[PATCH 077/111] AT697PCI: fix build warnings
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:39:19 UTC 2015
 c/src/lib/libbsp/sparc/leon2/Makefile.am         |    1 +
 c/src/lib/libbsp/sparc/leon2/include/at697_pci.h |   26 ++++++++++++++++++++++
 c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c     |   24 ++++++++++----------
 c/src/lib/libbsp/sparc/leon2/preinstall.am       |    4 +++
 4 files changed, 43 insertions(+), 12 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/leon2/include/at697_pci.h
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 7f1a19f..3f2cd9f 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -101,6 +101,7 @@ libbsp_a_SOURCES += ../../sparc/shared/timer/tlib.c
 include_HEADERS += ../../sparc/shared/include/grpci.h
 include_HEADERS += ../../sparc/shared/include/grpci2.h
 include_HEADERS += ../../sparc/shared/include/pcif.h
+include_HEADERS += include/at697_pci.h
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci2.c
 libbsp_a_SOURCES += ../../sparc/shared/pci/grpci.c
 libbsp_a_SOURCES += ../../sparc/shared/pci/pcif.c
diff --git a/c/src/lib/libbsp/sparc/leon2/include/at697_pci.h b/c/src/lib/libbsp/sparc/leon2/include/at697_pci.h
new file mode 100644
index 0000000..d114db7
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon2/include/at697_pci.h
@@ -0,0 +1,26 @@
+/*  AT697 PCI host bridge driver
+ *  COPYRIGHT (c) 2015.
+ *  Cobham Gaisler.
+ *  The license and distribution terms for this file may be
+ *  found in found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef __AT697PCI_H__
+#define __AT697PCI_H__
+#ifdef __cplusplus
+extern "C" {
+#endif
+/* Register AT697 PCI host bridge driver to Driver Manager */
+void at697pci_register_drv(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
index 423fada..bfa7f13 100644
--- a/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
+++ b/c/src/lib/libbsp/sparc/leon2/pci/at697_pci.c
@@ -43,6 +43,7 @@
 #include <drvmgr/pci_bus.h>
 #include <drvmgr/leon2_amba_bus.h>
+#include <at697_pci.h>
 #include <leon.h>
 /* Configuration options */
@@ -217,7 +218,7 @@ void at697pci_register_drv(void)
  *  AT697 pci controller to be able access all slots
-int at697pci_cfg_r32(pci_dev_t dev, int offset, uint32_t *val)
+static int at697pci_cfg_r32(pci_dev_t dev, int offset, uint32_t *val)
 	struct at697pci_regs *regs;
 	volatile unsigned int data = 0;
@@ -268,7 +269,7 @@ int at697pci_cfg_r32(pci_dev_t dev, int offset, uint32_t *val)
 	return retval;
-int at697pci_cfg_r16(pci_dev_t dev, int ofs, uint16_t *val)
+static int at697pci_cfg_r16(pci_dev_t dev, int ofs, uint16_t *val)
 	uint32_t v;
 	int retval;
@@ -282,7 +283,7 @@ int at697pci_cfg_r16(pci_dev_t dev, int ofs, uint16_t *val)
 	return retval;
-int at697pci_cfg_r8(pci_dev_t dev, int ofs, uint8_t *val)
+static int at697pci_cfg_r8(pci_dev_t dev, int ofs, uint8_t *val)
 	uint32_t v;
 	int retval;
@@ -294,7 +295,7 @@ int at697pci_cfg_r8(pci_dev_t dev, int ofs, uint8_t *val)
 	return retval;
-int at697pci_cfg_w32(pci_dev_t dev, int offset, uint32_t val)
+static int at697pci_cfg_w32(pci_dev_t dev, int offset, uint32_t val)
 	volatile unsigned int tmp_val = val;
@@ -340,7 +341,7 @@ int at697pci_cfg_w32(pci_dev_t dev, int offset, uint32_t val)
 	return retval;
-int at697pci_cfg_w16(pci_dev_t dev, int ofs, uint16_t val)
+static int at697pci_cfg_w16(pci_dev_t dev, int ofs, uint16_t val)
 	uint32_t v;
 	int retval;
@@ -357,7 +358,7 @@ int at697pci_cfg_w16(pci_dev_t dev, int ofs, uint16_t val)
 	return at697pci_cfg_w32(dev, ofs & ~0x3, v);
-int at697pci_cfg_w8(pci_dev_t dev, int ofs, uint8_t val)
+static int at697pci_cfg_w8(pci_dev_t dev, int ofs, uint8_t val)
 	uint32_t v;
@@ -377,7 +378,7 @@ int at697pci_cfg_w8(pci_dev_t dev, int ofs, uint8_t val)
  * Returns the "system IRQ" for the PCI INTA#..INTD# pin in irq_pin. Returns
  * 0xff if not assigned.
-uint8_t at697pci_bus0_irq_map(pci_dev_t dev, int irq_pin)
+static uint8_t at697pci_bus0_irq_map(pci_dev_t dev, int irq_pin)
 	uint8_t sysIrqNr = 0; /* not assigned */
 	int irq_group;
@@ -392,7 +393,7 @@ uint8_t at697pci_bus0_irq_map(pci_dev_t dev, int irq_pin)
 	return sysIrqNr;
-int at697pci_translate(uint32_t *address, int type, int dir)
+static int at697pci_translate(uint32_t *address, int type, int dir)
 	/* No address translation implmented at this point */
 	return 0;
@@ -401,7 +402,7 @@ int at697pci_translate(uint32_t *address, int type, int dir)
 extern struct pci_memreg_ops pci_memreg_sparc_be_ops;
 /* AT697 Big-Endian PCI access routines */
-struct pci_access_drv at697pci_access_drv = {
+static struct pci_access_drv at697pci_access_drv = {
 	.cfg =
 		at697pci_cfg_r8,
@@ -428,11 +429,10 @@ struct pci_access_drv at697pci_access_drv = {
 /* Initializes the AT697PCI core hardware
-int at697pci_hw_init(struct at697pci_priv *priv)
+static int at697pci_hw_init(struct at697pci_priv *priv)
 	struct at697pci_regs *regs = priv->regs;
 	unsigned short vendor = regs->pciid1 >> 16;
-	pci_dev_t host = PCI_DEV(0, 0, 0);
 	/* Must match ATMEL or ESA ID */
 	if ( !((vendor == 0x1202) || (vendor == 0x1E0F)) ) {
@@ -477,7 +477,7 @@ int at697pci_hw_init(struct at697pci_priv *priv)
  *  0             Successful initalization
  *  -1            Error during initialization.
-int at697pci_init(struct at697pci_priv *priv)
+static int at697pci_init(struct at697pci_priv *priv)
 	int pin;
 	union drvmgr_key_value *value;
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index 8ea53e0..cf5515b 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -133,6 +133,10 @@ $(PROJECT_INCLUDE)/pcif.h: ../../sparc/shared/include/pcif.h $(PROJECT_INCLUDE)/
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pcif.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/pcif.h
+$(PROJECT_INCLUDE)/at697_pci.h: include/at697_pci.h $(PROJECT_INCLUDE)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/at697_pci.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/at697_pci.h
 $(PROJECT_INCLUDE)/gr_701.h: ../../sparc/shared/include/gr_701.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/gr_701.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/gr_701.h
1.7.0.4
