[PATCH 030/111] GRSPW: Make sure buffers are 64-bit aligned
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:32 UTC 2015
This is to improve odds of getting a fast memcpy-operation.
c/src/lib/libbsp/sparc/shared/spw/grspw.c | 11 +++++++----
1 files changed, 7 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
index 83f3b97..b6ee255 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
@@ -112,6 +112,7 @@ typedef struct {
/* statistics */
spw_stats stat;
+ unsigned int _ptr_rxbuf0;
char *ptr_rxbuf0;
char *ptr_txdbuf0;
char *ptr_txhbuf0;
@@ -522,6 +523,7 @@ int grspw_device_init(GRSPW_DEV *pDev)
pDev->txbufcnt = SPACEWIRE_TXBUFS_NR;
pDev->rxbufcnt = SPACEWIRE_RXBUFS_NR;
+ pDev->_ptr_rxbuf0 = 0;
pDev->ptr_rxbuf0 = 0;
pDev->ptr_txdbuf0 = 0;
pDev->ptr_txhbuf0 = 0;
@@ -617,10 +619,11 @@ static int grspw_buffer_alloc(GRSPW_DEV *pDev)
pDev->ptr_rxbuf0 = pDev->rx_dma_area;
} else {
- if (pDev->ptr_rxbuf0) {
- free(pDev->ptr_rxbuf0);
+ if (pDev->_ptr_rxbuf0) {
+ free(pDev->_ptr_rxbuf0);
- pDev->ptr_rxbuf0 = (char *) malloc(pDev->rxbufsize * pDev->rxbufcnt);
+ pDev->_ptr_rxbuf0 = (unsigned int) malloc(pDev->rxbufsize * pDev->rxbufcnt+4);
+ pDev->ptr_rxbuf0 = (char *)((pDev->_ptr_rxbuf0+7)&~7);
if ( !pDev->ptr_rxbuf0 )
return 1;
@@ -1242,7 +1245,7 @@ static rtems_device_driver grspw_control(
/* Save new buffer sizes */
- pDev->rxbufsize = ps->rxsize;
+ pDev->rxbufsize = ((ps->rxsize+7)&~7);
pDev->txdbufsize = ps->txdsize;
pDev->txhbufsize = ps->txhsize;
pDev->config.rxmaxlen = pDev->rxbufsize;
1.7.0.4
