[PATCH 019/111] LEON2: added support for LEON2-GRLIB systems
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:21 UTC 2015
In some non-standard designs GRLIB peripherals are used together
LEON2. This patch adds a GRLIB amba Plug&Play driver so that AMBA
devices can be found from Plug&Play the same way as with the LEON3
BSP.
The user is required to add an AMBA-PnP device entry into the LEON2
bus configuration, so that the driver manager unite this driver
with the "fake" device and start scanning after AMBA PnP devices.
 c/src/lib/libbsp/sparc/Makefile.am                 |    1 +
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |    1 +
 .../libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c  |  265 ++++++++++++++++++++
 3 files changed, 267 insertions(+), 0 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index 0d61a41..3f0854e 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -89,6 +89,7 @@ EXTRA_DIST += shared/include/i2cmst.h
 # Driver Manager
 EXTRA_DIST += shared/drvmgr/ambapp_bus.c
 EXTRA_DIST += shared/drvmgr/ambapp_bus_grlib.c
+EXTRA_DIST += shared/drvmgr/ambapp_bus_leon2.c
 EXTRA_DIST += shared/drvmgr/leon2_amba_bus.c
 EXTRA_DIST += shared/include/drvmgr/ambapp_bus_grlib.h
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index ba98665..e923025 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -147,6 +147,7 @@ include_drvmgrdir = $(includedir)/drvmgr
 include_drvmgr_HEADERS = ../../sparc/shared/include/drvmgr/ambapp_bus.h
 include_drvmgr_HEADERS += ../../sparc/shared/include/drvmgr/leon2_amba_bus.h
 libbsp_a_SOURCES += ../../sparc/shared/drvmgr/ambapp_bus.c
+libbsp_a_SOURCES += ../../sparc/shared/drvmgr/ambapp_bus_leon2.c
 libbsp_a_SOURCES += ../../sparc/shared/drvmgr/leon2_amba_bus.c
 if HAS_SMP
diff --git a/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
new file mode 100644
index 0000000..12034dc
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/drvmgr/ambapp_bus_leon2.c
@@ -0,0 +1,265 @@
+/*  LEON2 GRLIB AMBA Plug & Play bus driver.
+ *  COPYRIGHT (c) 2008.
+ *  Cobham Gaisler AB.
+ *  This is driver is a wrapper for the general AMBA Plug & Play bus
+ *  driver. This is a bus driver for LEON2-GRLIB systems providing a
+ *  AMBA Plug & Play bus, the parent bus must be a LEON2 hardcoded
+ *  Bus. All IRQs must be routed to this bus driver in order for IRQs
+ *  to work. The PnP information is used to extract IRQs and base
+ *  register addresses.
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <bsp.h>
+#ifdef LEON2
+#include <stdlib.h>
+#include <stdio.h>
+#include <libcpu/access.h>
+#include <drvmgr/drvmgr.h>
+#include <drvmgr/ambapp_bus.h>
+#include <drvmgr/leon2_amba_bus.h>
+#define DBG(args...)
+int ambapp_leon2_int_register(
+	struct drvmgr_dev *dev,
+	int index,
+	const char *info,
+	drvmgr_isr isr,
+	void *arg);
+int ambapp_leon2_int_unregister(
+	int index,
+	drvmgr_isr isr,
+	void *arg);
+int ambapp_leon2_int_clear(
+	int index);
+int ambapp_leon2_int_mask(
+	int irq);
+int ambapp_leon2_int_unmask(
+	int irq);
+int ambapp_leon2_get_params(
+	struct drvmgr_bus_params *params);
+int ambapp_leon2_init1(struct drvmgr_dev *dev);
+int ambapp_leon2_init2(struct drvmgr_dev *dev);
+int ambapp_leon2_remove(struct drvmgr_dev *dev);
+void ambapp_leon2_register(void);
+/* READ/WRITE access to SpaceWire target over RMAP */
+void *ambapp_leon2_rw_arg(struct drvmgr_dev *dev);
+struct ambappl2_priv {
+	struct ambapp_bus abus;
+	struct ambapp_config config;
+struct ambapp_ops ambapp_leon2_ops = {
+	.int_register = ambapp_leon2_int_register,
+	.int_unregister = ambapp_leon2_int_unregister,
+	.int_clear = ambapp_leon2_int_clear,
+	.int_mask = ambapp_leon2_int_mask,
+	.int_unmask = ambapp_leon2_int_unmask,
+	.get_params = ambapp_leon2_get_params
+struct drvmgr_func ambapp_leon2_funcs[] = {
+	DRVMGR_FUNC(AMBAPP_RW_ARG, ambapp_leon2_rw_arg),
+	DRVMGR_FUNC(AMBAPP_R8,  _ld8),
+	DRVMGR_FUNC(AMBAPP_R16, _ld16),
+	DRVMGR_FUNC(AMBAPP_R32, _ld32),
+	DRVMGR_FUNC(AMBAPP_R64, _ld64),
+	DRVMGR_FUNC(AMBAPP_W8,  _st8),
+	DRVMGR_FUNC(AMBAPP_W16, _st16),
+	DRVMGR_FUNC(AMBAPP_W32, _st32),
+	DRVMGR_FUNC(AMBAPP_W64, _st64),
+	DRVMGR_FUNC(AMBAPP_RMEM, memcpy),
+	DRVMGR_FUNC(AMBAPP_WMEM, memcpy),
+	DRVMGR_FUNC_END
+struct drvmgr_drv_ops ambapp_ops = {
+	.init = {ambapp_leon2_init1, ambapp_leon2_init2, NULL, NULL},
+	.remove = ambapp_leon2_remove,
+	.info = NULL,
+struct leon2_amba_dev_id ambapp_leon2_ids[] = {
+	{LEON2_AMBA_AMBAPP_ID},
+	{0}
+struct leon2_amba_drv_info ambapp_bus_drv_leon2 = {
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_LEON2_AMBA_AMBAPP,	/* Driver ID */
+		"AMBAPP_LEON2_DRV",		/* Driver Name */
+		DRVMGR_BUS_TYPE_LEON2_AMBA,	/* Bus Type */
+		&ambapp_ops,
+		NULL,				/* Funcs */
+		0,
+		sizeof(struct ambappl2_priv),	/* Let DrvMgr allocate priv */
+	&ambapp_leon2_ids[0]
+	drvmgr_drv_register(&ambapp_bus_drv_leon2.general);
+/* Function called from a hard configuration */
+	union drvmgr_key_value *value;
+	struct ambappl2_priv *priv = dev->priv;
+	struct leon2_amba_dev_info *devinfo;
+	struct ambapp_config *config;
+	unsigned int ioarea;
+	unsigned int freq_hz;
+	LEON_Register_Map *regs;
+	dev->name = "LEON2 AMBA PnP";
+	if (!priv)
+		return DRVMGR_NOMEM;
+	config = &priv->config;
+	config->abus = &priv->abus;
+	config->ops = &ambapp_leon2_ops;
+	config->maps_up = DRVMGR_TRANSLATE_ONE2ONE;
+	config->maps_down = DRVMGR_TRANSLATE_ONE2ONE;
+	config->funcs = ambapp_leon2_funcs;
+	config->bus_type = DRVMGR_BUS_TYPE_LEON2_AMBA;
+	/* Get AMBA PnP Area from REG0 */
+	devinfo = (struct leon2_amba_dev_info *)dev->businfo;
+	ioarea = devinfo->reg_base;
+	/* Scan AMBA PnP Bus. ABUS has already been cleared with memset() */
+	ambapp_scan(&priv->abus, ioarea, NULL, NULL);
+	/* Try to get Configuration from resource configuration */
+	value = drvmgr_dev_key_get(dev, "busFreq", KEY_TYPE_INT);
+	if (value) {
+		/* Set frequency of AMBA bus if specified by user. The frequency
+		 * must be for AHB bus which IOAREA matches (AHB bus 0).
+		freq_hz = value->i;
+	} else {
+		/* Get Bus/LEON2 Frequency from timer prescaler,
+		 * the hardcoded address is used to get to timer
+		regs = (LEON_Register_Map *) 0x80000000;
+		freq_hz = (regs->Scaler_Reload + 1) * 1000 * 1000;
+	/* Note that this can be overrided by a driver on the AMBA PnP bus.*/
+	ambapp_freq_init(&priv->abus, NULL, freq_hz);
+	value = drvmgr_dev_key_get(dev, "drvRes", KEY_TYPE_POINTER);
+	if (!value) {
+		DBG("ambapp_leon2_init1: Failed getting resource drvRes\n");
+		config->resources = NULL;
+	} else {
+		DBG("ambapp_leon2_init1: drvRes: 0x%08x\n", (unsigned int)value->ptr);
+		config->resources = (struct drvmgr_bus_res *)value->ptr;
+	/* Initialize the AMBA Bus */
+	return ambapp_bus_register(dev, config);
+	return 0;
+	return 0;
+	return dev; /* No argument really needed, by for debug */
+	int index,
+	const char *info,
+	drvmgr_isr isr,
+	void *arg
+	/* Let LEON2 bus handle interrupt requests */
+	return drvmgr_interrupt_register(dev->parent->dev, index, info, isr, arg);
+	int index,
+	drvmgr_isr isr,
+	void *arg
+	return drvmgr_interrupt_unregister(dev->parent->dev, index, isr, arg);
+	int index
+	return drvmgr_interrupt_clear(dev->parent->dev, index);
+	int index
+	return drvmgr_interrupt_mask(dev->parent->dev, index);
+	int index
+	return drvmgr_interrupt_unmask(dev->parent->dev, index);
+int ambapp_leon2_get_params(struct drvmgr_dev *dev, struct drvmgr_bus_params *params)
+	params->dev_prefix = "";
+	return 0;
+#endif
1.7.0.4
