[PATCH 047/111] APBUART: debug bit was cleared incorrectly
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:38:49 UTC 2015
c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c | 32 ++++++++++----------
1 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index 64d1b15..e0fa64e 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -197,29 +197,29 @@ int apbuart_init1(struct drvmgr_dev *dev)
/* Clear HW regs, leave baudrate register as it is */
priv->regs->status = 0;
- /* leave debug bit, and Transmitter/receiver if this is the debug UART.
- * With old APBUARTs debug is enabled by setting LB and FL, since LB is
- * not reset we can not trust is, however since FL is reset we guess
- * that we are debugging old UART if both FL and LB is already set.
+ /* leave Transmitter/receiver if this is the RTEMS debug UART (assume
+ * it has been setup by boot loader).
+ db = 0;
#ifdef LEON3
if (priv->regs == dbg_uart) {
- db = priv->regs->ctrl & (LEON_REG_UART_CTRL_DB |
- LEON_REG_UART_CTRL_RE |
+ db = priv->regs->ctrl & (LEON_REG_UART_CTRL_RE |
LEON_REG_UART_CTRL_TE |
- LEON_REG_UART_CTRL_FL |
- LEON_REG_UART_CTRL_LB |
LEON_REG_UART_CTRL_PE |
LEON_REG_UART_CTRL_PS);
- } else
#endif
- if (priv->regs->ctrl & (LEON_REG_UART_CTRL_FL |
- LEON_REG_UART_CTRL_LB))
- db = priv->regs->ctrl & (LEON_REG_UART_CTRL_FL |
- LEON_REG_UART_CTRL_LB);
- else
- db = priv->regs->ctrl & LEON_REG_UART_CTRL_DB;
+ /* Let UART debug tunnelling be untouched if Flow-control is set.
+ * With old APBUARTs debug is enabled by setting LB and FL, since LB or
+ * DB are not reset we can not trust them. However since FL is reset we
+ * guess that we are debugging if FL is already set, the debugger set
+ * either LB or DB depending on UART capabilities.
+ if (priv->regs->ctrl & LEON_REG_UART_CTRL_FL) {
+ db |= priv->regs->ctrl & (LEON_REG_UART_CTRL_DB |
+ LEON_REG_UART_CTRL_LB | LEON_REG_UART_CTRL_FL);
priv->regs->ctrl = db;
1.7.0.4
