[PATCH 046/111] NGMP PCI: added support for NGMP prototype boards
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:48 UTC 2015
c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c | 13 ++++++++-----
cpukit/libpci/pci/ids_extra.h | 1 +
2 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c b/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
index 0433b9e..5e727ce 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_leon4_n2x.c
@@ -164,6 +164,7 @@ struct drvmgr_drv_ops gr_cpci_leon4_n2x_ops =
struct pci_dev_id_match gr_cpci_leon4_n2x_ids[] =
PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_LEON4_N2X),
+ PCIID_DEVVEND(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_NGMP_PROTO),
PCIID_END_TABLE /* Mark end of table */
@@ -351,15 +352,17 @@ int gr_cpci_leon4_n2x_hw_init1(struct gr_cpci_leon4_n2x_priv *priv)
/* Get extended Interrupt controller IRQ number */
priv->eirq = (priv->irq->mpstat >> 16) & 0xf;
- /* Find first Clock-Gating unit, enable/disable the requested cores */
+ /* Find first Clock-Gating unit, enable/disable the requested cores.
+ * It is optional in order to support FPGA prototypes.
+ priv->cg = NULL;
tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
(OPTIONS_ALL|OPTIONS_APB_SLVS),
VENDOR_GAISLER, GAISLER_CLKGATE,
ambapp_find_by_idx, NULL);
- if ( !tmp ) {
- return -5;
- priv->cg = (struct l4n2x_grcg_regs *)DEV_TO_APB(tmp)->start;
+ if (tmp)
+ priv->cg = (struct l4n2x_grcg_regs *)DEV_TO_APB(tmp)->start;
/* Do reset and enable sequence only if not already enabled */
if (priv->cg && ((enabled = priv->cg->enable) != priv->cg_en_mask)) {
/* First disable already enabled cores */
diff --git a/cpukit/libpci/pci/ids_extra.h b/cpukit/libpci/pci/ids_extra.h
index bce41c2..a7d2bc5 100644
--- a/cpukit/libpci/pci/ids_extra.h
+++ b/cpukit/libpci/pci/ids_extra.h
@@ -18,3 +18,4 @@
#define PCIID_DEVICE_GR_TMTC_1553 0x0198 /* GR-TMTC-1553 */
#define PCIID_DEVICE_GR_RASTA_SPW_RTR 0x0062 /* GR-RASTA-SPW-ROUTER */
#define PCIID_DEVICE_GR_LEON4_N2X 0x0061 /* GR-CPCI-LEON4-N2X */
+#define PCIID_DEVICE_GR_NGMP_PROTO 0x0064 /* GR-NGMP_PROTO */
1.7.0.4
