[PATCH 040/111] PCI-RASTA: set GRPCI1 target cache-line-size to avoid poor performance
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:42 UTC 2015
 .../lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c  |    6 ++++++
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c    |    6 ++++++
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c  |    6 ++++++
 3 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
index 21ca52c..3ee6293 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_adcdac.c
@@ -243,6 +243,12 @@ int gr_rasta_adcdac_hw_init1(struct gr_rasta_adcdac_priv *priv)
 	pci_cfg_r32(priv->pcidev, PCI_COMMAND, &data);
 	pci_cfg_w32(priv->pcidev, PCI_COMMAND, (data|PCI_COMMAND_PARITY));
+	/* Setup cache line size. Default cache line size will result in
+	 * poor performance (256 word fetches), 0xff will set it according
+	 * to the max size of the PCI FIFO.
+	pci_cfg_w8(priv->pcidev, PCI_CACHE_LINE_SIZE, 0xff);
 	/* Scan AMBA Plug&Play */
 	/* AMBA MAP bar0 (in CPU) ==> 0x80000000(remote amba address) */
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
index f96676d..dca0aa0 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_io.c
@@ -260,6 +260,12 @@ int gr_rasta_io_hw_init(struct gr_rasta_io_priv *priv)
 #endif
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
index 7a10083..823cd9e 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
@@ -250,6 +250,12 @@ int gr_rasta_tmtc_hw_init(struct gr_rasta_tmtc_priv *priv)
 #endif
+	pci_cfg_w8(pcidev, PCI_CACHE_LINE_SIZE, 0xff);
1.7.0.4
