[PATCH 048/111] LEON PCI: host bridge driver support for probing dev0=AD16
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:38:50 UTC 2015
Before the LIBPCI didn't probe device0 (AD16), the host bridge
drivers used bus=dev=func=0 to internally probe the host bridge's
target interface. Now that LIBPCI uses bus=dev=func=0 to access
device0, bus=0xff is introduced internally to identify the
host bridge target configuration space.
 c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c |    8 +----
 c/src/lib/libbsp/sparc/shared/pci/grpci.c    |   30 ++++++++++++++++++++---
 c/src/lib/libbsp/sparc/shared/pci/grpci2.c   |   13 ++++++++--
 c/src/lib/libbsp/sparc/shared/pci/pcif.c     |   33 ++++++++++++++++++++++----
 4 files changed, 66 insertions(+), 18 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
index 2387cc0..76b9c4d 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
@@ -161,7 +161,6 @@ struct at697pci_priv {
 	struct at697pci_regs	*regs;
 	int			minor;
-	uint32_t		devVend; /* PCI Device and Vendor ID of Host */
 	uint32_t		bar1_pci_adr;
 	uint32_t		bar2_pci_adr;
@@ -228,7 +227,7 @@ int at697pci_cfg_r32(pci_dev_t dev, int offset, uint32_t *val)
 	int func = PCI_DEV_FUNC(dev);
 	int retval;
-	if (slot > 21 || (offset & ~0xfc)) {
+	if (slot > 15 || (offset & ~0xfc)) {
 		*val = 0xffffffff;
 		return PCISTS_EINVAL;
@@ -239,7 +238,7 @@ int at697pci_cfg_r32(pci_dev_t dev, int offset, uint32_t *val)
 	if ( bus == 0 ) {
 		/* PCI Access - TYPE 0 */
-		address = (1<<(11+slot)) | (func << 8) | offset;
+		address = (1<<(16+slot)) | (func << 8) | offset;
 	} else {
 		/* PCI access - TYPE 1 */
 		address = ((bus & 0xff) << 16) | ((slot & 0x1f) << 11) |
@@ -462,9 +461,6 @@ int at697pci_hw_init(struct at697pci_priv *priv)
 	/* Set Inititator configuration so that AHB slave accesses generate memory read/write commands */
 	regs->pciic = 0x41;
-	/* Get the AT697PCI Host PCI ID */
-	at697pci_cfg_r32(host, PCI_VENDOR_ID, &priv->devVend);
 	return 0;
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci.c b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
index eb188bb..63e08ad 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci.c
@@ -85,6 +85,8 @@ struct grpci_regs {
 	volatile unsigned int irq;
+#define HOST_TGT PCI_DEV(0xff, 0, 0)
 struct grpci_priv *grpcipriv = NULL;
 static int grpci_minor = 0;
 static unsigned int *pcidma = (unsigned int *)DMAPCI_ADDR;
@@ -168,18 +170,28 @@ int grpci_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 	struct grpci_priv *priv = grpcipriv;
 	volatile uint32_t *pci_conf;
-	unsigned int devfn = PCI_DEV_DEVFUNC(dev);
+	uint32_t devfn;
 	int retval;
 	int bus = PCI_DEV_BUS(dev);
 	if (ofs & 3)
-	if (PCI_DEV_SLOT(dev) > 21) {
+	if (PCI_DEV_SLOT(dev) > 15) {
 		*val = 0xffffffff;
 		return PCISTS_OK;
+	/* GRPCI can access "non-standard" devices on bus0 (on AD11.AD16),
+	 * but we skip them.
+	if (dev == HOST_TGT)
+		bus = devfn = 0;
+	if (bus == 0)
+		devfn = PCI_DEV_DEVFUNC(dev) + PCI_DEV(0, 6, 0);
+	else
+		devfn = PCI_DEV_DEVFUNC(dev);
 	/* Select bus */
 	priv->regs->cfg_stat = (priv->regs->cfg_stat & ~(0xf<<23)) | (bus<<23);
@@ -240,9 +252,19 @@ int grpci_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
 	if (ofs & 0x3)
 		return PCISTS_MSTABRT;
+		bus = devfn = 0;
+	if (bus == 0)
+	else
 	/* Select bus */
@@ -409,7 +431,7 @@ int grpci_hw_init(struct grpci_priv *priv)
 	volatile unsigned int *mbar0, *page0;
 	uint32_t data, addr, mbar0size;
-	pci_dev_t host = PCI_DEV(0, 0, 0);
+	pci_dev_t host = HOST_TGT;
 	mbar0 = (volatile unsigned int *)priv->pci_area;
diff --git a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
index 5886336..29af4ab 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/grpci2.c
@@ -196,6 +196,9 @@ struct grpci2_cap_first {
 #define CAP9_BARSIZE_OFS 0x24
 #define CAP9_AHBPREF_OFS 0x3C
+/* Used internally for accessing the PCI bridge's configuration space itself */
 struct grpci2_priv *grpci2priv = NULL;
 /* PCI Interrupt assignment. Connects an PCI interrupt pin (INTA#..INTD#)
@@ -310,7 +313,9 @@ int grpci2_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 	/* GRPCI2 can access "non-standard" devices on bus0 (on AD11.AD16),
 	 * we skip them.
-	if (bus == 0 && PCI_DEV_SLOT(dev) != 0)
+		bus = devfn = 0;
+	else if (bus == 0)
 	else
@@ -398,7 +403,9 @@ int grpci2_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
 	 * we skip them.
+		bus = devfn = 0;
+	if (bus == 0)
 	else
@@ -627,7 +634,7 @@ int grpci2_hw_init(struct grpci2_priv *priv)
 	int i;
 	uint8_t capptr;
 	uint32_t data, io_map, ahbadr, pciadr, size;
 	struct grpci2_pcibar_cfg *barcfg = priv->barcfg;
 	/* Reset any earlier setup */
diff --git a/c/src/lib/libbsp/sparc/shared/pci/pcif.c b/c/src/lib/libbsp/sparc/shared/pci/pcif.c
index c69282d..2dc46a8 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/pcif.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/pcif.c
@@ -73,6 +73,9 @@ struct pcif_regs {
 	volatile unsigned int maps[(0x80-0x40)/4];   /* 0x40-0x80*/
 struct pcif_priv *pcifpriv = NULL;
 static int pcif_minor = 0;
@@ -154,18 +157,28 @@ int pcif_cfg_r32(pci_dev_t dev, int ofs, uint32_t *val)
 	struct pcif_priv *priv = pcifpriv;
+	uint32_t devfn;
 	int retval;
 	if (ofs & 3)
 		*val = 0xffffffff;
 		return PCISTS_OK;
+	/* PCIF can access "non-standard" devices on bus0 (on AD11.AD16),
+		bus = devfn = 0;
+	if (bus == 0)
+	else
 	/* Select bus */
 	priv->regs->bus = bus << 16;
@@ -214,15 +227,25 @@ int pcif_cfg_w32(pci_dev_t dev, int ofs, uint32_t val)
-	uint32_t devfn = PCI_DEV_DEVFUNC(dev);
+	uint32_t devfn;
 	if (ofs & ~0xfc)
+		bus = devfn = 0;
+	if (bus == 0)
+	else
 	/* Select bus */
@@ -332,7 +355,7 @@ int pcif_hw_init(struct pcif_priv *priv)
 	struct pcif_regs *regs;
 	uint32_t data, size;
 	int mst;
 	regs = priv->regs;
1.7.0.4
