[PATCH 039/111] GRETH: cleaned up parts of PHY init code
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:41 UTC 2015
c/src/lib/libbsp/sparc/shared/net/greth.c | 33 ++++++++++++----------------
1 files changed, 14 insertions(+), 19 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c b/c/src/lib/libbsp/sparc/shared/net/greth.c
index ac4ec77..d721586 100644
--- a/c/src/lib/libbsp/sparc/shared/net/greth.c
+++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
@@ -459,8 +459,8 @@ auto_neg_done:
sc->phydev.device = 0;
sc->phydev.rev = 0;
phystatus = read_mii(sc, phyaddr, 1);
- /*Read out PHY info if extended registers are available */
+ /* Read out PHY info if extended registers are available */
if (phystatus & 1) {
tmp1 = read_mii(sc, phyaddr, 2);
tmp2 = read_mii(sc, phyaddr, 3);
@@ -470,23 +470,18 @@ auto_neg_done:
sc->phydev.device = (tmp2 >> 4) & 0x3F;
- /* Force to 10 mbit half duplex if the 10/100 MAC is used with a 1000 PHY*/
- /*check if marvell 88EE1111 PHY. Needs special reset handling */
- if ((phystatus & 1) && (sc->phydev.vendor == 0x005043) && (sc->phydev.device == 0x0C)) {
- if (((sc->gb) && !(sc->gbit_mac)) || !((phyctrl >> 12) & 1)) {
- write_mii(sc, phyaddr, 0, sc->sp << 13);
- write_mii(sc, phyaddr, 0, 0x8000);
- sc->gb = 0;
- sc->sp = 0;
- sc->fd = 0;
- } else {
- sc->gb = 0;
- sc->sp = 0;
- sc->fd = 0;
+ /* Force to 10 mbit half duplex if the 10/100 MAC is used with a 1000 PHY */
+ if (((sc->gb) && !(sc->gbit_mac)) || !((phyctrl >> 12) & 1)) {
+ write_mii(sc, phyaddr, 0, sc->sp << 13);
+ /* check if marvell 88EE1111 PHY. Needs special reset handling */
+ if ((phystatus & 1) && (sc->phydev.vendor == 0x005043) &&
+ (sc->phydev.device == 0x0C))
+ write_mii(sc, phyaddr, 0, 0x8000);
+ sc->gb = 0;
+ sc->sp = 0;
+ sc->fd = 0;
while ((read_mii(sc, phyaddr, 0)) & 0x8000) {}
1.7.0.4
