gr_rasta_spw_router_resources[gr_rasta_spw_router_resources_cnt] )
+			gr_rasta_spw_router_resources_cnt++;
+	strcpy(priv->prefix, "/dev/spwrouter0");
+	priv->prefix[14] += dev->minor_drv;
+	priv->prefix[15] = '/';
+	priv->prefix[16] = '\0';
+	printf("\n\n--- GR-RASTA-SPW-ROUTER[%d] ---\n", dev->minor_drv);
+	printf(" PCI BAR[0]: 0x%08lx - 0x%08lx\n", bar0, bar0 + bar0_size - 1);
+	/* all neccessary space assigned to GR-RASTA-SPW-ROUTER target? */
+	if (bar0_size == 0)
+	 * GR-RASTA-SPW board access when doing DMA to CPU RAM. The AHB masters
+	if (value)
+	else
+	if ((status = gr_rasta_spw_router_hw_init(priv)) != 0) {
+		printf(" Failed to initialize GR-RASTA-SPW-ROUTER HW: %d\n", status);
+	priv->config.ops = &ambapp_rasta_spw_router_ops;
+	if ( priv->dev->minor_drv < gr_rasta_spw_router_resources_cnt ) {
+		priv->config.resources = gr_rasta_spw_router_resources[priv->dev->minor_drv];
+	} else {
+	struct gr_rasta_spw_router_priv *priv = dev->priv;
+	/* Enable System IRQ so that GR-RASTA-SPW-ROUTER PCI target interrupt
+	 * goes through.
+		dev,
+		0,
+		"gr_rasta_spw_router",
+		gr_rasta_spw_router_isr,
+		(void *)priv);
+	return gr_rasta_spw_router_hw_init2(priv);
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_rasta_spw_router_priv *priv = dev->parent->dev->priv;
+	int status;
+	if (status == 0) {
+	} else if (status == 1)
+		status = 0;
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+	return status;
+	int irq)
+	DBG("RASTA-SPW-ROUTER IRQ %d: unmask\n", irq);
+	return DRVMGR_OK;
+	int irq)
+	DBG("RASTA-SPW-ROUTER IRQ %d: mask\n", irq);
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_rasta_spw_router_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	return 0;
+void gr_rasta_spw_router_print_dev(struct drvmgr_dev *dev, int options)
+	/* Print */
+	printf("--- GR-RASTA-SPW-ROUTER [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	if (options & RASTA_SPW_ROUTER_OPTIONS_AMBA)
+#if 0
+	if (options & RASTA_SPW_ROUTER_OPTIONS_IRQ) {
+		int i;
+				(unsigned int)priv->isrs[i].arg);
+#endif
+void gr_rasta_spw_router_print(int options)
+	struct pci_drv_info *drv = &gr_rasta_spw_router_info;
+	while(dev) {
+		gr_rasta_spw_router_print_dev(dev, options);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
index 0000000..7a10083
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
@@ -0,0 +1,684 @@
+ *  Driver resources for the AMBA PnP bus provided can be set by overriding
+ *  the defaults by declaring gr_rasta_tmtc_resources[].
+#include <stdio.h>
+#include <bsp.h>
+#include <pci.h>
+#include <grlib.h>
+#include <gr_rasta_tmtc.h>
+#define GAISLER_GPIO         0x01a
+#define AHB1_IOAREA_BASE_ADDR 0x80200000
+#ifdef DEBUG
+#else
+#define DBG(x...)
+#endif
+int gr_rasta_tmtc_init1(struct drvmgr_dev *dev);
+int gr_rasta_tmtc_init2(struct drvmgr_dev *dev);
+struct gr_rasta_tmtc_ver {
+struct gr_rasta_tmtc_priv {
+	char				prefix[20];
+	/* PCI */
+	pci_dev_t			pcidev;
+	/* IRQ */
+	genirq_t			genirq;
+	/* GR-RASTA-TMTC */
+	struct gr_rasta_tmtc_ver	*version;
+	struct grgpio_regs		*gpio;
+	/* AMBA Plug&Play information on GR-RASTA-TMTC */
+struct gr_rasta_tmtc_ver gr_rasta_tmtc_ver0 = {
+	.amba_ioarea		= AHB1_IOAREA_BASE_ADDR,
+int ambapp_rasta_tmtc_int_register(
+	int irq,
+	const char *info,
+	void *arg);
+int ambapp_rasta_tmtc_int_unregister(
+	int irq,
+	void *arg);
+int ambapp_rasta_tmtc_int_unmask(
+	int irq);
+int ambapp_rasta_tmtc_int_mask(
+	int irq);
+int ambapp_rasta_tmtc_int_clear(
+	int irq);
+int ambapp_rasta_tmtc_get_params(
+struct ambapp_ops ambapp_rasta_tmtc_ops = {
+	.int_register = ambapp_rasta_tmtc_int_register,
+	.int_unregister = ambapp_rasta_tmtc_int_unregister,
+	.int_unmask = ambapp_rasta_tmtc_int_unmask,
+	.int_mask = ambapp_rasta_tmtc_int_mask,
+	.int_clear = ambapp_rasta_tmtc_int_clear,
+	.get_params = ambapp_rasta_tmtc_get_params
+struct drvmgr_drv_ops gr_rasta_tmtc_ops =
+	.init = {gr_rasta_tmtc_init1, gr_rasta_tmtc_init2, NULL, NULL},
+	.remove = NULL,
+	.info = NULL,
+struct pci_dev_id_match gr_rasta_tmtc_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_TMTC),
+struct pci_drv_info gr_rasta_tmtc_info =
+		DRIVER_PCI_GAISLER_RASTATMTC_ID,/* Driver ID */
+		"GR-RASTA-TMTC_DRV",		/* Driver Name */
+		&gr_rasta_tmtc_ops,
+		NULL,				/* Funcs */
+		sizeof(struct gr_rasta_tmtc_priv) /* Let drvmgr alloc private */
+	&gr_rasta_tmtc_ids[0]
+/* Driver resources configuration for the AMBA bus on the GR-RASTA-TMTC board.
+ * pointer determine the configuration of one GR-RASTA-TMTC board. Pointer
+struct drvmgr_bus_res *gr_rasta_tmtc_resources[] __attribute__((weak)) =
+	NULL,
+int gr_rasta_tmtc_resources_cnt = 0;
+	DBG("Registering GR-RASTA-TMTC PCI driver\n");
+	drvmgr_drv_register(&gr_rasta_tmtc_info.general);
+void gr_rasta_tmtc_isr (void *arg)
+	struct gr_rasta_tmtc_priv *priv = arg;
+	int irq;
+	/* printk("GR-RASTA-TMTC: IRQ 0x%x\n",status); */
+	for(irq=0; irq<32; irq++) {
+				break;
+	if ( tmp )
+	DBG("RASTA-TMTC-IRQ: 0x%x\n", tmp);
+int gr_rasta_tmtc_hw_init(struct gr_rasta_tmtc_priv *priv)
+	/* Select version of GR-RASTA-TMTC board */
+		case 0:
+			priv->version = &gr_rasta_tmtc_ver0;
+			break;
+		default:
+			return -2;
+#if 0
+		uint32_t data;
+#endif
+	priv->amba_maps[0].size = 0x10000000;
+	priv->amba_maps[0].remote_adr = AHB1_BASE_ADDR;
+	drvmgr_freq_get(priv->dev, 0, &pci_freq_hz);
+	*page0 = AHB1_BASE_ADDR;
+	if ( !tmp ) {
+		return -3;
+	 * the PCI window.
+	if ( !tmp ) {
+		return -4;
+	/* Set up GR-RASTA-TMTC irq controller */
+	priv->irq->iclear = 0xffffffff;
+	/* Find First GPIO controller */
+					VENDOR_GAISLER, GAISLER_GPIO,
+	if ( !tmp ) {
+		return -5;
+	priv->gpio = (struct grgpio_regs *) (((struct ambapp_apb_info *)tmp->devinfo)->start);
+	/* Clear GR-RASTA-TMTC GPIO controller */
+	priv->gpio->imask = 0;
+	priv->gpio->ipol = 0;
+	priv->gpio->iedge = 0;
+	priv->gpio->bypass = 0;
+	/* Set up GR-RASTA-TMTC GPIO controller to select GRTM and GRTC */
+	priv->gpio->output = (GR_TMTC_GPIO_GRTM_SEL|GR_TMTC_GPIO_TRANSP_CLK) | (GR_TMTC_GPIO_TC_BIT_LOCK|GR_TMTC_GPIO_TC_RF_AVAIL|GR_TMTC_GPIO_TC_ACTIVE_HIGH|GR_TMTC_GPIO_TC_RISING_CLK);
+	priv->gpio->dir = 0xffffffff;
+	DBG("GR-TMTC GPIO: 0x%x\n", (unsigned int)priv->gpio);
+	pci_master_enable(pcidev);
+	tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
+	if ( !tmp ) {
+		return -6;
+	priv->bus_maps_up[0].size = ahb->mask[0]; /* AMBA->PCI Window on GR-RASTA-TMTC board */
+	return 0;
+void gr_rasta_tmtc_hw_init2(struct gr_rasta_tmtc_priv *priv)
+ * given in gr_rasta_tmtc_ids[].
+	struct gr_rasta_tmtc_priv *priv;
+	int status;
+	priv = dev->priv;
+	if (!priv)
+	priv->dev = dev;
+	if ( gr_rasta_tmtc_resources_cnt == 0 ) {
+		while ( gr_rasta_tmtc_resources[gr_rasta_tmtc_resources_cnt] )
+			gr_rasta_tmtc_resources_cnt++;
+	strcpy(priv->prefix, "/dev/rastatmtc0");
+	printf("\n\n--- GR-RASTA-TMTC[%d] ---\n", dev->minor_drv);
+	 * GR-RASTA-TMTC board access when doing DMA to CPU RAM. The AHB masters
+	if (value)
+	else
+	priv->genirq = genirq_init(32);
+	status = gr_rasta_tmtc_hw_init(priv);
+		printf(" Failed to initialize GR-RASTA-TMTC HW: %d\n", status);
+	priv->config.ops = &ambapp_rasta_tmtc_ops;
+	if ( priv->dev->minor_drv < gr_rasta_tmtc_resources_cnt ) {
+		priv->config.resources = gr_rasta_tmtc_resources[priv->dev->minor_drv];
+	} else {
+	struct gr_rasta_tmtc_priv *priv = dev->priv;
+	/* Enable System IRQ so that GR-RASTA-TMTC PCI target interrupt goes
+	 * through.
+	 * PCI target is connected, this is because PCI interrupts might
+		priv->dev,
+		0,
+		"gr_rasta_tmtc",
+		gr_rasta_tmtc_isr,
+		(void *)priv);
+	gr_rasta_tmtc_hw_init2(priv);
+	return DRVMGR_OK;
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_rasta_tmtc_priv *priv = dev->parent->dev->priv;
+	int status;
+		/* Disable and clear IRQ for first registered handler */
+		status = 0;
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+		status = 0;
+	return status;
+	int irq)
+	DBG("RASTA-TMTC IRQ %d: unmask\n", irq);
+	/* Enable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	DBG("RASTA-TMTC IRQ %d: mask\n", irq);
+	/* Disable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_rasta_tmtc_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	return 0;
+void gr_rasta_tmtc_print_dev(struct drvmgr_dev *dev, int options)
+	/* Print */
+	printf("--- GR-RASTA-TMTC [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	if ( options & RASTA_TMTC_OPTIONS_AMBA ) {
+#if 0
+	if ( options & RASTA_TMTC_OPTIONS_IRQ ) {
+		int i;
+#endif
+	struct pci_drv_info *drv = &gr_rasta_tmtc_info;
+	while(dev) {
+		gr_rasta_tmtc_print_dev(dev, options);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c b/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
index 0000000..6b512a9
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
@@ -0,0 +1,571 @@
+#include <stdio.h>
+#include <bsp.h>
+#include <pci.h>
+#include <grlib.h>
+#include <gr_tmtc_1553.h>
+/*#define DEBUG 1 */
+#ifdef DEBUG
+#else
+#define DBG(x...)
+#endif
+/* PCI ID */
+int gr_tmtc_1553_init1(struct drvmgr_dev *dev);
+int gr_tmtc_1553_init2(struct drvmgr_dev *dev);
+struct gr_tmtc_1553_ver {
+struct gr_tmtc_1553_priv {
+	char				prefix[32];
+	/* PCI */
+	pci_dev_t			pcidev;
+	/* IRQ */
+	genirq_t			genirq;
+	struct gr_tmtc_1553_ver         *version;
+struct gr_tmtc_1553_ver gr_tmtc_1553_ver0 = {
+	.amba_freq_hz		= 33333333,
+int ambapp_tmtc_1553_int_register(
+	int irq,
+	const char *info,
+	void *arg);
+int ambapp_tmtc_1553_int_unregister(
+	int irq,
+	void *arg);
+int ambapp_tmtc_1553_int_unmask(
+	int irq);
+int ambapp_tmtc_1553_int_mask(
+	int irq);
+int ambapp_tmtc_1553_int_clear(
+	int irq);
+int ambapp_tmtc_1553_get_params(
+struct ambapp_ops ambapp_tmtc_1553_ops = {
+	.int_register = ambapp_tmtc_1553_int_register,
+	.int_unregister = ambapp_tmtc_1553_int_unregister,
+	.int_unmask = ambapp_tmtc_1553_int_unmask,
+	.int_mask = ambapp_tmtc_1553_int_mask,
+	.int_clear = ambapp_tmtc_1553_int_clear,
+	.get_params = ambapp_tmtc_1553_get_params
+struct drvmgr_drv_ops gr_tmtc_1553_ops =
+	{gr_tmtc_1553_init1, gr_tmtc_1553_init2, NULL, NULL},
+	NULL,
+	NULL
+struct pci_dev_id_match gr_tmtc_1553_ids[] =
+	PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553),
+struct pci_drv_info gr_tmtc_1553_info =
+		DRIVER_PCI_GAISLER_TMTC_1553_ID, /* Driver ID */
+		"GR-TMTC-1553_DRV",		/* Driver Name */
+		&gr_tmtc_1553_ops,
+		NULL,				/* Funcs */
+		0,
+	&gr_tmtc_1553_ids[0]
+struct drvmgr_bus_res *gr_tmtc_1553_resources[] __attribute__((weak)) =
+	NULL
+int gr_tmtc_1553_resources_cnt = 0;
+	DBG("Registering GR-TMTC-1553 PCI driver\n");
+	drvmgr_drv_register(&gr_tmtc_1553_info.general);
+void gr_tmtc_1553_isr (void *arg)
+	struct gr_tmtc_1553_priv *priv = arg;
+	int irq;
+				break;
+	if ( tmp )
+	DBG("GR-TMTC-1553-IRQ: 0x%x\n", tmp);
+int gr_tmtc_1553_hw_init(struct gr_tmtc_1553_priv *priv)
+	int status;
+	/* Select version of GR-TMTC-1553 board */
+		case 0:
+			priv->version = &gr_tmtc_1553_ver0;
+			break;
+		default:
+			return -2;
+	/* Point PAGE0 to start of board address map. RAM at 0xff000000, APB at 0xffc00000, IOAREA at 0xfff000000 */
+	/* XXX We assume little endian host with byte twisting enabled here */
+	*page0 = 0x010000ff;	/* Set little endian mode on peripheral. */
+	priv->amba_maps[0].size = 0x1000000;
+	priv->amba_maps[0].remote_adr = 0xff000000;
+		bar0 + (priv->version->amba_ioarea & ~0xff000000),
+	/* Frequency is the hsame as the PCI bus frequency */
+	if ( !tmp ) {
+		return -4;
+	/* Set up irq controller */
+	/* Successfully registered the board */
+	return 0;
+ * given in gr_tmtc_1553_ids[].
+	struct gr_tmtc_1553_priv *priv;
+	int status;
+	/* PCI device does not have the IRQ line register, when PCI autoconf configures it the configuration
+	 * is forgotten. We take the IRQ number from the PCI Host device (AMBA device), this works as long
+	 * as PCI-IRQs are ored together on the bus.
+	 * Note that this only works on LEON.
+	((struct pci_dev_info *)dev->businfo)->irq = ((struct amba_dev_info *)dev->parent->dev->businfo)->info.irq;
+	priv = malloc(sizeof(struct gr_tmtc_1553_priv));
+	if ( !priv )
+	dev->priv = priv;
+	priv->dev = dev;
+	if ( gr_tmtc_1553_resources_cnt == 0 ) {
+		while ( gr_tmtc_1553_resources[gr_tmtc_1553_resources_cnt] )
+			gr_tmtc_1553_resources_cnt++;
+	strcpy(priv->prefix, "/dev/tmtc1553_0/");
+	priv->prefix[19] += dev->minor_drv;
+	priv->prefix[20] = '/';
+	priv->prefix[21] = '\0';
+	printf("\n\n--- GR-TMTC-1553[%d] ---\n", dev->minor_drv);
+	/* all neccessary space assigned to GR-TMTC-1553 target? */
+		free(priv);
+		dev->priv = NULL;
+	status = gr_tmtc_1553_hw_init(priv);
+		free(priv);
+		dev->priv = NULL;
+		printf(" Failed to initialize GR-TMTC-1553 HW: %d\n", status);
+	priv->config.ops = &ambapp_tmtc_1553_ops;
+	/* This PCI device has only target interface so DMA is not supported,
+	 * which means that translation from AMBA->PCI should fail if attempted.
+	priv->config.maps_up = DRVMGR_TRANSLATE_NO_BRIDGE;
+	if ( priv->dev->minor_drv < gr_tmtc_1553_resources_cnt ) {
+		priv->config.resources = gr_tmtc_1553_resources[priv->dev->minor_drv];
+	} else {
+	/* Create And Register AMBA PnP Bus */
+	struct gr_tmtc_1553_priv *priv = dev->priv;
+	/* Enable System IRQ so that GR-TMTC-1553 PCI target interrupt goes through.
+	 * It is important to enable it in stage init2. If interrupts were enabled in init1
+	 * this might hang the system when more than one PCI target is connected, this is
+	 * because PCI interrupts might be shared and PCI target 2 have not initialized and
+		dev,
+		0,
+		"gr_tmtc_1553",
+		gr_tmtc_1553_isr,
+		(void *)priv);
+	return DRVMGR_OK;
+	int irq,
+	const char *info,
+	void *arg)
+	struct gr_tmtc_1553_priv *priv = dev->parent->dev->priv;
+	int status;
+		status = 0;
+		status = 0;
+	return status;
+	int irq,
+	drvmgr_isr isr,
+	void *arg)
+	int status;
+		status = 0;
+	return status;
+	int irq)
+	DBG("TMTC-1553 IRQ %d: enable\n", irq);
+	/* Enable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	DBG("TMTC-1553 IRQ %d: disable\n", irq);
+	/* Disable IRQ */
+	return DRVMGR_OK;
+	int irq)
+	return DRVMGR_OK;
+int ambapp_tmtc_1553_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	return 0;
+void gr_tmtc_1553_print_dev(struct drvmgr_dev *dev, int options)
+	/* Print */
+	printf("--- GR-TMTC-1553 [bus 0x%x, dev 0x%x, fun 0x%x] ---\n",
+	if ( options & TMTC_1553_OPTIONS_AMBA ) {
+#if 0
+	if ( options & TMTC_1553_OPTIONS_IRQ ) {
+		int i;
+#endif
+	struct pci_drv_info *drv = &gr_tmtc_1553_info;
+	while(dev) {
+		gr_tmtc_1553_print_dev(dev, options);
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
deleted file mode 100644
index fce2fa8..0000000
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_pci.c
+++ /dev/null
@@ -1,132 +0,0 @@
-#include <ambapp.h>
-#include <rtems/libio.h>
-#include <grspw_pci.h>
-/* Select PCI driver */
-#define GRSPW_PCI
-#undef GRSPW_MAXDEVS
-#undef DEBUG_SPACEWIRE_ONOFF
-/* Only Malloced memory supported
-#undef GRSPW_LOCAL_MEM
-/* memory must be aligned to a 128k boundary */
-unsigned int grspwpci_memarea_address;
-#define GRSPW_LOCAL_MEM_ADR grspwpci_memarea_address
-/* We have custom address tranlation for HW addresses */
-#define GRSPW_ADR_TO
-/* MEMAREA=>CPU used when reading descriptor buffer pointers,
- * they need to be translated from adresses used by GRSPW HW
- * into CPU readable addresses.
- * NOT NEEDED AS GRSPW DRIVER USES INDEXES TO GET DESCRIPTOR
- * DATA POINTER ADDRESSES.
-#undef GRSPW_ADR_FROM
-/* Set registered device name */
-#define GRSPW_DEVNAME "/dev/grspwpci0"
-#define GRSPW_DEVNAME_NO(devstr,no) ((devstr)[13]='0'+(no))
-/* Any non-static function will begin with */
-#define GRSPW_PREFIX(name) grspwpci##name
-/* do nothing, assume that the interrupt handler is called
- * setup externally calling b1553_interrupt_handler.
-#define GRSPW_REG_INT(handler,irq,arg) \
- if ( grspw_pci_int_reg ) \
-   grspw_pci_int_reg(handler,irq,arg);
-void (*grspw_pci_int_reg)(void *handler, int irq, void *arg) = 0;
-#ifdef GRSPW_ADR_TO
-/* Translate an address within the Memory Region (memarea) into an Hardware
- * device address. This address is put into hardware registers or descriptors
- * so that the hardware can access the Memory Region.
- * Example:
- * A local AMBA access at 0xe0000000 will translate into PCI address 0x40000000,
- * the PCI address 0x40000000 will translate into LEON-AMBA address 0x40000000.
-unsigned int grspwpci_hw_address;
-static inline unsigned int memarea_to_hw(unsigned int addr) {
-		/* don't translate? */
-		if ( grspwpci_hw_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x0fffffff) | grspwpci_hw_address);
-#endif
-/* not used since BRM Core work with offsets */
-#ifdef GRSPW_ADR_FROM
-unsigned int grspwpci_cpu_access_address;
-static inline unsigned int hw_to_cpu(unsigned int addr) {
-		if ( grspwpci_cpu_address == 0xffffffff )
-			return addr;
-    return ((addr & 0x0fffffff) | grspwpci_cpu_address);
-#endif
-int grspwpci_interrupt_handler(int irq, void *arg);
-#include "grspw.c"
- * memarea     = preallocated memory somewhere, pointer to start of memory.
- * hw_address  = how to translate a memarea address into an HW device AMBA address.
-int grspw_pci_register(
- struct ambapp_bus *bus,
- unsigned int hw_address
-	/* Setup configuration */
-	/* if zero the malloc will be used */
-	grspwpci_memarea_address = memarea;
-	grspwpci_hw_address = hw_address;
-	grspwpci_cpu_address = memarea & 0xf0000000;
-#endif
-	/* Register the driver */
-	return GRSPW_PREFIX(_register)(bus);
-/* Call this from PCI interrupt handler
- * irq = the irq number of the HW device local to that IRQMP controller
-int grspwpci_interrupt_handler(int irq, void *arg){
-	grspw_interrupt( (GRSPW_DEV *)arg );
-  return 0;
-#if 0
-int grspw_pci_interrupt_handler(int irqmask){
-	int i;
-	unsigned int mask=0;
-	/* find minor */
-	for(i=0; i<spw_cores; i++){
-		if ( (1<<SPW_PARAM(i).irq) & irqmask ){
-			mask |= 1<<SPW_PARAM(i).irq;
-			grspw_interrupt(i);
-			/* more interrupts to scan for? */
-			if ( irqmask & ~mask )
-				return mask; /* handled */
-	return mask;
-#endif
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
index b76d46a..0000000
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_rasta.c
+++ /dev/null
@@ -1,158 +0,0 @@
-#include <rtems.h>
-#include <grspw_rasta.h>
-#define GRSPW_PCI
-/*#define DEBUG_SPACEWIRE_ONOFF*/
- * If USE_AT697_RAM is defined the RAM on the AT697 board will be used for DMA buffers (but rx message queue is always in AT697 ram).
- * USE_AT697_DMA specifies whether the messages will be fetched using DMA or PIO.
- * RASTA_PCI_BASE is the base address of the GRPCI AHB slave
-#define USE_AT697_RAM              1
-#define USE_AT697_DMA              0
-#define RASTA_PCI_BASE             0xe0000000
-#define GRSPW_RASTA_MEM_OFF        0x21000
-/* Make GRSPW driver use malloced or static memory
-#ifdef USE_AT697_RAM
-#undef GRSPW_STATIC_MEM
-#else
-#define GRSPW_STATIC_MEM
-#define GRSPW_CALC_MEMOFS(maxcores,corenum,ptr_mem_base,ptr_mem_end,ptr_bdtable_base) \
-	grspw_rasta_calc_memoffs((maxcores),(corenum),(ptr_mem_base),(ptr_mem_end),(ptr_bdtable_base))
-#endif
-#define GRSPW_DEVNAME "/dev/grspwrasta0"
-#define GRSPW_DEVNAME_NO(devstr,no) ((devstr)[15]='0'+(no))
-#define GRSPW_PREFIX(name) grspwrasta##name
- * setup externally calling grspw_interrupt_handler.
-  if ( grspw_rasta_int_reg ) \
-    grspw_rasta_int_reg(handler,irq,arg);
-#define GRSPW_DONT_BYPASS_CACHE
-/* Translate a address within the Memory Region (memarea) into an Hardware
- * Example:
- * An local AMBA access at 0xe0000000 will translate into PCI address 0x40000000,
- * the PCI address 0x40000000 will translate into CPU-AMBA address 0x40000000.
-    return ((addr & 0x0fffffff) | RASTA_PCI_BASE);
-#endif
-void (*grspw_rasta_int_reg)(void *handler, int irq, void *arg) = 0;
-#ifdef GRSPW_STATIC_MEM
-static int grspw_rasta_calc_memoffs(int maxcores, int corenum, unsigned int *mem_base, unsigned int *mem_end, unsigned int *bdtable_base);
-#endif
-void grspwrasta_interrupt_handler(int irq, void *pDev);
-#include "grspw.c"
-unsigned int grspw_rasta_memarea_address;
-/* Register RASTA GRSPW driver.
-	grspw_rasta_memarea_address = ram_base + GRSPW_RASTA_MEM_OFF;
-#if 0
-/* Call this from PCI interrupt handler, simply figures out
- * which GRSPW core was responsible for the IRQ (may be multiple).
- * v = status of the PCI/AMBA MCPU IRQ CTRL
-        int minor;
-        for(minor = 0; minor < spw_cores; minor++) {
-                if (status & (1<<grspw_devs[minor].irq) ) {
-                        grspw_interrupt(&grspw_devs[minor]);
-#endif
-void GRSPW_PREFIX(_interrupt_handler)(int irq, void *pDev)
-  grspw_interrupt(pDev);
- *  | Core1: BD TABLE 1 and 2             |
- *  | Core2: BD TABLE 1 and 2             |
- *  | Core3: BD TABLE 1 and 2             |
- *  | Core1: rx data buf + rx header buf  |
- *  | Core2: rx data buf + rx header buf  |
- *  | Core3: rx data buf + rx header buf  |
-	if ( maxcores > 3 )
-		return -1;
-	if ( bdtable_base )
-		*bdtable_base = grspw_rasta_memarea_address + corenum*2*SPACEWIRE_BDTABLE_SIZE;
-	if ( mem_base )
-		*mem_base = grspw_rasta_memarea_address + coremax*2*SPACEWIRE_BDTABLE_SIZE + corenum*BUFMEM_PER_LINK;
-	if ( mem_end )
-		*mem_end = grspw_rasta_memarea_address + coremax*2*SPACEWIRE_BDTABLE_SIZE + (corenum+1)*BUFMEM_PER_LINK;
-	return 0;
-#endif
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
index 9ea3967..0000000
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_pci.c
+++ /dev/null
@@ -1,44 +0,0 @@
-#include <apbuart_pci.h>
-#undef DEBUG
-#define APBUART_DEVNAME "/dev/apbupci0"
-#define APBUART_DEVNAME_NO(devstr,no) ((devstr)[12]='0'+(no))
-#define APBUART_PREFIX(name) apbuartpci##name
- * setup externally calling apbuartpci_interrupt_handler.
-#define APBUART_REG_INT(handler,irq,arg) \
- if ( apbuart_pci_int_reg ) \
-   apbuart_pci_int_reg(handler,irq,arg);
-void (*apbuart_pci_int_reg)(void *handler, int irq, void *arg) = 0;
-void apbuartpci_interrupt_handler(int irq, void *arg);
-/* AMBA Bus is clocked using the PCI clock (33.3MHz) */
-#define SYS_FREQ_HZ 33333333
-#include "apbuart.c"
-int apbuart_pci_register(struct ambapp_bus *bus)
-	return APBUART_PREFIX(_register)(bus);
-void apbuartpci_interrupt_handler(int irq, void *arg){
-	apbuart_interrupt(arg);
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
index f6d561e..0000000
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_rasta.c
+++ /dev/null
@@ -1,43 +0,0 @@
-#undef DEBUG
-#include <apbuart_rasta.h>
-#define APBUART_DEVNAME "/dev/apburasta0"
-#define APBUART_DEVNAME_NO(devstr,no) ((devstr)[14]='0'+(no))
-#define APBUART_PREFIX(name) apbuartrasta##name
- * setup externally calling apbuartrasta_interrupt_handler.
- if ( apbuart_rasta_int_reg ) \
-   apbuart_rasta_int_reg(handler,irq,arg);
-void (*apbuart_rasta_int_reg)(void *handler, int irq, void *arg) = 0;
-void apbuartrasta_interrupt_handler(int irq, void *arg);
-/* AMBA Bus is clocked using the RASTA internal clock (30MHz) */
-#define SYS_FREQ_HZ 30000000
-int apbuart_rasta_register(struct ambapp_bus *bus)
-/* Call this from RASTA interrupt handler
-void apbuartrasta_interrupt_handler(int irq, void *arg){
1.7.0.4
