[PATCH 028/111] GRSPW: New packet based driver for SPW/SPW2/SPW2_DMA
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:30 UTC 2015
This patch adds a new driver for the GRSPW SpaceWire AMBA
interface family. The new driver does not implement a standard
RTEMS driver, instead it provides only a library interface to
the GRSPW devices. This driver can be used to implement a
RTEMS I/O driver or used directly.
New features compared with old GRSPW driver:
 * zero-copy packet interface
 * possibility to send/receive mulitple packets per call
 * optional interrupt awaken work-task to process TX/RX queues
 * DMA channels support. Before only first DMA channel supported
 * Separate DMA and link control
 * Packet based error flags
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |    2 +
 c/src/lib/libbsp/sparc/leon3/preinstall.am         |    4 +
 .../sparc/shared/include/drvmgr/ambapp_bus.h       |    1 +
 c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h  |  598 +++++
 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c      | 2642 ++++++++++++++++++++
 cpukit/libdrvmgr/drvmgr_confdefs.h                 |    6 +
 6 files changed, 3253 insertions(+), 0 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
 create mode 100644 c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 4517ee3..d50b210 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -151,8 +151,10 @@ libbsp_a_SOURCES += ../../sparc/shared/can/occan.c \
 # SpaceWire
 include_HEADERS += ../../sparc/shared/include/grspw.h
+include_HEADERS += ../../sparc/shared/include/grspw_pkt.h
 include_HEADERS += ../../sparc/shared/include/grspw_router.h
 libbsp_a_SOURCES += ../../sparc/shared/spw/grspw.c
+libbsp_a_SOURCES += ../../sparc/shared/spw/grspw_pkt.c
 libbsp_a_SOURCES += ../../sparc/shared/spw/grspw_router.c
 # UART
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 29fd095..e157862 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -197,6 +197,10 @@ $(PROJECT_INCLUDE)/grspw.h: ../../sparc/shared/include/grspw.h $(PROJECT_INCLUDE
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw.h
+$(PROJECT_INCLUDE)/grspw_pkt.h: ../../sparc/shared/include/grspw_pkt.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw_pkt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw_pkt.h
 $(PROJECT_INCLUDE)/grspw_router.h: ../../sparc/shared/include/grspw_router.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/grspw_router.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/grspw_router.h
diff --git a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
index 687bafd..e419862 100644
--- a/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
+++ b/c/src/lib/libbsp/sparc/shared/include/drvmgr/ambapp_bus.h
@@ -45,6 +45,7 @@ extern "C" {
 #define DRIVER_AMBAPP_GAISLER_GRPWM_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRPWM)
 #define DRIVER_AMBAPP_GAISLER_GRPWRX_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PW2APB)
 #define DRIVER_AMBAPP_GAISLER_GRSPW_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW)
+#define DRIVER_AMBAPP_GAISLER_GRSPW2_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW2)
 #define DRIVER_AMBAPP_GAISLER_GRTC_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTC)
 #define DRIVER_AMBAPP_GAISLER_GRTM_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTM)
 #define DRIVER_AMBAPP_GAISLER_I2CMST_ID		DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_I2CMST)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
new file mode 100644
index 0000000..943dbe0
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_pkt.h
@@ -0,0 +1,598 @@
+ *  GRSPW/GRSPW2 SpaceWire Kernel Library Interface
+ *  COPYRIGHT (c) 2011
+ *  Cobham Gaisler AB
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef __GRSPW_PKT_H__
+#define __GRSPW_PKT_H__
+struct grspw_pkt;
+/* Maximum number of GRSPW devices supported by driver */
+#define GRSPW_MAX 32
+/* Weak overridable variable the user can use to define the worker-task
+ * priority (0..255) or to disable (-1) the creation of the worker-task
+ * and the message queue to save space */
+extern int grspw_work_task_priority;
+#ifndef GRSPW_PKT_FLAGS
+#define GRSPW_PKT_FLAGS
+/*** TX Packet flags ***/
+/* Enable IRQ generation */
+#define TXPKT_FLAG_IE 0x0040
+/* Enable Header CRC generation (if CRC is available in HW)
+ * Header CRC will be appended (one byte at end of header)
+#define TXPKT_FLAG_HCRC 0x0100
+/* Enable Data CRC generation (if CRC is available in HW)
+ * Data CRC will be appended (one byte at end of packet)
+#define TXPKT_FLAG_DCRC 0x0200
+/* Control how many bytes the beginning of the Header
+ * the CRC should not be calculated for */
+#define TXPKT_FLAG_NOCRC_MASK 0x0000000f
+#define TXPKT_FLAG_NOCRC_LEN0 0x00000000
+#define TXPKT_FLAG_NOCRC_LEN1 0x00000001
+#define TXPKT_FLAG_NOCRC_LEN2 0x00000002
+#define TXPKT_FLAG_NOCRC_LEN3 0x00000003
+#define TXPKT_FLAG_NOCRC_LEN4 0x00000004
+#define TXPKT_FLAG_NOCRC_LEN5 0x00000005
+#define TXPKT_FLAG_NOCRC_LEN6 0x00000006
+#define TXPKT_FLAG_NOCRC_LEN7 0x00000007
+#define TXPKT_FLAG_NOCRC_LEN8 0x00000008
+#define TXPKT_FLAG_NOCRC_LEN9 0x00000009
+#define TXPKT_FLAG_NOCRC_LENa 0x0000000a
+#define TXPKT_FLAG_NOCRC_LENb 0x0000000b
+#define TXPKT_FLAG_NOCRC_LENc 0x0000000c
+#define TXPKT_FLAG_NOCRC_LENd 0x0000000d
+#define TXPKT_FLAG_NOCRC_LENe 0x0000000e
+#define TXPKT_FLAG_NOCRC_LENf 0x0000000f
+/* Marks if packet was transmitted or not */
+#define TXPKT_FLAG_TX 0x8000
+#define TXPKT_FLAG_INPUT_MASK (TXPKT_FLAG_NOCRC_MASK | TXPKT_FLAG_IE | \
+				TXPKT_FLAG_HCRC | TXPKT_FLAG_DCRC)
+/* Link Error */
+#define TXPKT_FLAG_LINKERR 0x4000
+#define TXPKT_FLAG_OUTPUT_MASK (TXPKT_FLAG_LINKERR)
+/*** RX Packet Flags ***/
+#define RXPKT_FLAG_IE 0x0010
+#define RXPKT_FLAG_INPUT_MASK (RXPKT_FLAG_IE)
+/* Packet was truncated */
+#define RXPKT_FLAG_TRUNK 0x0800
+/* Data CRC error (only valid if RMAP CRC is enabled) */
+#define RXPKT_FLAG_DCRC 0x0400
+/* Header CRC error (only valid if RMAP CRC is enabled) */
+#define RXPKT_FLAG_HCRC 0x0200
+/* Error in End-of-Packet */
+#define RXPKT_FLAG_EEOP 0x0100
+/* Marks if packet was recevied or not */
+#define RXPKT_FLAG_RX 0x8000
+#define RXPKT_FLAG_OUTPUT_MASK (RXPKT_FLAG_TRUNK | RXPKT_FLAG_DCRC | \
+				RXPKT_FLAG_HCRC | RXPKT_FLAG_EEOP)
+/*** General packet flag options ***/
+/* Translate Hdr and/or Payload address */
+#define PKT_FLAG_TR_DATA 0x1000
+#define PKT_FLAG_TR_HDR 0x2000
+/* All General options */
+#define PKT_FLAG_MASK 0x3000
+#endif
+/* GRSPW RX/TX Packet structure.
+ * - For RX the 'hdr' and 'hlen' fields are not used, they are not written
+ *   by driver.
+ * - The 'pkt_id' field is untouched by driver, it is intended for packet
+ *   numbering or user-custom data.
+ * - The last packet in a list must have 'next' set to NULL.
+ * - data and hdr pointers are written without modification to hardware,
+ *   this means that caller must do address translation to hardware
+ *   address itself.
+ * - the 'flags' field are interpreted differently depending on transfer
+ *   type (RX/TX). See XXPKT_FLAG_* options above.
+struct grspw_pkt {
+	struct grspw_pkt *next;
+	unsigned int pkt_id;	/* User assigned ID */
+	unsigned short flags;	/* RX/TX Options */
+	unsigned char reserved;	/* Reserved, must be zero */
+	unsigned char hlen;	/* Length of Header Buffer */
+	unsigned int dlen;	/* Length of Data Buffer */
+	void *data;	/* 4-byte or byte aligned depends on HW */
+	void *hdr;	/* 4-byte or byte aligned depends on HW */
+/* GRSPW SpaceWire Packet List */
+struct grspw_list {
+	struct grspw_pkt *head;
+	struct grspw_pkt *tail;
+/* SpaceWire Link State */
+typedef enum {
+	SPW_LS_ERRRST = 0,
+	SPW_LS_ERRWAIT = 1,
+	SPW_LS_READY = 2,
+	SPW_LS_CONNECTING = 3,
+	SPW_LS_STARTED = 4,
+	SPW_LS_RUN = 5
+} spw_link_state_t;
+/* Address Configuration */
+struct grspw_addr_config {
+	/* Ignore address field and put all received packets to first
+	 * DMA channel.
+	int promiscuous;
+	/* Default Node Address and Mask */
+	unsigned char def_addr;
+	unsigned char def_mask;
+	/* DMA Channel custom Node Address and Mask */
+	struct {
+		char node_en;			/* Enable Separate Addr */
+		unsigned char node_addr;	/* Node address */
+		unsigned char node_mask;	/* Node address mask */
+	} dma_nacfg[4];
+/* Hardware Support in GRSPW Core */
+struct grspw_hw_sup {
+	char	rmap;		/* If RMAP in HW is available */
+	char	rmap_crc;	/* If RMAP CRC is available */
+	char	rx_unalign;	/* RX unaligned (byte boundary) access allowed*/
+	char	nports;		/* Number of Ports (1 or 2) */
+	char	ndma_chans;	/* Number of DMA Channels (1..4) */
+	char	strip_adr;	/* Hardware can strip ADR from packet data */
+	char	strip_pid;	/* Hardware can strip PID from packet data */
+	int	hw_version;	/* GRSPW Hardware Version */
+	char	reserved[2];
+struct grspw_core_stats {
+	int irq_cnt;
+	int err_credit;
+	int err_eeop;
+	int err_addr;
+	int err_parity;
+	int err_escape;
+	int err_wsync; /* only in GRSPW1 */
+/* grspw_link_ctrl() options */
+#define LINKOPTS_ENABLE		0x0000
+#define LINKOPTS_DISABLE	0x0001
+#define LINKOPTS_START		0x0002
+#define LINKOPTS_AUTOSTART	0x0004
+#define LINKOPTS_DIS_ONERR	0x0008
+/*#define LINKOPTS_TICK_OUT_IRQ	0x0100*//* Enable Tick-out IRQ */
+#define LINKOPTS_IRQ		0x0200	/* Enable Error Link IRQ */
+#define LINKOPTS_MASK		0x020f	/* All above options */
+/* grspw_tc_ctrl() options */
+#define TCOPTS_EN_RXIRQ	0x0001	/* Tick-Out IRQ */
+#define TCOPTS_EN_TX	0x0004
+#define TCOPTS_EN_RX	0x0008
+/* grspw_rmap_ctrl() options */
+#define RMAPOPTS_EN_RMAP	0x0001
+#define RMAPOPTS_EN_BUF		0x0002
+/* grspw_dma_config.flags options */
+#define DMAFLAG_NO_SPILL	0x0001	/* See HW doc DMA-CTRL NS bit */
+#define DMAFLAG_RESV1		0x0002	/* HAS NO EFFECT */
+#define DMAFLAG_STRIP_ADR	0x0004	/* See HW doc DMA-CTRL SA bit */
+#define DMAFLAG_STRIP_PID	0x0008	/* See HW doc DMA-CTRL SP bit */
+#define DMAFLAG_RESV2		0x0010	/* HAS NO EFFECT */
+#define DMAFLAG_MASK	(DMAFLAG_NO_SPILL|DMAFLAG_STRIP_ADR|DMAFLAG_STRIP_PID)
+struct grspw_dma_config {
+	int flags;
+	int rxmaxlen;		/* RX Max Packet Length */
+	int rx_irq_en_cnt;	/* Enable RX IRQ every cnt descriptors */
+	int tx_irq_en_cnt;	/* Enable TX IRQ every cnt descriptors */
+/* Statistics per DMA channel */
+struct grspw_dma_stats {
+	/* IRQ Statistics */
+	int irq_cnt;		/* Number of DMA IRQs generated by channel */
+	/* Descriptor Statistics */
+	int tx_pkts;		/* Number of Transmitted packets */
+	int tx_err_link;	/* Number of Transmitted packets with Link Error*/
+	int rx_pkts;		/* Number of Received packets */
+	int rx_err_trunk;	/* Number of Received Truncated packets */
+	int rx_err_endpkt;	/* Number of Received packets with bad ending */
+	/* Diagnostics to help developers sizing their number buffers to avoid
+	 * out-of-buffers or other phenomenons.
+	int send_cnt_min;	/* Minimum number of packets in TX SEND Q */
+	int send_cnt_max;	/* Maximum number of packets in TX SEND Q */
+	int tx_sched_cnt_min;	/* Minimum number of packets in TX SCHED Q */
+	int tx_sched_cnt_max;	/* Maximum number of packets in TX SCHED Q */
+	int sent_cnt_max;	/* Maximum number of packets in TX SENT Q */
+	int tx_work_cnt;	/* Times the work thread processed TX BDs */
+	int tx_work_enabled;	/* No. RX BDs enabled by work thread */
+	int ready_cnt_min;	/* Minimum number of packets in RX READY Q */
+	int ready_cnt_max;	/* Maximum number of packets in RX READY Q */
+	int rx_sched_cnt_min;	/* Minimum number of packets in RX SCHED Q */
+	int rx_sched_cnt_max;	/* Maximum number of packets in RX SCHED Q */
+	int recv_cnt_max;	/* Maximum number of packets in RX RECV Q */
+	int rx_work_cnt;	/* Times the work thread processed RX BDs */
+	int rx_work_enabled;	/* No. RX BDs enabled by work thread */
+extern void grspw_initialize_user(
+	/* Callback every time a GRSPW device is found. Args: DeviceIndex */
+	void *(*devfound)(int),
+	/* Callback every time a GRSPW device is removed. Args:
+	 * int   = DeviceIndex
+	 * void* = Return Value from devfound()
+	void (*devremove)(int,void*)
+extern int grspw_dev_count(void);
+extern void *grspw_open(int dev_no);
+extern void grspw_close(void *d);
+extern void grspw_hw_support(void *d, struct grspw_hw_sup *hw);
+extern void grspw_stats_read(void *d, struct grspw_core_stats *sts);
+extern void grspw_stats_clr(void *d);
+/* Set and Read current node address configuration. The dma_nacfg[N] field
+ * represents the configuration for DMA Channel N.
+ * Set cfg->promiscous to -1 in order to only read current configuration.
+extern void grspw_addr_ctrl(void *d, struct grspw_addr_config *cfg);
+/*** Link Control interface ***/
+/* Read Link State */
+extern spw_link_state_t grspw_link_state(void *d);
+/* options [in/out]: set to -1 to only read current config
+ * CLKDIV register contain:
+ *  bits 7..0  : Clock Div RUN (only run-state)
+ *  bits 15..8 : Clock Div During Startup (all link states except run-state)
+extern void grspw_link_ctrl(void *d, int *options, int *clkdiv);
+/* Read the current value of the status register */
+extern unsigned int grspw_status(void *d);
+/*** Time Code Interface ***/
+/* Generate Tick-In (increment Time Counter, Send Time Code) */
+extern void grspw_tc_tx(void *d);
+/* Control Timcode settings of core */
+extern void grspw_tc_ctrl(void *d, int *options);
+/* Assign ISR Function to TimeCode RX IRQ */
+extern void grspw_tc_isr(void *d, void (*tcisr)(void *data, int tc), void *data);
+/* Read/Write TCTRL and TIMECNT. Write if not -1, always read current value
+ * TCTRL   = bits 7 and 6
+ * TIMECNT = bits 5 to 0
+extern void grspw_tc_time(void *d, int *time);
+/*** RMAP Control Interface ***/
+/* Set (not -1) and/or read RMAP options. */
+extern int grspw_rmap_ctrl(void *d, int *options, int *dstkey);
+extern void grspw_rmap_support(void *d, char *rmap, char *rmap_crc);
+/*** SpW Port Control Interface ***/
+/* Select port, if
+ * -1=The current selected port is returned
+ * 0=Port 0
+ * 1=Port 1
+ * Other positive values=Both Port0 and Port1
+extern int grspw_port_ctrl(void *d, int *port);
+/* Returns Number ports available in hardware */
+extern int grspw_port_count(void *d);
+/* Returns the current active port */
+extern int grspw_port_active(void *d);
+/*** DMA Interface ***/
+extern void *grspw_dma_open(void *d, int chan_no);
+extern void grspw_dma_close(void *c);
+extern int grspw_dma_start(void *c);
+extern void grspw_dma_stop(void *c);
+/* Schedule List of packets for transmission at some point in
+ * future.
+ * 1. Move transmitted packets to SENT List (SCHED->SENT)
+ * 2. Add the requested packets to the SEND List (USER->SEND)
+ * 3. Schedule as many packets as possible for transmission (SEND->SCHED)
+ * Call this function with pkts=NULL to just do step 1 and 3. This may be
+ * required in Polling-mode.
+ * The above steps 1 and 3 may be skipped by setting 'opts':
+ *  bit0 = 1: Skip Step 1.
+ *  bit1 = 1: Skip Step 3.
+ * Skipping both step 1 and 3 may be usefull when IRQ is enabled, then
+ * the work queue will be totaly responsible for handling descriptors.
+ * The fastest solution in retreiving sent TX packets and sending new frames
+ * is to call:
+ *  A. grspw_dma_tx_reclaim(opts=0)
+ *  B. grspw_dma_tx_send(opts=1)
+ * NOTE: the TXPKT_FLAG_TX flag must not be set.
+ * Return Code
+ *  -1   Error
+ *  0    Successfully added pkts to send/sched list
+ *  1    DMA stopped. No operation.
+extern int grspw_dma_tx_send(void *c, int opts, struct grspw_list *pkts, int count);
+/* Reclaim TX packet buffers that has previously been scheduled for transmission
+ * with grspw_dma_tx_send().
+ * 2. Move all SENT List to pkts list (SENT->USER)
+ * The above steps 1 may be skipped by setting 'opts':
+ * is to call:
+ *  A. grspw_dma_tx_reclaim(opts=2) (Skip step 3)
+ *  B. grspw_dma_tx_send(opts=1) (Skip step 1)
+ * Return Code
+ *  -1   Error
+ *  0    Successful. pkts list filled with all packets from sent list
+ *  1    Same as 0, but indicates that DMA stopped
+extern int grspw_dma_tx_reclaim(void *c, int opts, struct grspw_list *pkts, int *count);
+/* Get current number of Packets in respective TX Queue. */
+extern void grspw_dma_tx_count(void *c, int *send, int *sched, int *sent);
+#define GRSPW_OP_AND 0
+#define GRSPW_OP_OR 1
+/* Block until ready_cnt or fewer packets are Queued in "Send and Scheduled" Q,
+ * op (AND or OR), sent_cnt or more packet "have been sent" (Sent Q) condition
+ * is met.
+ * If a link error occurs and the Stop on Link error is defined, this function
+ * will also return to caller.
+ * The timeout argument is used to return after timeout ticks, regardless of
+ * the other conditions. If timeout is zero, the function will wait forever
+ * until the condition is satisfied.
+ * NOTE: if IRQ of TX descriptors are not enabled conditions are never
+ *       checked, this may hang infinitely unless a timeout has been specified
+ * Return Code
+ *  -1   Error
+ *  0    Returing to caller because specified conditions are now fullfilled
+ *  1    DMA stopped
+ *  2    Timeout, conditions are not met
+extern int grspw_dma_tx_wait(void *c, int send_cnt, int op, int sent_cnt, int timeout);
+/* Get received RX packet buffers that has previously been scheduled for
+ * reception with grspw_dma_rx_prepare().
+ * 1. Move Scheduled packets to RECV List (SCHED->RECV)
+ * 2. Move all RECV packet to the callers list (RECV->USER)
+ * 3. Schedule as many free packet buffers as possible (READY->SCHED)
+ * The fastest solution in retreiving received RX packets and preparing new
+ * packet buffers for future receive, is to call:
+ *  A. grspw_dma_rx_recv(opts=2, &recvlist) (Skip step 3)
+ *  B. grspw_dma_rx_prepare(opts=1, &freelist) (Skip step 1)
+ * Return Code
+ *  -1   Error
+ *  0    Successfully filled pkts list with packets from recv list.
+ *  1    DMA stopped
+extern int grspw_dma_rx_recv(void *c, int opts, struct grspw_list *pkts, int *count);
+/* Add more RX packet buffers for future for reception. The received packets
+ * can later be read out with grspw_dma_rx_recv().
+ * 1. Move Received packets to RECV List (SCHED->RECV)
+ * 2. Add the "free/ready" packet buffers to the READY List (USER->READY)
+ * 3. Schedule as many packets as possible (READY->SCHED)
+ * Return Code
+ *  -1   Error
+ *  0    Successfully added packet buffers from pkt list into the ready queue
+ *  1    DMA stopped
+extern int grspw_dma_rx_prepare(void *c, int opts, struct grspw_list *pkts, int count);
+/* Get current number of Packets in respective RX Queue. */
+extern void grspw_dma_rx_count(void *c, int *ready, int *sched, int *recv);
+/* Block until recv_cnt or more packets are Queued in RECV Q, op (AND or OR),
+ * ready_cnt or fewer packet buffers are available in the "READY and Scheduled" Q,
+ * condition is met.
+ * will also return to caller, however with an error.
+ * Return Code
+ *  -1   Error
+ *  1    DMA stopped
+extern int grspw_dma_rx_wait(void *c, int recv_cnt, int op, int ready_cnt, int timeout);
+extern int grspw_dma_config(void *c, struct grspw_dma_config *cfg);
+extern void grspw_dma_config_read(void *c, struct grspw_dma_config *cfg);
+extern void grspw_dma_stats_read(void *c, struct grspw_dma_stats *sts);
+extern void grspw_dma_stats_clr(void *c);
+/*** GRSPW SpaceWire Packet List Handling Routines ***/
+static inline void grspw_list_clr(struct grspw_list *list)
+        list->head = NULL;
+        list->tail = NULL;
+static inline int grspw_list_is_empty(struct grspw_list *list)
+        return (list->head == NULL);
+/* Return Number of entries in list */
+static inline int grspw_list_cnt(struct grspw_list *list)
+	struct grspw_pkt *lastpkt = NULL, *pkt = list->head;
+	int cnt = 0;
+	while ( pkt ) {
+		cnt++;
+		lastpkt = pkt;
+		pkt = pkt->next;
+	if ( lastpkt && (list->tail != lastpkt) )
+		return -1;
+	return cnt;
+static inline void
+grspw_list_append(struct grspw_list *list, struct grspw_pkt *pkt)
+	pkt->next = NULL;
+	if ( list->tail == NULL ) {
+		list->head = pkt;
+	} else {
+		list->tail->next = pkt;
+	list->tail = pkt;
+static inline void
+grspw_list_prepend(struct grspw_list *list, struct grspw_pkt *pkt)
+	pkt->next = list->head;
+	if ( list->head == NULL ) {
+		list->tail = pkt;
+	list->head = pkt;
+static inline void
+grspw_list_append_list(struct grspw_list *list, struct grspw_list *alist)
+	alist->tail->next = NULL;
+		list->head = alist->head;
+	} else {
+		list->tail->next = alist->head;
+	list->tail = alist->tail;
+static inline void
+grspw_list_prepend_list(struct grspw_list *list, struct grspw_list *alist)
+	} else {
+		alist->tail->next = list->head;
+/* Remove dlist (delete-list) from head of list */
+static inline void
+grspw_list_remove_head_list(struct grspw_list *list, struct grspw_list *dlist)
+	list->head = dlist->tail->next;
+	dlist->tail->next = NULL;
+/* Take A number of entries from head of list 'list' and put the entires
+ * to rlist (result list).
+static inline int
+grspw_list_take_head_list(struct grspw_list *list, struct grspw_list *rlist, int max)
+	int cnt;
+	struct grspw_pkt *pkt, *last;
+	pkt = list->head;
+	if ( (max < 1) || (pkt == NULL) ) {
+		grspw_list_clr(rlist);
+		return 0;
+	cnt = 0;
+	rlist->head = pkt;
+	last = pkt;
+	while ((cnt < max) && pkt) {
+		last = pkt;
+		pkt = pkt->next;
+		cnt++;
+	rlist->tail = last;
+	grspw_list_remove_head_list(list, rlist);
+	return cnt;
+#endif
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
index 0000000..6b6820a
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_pkt.c
@@ -0,0 +1,2642 @@
+ * Cobham Gaisler GRSPW/GRSPW2 SpaceWire Kernel Library Interface for RTEMS.
+ * This driver can be used to implement a standard I/O system "char"-driver
+ * or used directly. NOTE SMP support has not been tested.
+#include <rtems.h>
+#include <bsp.h>
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <assert.h>
+#include <ctype.h>
+#include <malloc.h>
+#include <rtems/bspIo.h>
+#include <drvmgr/drvmgr.h>
+#include <ambapp.h>
+#include <drvmgr/ambapp_bus.h>
+#include <grspw_pkt.h>
+/* This driver has been prepared for SMP operation however never tested
+ * on a SMP system - use on your own risk.
+#ifdef RTEMS_HAS_SMP
+#include <rtems/score/smplock.h> /* spin-lock */
+/* SPIN_LOCK() and SPIN_UNLOCK() NOT_IMPLEMENTED_BY_RTEMS. Use _IRQ version
+ * to implement.
+#define SPIN_DECLARE(name) SMP_lock_spinlock_simple_Control name
+#define SPIN_INIT(lock) _SMP_lock_spinlock_simple_Initialize(lock)
+#define SPIN_LOCK(lock, level) SPIN_LOCK_IRQ(lock, level)
+#define SPIN_LOCK_IRQ(lock, level) (level) = _SMP_lock_spinlock_simple_Obtain(lock)
+#define SPIN_UNLOCK(lock, level) SPIN_UNLOCK_IRQ(lock, level)
+#define SPIN_UNLOCK_IRQ(lock, level) _SMP_lock_spinlock_simple_Release(lock, level)
+#define IRQFLAGS_TYPE ISR_Level
+#else
+#define SPIN_LOCK_IRQ(lock, level) rtems_interrupt_disable(level)
+#define SPIN_UNLOCK_IRQ(lock, level) rtems_interrupt_enable(level)
+#define IRQFLAGS_TYPE rtems_interrupt_level
+#endif
+/*#define STATIC*/
+#define STATIC static
+/*#define GRSPW_DBG(args...) printk(args)*/
+#define GRSPW_DBG(args...)
+struct grspw_dma_regs {
+	volatile unsigned int ctrl;	/* DMA Channel Control */
+	volatile unsigned int rxmax;	/* RX Max Packet Length */
+	volatile unsigned int txdesc;	/* TX Descriptor Base/Current */
+	volatile unsigned int rxdesc;	/* RX Descriptor Base/Current */
+	volatile unsigned int addr;	/* Address Register */
+	volatile unsigned int resv[3];
+struct grspw_regs {
+	volatile unsigned int status;
+	volatile unsigned int nodeaddr;
+	volatile unsigned int clkdiv;
+	volatile unsigned int destkey;
+	volatile unsigned int time;
+	volatile unsigned int timer;	/* Used only in GRSPW1 */
+	volatile unsigned int resv1;
+	/* DMA Registers, ctrl.NCH determines number of ports,
+	 * up to 4 channels are supported
+	struct grspw_dma_regs dma[4];
+/* GRSPW - Control Register - 0x00 */
+#define GRSPW_CTRL_RA_BIT	31
+#define GRSPW_CTRL_RX_BIT	30
+#define GRSPW_CTRL_RC_BIT	29
+#define GRSPW_CTRL_NCH_BIT	27
+#define GRSPW_CTRL_PO_BIT	26
+#define GRSPW_CTRL_PS_BIT	21
+#define GRSPW_CTRL_NP_BIT	20
+#define GRSPW_CTRL_RD_BIT	17
+#define GRSPW_CTRL_RE_BIT	16
+#define GRSPW_CTRL_TR_BIT	11
+#define GRSPW_CTRL_TT_BIT	10
+#define GRSPW_CTRL_LI_BIT	9
+#define GRSPW_CTRL_TQ_BIT	8
+#define GRSPW_CTRL_RS_BIT	6
+#define GRSPW_CTRL_PM_BIT	5
+#define GRSPW_CTRL_TI_BIT	4
+#define GRSPW_CTRL_IE_BIT	3
+#define GRSPW_CTRL_AS_BIT	2
+#define GRSPW_CTRL_LS_BIT	1
+#define GRSPW_CTRL_LD_BIT	0
+#define GRSPW_CTRL_RA	(1<<GRSPW_CTRL_RA_BIT)
+#define GRSPW_CTRL_RX	(1<<GRSPW_CTRL_RX_BIT)
+#define GRSPW_CTRL_RC	(1<<GRSPW_CTRL_RC_BIT)
+#define GRSPW_CTRL_NCH	(0x3<<GRSPW_CTRL_NCH_BIT)
+#define GRSPW_CTRL_PO	(1<<GRSPW_CTRL_PO_BIT)
+#define GRSPW_CTRL_PS	(1<<GRSPW_CTRL_PS_BIT)
+#define GRSPW_CTRL_NP	(1<<GRSPW_CTRL_NP_BIT)
+#define GRSPW_CTRL_RD	(1<<GRSPW_CTRL_RD_BIT)
+#define GRSPW_CTRL_RE	(1<<GRSPW_CTRL_RE_BIT)
+#define GRSPW_CTRL_TR	(1<<GRSPW_CTRL_TR_BIT)
+#define GRSPW_CTRL_TT	(1<<GRSPW_CTRL_TT_BIT)
+#define GRSPW_CTRL_LI	(1<<GRSPW_CTRL_LI_BIT)
+#define GRSPW_CTRL_TQ	(1<<GRSPW_CTRL_TQ_BIT)
+#define GRSPW_CTRL_RS	(1<<GRSPW_CTRL_RS_BIT)
+#define GRSPW_CTRL_PM	(1<<GRSPW_CTRL_PM_BIT)
+#define GRSPW_CTRL_TI	(1<<GRSPW_CTRL_TI_BIT)
+#define GRSPW_CTRL_IE	(1<<GRSPW_CTRL_IE_BIT)
+#define GRSPW_CTRL_AS	(1<<GRSPW_CTRL_AS_BIT)
+#define GRSPW_CTRL_LS	(1<<GRSPW_CTRL_LS_BIT)
+#define GRSPW_CTRL_LD	(1<<GRSPW_CTRL_LD_BIT)
+/* GRSPW - Status Register - 0x04 */
+#define GRSPW_STS_LS_BIT	21
+#define GRSPW_STS_AP_BIT	9
+#define GRSPW_STS_EE_BIT	8
+#define GRSPW_STS_IA_BIT	7
+#define GRSPW_STS_WE_BIT	6
+#define GRSPW_STS_PE_BIT	4
+#define GRSPW_STS_DE_BIT	3
+#define GRSPW_STS_ER_BIT	2
+#define GRSPW_STS_CE_BIT	1
+#define GRSPW_STS_TO_BIT	0
+#define GRSPW_STS_LS	(0x7<<GRSPW_STS_LS_BIT)
+#define GRSPW_STS_AP	(1<<GRSPW_STS_AP_BIT)
+#define GRSPW_STS_EE	(1<<GRSPW_STS_EE_BIT)
+#define GRSPW_STS_IA	(1<<GRSPW_STS_IA_BIT)
+#define GRSPW_STS_WE	(1<<GRSPW_STS_WE_BIT)
+#define GRSPW_STS_PE	(1<<GRSPW_STS_PE_BIT)
+#define GRSPW_STS_DE	(1<<GRSPW_STS_DE_BIT)
+#define GRSPW_STS_ER	(1<<GRSPW_STS_ER_BIT)
+#define GRSPW_STS_CE	(1<<GRSPW_STS_CE_BIT)
+#define GRSPW_STS_TO	(1<<GRSPW_STS_TO_BIT)
+/* GRSPW - Default Address Register - 0x08 */
+#define GRSPW_DEF_ADDR_BIT	0
+#define GRSPW_DEF_MASK_BIT	8
+#define GRSPW_DEF_ADDR	(0xff<<GRSPW_DEF_ADDR_BIT)
+#define GRSPW_DEF_MASK	(0xff<<GRSPW_DEF_MASK_BIT)
+/* GRSPW - Clock Divisor Register - 0x0C */
+#define GRSPW_CLKDIV_START_BIT	8
+#define GRSPW_CLKDIV_RUN_BIT	0
+#define GRSPW_CLKDIV_START	(0xff<<GRSPW_CLKDIV_START_BIT)
+#define GRSPW_CLKDIV_RUN	(0xff<<GRSPW_CLKDIV_RUN_BIT)
+#define GRSPW_CLKDIV_MASK	(GRSPW_CLKDIV_START|GRSPW_CLKDIV_RUN)
+/* GRSPW - Destination key Register - 0x10 */
+#define GRSPW_DK_DESTKEY_BIT	0
+#define GRSPW_DK_DESTKEY	(0xff<<GRSPW_DK_DESTKEY_BIT)
+/* GRSPW - Time Register - 0x14 */
+#define GRSPW_TIME_CTRL_BIT	0
+#define GRSPW_TIME_CNT_BIT	6
+#define GRSPW_TIME_CTRL		(0x3f<<GRSPW_TIME_CTRL_BIT)
+#define GRSPW_TIME_TCNT		(0x3<<GRSPW_TIME_CNT_BIT)
+/* GRSPW - DMA Control Register - 0x20*N */
+#define GRSPW_DMACTRL_LE_BIT	16
+#define GRSPW_DMACTRL_SP_BIT	15
+#define GRSPW_DMACTRL_SA_BIT	14
+#define GRSPW_DMACTRL_EN_BIT	13
+#define GRSPW_DMACTRL_NS_BIT	12
+#define GRSPW_DMACTRL_RD_BIT	11
+#define GRSPW_DMACTRL_RX_BIT	10
+#define GRSPW_DMACTRL_AT_BIT	9
+#define GRSPW_DMACTRL_RA_BIT	8
+#define GRSPW_DMACTRL_TA_BIT	7
+#define GRSPW_DMACTRL_PR_BIT	6
+#define GRSPW_DMACTRL_PS_BIT	5
+#define GRSPW_DMACTRL_AI_BIT	4
+#define GRSPW_DMACTRL_RI_BIT	3
+#define GRSPW_DMACTRL_TI_BIT	2
+#define GRSPW_DMACTRL_RE_BIT	1
+#define GRSPW_DMACTRL_TE_BIT	0
+#define GRSPW_DMACTRL_LE	(1<<GRSPW_DMACTRL_LE_BIT)
+#define GRSPW_DMACTRL_SP	(1<<GRSPW_DMACTRL_SP_BIT)
+#define GRSPW_DMACTRL_SA	(1<<GRSPW_DMACTRL_SA_BIT)
+#define GRSPW_DMACTRL_EN	(1<<GRSPW_DMACTRL_EN_BIT)
+#define GRSPW_DMACTRL_NS	(1<<GRSPW_DMACTRL_NS_BIT)
+#define GRSPW_DMACTRL_RD	(1<<GRSPW_DMACTRL_RD_BIT)
+#define GRSPW_DMACTRL_RX	(1<<GRSPW_DMACTRL_RX_BIT)
+#define GRSPW_DMACTRL_AT	(1<<GRSPW_DMACTRL_AT_BIT)
+#define GRSPW_DMACTRL_RA	(1<<GRSPW_DMACTRL_RA_BIT)
+#define GRSPW_DMACTRL_TA	(1<<GRSPW_DMACTRL_TA_BIT)
+#define GRSPW_DMACTRL_PR	(1<<GRSPW_DMACTRL_PR_BIT)
+#define GRSPW_DMACTRL_PS	(1<<GRSPW_DMACTRL_PS_BIT)
+#define GRSPW_DMACTRL_AI	(1<<GRSPW_DMACTRL_AI_BIT)
+#define GRSPW_DMACTRL_RI	(1<<GRSPW_DMACTRL_RI_BIT)
+#define GRSPW_DMACTRL_TI	(1<<GRSPW_DMACTRL_TI_BIT)
+#define GRSPW_DMACTRL_RE	(1<<GRSPW_DMACTRL_RE_BIT)
+#define GRSPW_DMACTRL_TE	(1<<GRSPW_DMACTRL_TE_BIT)
+/* GRSPW - DMA Channel Max Packet Length Register - (0x20*N + 0x04) */
+#define GRSPW_DMARXLEN_MAX_BIT	0
+#define GRSPW_DMARXLEN_MAX	(0xffffff<<GRSPW_DMARXLEN_MAX_BIT)
+/* GRSPW - DMA Channel Address Register - (0x20*N + 0x10) */
+#define GRSPW_DMAADR_ADDR_BIT	0
+#define GRSPW_DMAADR_MASK_BIT	8
+#define GRSPW_DMAADR_ADDR	(0xff<<GRSPW_DMAADR_ADDR_BIT)
+#define GRSPW_DMAADR_MASK	(0xff<<GRSPW_DMAADR_MASK_BIT)
+/* RX Buffer Descriptor */
+struct grspw_rxbd {
+/* TX Buffer Descriptor */
+struct grspw_txbd {
+   volatile unsigned int haddr;
+   volatile unsigned int dlen;
+   volatile unsigned int daddr;
+/* GRSPW - DMA RXBD Ctrl */
+#define GRSPW_RXBD_LEN_BIT 0
+#define GRSPW_RXBD_LEN	(0x1ffffff<<GRSPW_RXBD_LEN_BIT)
+#define GRSPW_RXBD_EN	(1<<25)
+#define GRSPW_RXBD_WR	(1<<26)
+#define GRSPW_RXBD_IE	(1<<27)
+#define GRSPW_RXBD_EP	(1<<28)
+#define GRSPW_RXBD_HC	(1<<29)
+#define GRSPW_RXBD_DC	(1<<30)
+#define GRSPW_RXBD_TR	(1<<31)
+#define GRSPW_TXBD_HLEN	(0xff<<0)
+#define GRSPW_TXBD_NCL	(0xf<<8)
+#define GRSPW_TXBD_EN	(1<<12)
+#define GRSPW_TXBD_WR	(1<<13)
+#define GRSPW_TXBD_IE	(1<<14)
+#define GRSPW_TXBD_LE	(1<<15)
+#define GRSPW_TXBD_HC	(1<<16)
+#define GRSPW_TXBD_DC	(1<<17)
+/* GRSPW Error Condition */
+#define GRSPW_STAT_ERROR	(GRSPW_STS_EE | GRSPW_STS_IA | GRSPW_STS_WE | GRSPW_STS_PE | GRSPW_STS_DE | GRSPW_STS_ER | GRSPW_STS_CE)
+#define GRSPW_DMA_STATUS_ERROR	(GRSPW_DMACTRL_RA | GRSPW_DMACTRL_TA)
+/* GRSPW Link configuration options */
+#define GRSPW_LINK_CFG		(GRSPW_CTRL_LI | GRSPW_CTRL_LD | GRSPW_CTRL_LS | GRSPW_CTRL_AS)
+#define GRSPW_LINKSTATE(status)	((status & GRSPW_CTRL_LS) >> GRSPW_CTRL_LS_BIT)
+/* Software Defaults */
+#define DEFAULT_RXMAX 1024	/* 1 KBytes Max RX Packet Size */
+/* GRSPW Constants */
+#define GRSPW_TXBD_NR 64	/* Maximum number of TX Descriptors */
+#define GRSPW_RXBD_NR 128	/* Maximum number of RX Descriptors */
+#define BDTAB_SIZE 0x400	/* BD Table Size (RX or TX) */
+#define BDTAB_ALIGN 0x400	/* BD Table Alignment Requirement */
+/* Memory and HW Registers Access routines. All 32-bit access routines */
+#define BD_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+/*#define BD_READ(addr) (*(volatile unsigned int *)(addr))*/
+#define BD_READ(addr) leon_r32_no_cache((unsigned long)(addr))
+#define REG_WRITE(addr, val) (*(volatile unsigned int *)(addr) = (unsigned int)(val))
+#define REG_READ(addr) (*(volatile unsigned int *)(addr))
+struct grspw_ring {
+	struct grspw_ring *next;	/* Next Descriptor */
+	union {
+		struct grspw_txbd *tx;	/* Descriptor Address */
+		struct grspw_rxbd *rx;	/* Descriptor Address */
+	} bd;
+	struct grspw_pkt *pkt;		/* Packet description associated.NULL if none*/
+/* An entry in the TX descriptor Ring */
+struct grspw_txring {
+	struct grspw_txring *next;	/* Next Descriptor */
+	struct grspw_txbd *bd;		/* Descriptor Address */
+/* An entry in the RX descriptor Ring */
+struct grspw_rxring {
+	struct grspw_rxring *next;	/* Next Descriptor */
+	struct grspw_rxbd *bd;		/* Descriptor Address */
+struct grspw_dma_priv {
+	struct grspw_priv *core;	/* GRSPW Core */
+	struct grspw_dma_regs *regs;	/* DMA Channel Registers */
+	int index;			/* DMA Channel Index @ GRSPW core */
+	int open;			/* DMA Channel opened by user */
+	int started;			/* DMA Channel activity (start|stop) */
+	rtems_id sem_dma;		/* DMA Channel Semaphore */
+	struct grspw_dma_stats stats;	/* DMA Channel Statistics */
+	struct grspw_dma_config cfg;	/* DMA Channel Configuration */
+	/*** RX ***/
+	/* RX Descriptor Ring */
+	struct grspw_rxbd *rx_bds;		/* Descriptor Address */
+	struct grspw_rxbd *rx_bds_hwa;		/* Descriptor HW Address */
+	struct grspw_rxring *rx_ring_base;
+	struct grspw_rxring *rx_ring_head;	/* Next descriptor to enable */
+	struct grspw_rxring *rx_ring_tail;	/* Oldest enabled Descriptor */
+	int rx_irq_en_cnt_curr;
+	struct {
+		int waiting;
+		int ready_cnt;
+		int op;
+		int recv_cnt;
+		rtems_id sem_wait;		/* RX Semaphore used to implement RX blocking */
+	} rx_wait;
+	/* Queue of Packets READY to be scheduled */
+	struct grspw_list ready;
+	int ready_cnt;
+	/* Scheduled RX Packets Queue */
+	struct grspw_list rx_sched;
+	int rx_sched_cnt;
+	/* Queue of Packets that has been RECIEVED */
+	struct grspw_list recv;
+	int recv_cnt;
+	/*** TX ***/
+	/* TX Descriptor Ring */
+	struct grspw_txbd *tx_bds;		/* Descriptor Address */
+	struct grspw_txbd *tx_bds_hwa;		/* Descriptor HW Address */
+	struct grspw_txring *tx_ring_base;
+	struct grspw_txring *tx_ring_head;
+	struct grspw_txring *tx_ring_tail;
+	int tx_irq_en_cnt_curr;
+	struct {
+		int waiting;
+		int send_cnt;
+		int op;
+		int sent_cnt;
+		rtems_id sem_wait;		/* TX Semaphore used to implement TX blocking */
+	} tx_wait;
+	/* Queue of Packets ready to be scheduled for transmission */
+	struct grspw_list send;
+	int send_cnt;
+	/* Scheduled TX Packets Queue */
+	struct grspw_list tx_sched;
+	int tx_sched_cnt;
+	/* Queue of Packets that has been SENT */
+	struct grspw_list sent;
+	int sent_cnt;
+struct grspw_priv {
+	char devname[8];		/* Device name "grspw%d" */
+	struct drvmgr_dev *dev;		/* Device */
+	struct grspw_regs *regs;	/* Virtual Address of APB Registers */
+	int irq;			/* AMBA IRQ number of core */
+	int index;			/* Index in order it was probed */
+	int core_index;			/* Core Bus Index */
+	int open;			/* If Device is alrady opened (=1) or not (=0) */
+	void *data;			/* User private Data for this device instance, set by grspw_initialize_user */
+	/* Features supported by Hardware */
+	struct grspw_hw_sup hwsup;
+	/* Pointer to an array of Maximally 4 DMA Channels */
+	struct grspw_dma_priv *dma;
+	/* Spin-lock ISR protection */
+	SPIN_DECLARE(devlock);
+	/* Descriptor Memory Area for TX & RX and all DMA channels */
+	unsigned int bd_mem;
+	unsigned int bd_mem_alloced;
+	/*** Time Code Handling ***/
+	void (*tcisr)(void *data, int timecode);
+	void *tcisr_arg;
+	/* Disable Link on SpW Link error */
+	int dis_link_on_err;
+	/* "Core Global" Statistics gathered, not dependent on DMA channel */
+	struct grspw_core_stats stats;
+int grspw_initialized = 0;
+int grspw_count = 0;
+struct workqueue_struct *grspw_workq = NULL;
+rtems_id grspw_sem;
+static struct grspw_priv *priv_tab[GRSPW_MAX];
+/* callback to upper layer when devices are discovered/removed */
+void *(*grspw_dev_add)(int) = NULL;
+void (*grspw_dev_del)(int,void*) = NULL;
+/* USER OVERRIDABLE - The work task priority. Set to -1 to disable creating
+ * the work-task and work-queue to save space.
+int grspw_work_task_priority __attribute__((weak)) = 100;
+int grspw_task_stop = 0;
+rtems_id grspw_work_task;
+rtems_id grspw_work_queue = 0;
+#define WORK_NONE         0
+#define WORK_SHUTDOWN     0x100
+#define WORK_DMA(channel) (0x1 << (channel))
+#define WORK_DMA_MASK     0xf /* max 4 channels */
+#define WORK_CORE_BIT     16
+#define WORK_CORE_MASK    0xffff
+#define WORK_CORE(device) ((device) << WORK_CORE_BIT)
+STATIC void grspw_hw_stop(struct grspw_priv *priv);
+STATIC void grspw_hw_dma_stop(struct grspw_dma_priv *dma);
+STATIC void grspw_dma_reset(struct grspw_dma_priv *dma);
+STATIC void grspw_dma_stop_locked(struct grspw_dma_priv *dma);
+STATIC void grspw_isr(void *data);
+void *grspw_open(int dev_no)
+	struct grspw_priv *priv;
+	unsigned int bdtabsize, hwa;
+	int i;
+	union drvmgr_key_value *value;
+	if (grspw_initialized != 1 || (dev_no >= grspw_count))
+		return NULL;
+	priv = priv_tab[dev_no];
+	/* Take GRSPW lock - Wait until we get semaphore */
+	if (rtems_semaphore_obtain(grspw_sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT)
+	    != RTEMS_SUCCESSFUL)
+		return NULL;
+	if (priv->open) {
+		priv = NULL;
+		goto out;
+	/* Initialize Spin-lock for GRSPW Device. This is to protect
+	 * CTRL and DMACTRL registers from ISR.
+	SPIN_INIT(&priv->devlock);
+	priv->tcisr = NULL;
+	priv->tcisr_arg = NULL;
+	grspw_stats_clr(priv);
+	/* Allocate TX & RX Descriptor memory area for all DMA
+	 * channels. Max-size descriptor area is allocated (or user assigned):
+	 *  - 128 RX descriptors per DMA Channel
+	 *  - 64 TX descriptors per DMA Channel
+	bdtabsize = 2 * BDTAB_SIZE * priv->hwsup.ndma_chans;
+	value = drvmgr_dev_key_get(priv->dev, "bdDmaArea", KEY_TYPE_INT);
+	if (value) {
+		priv->bd_mem = value->i;
+		priv->bd_mem_alloced = 0;
+		if (priv->bd_mem & (BDTAB_ALIGN-1)) {
+			GRSPW_DBG("GRSPW[%d]: user-def DMA-area not aligned",
+			          priv->index);
+			priv = NULL;
+			goto out;
+	} else {
+		priv->bd_mem_alloced = (unsigned int)malloc(bdtabsize + BDTAB_ALIGN - 1);
+		if (priv->bd_mem_alloced == 0) {
+			priv = NULL;
+			goto out;
+		/* Align memory */
+		priv->bd_mem = (priv->bd_mem_alloced + (BDTAB_ALIGN - 1)) &
+		               ~(BDTAB_ALIGN-1);
+	/* Translate into DMA address that HW can use to access DMA
+	 * descriptors
+	drvmgr_translate_check(
+		priv->dev,
+		CPUMEM_TO_DMA,
+		(void *)priv->bd_mem,
+		(void **)&hwa,
+		bdtabsize);
+	GRSPW_DBG("GRSPW%d DMA descriptor table setup: (alloced:%p, bd_mem:%p, size: %d)\n",
+		priv->index, priv->bd_mem_alloced, priv->bd_mem, bdtabsize + BDTAB_ALIGN - 1);
+	for (i=0; i<priv->hwsup.ndma_chans; i++) {
+		/* Do DMA Channel Init, other variables etc. are inited
+		 * when respective DMA channel is opened.
+		 * index & core are initialized by probe function.
+		priv->dma[i].open = 0;
+		priv->dma[i].rx_bds = (struct grspw_rxbd *)
+			(priv->bd_mem + i*BDTAB_SIZE*2);
+		priv->dma[i].rx_bds_hwa = (struct grspw_rxbd *)
+			(hwa + BDTAB_SIZE*(2*i));
+		priv->dma[i].tx_bds = (struct grspw_txbd *)
+			(priv->bd_mem + BDTAB_SIZE*(2*i+1));
+		priv->dma[i].tx_bds_hwa = (struct grspw_txbd *)
+			(hwa + BDTAB_SIZE*(2*i+1));
+		GRSPW_DBG("  DMA[%i]: RX %p - %p (%p - %p)   TX %p - %p (%p - %p)\n",
+			i,
+			priv->dma[i].rx_bds, (void *)priv->dma[i].rx_bds + BDTAB_SIZE - 1,
+			priv->dma[i].rx_bds_hwa, (void *)priv->dma[i].rx_bds_hwa + BDTAB_SIZE - 1,
+			priv->dma[i].tx_bds, (void *)priv->dma[i].tx_bds + BDTAB_SIZE - 1,
+			priv->dma[i].tx_bds_hwa, (void *)priv->dma[i].tx_bds_hwa + BDTAB_SIZE - 1);
+	/* Basic initialization of hardware, clear some registers but
+	 * keep Link/RMAP/Node-Address registers intact.
+	grspw_hw_stop(priv);
+	/* Register Interrupt handler and enable IRQ at IRQ ctrl */
+	drvmgr_interrupt_register(priv->dev, 0, priv->devname, grspw_isr, priv);
+	/* Take the device */
+	priv->open = 1;
+out:
+	rtems_semaphore_release(grspw_sem);
+	return priv;
+void grspw_close(void *d)
+	struct grspw_priv *priv = d;
+	int i;
+		return;
+	/* Stop Hardware from doing DMA, put HW into "startup-state",
+	 * Stop hardware from generating IRQ.
+		grspw_dma_close(&priv->dma[i]);
+	/* Mark not open */
+	priv->open = 0;
+	/* Check that all threads are out? */
+void grspw_hw_support(void *d, struct grspw_hw_sup *hw)
+	*hw = priv->hwsup;
+void grspw_addr_ctrl(void *d, struct grspw_addr_config *cfg)
+	struct grspw_regs *regs = priv->regs;
+	unsigned int ctrl, nodeaddr;
+	IRQFLAGS_TYPE irqflags;
+	int i;
+	if (!priv || !cfg)
+		return;
+	SPIN_LOCK_IRQ(&priv->devlock, irqflags);
+	if (cfg->promiscuous != -1) {
+		/* Set Configuration */
+		ctrl = REG_READ(&regs->ctrl);
+		if (cfg->promiscuous)
+			ctrl |= GRSPW_CTRL_PM;
+		else
+			ctrl &= ~GRSPW_CTRL_PM;
+		REG_WRITE(&regs->ctrl, ctrl);
+		REG_WRITE(&regs->nodeaddr, (cfg->def_mask<<8) | cfg->def_addr);
+			ctrl = REG_READ(&regs->dma[i].ctrl);
+			ctrl &= ~(GRSPW_DMACTRL_PS|GRSPW_DMACTRL_PR|GRSPW_DMA_STATUS_ERROR);
+			if (cfg->dma_nacfg[i].node_en) {
+				ctrl |= GRSPW_DMACTRL_EN;
+				REG_WRITE(&regs->dma[i].addr,
+				          (cfg->dma_nacfg[i].node_addr & 0xff) |
+				          ((cfg->dma_nacfg[i].node_mask & 0xff)<<8));
+			} else {
+				ctrl &= ~GRSPW_DMACTRL_EN;
+			REG_WRITE(&regs->dma[i].ctrl, ctrl);
+	/* Read Current Configuration */
+	cfg->promiscuous = REG_READ(&regs->ctrl) & GRSPW_CTRL_PM;
+	nodeaddr = REG_READ(&regs->nodeaddr);
+	cfg->def_addr = (nodeaddr & GRSPW_DEF_ADDR) >> GRSPW_DEF_ADDR_BIT;
+	cfg->def_mask = (nodeaddr & GRSPW_DEF_MASK) >> GRSPW_DEF_MASK_BIT;
+		cfg->dma_nacfg[i].node_en = REG_READ(&regs->dma[i].ctrl) &
+						GRSPW_DMACTRL_EN;
+		ctrl = REG_READ(&regs->dma[i].addr);
+		cfg->dma_nacfg[i].node_addr = (ctrl & GRSPW_DMAADR_ADDR) >>
+						GRSPW_DMAADR_ADDR_BIT;
+		cfg->dma_nacfg[i].node_mask = (ctrl & GRSPW_DMAADR_MASK) >>
+						GRSPW_DMAADR_MASK_BIT;
+	SPIN_UNLOCK_IRQ(&priv->devlock, irqflags);
+	for (; i<4; i++) {
+		cfg->dma_nacfg[i].node_en = 0;
+		cfg->dma_nacfg[i].node_addr = 0;
+		cfg->dma_nacfg[i].node_mask = 0;
+/* Return Current Status Register */
+unsigned int grspw_link_status(void *d)
+	return REG_READ(&priv->regs->status);
+/* Return Current Link State */
+spw_link_state_t grspw_link_state(void *d)
+	unsigned int status = REG_READ(&priv->regs->status);
+	return (status & GRSPW_STS_LS) >> GRSPW_STS_LS_BIT;
+/* options and clkdiv [in/out]: set to -1 to only read current config */
+void grspw_link_ctrl(void *d, int *options, int *clkdiv)
+	unsigned int ctrl;
+	/* Write? */
+	if (clkdiv) {
+		if (*clkdiv != -1)
+			REG_WRITE(&regs->clkdiv, *clkdiv & GRSPW_CLKDIV_MASK);
+		*clkdiv = REG_READ(&regs->clkdiv) & GRSPW_CLKDIV_MASK;
+	if (options) {
+		if (*options != -1) {
+			ctrl = (ctrl & ~GRSPW_LINK_CFG) |
+				(*options & GRSPW_LINK_CFG);
+			/* Enable Global IRQ only of LI or TQ is set */
+			if (ctrl & (GRSPW_CTRL_LI|GRSPW_CTRL_TQ))
+				ctrl |= GRSPW_CTRL_IE;
+			else
+				ctrl &= ~GRSPW_CTRL_IE;
+			priv->dis_link_on_err = (*options & LINKOPTS_DIS_ONERR) >> 3;
+		*options = (ctrl & GRSPW_LINK_CFG)|(priv->dis_link_on_err << 3);
+void grspw_tc_tx(void *d)
+	REG_WRITE(&regs->ctrl, REG_READ(&regs->ctrl) | GRSPW_CTRL_TI);
+void grspw_tc_ctrl(void *d, int *options)
+	if (options == NULL)
+		return;
+	/* Write? */
+		ctrl &= ~(GRSPW_CTRL_TR|GRSPW_CTRL_TT|GRSPW_CTRL_TQ);
+		ctrl |= (*options & 0xd) << GRSPW_CTRL_TQ_BIT;
+		else
+	} else
+	*options = (ctrl >> GRSPW_CTRL_TQ_BIT) & 0xd;
+void grspw_tc_isr(void *d, void (*tcisr)(void *data, int tc), void *data)
+	priv->tcisr_arg = data;
+	priv->tcisr = tcisr;
+void grspw_tc_time(void *d, int *time)
+	if (time == NULL)
+		return;
+	if (*time != -1)
+		REG_WRITE(&regs->time, *time & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL));
+	*time = REG_READ(&regs->time) & (GRSPW_TIME_TCNT | GRSPW_TIME_CTRL);
+int grspw_rmap_ctrl(void *d, int *options, int *dstkey)
+	if (dstkey) {
+		if (*dstkey != -1)
+			REG_WRITE(&regs->destkey, *dstkey & GRSPW_DK_DESTKEY);
+		*dstkey = REG_READ(&regs->destkey) & GRSPW_DK_DESTKEY;
+	if (options) {
+			if ((*options & RMAPOPTS_EN_RMAP) && !priv->hwsup.rmap)
+				return -1;
+			ctrl &= ~(GRSPW_CTRL_RE|GRSPW_CTRL_RD);
+			ctrl |= (*options & 0x3) << GRSPW_CTRL_RE_BIT;
+		*options = (REG_READ(&regs->ctrl) >> GRSPW_CTRL_RE_BIT) & 0x3;
+	return 0;
+void grspw_rmap_support(void *d, char *rmap, char *rmap_crc)
+	if (rmap)
+		*rmap = priv->hwsup.rmap;
+	if (rmap_crc)
+		*rmap_crc = priv->hwsup.rmap_crc;
+/* Select port, if
+ * 0=Port 0
+ * 1=Port 1
+ * Others=Both Port0 and Port1
+int grspw_port_ctrl(void *d, int *port)
+	if (port == NULL)
+		return -1;
+	if ((*port == 1) || (*port == 0)) {
+		/* Select port user selected */
+		if ((*port == 1) && (priv->hwsup.nports < 2))
+			return -1; /* Changing to Port 1, but only one port available */
+		ctrl &= ~(GRSPW_CTRL_NP | GRSPW_CTRL_PS);
+		ctrl |= (*port & 1) << GRSPW_CTRL_PS_BIT;
+	} else if (*port > 1) {
+		/* Select both ports */
+		REG_WRITE(&regs->ctrl, REG_READ(&regs->ctrl) | GRSPW_CTRL_NP);
+	/* Get current settings */
+	if (ctrl & GRSPW_CTRL_NP) {
+		/* Any port, selected by hardware */
+		if (priv->hwsup.nports > 1)
+			*port = 3;
+		else
+			*port = 0; /* Port0 the only port available */
+	} else {
+		*port = (ctrl & GRSPW_CTRL_PS) >> GRSPW_CTRL_PS_BIT;
+	return 0;
+int grspw_port_count(void *d)
+	return priv->hwsup.nports;
+/* Current active port: 0 or 1 */
+int grspw_port_active(void *d)
+	unsigned int status;
+	status = REG_READ(&priv->regs->status);
+	return (status & GRSPW_STS_AP) >> GRSPW_STS_AP_BIT;
+void grspw_stats_read(void *d, struct grspw_core_stats *sts)
+	if (sts == NULL)
+		return;
+	memcpy(sts, &priv->stats, sizeof(priv->stats));
+void grspw_stats_clr(void *d)
+	/* Clear most of the statistics */
+	memset(&priv->stats, 0, sizeof(priv->stats));
+/* Initialize the RX and TX Descriptor Ring, empty of packets */
+STATIC void grspw_bdrings_init(struct grspw_dma_priv *dma)
+	struct grspw_ring *r;
+	int i;
+	/* Empty BD rings */
+	dma->rx_ring_head = dma->rx_ring_base;
+	dma->rx_ring_tail = dma->rx_ring_base;
+	dma->tx_ring_head = dma->tx_ring_base;
+	dma->tx_ring_tail = dma->tx_ring_base;
+	/* Init RX Descriptors */
+	r = (struct grspw_ring *)dma->rx_ring_base;
+	for (i=0; i<GRSPW_RXBD_NR; i++) {
+		/* Init Ring Entry */
+		r[i].next = &r[i+1];
+		r[i].bd.rx = &dma->rx_bds[i];
+		r[i].pkt = NULL;
+		/* Init HW Descriptor */
+		BD_WRITE(&r[i].bd.rx->ctrl, 0);
+		BD_WRITE(&r[i].bd.rx->addr, 0);
+	r[GRSPW_RXBD_NR-1].next = &r[0];
+	/* Init TX Descriptors */
+	r = (struct grspw_ring *)dma->tx_ring_base;
+	for (i=0; i<GRSPW_TXBD_NR; i++) {
+		r[i].bd.tx = &dma->tx_bds[i];
+		r[i].pkt = NULL;
+		BD_WRITE(&r[i].bd.tx->ctrl, 0);
+		BD_WRITE(&r[i].bd.tx->haddr, 0);
+		BD_WRITE(&r[i].bd.tx->dlen, 0);
+		BD_WRITE(&r[i].bd.tx->daddr, 0);
+	r[GRSPW_TXBD_NR-1].next = &r[0];
+/* Try to populate descriptor ring with as many as possible READY unused packet
+ * buffers. The packets assigned with to a descriptor are put in the end of
+ * the scheduled list.
+ * The number of Packets scheduled is returned.
+ *  - READY List -> RX-SCHED List
+ *  - Descriptors are initialized and enabled for reception
+STATIC int grspw_rx_schedule_ready(struct grspw_dma_priv *dma)
+	int cnt;
+	unsigned int ctrl, dmactrl;
+	void *hwaddr;
+	struct grspw_rxring *curr_bd;
+	struct grspw_pkt *curr_pkt, *last_pkt;
+	struct grspw_list lst;
+	/* Is Ready Q empty? */
+	if (grspw_list_is_empty(&dma->ready))
+		return 0;
+	cnt = 0;
+	lst.head = curr_pkt = dma->ready.head;
+	curr_bd = dma->rx_ring_head;
+	while (!curr_bd->pkt) {
+		/* Assign Packet to descriptor */
+		curr_bd->pkt = curr_pkt;
+		/* Prepare descriptor address. */
+		hwaddr = curr_pkt->data;
+		if (curr_pkt->flags & PKT_FLAG_TR_DATA) {
+			drvmgr_translate(dma->core->dev, CPUMEM_TO_DMA,
+					 hwaddr, &hwaddr);
+			if (curr_pkt->data == hwaddr) /* translation needed? */
+				curr_pkt->flags &= ~PKT_FLAG_TR_DATA;
+		BD_WRITE(&curr_bd->bd->addr, hwaddr);
+		ctrl = GRSPW_RXBD_EN;
+		if (curr_bd->next == dma->rx_ring_base) {
+			/* Wrap around (only needed when smaller descriptor
+			 * table)
+			ctrl |= GRSPW_RXBD_WR;
+		/* Is this Packet going to be an interrupt Packet? */
+		if ((--dma->rx_irq_en_cnt_curr) <= 0) {
+			if (dma->cfg.rx_irq_en_cnt == 0) {
+				/* IRQ is disabled. A big number to avoid
+				 * equal to zero too often
+				dma->rx_irq_en_cnt_curr = 0x3fffffff;
+			} else {
+				dma->rx_irq_en_cnt_curr = dma->cfg.rx_irq_en_cnt;
+				ctrl |= GRSPW_RXBD_IE;
+		if (curr_pkt->flags & RXPKT_FLAG_IE)
+		/* Enable descriptor */
+		BD_WRITE(&curr_bd->bd->ctrl, ctrl);
+		last_pkt = curr_pkt;
+		curr_bd = curr_bd->next;
+		cnt++;
+		/* Get Next Packet from Ready Queue */
+		if (curr_pkt == dma->ready.tail) {
+			/* Handled all in ready queue. */
+			curr_pkt = NULL;
+			break;
+		curr_pkt = curr_pkt->next;
+	/* Has Packets been scheduled? */
+	if (cnt > 0) {
+		/* Prepare list for insertion/deleation */
+		lst.tail = last_pkt;
+		/* Remove scheduled packets from ready queue */
+		grspw_list_remove_head_list(&dma->ready, &lst);
+		dma->ready_cnt -= cnt;
+		if (dma->stats.ready_cnt_min > dma->ready_cnt)
+			dma->stats.ready_cnt_min = dma->ready_cnt;
+		/* Insert scheduled packets into scheduled queue */
+		grspw_list_append_list(&dma->rx_sched, &lst);
+		dma->rx_sched_cnt += cnt;
+		if (dma->stats.rx_sched_cnt_max < dma->rx_sched_cnt)
+			dma->stats.rx_sched_cnt_max = dma->rx_sched_cnt;
+		/* Update TX ring posistion */
+		dma->rx_ring_head = curr_bd;
+		/* Make hardware aware of the newly enabled descriptors
+		 * We must protect from ISR which writes RI|TI
+		SPIN_LOCK_IRQ(&dma->core->devlock, irqflags);
+		dmactrl = REG_READ(&dma->regs->ctrl);
+		dmactrl &= ~(GRSPW_DMACTRL_PS|GRSPW_DMACTRL_PR|GRSPW_DMA_STATUS_ERROR);
+		dmactrl |= GRSPW_DMACTRL_RE | GRSPW_DMACTRL_RD;
+		REG_WRITE(&dma->regs->ctrl, dmactrl);
+		SPIN_UNLOCK_IRQ(&dma->core->devlock, irqflags);
+	return cnt;
+/* Scans the RX desciptor table for scheduled Packet that has been received,
+ * and moves these Packet from the head of the scheduled queue to the
+ * tail of the recv queue.
+ * Also, for all packets the status is updated.
+ *  - SCHED List -> SENT List
+ * Return Value
+ * Number of packets moved
+STATIC int grspw_rx_process_scheduled(struct grspw_dma_priv *dma)
+	struct grspw_rxring *curr;
+	struct grspw_pkt *last_pkt;
+	int recv_pkt_cnt = 0;
+	curr = dma->rx_ring_tail;
+	/* Step into RX ring to find if packets have been scheduled for
+	 * reception.
+	if (!curr->pkt)
+		return 0; /* No scheduled packets, thus no received, abort */
+	/* There has been Packets scheduled ==> scheduled Packets may have been
+	 * received and needs to be collected into RECV List.
+	 * A temporary list "lst" with all received packets is created.
+	lst.head = curr->pkt;
+	/* Loop until first enabled "unrecveived" SpW Packet is found.
+	 * An unused descriptor is indicated by an unassigned pkt field.
+	while (curr->pkt && !((ctrl=BD_READ(&curr->bd->ctrl)) & GRSPW_RXBD_EN)) {
+		/* Handle one received Packet */
+		/* Remember last handled Packet so that insertion/removal from
+		 * Packet lists go fast.
+		last_pkt = curr->pkt;
+		/* Get Length of Packet in bytes, and reception options */
+		last_pkt->dlen = (ctrl & GRSPW_RXBD_LEN) >> GRSPW_RXBD_LEN_BIT;
+		/* Set flags to indicate error(s) and CRC information,
+		 * and Mark Received.
+		last_pkt->flags = (last_pkt->flags & ~RXPKT_FLAG_OUTPUT_MASK) |
+		                  ((ctrl >> 20) & RXPKT_FLAG_OUTPUT_MASK) |
+		                  RXPKT_FLAG_RX;
+		/* Packet was Truncated? */
+		if (ctrl & GRSPW_RXBD_TR)
+			dma->stats.rx_err_trunk++;
+		/* Error End-Of-Packet? */
+		if (ctrl & GRSPW_RXBD_EP)
+			dma->stats.rx_err_endpkt++;
+		curr->pkt = NULL; /* Mark descriptor unused */
+		/* Increment */
+		curr = curr->next;
+		recv_pkt_cnt++;
+	/* 1. Remove all handled packets from scheduled queue
+	 * 2. Put all handled packets into recv queue
+	if (recv_pkt_cnt > 0) {
+		/* Update Stats, Number of Received Packets */
+		dma->stats.rx_pkts += recv_pkt_cnt;
+		/* Save RX ring posistion */
+		dma->rx_ring_tail = curr;
+		/* Remove received Packets from RX-SCHED queue */
+		grspw_list_remove_head_list(&dma->rx_sched, &lst);
+		dma->rx_sched_cnt -= recv_pkt_cnt;
+		if (dma->stats.rx_sched_cnt_min > dma->rx_sched_cnt)
+			dma->stats.rx_sched_cnt_min = dma->rx_sched_cnt;
+		/* Insert received Packets into RECV queue */
+		grspw_list_append_list(&dma->recv, &lst);
+		dma->recv_cnt += recv_pkt_cnt;
+		if (dma->stats.recv_cnt_max < dma->recv_cnt)
+			dma->stats.recv_cnt_max = dma->recv_cnt;
+	return recv_pkt_cnt;
+/* Try to populate descriptor ring with as many SEND packets as possible. The
+ * packets assigned with to a descriptor are put in the end of
+ *  - SEND List -> TX-SCHED List
+ *  - Descriptors are initialized and enabled for transmission
+STATIC int grspw_tx_schedule_send(struct grspw_dma_priv *dma)
+	int cnt;
+	void *hwaddr;
+	struct grspw_txring *curr_bd;
+	if (grspw_list_is_empty(&dma->send))
+		return 0;
+	cnt = 0;
+	lst.head = curr_pkt = dma->send.head;
+	curr_bd = dma->tx_ring_head;
+		/* Set up header transmission */
+		if (curr_pkt->hdr && curr_pkt->hlen) {
+			hwaddr = curr_pkt->hdr;
+			if (curr_pkt->flags & PKT_FLAG_TR_HDR) {
+						 hwaddr, &hwaddr);
+				/* translation needed? */
+				if (curr_pkt->hdr == hwaddr)
+					curr_pkt->flags &= ~PKT_FLAG_TR_HDR;
+			BD_WRITE(&curr_bd->bd->haddr, hwaddr);
+			ctrl = GRSPW_TXBD_EN | curr_pkt->hlen;
+		} else {
+			ctrl = GRSPW_TXBD_EN;
+		/* Enable IRQ generation and CRC options as specified
+		 * by user.
+		ctrl |= (curr_pkt->flags & TXPKT_FLAG_INPUT_MASK) << 8;
+		if (curr_bd->next == dma->tx_ring_base) {
+			/* Wrap around (only needed when smaller descriptor table) */
+			ctrl |= GRSPW_TXBD_WR;
+		if ((--dma->tx_irq_en_cnt_curr) <= 0) {
+			if (dma->cfg.tx_irq_en_cnt == 0) {
+				 * A big number to avoid equal to zero too often
+				dma->tx_irq_en_cnt_curr = 0x3fffffff;
+			} else {
+				dma->tx_irq_en_cnt_curr = dma->cfg.tx_irq_en_cnt;
+				ctrl |= GRSPW_TXBD_IE;
+		/* Prepare descriptor address. Parts of CTRL is written to
+		 * DLEN for debug-only (CTRL is cleared by HW).
+		if (curr_pkt->data && curr_pkt->dlen) {
+						 hwaddr, &hwaddr);
+			BD_WRITE(&curr_bd->bd->daddr, hwaddr);
+			BD_WRITE(&curr_bd->bd->dlen, curr_pkt->dlen |
+			                             ((ctrl & 0x3f000) << 12));
+		} else {
+			BD_WRITE(&curr_bd->bd->daddr, 0);
+			BD_WRITE(&curr_bd->bd->dlen, ((ctrl & 0x3f000) << 12));
+		cnt++;
+		if (curr_pkt == dma->send.tail) {
+			curr_pkt = NULL;
+			break;
+	/* Have Packets been scheduled? */
+	if (cnt > 0) {
+		grspw_list_remove_head_list(&dma->send, &lst);
+		dma->send_cnt -= cnt;
+		if (dma->stats.send_cnt_min > dma->send_cnt)
+			dma->stats.send_cnt_min = dma->send_cnt;
+		grspw_list_append_list(&dma->tx_sched, &lst);
+		dma->tx_sched_cnt += cnt;
+		if (dma->stats.tx_sched_cnt_max < dma->tx_sched_cnt)
+			dma->stats.tx_sched_cnt_max = dma->tx_sched_cnt;
+		dma->tx_ring_head = curr_bd;
+		/* Make hardware aware of the newly enabled descriptors */
+		dmactrl |= GRSPW_DMACTRL_TE;
+	return cnt;
+/* Scans the TX desciptor table for transmitted packets, and moves these
+ * packets from the head of the scheduled queue to the tail of the sent queue.
+ * Return Value
+ * Number of packet moved
+STATIC int grspw_tx_process_scheduled(struct grspw_dma_priv *dma)
+	struct grspw_txring *curr;
+	int sent_pkt_cnt = 0;
+	curr = dma->tx_ring_tail;
+	/* Step into TX ring to find if packets have been scheduled for
+	 * transmission.
+	if (!curr->pkt)
+		return 0; /* No scheduled packets, thus no sent, abort */
+	 * transmitted and needs to be collected into SENT List.
+	 * A temporary list "lst" with all sent packets is created.
+	/* Loop until first enabled "un-transmitted" SpW Packet is found.
+	while (curr->pkt && !((ctrl=BD_READ(&curr->bd->ctrl)) & GRSPW_TXBD_EN)) {
+		/* Handle one sent Packet */
+		 * packet lists go fast.
+		/* Set flags to indicate error(s) and Mark Sent.
+		last_pkt->flags = (last_pkt->flags & ~TXPKT_FLAG_OUTPUT_MASK) |
+					(ctrl & TXPKT_FLAG_LINKERR) |
+					TXPKT_FLAG_TX;
+		/* Sent packet experienced link error? */
+		if (ctrl & GRSPW_TXBD_LE)
+			dma->stats.tx_err_link++;
+		/* Increment */
+		sent_pkt_cnt++;
+	/* 1. Remove all handled packets from TX-SCHED queue
+	 * 2. Put all handled packets into SENT queue
+	if (sent_pkt_cnt > 0) {
+		/* Update Stats, Number of Transmitted Packets */
+		dma->stats.tx_pkts += sent_pkt_cnt;
+		/* Save TX ring posistion */
+		dma->tx_ring_tail = curr;
+		/* Remove sent packets from TX-SCHED queue */
+		grspw_list_remove_head_list(&dma->tx_sched, &lst);
+		dma->tx_sched_cnt -= sent_pkt_cnt;
+		if (dma->stats.tx_sched_cnt_min > dma->tx_sched_cnt)
+			dma->stats.tx_sched_cnt_min = dma->tx_sched_cnt;
+		/* Insert received packets into SENT queue */
+		grspw_list_append_list(&dma->sent, &lst);
+		dma->sent_cnt += sent_pkt_cnt;
+		if (dma->stats.sent_cnt_max < dma->sent_cnt)
+			dma->stats.sent_cnt_max = dma->sent_cnt;
+	return sent_pkt_cnt;
+void *grspw_dma_open(void *d, int chan_no)
+	int size;
+	if ((chan_no < 0) && (priv->hwsup.ndma_chans <= chan_no))
+		return NULL;
+	dma = &priv->dma[chan_no];
+	/* Take GRSPW lock */
+		return NULL;
+	if (dma->open) {
+		dma = NULL;
+		goto out;
+	dma->started = 0;
+	/* Set Default Configuration:
+	 *  - MAX RX Packet Length =
+	 *  - Disable IRQ generation
+	dma->cfg.rxmaxlen = DEFAULT_RXMAX;
+	dma->cfg.rx_irq_en_cnt = 0;
+	dma->cfg.tx_irq_en_cnt = 0;
+	dma->cfg.flags = DMAFLAG_NO_SPILL;
+	/* DMA Channel Semaphore created with count = 1 */
+	if (rtems_semaphore_create(
+	    rtems_build_name('S', 'D', '0' + priv->index, '0' + chan_no), 1,
+	    RTEMS_FIFO | RTEMS_SIMPLE_BINARY_SEMAPHORE | \
+	    RTEMS_NO_INHERIT_PRIORITY | RTEMS_LOCAL | \
+	    RTEMS_NO_PRIORITY_CEILING, 0, &dma->sem_dma) != RTEMS_SUCCESSFUL) {
+		dma = NULL;
+		goto out;
+	/* Allocate memory for the two descriptor rings */
+	size = sizeof(struct grspw_ring) * (GRSPW_RXBD_NR + GRSPW_TXBD_NR);
+	dma->rx_ring_base = (struct grspw_rxring *)malloc(size);
+	dma->tx_ring_base = (struct grspw_txring *)&dma->rx_ring_base[GRSPW_RXBD_NR];
+	if (dma->rx_ring_base == NULL) {
+		dma = NULL;
+		goto out;
+	/* Create DMA RX and TX Channel sempahore with count = 0 */
+	    rtems_build_name('S', 'R', '0' + priv->index, '0' + chan_no), 0,
+	    RTEMS_NO_PRIORITY_CEILING, 0, &dma->rx_wait.sem_wait) != RTEMS_SUCCESSFUL) {
+		dma = NULL;
+		goto out;
+	    rtems_build_name('S', 'T', '0' + priv->index, '0' + chan_no), 0,
+	    RTEMS_NO_PRIORITY_CEILING, 0, &dma->tx_wait.sem_wait) != RTEMS_SUCCESSFUL) {
+		dma = NULL;
+		goto out;
+	/* Reset software structures */
+	grspw_dma_reset(dma);
+	dma->open = 1;
+out:
+	/* Return GRSPW Lock */
+	return dma;
+/* Initialize Software Structures:
+ *  - Clear all Queues
+ *  - init BD ring
+ *  - init IRQ counter
+ *  - clear statistics counters
+ *  - init wait structures and semaphores
+	/* Empty RX and TX queues */
+	grspw_list_clr(&dma->ready);
+	grspw_list_clr(&dma->rx_sched);
+	grspw_list_clr(&dma->recv);
+	grspw_list_clr(&dma->send);
+	grspw_list_clr(&dma->tx_sched);
+	grspw_list_clr(&dma->sent);
+	dma->ready_cnt = 0;
+	dma->rx_sched_cnt = 0;
+	dma->recv_cnt = 0;
+	dma->send_cnt = 0;
+	dma->tx_sched_cnt = 0;
+	dma->sent_cnt = 0;
+	dma->rx_irq_en_cnt_curr = 0;
+	dma->tx_irq_en_cnt_curr = 0;
+	grspw_bdrings_init(dma);
+	dma->rx_wait.waiting = 0;
+	dma->tx_wait.waiting = 0;
+	grspw_dma_stats_clr(dma);
+void grspw_dma_close(void *c)
+	struct grspw_dma_priv *dma = c;
+	if (!dma->open)
+		return;
+	/* Take device lock - Wait until we get semaphore */
+	if (rtems_semaphore_obtain(dma->sem_dma, RTEMS_WAIT, RTEMS_NO_TIMEOUT)
+		return;
+	grspw_dma_stop_locked(dma);
+	/* Free resources */
+	rtems_semaphore_delete(dma->rx_wait.sem_wait);
+	rtems_semaphore_delete(dma->tx_wait.sem_wait);
+	rtems_semaphore_delete(dma->sem_dma); /* Release and delete lock */
+	/* Free memory */
+	if (dma->rx_ring_base)
+		free(dma->rx_ring_base);
+	dma->rx_ring_base = NULL;
+	dma->tx_ring_base = NULL;
+	dma->open = 0;
+ * future.
+ * 3. Schedule as many packets as possible (SEND->SCHED)
+int grspw_dma_tx_send(void *c, int opts, struct grspw_list *pkts, int count)
+	int ret;
+	/* Take DMA channel lock */
+		return -1;
+	if (dma->started == 0) {
+		ret = 1; /* signal DMA has been stopped */
+		goto out;
+	ret = 0;
+	/* 1. Move transmitted packets to SENT List (SCHED->SENT) */
+	if ((opts & 1) == 0)
+		grspw_tx_process_scheduled(dma);
+	/* 2. Add the requested packets to the SEND List (USER->SEND) */
+	if (pkts) {
+		grspw_list_append_list(&dma->send, pkts);
+		dma->send_cnt += count;
+		if (dma->stats.send_cnt_max < dma->send_cnt)
+			dma->stats.send_cnt_max = dma->send_cnt;
+	/* 3. Schedule as many packets as possible (SEND->SCHED) */
+	if ((opts & 2) == 0)
+		grspw_tx_schedule_send(dma);
+out:
+	/* Unlock DMA channel */
+	rtems_semaphore_release(dma->sem_dma);
+	return ret;
+int grspw_dma_tx_reclaim(void *c, int opts, struct grspw_list *pkts, int *count)
+	struct grspw_pkt *pkt, *lastpkt;
+	int cnt, started;
+		return -1;
+	started = dma->started;
+	if ((started > 0) && ((opts & 1) == 0))
+	/* Move all/count SENT packet to the callers list (SENT->USER) */
+	if (pkts) {
+		if ((count == NULL) || (*count == -1) ||
+		    (*count >= dma->sent_cnt)) {
+			/* Move all SENT Packets */
+			*pkts = dma->sent;
+			if (count)
+				*count = dma->sent_cnt;
+		} else {
+			/* Move a number of SENT Packets */
+			pkts->head = pkt = lastpkt = dma->sent.head;
+			cnt = 0;
+			while (cnt < *count) {
+				lastpkt = pkt;
+				pkt = pkt->next;
+				cnt++;
+			if (cnt > 0) {
+				pkts->tail = lastpkt;
+				grspw_list_remove_head_list(&dma->sent, pkts);
+				dma->sent_cnt -= cnt;
+			} else {
+				grspw_list_clr(pkts);
+	} else if (count) {
+		*count = 0;
+	if ((started > 0 ) && ((opts & 2) == 0))
+	return (~started) & 1; /* signal DMA has been stopped */
+void grspw_dma_tx_count(void *c, int *send, int *sched, int *sent)
+	if (send)
+		*send = dma->send_cnt;
+	if (sched)
+		*sched = dma->tx_sched_cnt;
+	if (sent)
+		*sent = dma->sent_cnt;
+static inline int grspw_tx_wait_eval(struct grspw_dma_priv *dma)
+	int send_val, sent_val;
+	if (dma->tx_wait.send_cnt >= (dma->send_cnt + dma->tx_sched_cnt))
+		send_val = 1;
+	else
+		send_val = 0;
+	if (dma->tx_wait.sent_cnt <= dma->sent_cnt)
+		sent_val = 1;
+	else
+		sent_val = 0;
+	/* AND or OR ? */
+	if (dma->tx_wait.op == 0)
+		return send_val & sent_val; /* AND */
+	else
+		return send_val | sent_val; /* OR */
+/* Block until send_cnt or fewer packets are Queued in "Send and Scheduled" Q,
+ * is met.
+int grspw_dma_tx_wait(void *c, int send_cnt, int op, int sent_cnt, int timeout)
+	int ret, rc;
+	if (timeout == 0)
+		timeout = RTEMS_NO_TIMEOUT;
+check_condition:
+		return -1;
+	/* Check so that no other thread is waiting, this driver only supports
+	 * one waiter at a time.
+	if (dma->tx_wait.waiting) {
+		ret = -1;
+		goto out;
+	/* Stop if link error or similar, abort */
+		ret = 1;
+		goto out;
+	/* Set up Condition */
+	dma->tx_wait.send_cnt = send_cnt;
+	dma->tx_wait.op = op;
+	dma->tx_wait.sent_cnt = sent_cnt;
+	if (grspw_tx_wait_eval(dma) == 0) {
+		/* Prepare Wait */
+		dma->tx_wait.waiting = 1;
+		/* Release DMA channel lock */
+		/* Try to take Wait lock, if this fail link may have gone down
+		 * or user stopped this DMA channel
+		rc = rtems_semaphore_obtain(dma->tx_wait.sem_wait, RTEMS_WAIT,
+						timeout);
+		if (rc == RTEMS_TIMEOUT) {
+			return 2;
+		} else if (rc == RTEMS_UNSATISFIED ||
+		           rc == RTEMS_OBJECT_WAS_DELETED) {
+			return 1; /* sem was flushed/deleted, means DMA stop */
+		} else if (rc != RTEMS_SUCCESSFUL)
+		    	return -1;
+		/* Check condition once more */
+		goto check_condition;
+	} else {
+		/* No Wait needed */
+	ret = 0;
+out:
+	return ret;
+int grspw_dma_rx_recv(void *c, int opts, struct grspw_list *pkts, int *count)
+	int cnt, started;
+		return -1;
+	/* 1. Move Scheduled packets to RECV List (SCHED->RECV) */
+	if (((opts & 1) == 0) && (started > 0))
+		grspw_rx_process_scheduled(dma);
+	/* Move all RECV packet to the callers list */
+	if (pkts) {
+		    (*count >= dma->recv_cnt)) {
+			/* Move all Received packets */
+			*pkts = dma->recv;
+			if ( count )
+				*count = dma->recv_cnt;
+		} else {
+			/* Move a number of RECV Packets */
+			pkts->head = pkt = lastpkt = dma->recv.head;
+			cnt = 0;
+				lastpkt = pkt;
+				pkt = pkt->next;
+				cnt++;
+			if (cnt > 0) {
+				grspw_list_remove_head_list(&dma->recv, pkts);
+				dma->recv_cnt -= cnt;
+			} else {
+		*count = 0;
+	/* 3. Schedule as many free packet buffers as possible (READY->SCHED) */
+	if (((opts & 2) == 0) && (started > 0))
+		grspw_rx_schedule_ready(dma);
+int grspw_dma_rx_prepare(void *c, int opts, struct grspw_list *pkts, int count)
+	int ret;
+		return -1;
+		ret = 1;
+		goto out;
+	/* 1. Move Received packets to RECV List (SCHED->RECV) */
+	/* 2. Add the "free/ready" packet buffers to the READY List (USER->READY) */
+	if (pkts && (count > 0)) {
+		grspw_list_append_list(&dma->ready, pkts);
+		dma->ready_cnt += count;
+		if (dma->stats.ready_cnt_max < dma->ready_cnt)
+			dma->stats.ready_cnt_max = dma->ready_cnt;
+	/* 3. Schedule as many packets as possible (READY->SCHED) */
+	ret = 0;
+out:
+	return ret;
+void grspw_dma_rx_count(void *c, int *ready, int *sched, int *recv)
+	if (ready)
+		*ready = dma->ready_cnt;
+	if (sched)
+		*sched = dma->rx_sched_cnt;
+	if (recv)
+		*recv = dma->recv_cnt;
+static inline int grspw_rx_wait_eval(struct grspw_dma_priv *dma)
+	int ready_val, recv_val;
+	if (dma->rx_wait.ready_cnt >= (dma->ready_cnt + dma->rx_sched_cnt))
+		ready_val = 1;
+	else
+		ready_val = 0;
+	if (dma->rx_wait.recv_cnt <= dma->recv_cnt)
+		recv_val = 1;
+	else
+		recv_val = 0;
+	/* AND or OR ? */
+	if (dma->rx_wait.op == 0)
+		return ready_val & recv_val; /* AND */
+	else
+		return ready_val | recv_val; /* OR */
+int grspw_dma_rx_wait(void *c, int recv_cnt, int op, int ready_cnt, int timeout)
+	int ret, rc;
+	if (timeout == 0)
+check_condition:
+		return -1;
+	if (dma->rx_wait.waiting) {
+		ret = -1;
+		goto out;
+	/* Stop if link error or similar (MDA stopped) */
+		ret = 1;
+		goto out;
+	dma->rx_wait.recv_cnt = recv_cnt;
+	dma->rx_wait.op = op;
+	dma->rx_wait.ready_cnt = ready_cnt;
+	if (grspw_rx_wait_eval(dma) == 0) {
+		dma->rx_wait.waiting = 1;
+		/* Release channel lock */
+		rc = rtems_semaphore_obtain(dma->rx_wait.sem_wait, RTEMS_WAIT,
+		                           timeout);
+			return 2;
+		    	return -1;
+	} else {
+	ret = 0;
+out:
+	return ret;
+int grspw_dma_config(void *c, struct grspw_dma_config *cfg)
+	if (dma->started || !cfg)
+		return -1;
+	if (cfg->flags & ~DMAFLAG_MASK)
+		return -1;
+	/* Update Configuration */
+	memcpy(&dma->cfg, cfg, sizeof(*cfg));
+	return 0;
+void grspw_dma_config_read(void *c, struct grspw_dma_config *cfg)
+	/* Copy Current Configuration */
+	memcpy(cfg, &dma->cfg, sizeof(*cfg));
+void grspw_dma_stats_read(void *c, struct grspw_dma_stats *sts)
+	memcpy(sts, &dma->stats, sizeof(dma->stats));
+void grspw_dma_stats_clr(void *c)
+	memset(&dma->stats, 0, sizeof(dma->stats));
+	/* Init proper default values so that comparisons will work the
+	 * first time.
+	dma->stats.send_cnt_min = 0x3fffffff;
+	dma->stats.tx_sched_cnt_min = 0x3fffffff;
+	dma->stats.ready_cnt_min = 0x3fffffff;
+	dma->stats.rx_sched_cnt_min = 0x3fffffff;
+int grspw_dma_start(void *c)
+	struct grspw_dma_regs *dregs = dma->regs;
+	if (dma->started)
+		return 0;
+	/* Initialize Software Structures:
+	 *  - init BD ring
+	/* RX&RD and TX is not enabled until user fills SEND and READY Queue
+	 * with SpaceWire Packet buffers. So we do not have to worry about
+	 * IRQs for this channel just yet. However other DMA channels
+	 * may be active.
+	 * Some functionality that is not changed during started mode is set up
+	 * once and for all here:
+	 *   - RX MAX Packet length
+	 *   - TX Descriptor base address to first BD in TX ring (not enabled)
+	 *   - RX Descriptor base address to first BD in RX ring (not enabled)
+	 *   - IRQs (TX DMA, RX DMA, DMA ERROR)
+	 *   - Strip PID
+	 *   - Strip Address
+	 *   - No Spill
+	 *   - Receiver Enable
+	 *   - disable on link error (LE)
+	 * Note that the address register and the address enable bit in DMACTRL
+	 * register must be left untouched, they are configured on a GRSPW
+	 * core level.
+	 * Note that the receiver is enabled here, but since descriptors are
+	 * not enabled the GRSPW core may stop/pause RX (if NS bit set) until
+	 * descriptors are enabled or it may ignore RX packets (NS=0) until
+	 * descriptors are enabled (writing RD bit).
+	REG_WRITE(&dregs->txdesc, dma->tx_bds_hwa);
+	REG_WRITE(&dregs->rxdesc, dma->rx_bds_hwa);
+	/* MAX Packet length */
+	REG_WRITE(&dma->regs->rxmax, dma->cfg.rxmaxlen);
+	ctrl =  GRSPW_DMACTRL_AI | GRSPW_DMACTRL_PS | GRSPW_DMACTRL_PR |
+		GRSPW_DMACTRL_TA | GRSPW_DMACTRL_RA | GRSPW_DMACTRL_RE |
+		(dma->cfg.flags & DMAFLAG_MASK) << GRSPW_DMACTRL_NS_BIT;
+	if (dma->core->dis_link_on_err)
+		ctrl |= GRSPW_DMACTRL_LE;
+	if (dma->cfg.rx_irq_en_cnt != 0)
+		ctrl |= GRSPW_DMACTRL_RI;
+	if (dma->cfg.tx_irq_en_cnt != 0)
+		ctrl |= GRSPW_DMACTRL_TI;
+	REG_WRITE(&dregs->ctrl, ctrl);
+	dma->started = 1; /* open up other DMA interfaces */
+	return 0;
+		return;
+	dma->started = 0;
+	grspw_hw_dma_stop(dma);
+	/* From here no more packets will be sent, however
+	 * there may still exist scheduled packets that has been
+	 * sent, and packets in the SEND Queue waiting for free
+	 * descriptors. All packets are moved to the SENT Queue
+	 * so that the user may get its buffers back, the user
+	 * must look at the TXPKT_FLAG_TX in order to determine
+	 * if the packet was sent or not.
+	/* Retreive scheduled all sent packets */
+	/* Move un-sent packets in SEND and SCHED queue to the
+	 * SENT Queue. (never marked sent)
+	if (!grspw_list_is_empty(&dma->tx_sched)) {
+		grspw_list_append_list(&dma->sent, &dma->tx_sched);
+		dma->sent_cnt += dma->tx_sched_cnt;
+	if (!grspw_list_is_empty(&dma->send)) {
+		grspw_list_append_list(&dma->sent, &dma->send);
+		dma->sent_cnt += dma->send_cnt;
+	/* Similar for RX */
+	if (!grspw_list_is_empty(&dma->rx_sched)) {
+		grspw_list_append_list(&dma->recv, &dma->rx_sched);
+		dma->recv_cnt += dma->rx_sched_cnt;
+	if (!grspw_list_is_empty(&dma->ready)) {
+		grspw_list_append_list(&dma->recv, &dma->ready);
+		dma->recv_cnt += dma->ready_cnt;
+	/* Throw out blocked threads */
+	rtems_semaphore_flush(dma->rx_wait.sem_wait);
+	rtems_semaphore_flush(dma->tx_wait.sem_wait);
+void grspw_dma_stop(void *c)
+	/* Take DMA Channel lock */
+		return;
+/* Do general work, invoked indirectly from ISR */
+static void grspw_work_shutdown_func(struct grspw_priv *priv)
+	int i;
+	/* Link is down for some reason, and the user has configured
+	 * that we stop all DMA channels and throw out all blocked
+	 * threads.
+		grspw_dma_stop(&priv->dma[i]);
+/* Do DMA work on one channel, invoked indirectly from ISR */
+static void grspw_work_dma_func(struct grspw_dma_priv *dma)
+	int tx_cond_true, rx_cond_true;
+	rx_cond_true = 0;
+	tx_cond_true = 0;
+	dma->stats.irq_cnt++;
+		return;
+	/* Look at cause we were woken up and clear source */
+	ctrl = REG_READ(&dma->regs->ctrl);
+	/* Read/Write DMA error ? */
+	if (ctrl & GRSPW_DMA_STATUS_ERROR) {
+		/* DMA error -> Stop DMA channel (both RX and TX) */
+	} else if (ctrl & (GRSPW_DMACTRL_PR | GRSPW_DMACTRL_PS)) {
+		/* DMA has finished a TX/RX packet */
+		ctrl &= ~GRSPW_DMACTRL_AT;
+		REG_WRITE(&dma->regs->ctrl, ctrl);
+		if (ctrl & GRSPW_DMACTRL_PR) {
+			/* Do RX Work */
+			dma->stats.rx_work_cnt++;
+			dma->stats.rx_work_enabled += grspw_rx_schedule_ready(dma);
+			/* Check to see if condition for waking blocked USER
+		 	 * task is fullfilled.
+				rx_cond_true = grspw_rx_wait_eval(dma);
+				if (rx_cond_true)
+		if (ctrl & GRSPW_DMACTRL_PS) {
+			/* Do TX Work */
+			dma->stats.tx_work_cnt++;
+			dma->stats.tx_work_enabled += grspw_tx_schedule_send(dma);
+				tx_cond_true = grspw_tx_wait_eval(dma);
+				if (tx_cond_true)
+	} else
+	/* Release lock */
+	if (rx_cond_true)
+		rtems_semaphore_release(dma->rx_wait.sem_wait);
+	if (tx_cond_true)
+		rtems_semaphore_release(dma->tx_wait.sem_wait);
+/* Work task is receiving work for the work message queue posted from
+ * the ISR.
+void grspw_work_func(rtems_task_argument unused)
+	rtems_status_code status;
+	unsigned int message;
+	size_t size;
+	int i;
+	while (grspw_task_stop == 0) {
+		/* Wait for ISR to schedule work */
+		status = rtems_message_queue_receive(
+			grspw_work_queue, &message,
+			&size, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+		if (status != RTEMS_SUCCESSFUL)
+			break;
+		/* Handle work */
+		priv = priv_tab[message >> WORK_CORE_BIT];
+		if (message & WORK_SHUTDOWN)
+			grspw_work_shutdown_func(priv);
+		else if (message & WORK_DMA_MASK) {
+			for (i = 0; i < 4; i++) {
+				if (message & WORK_DMA(i))
+					grspw_work_dma_func(&priv->dma[i]);
+	rtems_task_delete(RTEMS_SELF);
+	struct grspw_priv *priv = data;
+	unsigned int dma_stat, stat, stat_clrmsk, ctrl, timecode;
+	int i, handled = 0, message = WORK_NONE;
+#endif
+	/* Get Status from Hardware */
+	stat = REG_READ(&priv->regs->status);
+	stat_clrmsk = stat & (GRSPW_STS_TO | GRSPW_STAT_ERROR);
+	/* Make sure to put the timecode handling first in order to get the
+	 * smallest possible interrupt latency
+	if ((stat & GRSPW_STS_TO) && (priv->tcisr != NULL)) {
+		/* Timecode received. Let custom function handle this */
+		timecode = priv->regs->time;
+		(priv->tcisr)(priv->tcisr_arg, timecode);
+	/* An Error occured? */
+	if (stat & GRSPW_STAT_ERROR) {
+		/* Wake Global WorkQ */
+		handled = 1;
+		if (stat & GRSPW_STS_EE)
+			priv->stats.err_eeop++;
+		if (stat & GRSPW_STS_IA)
+			priv->stats.err_addr++;
+		if (stat & GRSPW_STS_PE)
+			priv->stats.err_parity++;
+		if (stat & GRSPW_STS_ER)
+			priv->stats.err_escape++;
+		if (stat & GRSPW_STS_CE)
+			priv->stats.err_credit++;
+		if (stat & GRSPW_STS_WE)
+			priv->stats.err_wsync++;
+		if (priv->dis_link_on_err) {
+			/* Disable the link, no more transfers are expected
+			 * on any DMA channel.
+			SPIN_LOCK(&priv->devlock, irqflags);
+			ctrl = REG_READ(&priv->regs->ctrl);
+			REG_WRITE(&priv->regs->ctrl, GRSPW_CTRL_LD |
+				(ctrl & ~(GRSPW_CTRL_IE|GRSPW_CTRL_LS)));
+			SPIN_UNLOCK(&priv->devlock, irqflags);
+			/* Signal to work-thread to stop DMA and clean up */
+			message = WORK_SHUTDOWN;
+	/* Clear Status Flags */
+	if (stat_clrmsk) {
+		handled = 1;
+		REG_WRITE(&priv->regs->status, stat_clrmsk);
+	/* A DMA transfer or Error occured? In that case disable more IRQs
+	 * from the DMA channel, then invoke the workQ.
+	 * Also the GI interrupt flag may not be available for older
+	 * designs where (was added together with mutiple DMA channels).
+		dma_stat = REG_READ(&priv->regs->dma[i].ctrl);
+		/* Check for Errors and if Packets been sent or received if
+		 * respective IRQ are enabled
+#ifdef HW_WITH_GI
+		if ( dma_stat & (GRSPW_DMA_STATUS_ERROR | GRSPW_DMACTRL_GI) ) {
+#else
+		if ( (((dma_stat << 3) & (GRSPW_DMACTRL_PR | GRSPW_DMACTRL_PS))
+		     | GRSPW_DMA_STATUS_ERROR) & dma_stat ) {
+#endif
+			/* Disable Further IRQs (until enabled again)
+			 * from this DMA channel. Let the status
+			 * bit remain so that they can be handled by
+			 * work function.
+			REG_WRITE(&priv->regs->dma[i].ctrl, dma_stat &
+				~(GRSPW_DMACTRL_RI|GRSPW_DMACTRL_TI|
+				GRSPW_DMACTRL_PR|GRSPW_DMACTRL_PS|
+				GRSPW_DMACTRL_RA|GRSPW_DMACTRL_TA|
+				GRSPW_DMACTRL_AT));
+			message |= WORK_DMA(i);
+			handled = 1;
+	if (handled != 0)
+		priv->stats.irq_cnt++;
+	/* Schedule work by sending message to work thread */
+	if ((message != WORK_NONE) && grspw_work_queue) {
+		message |= WORK_CORE(priv->index);
+		stat = rtems_message_queue_send(grspw_work_queue, &message, 4);
+		if (stat != RTEMS_SUCCESSFUL)
+			printk("grspw_isr(%d): message fail %d (0x%x)\n",
+				priv->index, stat, message);
+	ctrl = REG_READ(&dregs->ctrl) & (GRSPW_DMACTRL_LE | GRSPW_DMACTRL_EN |
+	       GRSPW_DMACTRL_SP | GRSPW_DMACTRL_SA | GRSPW_DMACTRL_NS);
+	ctrl |=	GRSPW_DMACTRL_AT;
+STATIC void grspw_hw_dma_softreset(struct grspw_dma_priv *dma)
+	ctrl = REG_READ(&dregs->ctrl) & (GRSPW_DMACTRL_LE | GRSPW_DMACTRL_EN);
+	REG_WRITE(&dregs->rxmax, DEFAULT_RXMAX);
+	REG_WRITE(&dregs->txdesc, 0);
+	REG_WRITE(&dregs->rxdesc, 0);
+/* Hardware Action:
+ *  - stop DMA
+ *  - do not bring down the link (RMAP may be active)
+ *  - RMAP settings untouched (RMAP may be active)
+ *  - port select untouched (RMAP may be active)
+ *  - timecodes are disabled
+ *  - IRQ generation disabled
+ *  - status not cleared (let user analyze it if requested later on)
+ *  - Node address / First DMA channels Node address
+ *    is untouched (RMAP may be active)
+	int i;
+		grspw_hw_dma_stop(&priv->dma[i]);
+	REG_WRITE(&priv->regs->ctrl, ctrl & (
+		GRSPW_CTRL_LD | GRSPW_CTRL_LS | GRSPW_CTRL_AS |
+		GRSPW_CTRL_RE | GRSPW_CTRL_RD |
+		GRSPW_CTRL_NP | GRSPW_CTRL_PS));
+/* Soft reset of GRSPW core registers */
+STATIC void grspw_hw_softreset(struct grspw_priv *priv)
+	int i;
+		grspw_hw_dma_softreset(&priv->dma[i]);
+	REG_WRITE(&priv->regs->status, 0xffffffff);
+	REG_WRITE(&priv->regs->time, 0);
+int grspw_dev_count(void)
+	return grspw_count;
+void grspw_initialize_user(void *(*devfound)(int), void (*devremove)(int,void*))
+	int i;
+	/* Set new Device Found Handler */
+	grspw_dev_add = devfound;
+	grspw_dev_del = devremove;
+	if (grspw_initialized == 1 && grspw_dev_add) {
+		/* Call callback for every previously found device */
+		for (i=0; i<grspw_count; i++) {
+			priv = priv_tab[i];
+			if (priv)
+				priv->data = grspw_dev_add(i);
+/******************* Driver manager interface ***********************/
+/* Driver prototypes */
+static int grspw_common_init(void);
+static int grspw2_init3(struct drvmgr_dev *dev);
+static struct drvmgr_drv_ops grspw2_ops =
+	.init = {NULL,  NULL, grspw2_init3, NULL},
+	.remove = NULL,
+	.info = NULL
+static struct amba_dev_id grspw2_ids[] =
+	{VENDOR_GAISLER, GAISLER_SPW}, /* not yet supported */
+	{VENDOR_GAISLER, GAISLER_SPW2},
+	{VENDOR_GAISLER, GAISLER_SPW2_DMA},
+	{0, 0}		/* Mark end of table */
+static struct amba_drv_info grspw2_drv_info =
+		DRVMGR_OBJ_DRV,			/* Driver */
+		NULL,				/* Next driver */
+		NULL,				/* Device list */
+		DRIVER_AMBAPP_GAISLER_GRSPW2_ID,/* Driver ID */
+		"GRSPW_PKT_DRV",		/* Driver Name */
+		DRVMGR_BUS_TYPE_AMBAPP,		/* Bus Type */
+		&grspw2_ops,
+		NULL,				/* Funcs */
+		0,				/* No devices yet */
+		sizeof(struct grspw_priv),	/* Let DrvMgr alloc priv */
+	&grspw2_ids[0]
+void grspw2_register_drv (void)
+	GRSPW_DBG("Registering GRSPW2 packet driver\n");
+	drvmgr_drv_register(&grspw2_drv_info.general);
+	struct amba_dev_info *ambadev;
+	struct ambapp_core *pnpinfo;
+	int i, size;
+	GRSPW_DBG("GRSPW[%d] on bus %s\n", dev->minor_drv,
+		dev->parent->dev->name);
+	if (grspw_count > GRSPW_MAX)
+		return DRVMGR_ENORES;
+	priv = dev->priv;
+	if (priv == NULL)
+		return DRVMGR_NOMEM;
+	priv->dev = dev;
+	/* If first device init common part of driver */
+	if (grspw_common_init())
+		return DRVMGR_FAIL;
+	/*** Now we take care of device initialization ***/
+	/* Get device information from AMBA PnP information */
+	ambadev = (struct amba_dev_info *)dev->businfo;
+	if (ambadev == NULL)
+		return -1;
+	pnpinfo = &ambadev->info;
+	priv->irq = pnpinfo->irq;
+	priv->regs = (struct grspw_regs *)pnpinfo->apb_slv->start;
+	/* Read Hardware Support from Control Register */
+	priv->hwsup.rmap = (ctrl & GRSPW_CTRL_RA) >> GRSPW_CTRL_RA_BIT;
+	priv->hwsup.rmap_crc = (ctrl & GRSPW_CTRL_RC) >> GRSPW_CTRL_RC_BIT;
+	priv->hwsup.rx_unalign = (ctrl & GRSPW_CTRL_RX) >> GRSPW_CTRL_RX_BIT;
+	priv->hwsup.nports = 1 + ((ctrl & GRSPW_CTRL_PO) >> GRSPW_CTRL_PO_BIT);
+	priv->hwsup.ndma_chans = 1 + ((ctrl & GRSPW_CTRL_NCH) >> GRSPW_CTRL_NCH_BIT);
+	/* Construct hardware version identification */
+	priv->hwsup.hw_version = pnpinfo->device << 16 | pnpinfo->apb_slv->ver;
+	if ((pnpinfo->device == GAISLER_SPW2) ||
+	    (pnpinfo->device == GAISLER_SPW2_DMA)) {
+		priv->hwsup.strip_adr = 1; /* All GRSPW2 can strip Address */
+		priv->hwsup.strip_pid = 1; /* All GRSPW2 can strip PID */
+	} else {
+		/* Autodetect GRSPW1 features? */
+		priv->hwsup.strip_adr = 0;
+		priv->hwsup.strip_pid = 0;
+	/* Let user limit the number of DMA channels on this core to save
+	 * space. Only the first nDMA channels will be available.
+	value = drvmgr_dev_key_get(priv->dev, "nDMA", KEY_TYPE_INT);
+	if (value && (value->i < priv->hwsup.ndma_chans))
+		priv->hwsup.ndma_chans = value->i;
+	/* Allocate and init Memory for all DMA channels */
+	size = sizeof(struct grspw_dma_priv) * priv->hwsup.ndma_chans;
+	priv->dma = (struct grspw_dma_priv *) malloc(size);
+	if (priv->dma == NULL)
+	memset(priv->dma, 0, size);
+		priv->dma[i].core = priv;
+		priv->dma[i].index = i;
+		priv->dma[i].regs = &priv->regs->dma[i];
+	/* Startup Action:
+	 *  - stop DMA
+	 *  - timecodes are diabled
+	 *  - status cleared
+	grspw_hw_softreset(priv);
+	/* Register character device in registered region */
+	priv->index = grspw_count;
+	priv_tab[priv->index] = priv;
+	grspw_count++;
+	/* Device name */
+	sprintf(priv->devname, "grspw%d", priv->index);
+	/* Tell above layer about new device */
+	if (grspw_dev_add)
+		priv->data = grspw_dev_add(priv->index);
+	return DRVMGR_OK;
+/******************* Driver Implementation ***********************/
+	if (grspw_initialized == 1)
+		return 0;
+	if (grspw_initialized == -1)
+		return -1;
+	grspw_initialized = -1;
+	/* Device Semaphore created with count = 1 */
+	if (rtems_semaphore_create(rtems_build_name('S', 'G', 'L', 'S'), 1,
+	    RTEMS_NO_PRIORITY_CEILING, 0, &grspw_sem) != RTEMS_SUCCESSFUL)
+		return -1;
+	/* Work queue, Work thread. Not created if user disables it.
+	 * user can disable it when interrupt is not used to save resources
+	if (grspw_work_task_priority != -1) {
+		if (rtems_message_queue_create(
+		    rtems_build_name('S', 'G', 'L', 'Q'), 32, 4, RTEMS_FIFO,
+		    &grspw_work_queue) != RTEMS_SUCCESSFUL)
+			return -1;
+		if (rtems_task_create(rtems_build_name('S', 'G', 'L', 'T'),
+		    grspw_work_task_priority, RTEMS_MINIMUM_STACK_SIZE,
+		    RTEMS_PREEMPT | RTEMS_NO_ASR, RTEMS_NO_FLOATING_POINT,
+		    &grspw_work_task) != RTEMS_SUCCESSFUL)
+			return -1;
+		if (rtems_task_start(grspw_work_task, grspw_work_func, 0) !=
+		    RTEMS_SUCCESSFUL)
+			return -1;
+	grspw_initialized = 1;
+	return 0;
diff --git a/cpukit/libdrvmgr/drvmgr_confdefs.h b/cpukit/libdrvmgr/drvmgr_confdefs.h
index b2e4aba..957e4e0 100644
--- a/cpukit/libdrvmgr/drvmgr_confdefs.h
+++ b/cpukit/libdrvmgr/drvmgr_confdefs.h
@@ -42,6 +42,9 @@ extern void greth_register_drv(void);
 #define DRIVER_AMBAPP_GAISLER_GRSPW_REG {grspw_register_drv}
 extern void grspw_register_drv(void);
+#define DRIVER_AMBAPP_GAISLER_GRSPW2_REG {grspw2_register_drv}
+extern void grspw2_register_drv(void);
 #define DRIVER_AMBAPP_GAISLER_GRCAN_REG {grcan_register_drv}
 extern void grcan_register_drv(void);
@@ -155,6 +158,9 @@ struct drvmgr_drv_reg_func drvmgr_drivers[] = {
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW
 	DRIVER_AMBAPP_GAISLER_GRSPW_REG,
 #endif
+#ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRSPW2
+	DRIVER_AMBAPP_GAISLER_GRSPW2_REG,
+#endif
 #ifdef CONFIGURE_DRIVER_AMBAPP_GAISLER_GRCAN
 	DRIVER_AMBAPP_GAISLER_GRCAN_REG,
 #endif
1.7.0.4
