[PATCH 029/111] APBUART: fix GRMON -u support for older UARTs
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:31 UTC 2015
c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c | 16 ++++++++++++++--
1 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index 2785286..64d1b15 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -197,18 +197,30 @@ int apbuart_init1(struct drvmgr_dev *dev)
/* Clear HW regs, leave baudrate register as it is */
priv->regs->status = 0;
- /* leave debug bit, and Transmitter/receiver if this is the debug UART */
+ /* leave debug bit, and Transmitter/receiver if this is the debug UART.
+ * With old APBUARTs debug is enabled by setting LB and FL, since LB is
+ * not reset we can not trust is, however since FL is reset we guess
+ * that we are debugging old UART if both FL and LB is already set.
#ifdef LEON3
if (priv->regs == dbg_uart) {
db = priv->regs->ctrl & (LEON_REG_UART_CTRL_DB |
LEON_REG_UART_CTRL_RE |
LEON_REG_UART_CTRL_TE |
LEON_REG_UART_CTRL_FL |
+ LEON_REG_UART_CTRL_LB |
LEON_REG_UART_CTRL_PE |
LEON_REG_UART_CTRL_PS);
} else
#endif
- db = priv->regs->ctrl & LEON_REG_UART_CTRL_DB;
+ if (priv->regs->ctrl & (LEON_REG_UART_CTRL_FL |
+ LEON_REG_UART_CTRL_LB))
+ db = priv->regs->ctrl & (LEON_REG_UART_CTRL_FL |
+ LEON_REG_UART_CTRL_LB);
+ else
+ db = priv->regs->ctrl & LEON_REG_UART_CTRL_DB;
priv->regs->ctrl = db;
1.7.0.4
