[PATCH 041/111] GRPCI2: work-around for rev0 bug by limiting prefetching
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:43 UTC 2015
c/src/lib/libbsp/sparc/shared/pci/grpci2.c | 8 ++++++++
1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index 55a69ef..3891c25 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -187,11 +187,13 @@ struct grpci2_cap_first {
unsigned int ext2ahb_map;
unsigned int io_map;
unsigned int pcibar_size[6];
+ unsigned int ahb_pref;
#define CAP9_CTRL_OFS 0
#define CAP9_BAR_OFS 0x4
#define CAP9_IOMAP_OFS 0x20
#define CAP9_BARSIZE_OFS 0x24
+#define CAP9_AHBPREF_OFS 0x3C
struct grpci2_priv *grpci2priv = NULL;
@@ -224,6 +226,7 @@ struct grpci2_pcibar_cfg grpci2_default_bar_mapping[6] = {
struct grpci2_priv {
struct drvmgr_dev *dev;
struct grpci2_regs *regs;
+ unsigned char ver;
char irq;
char irq_mode; /* IRQ Mode from CAPSTS REG */
char bt_enabled;
@@ -649,6 +652,10 @@ int grpci2_hw_init(struct grpci2_priv *priv)
if (capptr == 0)
return -1;
+ /* Limit the prefetch for GRPCI2 version 0. */
+ if (priv->ver == 0)
+ grpci2_cfg_w32(host, capptr+CAP9_AHBPREF_OFS, 0);
/* Enable/Disable Byte twisting */
grpci2_cfg_r32(host, capptr+CAP9_IOMAP_OFS, &io_map);
io_map = (io_map & ~0x1) | (priv->bt_enabled ? 1 : 0);
@@ -708,6 +715,7 @@ int grpci2_init(struct grpci2_priv *priv)
/* Found PCI core, init private structure */
priv->irq = apb->irq;
+ priv->ver = apb->ver;
priv->regs = (struct grpci2_regs *)apb->start;
priv->bt_enabled = DEFAULT_BT_ENABLED;
priv->irq_mode = (priv->regs->sts_cap & STS_IRQMODE) >> STS_IRQMODE_BIT;
1.7.0.4
