[PATCH 031/111] leon,gpiolib: add mask/unmask interrupt support
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:33 UTC 2015
c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c | 11 +++++++++++
c/src/lib/libbsp/sparc/shared/gpio/grgpio.c | 12 ++++++++++++
c/src/lib/libbsp/sparc/shared/include/gpiolib.h | 4 ++++
3 files changed, 27 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c b/c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c
index 22f1baa..4eca013 100644
--- a/c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c
+++ b/c/src/lib/libbsp/sparc/shared/gpio/gpiolib.c
@@ -251,6 +251,17 @@ int gpiolib_irq_disable(void *handle)
return gpiolib_irq_opts(handle, GPIOLIB_IRQ_DISABLE);
+int gpiolib_irq_mask(void *handle)
+ return gpiolib_irq_opts(handle, GPIOLIB_IRQ_MASK);
+int gpiolib_irq_unmask(void *handle)
+ return gpiolib_irq_opts(handle, GPIOLIB_IRQ_UNMASK);
/*** Initialization ***/
int gpiolib_initialize(void)
diff --git a/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c b/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
index 92e9657..eab8ef9 100644
--- a/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
+++ b/c/src/lib/libbsp/sparc/shared/gpio/grgpio.c
@@ -262,6 +262,18 @@ int grgpio_grpiolib_irq_opts(void *handle, unsigned int options)
return -1;
+ if ( options & GPIOLIB_IRQ_MASK ) {
+ /* Mask (disable) interrupt at interrupt controller */
+ if ( drvmgr_interrupt_mask(priv->dev, portnr) ) {
+ return -1;
+ if ( options & GPIOLIB_IRQ_UNMASK ) {
+ /* Unmask (enable) interrupt at interrupt controller */
+ if ( drvmgr_interrupt_unmask(priv->dev, portnr) ) {
+ return -1;
return 0;
diff --git a/c/src/lib/libbsp/sparc/shared/include/gpiolib.h b/c/src/lib/libbsp/sparc/shared/include/gpiolib.h
index 466a131..c8bfe0f 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gpiolib.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gpiolib.h
@@ -51,6 +51,8 @@ extern int gpiolib_get(void *handle, int *inval);
extern int gpiolib_irq_clear(void *handle);
extern int gpiolib_irq_enable(void *handle);
extern int gpiolib_irq_disable(void *handle);
+extern int gpiolib_irq_mask(void *handle);
+extern int gpiolib_irq_unmask(void *handle);
extern int gpiolib_irq_force(void *handle);
extern int gpiolib_irq_register(void *handle, void *func, void *arg);
@@ -75,6 +77,8 @@ struct gpiolib_drv_ops {
#define GPIOLIB_IRQ_DISABLE 0x02
#define GPIOLIB_IRQ_CLEAR 0x04
#define GPIOLIB_IRQ_FORCE 0x08
+#define GPIOLIB_IRQ_MASK 0x10
+#define GPIOLIB_IRQ_UNMASK 0x20
struct gpiolib_drv {
struct gpiolib_drv_ops *ops;
1.7.0.4
