[PATCH 078/111] GR1553B: fixed build warnings
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:39:20 UTC 2015
 c/src/lib/libbsp/sparc/shared/1553/gr1553b.c    |   16 +++---
 c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c   |    4 +-
 c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c   |    4 +-
 c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c   |   28 ++++++----
 c/src/lib/libbsp/sparc/shared/include/gr1553b.h |   68 ++++++++++++-----------
 5 files changed, 64 insertions(+), 56 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c b/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
index 26d7b40..c715e4f 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/gr1553b.c
@@ -39,15 +39,15 @@ struct gr1553_device_feature {
 /* Device lists */
-struct gr1553_device_feature *gr1553_bm_root = NULL;
-struct gr1553_device_feature *gr1553_rt_root = NULL;
-struct gr1553_device_feature *gr1553_bc_root = NULL;
+static struct gr1553_device_feature *gr1553_bm_root = NULL;
+static struct gr1553_device_feature *gr1553_rt_root = NULL;
+static struct gr1553_device_feature *gr1553_bc_root = NULL;
 /* Driver registered */
-int gr1553_driver_registerd = 0;
+static int gr1553_driver_registerd = 0;
 /* Add 'feat' to linked list pointed to by 'root'. A minor is also assigned. */
-void gr1553_list_add
+static void gr1553_list_add
 	struct gr1553_device_feature **root,
 	struct gr1553_device_feature *feat
@@ -79,7 +79,7 @@ retry_new_minor:
 	curr->next = feat;
-struct gr1553_device_feature *gr1553_list_find
+static struct gr1553_device_feature *gr1553_list_find
 	struct gr1553_device_feature *root,
 	int minor
@@ -179,7 +179,7 @@ void gr1553_bm_close(struct drvmgr_dev **dev)
 	d->alloc &= ~ALLOC_BM;
-int gr1553_init2(struct drvmgr_dev *dev)
+static int gr1553_init2(struct drvmgr_dev *dev)
 	struct amba_dev_info *ambadev;
 	struct ambapp_core *pnpinfo;
@@ -209,7 +209,7 @@ int gr1553_init2(struct drvmgr_dev *dev)
 /* Register the different functionalities that the
  * core supports.
-int gr1553_init3(struct drvmgr_dev *dev)
+static int gr1553_init3(struct drvmgr_dev *dev)
diff --git a/c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c b/c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c
index 4133200..636d39c 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/gr1553bc.c
@@ -615,7 +615,7 @@ union gr1553bc_bd *gr1553bc_slot_bd
 	return &minor->bds[slot_no];
-int gr1553bc_minor_first_avail(struct gr1553bc_minor *minor)
+static int gr1553bc_minor_first_avail(struct gr1553bc_minor *minor)
 	int slot_num;
 	uint32_t alloc;
@@ -1233,7 +1233,7 @@ void gr1553bc_register(void)
 	gr1553_register();
-void gr1553bc_isr_std(union gr1553bc_bd *bd, void *data)
+static void gr1553bc_isr_std(union gr1553bc_bd *bd, void *data)
 	/* Do nothing */
diff --git a/c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c b/c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c
index 1ce731e..746899f 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/gr1553bm.c
@@ -17,10 +17,10 @@
 #include <gr1553bm.h>
-#define GR1553BM_WRITE_MEM(adr, val) *(volatile uint32_t *)(adr) = (val)
+#define GR1553BM_WRITE_MEM(adr, val) *(volatile uint32_t *)(adr) = (uint32_t)(val)
 #define GR1553BM_READ_MEM(adr) (*(volatile uint32_t *)(adr))
-#define GR1553BM_WRITE_REG(adr, val) *(volatile uint32_t *)(adr) = (val)
+#define GR1553BM_WRITE_REG(adr, val) *(volatile uint32_t *)(adr) = (uint32_t)(val)
 #define GR1553BM_READ_REG(adr) (*(volatile uint32_t *)(adr))
 #ifndef IRQ_GLOBAL_PREPARE
diff --git a/c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c b/c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c
index ff05ce5..f1d5fdd 100644
--- a/c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c
+++ b/c/src/lib/libbsp/sparc/shared/1553/gr1553rt.c
@@ -19,10 +19,10 @@
 #include <drvmgr/drvmgr.h>
 #include <drvmgr/ambapp_bus.h>
-#define GR1553RT_WRITE_MEM(adr, val) *(volatile uint32_t *)(adr) = (val)
+#define GR1553RT_WRITE_MEM(adr, val) *(volatile uint32_t *)(adr) = (uint32_t)(val)
 #define GR1553RT_READ_MEM(adr) (*(volatile uint32_t *)(adr))
-#define GR1553RT_WRITE_REG(adr, val) *(volatile uint32_t *)(adr) = (val)
+#define GR1553RT_WRITE_REG(adr, val) *(volatile uint32_t *)(adr) = (uint32_t)(val)
 #define GR1553RT_READ_REG(adr) (*(volatile uint32_t *)(adr))
@@ -129,14 +129,14 @@ struct gr1553rt_priv {
 void gr1553rt_sw_init(struct gr1553rt_priv *priv);
 void gr1553rt_sw_free(struct gr1553rt_priv *priv);
-int gr1553rt_sw_alloc(struct gr1553rt_priv *priv);
+void gr1553rt_isr(void *data);
 /* Assign and ID to the list. An LIST ID is needed before scheduling list
  * on an RT subaddress.
  * Only 64 lists can be registered at a time on the same device.
-int gr1553rt_list_reg(struct gr1553rt_list *list)
+static int gr1553rt_list_reg(struct gr1553rt_list *list)
 	struct gr1553rt_priv *priv = list->rt;
 	int i;
@@ -156,14 +156,16 @@ int gr1553rt_list_reg(struct gr1553rt_list *list)
 	return -1;
+#if 0 /* unused for now */
 /* Unregister List from device */
-void gr1553rt_list_unreg(struct gr1553rt_list *list)
+static void gr1553rt_list_unreg(struct gr1553rt_list *list)
 	priv->lists[list->listid] = NULL;
 	list->listid = -1;
+#endif
 static int gr1553rt_bdid(void *rt, struct gr1553rt_sw_bd *bd)
@@ -178,7 +180,7 @@ static int gr1553rt_bdid(void *rt, struct gr1553rt_sw_bd *bd)
 	return index;
-void gr1553rt_bd_alloc_init(void *rt, int count)
+static void gr1553rt_bd_alloc_init(void *rt, int count)
 	struct gr1553rt_priv *priv = rt;
 	int i;
@@ -192,7 +194,7 @@ void gr1553rt_bd_alloc_init(void *rt, int count)
 /* Allocate a Chain of descriptors */
-int gr1553rt_bd_alloc(void *rt, struct gr1553rt_sw_bd **bd, int cnt)
+static int gr1553rt_bd_alloc(void *rt, struct gr1553rt_sw_bd **bd, int cnt)
 	struct gr1553rt_sw_bd *curr;
@@ -222,7 +224,8 @@ int gr1553rt_bd_alloc(void *rt, struct gr1553rt_sw_bd **bd, int cnt)
 	return 0;
-void gr1553rt_bd_free(void *rt, struct gr1553rt_sw_bd *bd)
+static void gr1553rt_bd_free(void *rt, struct gr1553rt_sw_bd *bd)
 	unsigned short index;
@@ -235,6 +238,7 @@ void gr1553rt_bd_free(void *rt, struct gr1553rt_sw_bd *bd)
 	priv->swbd_free = index;
 	priv->swbd_free_cnt++;
+#endif
 int gr1553rt_list_init
@@ -816,7 +820,7 @@ void gr1553rt_sw_free(struct gr1553rt_priv *priv)
 /* Free dynamically allocated buffers, if any */
+static int gr1553rt_sw_alloc(struct gr1553rt_priv *priv)
 	int size;
@@ -863,7 +867,8 @@ int gr1553rt_sw_alloc(struct gr1553rt_priv *priv)
 	size = priv->bds_cnt * sizeof(struct gr1553rt_bd);
 	if ((unsigned int)priv->cfg.bd_buffer & 1) {
 		/* Translate Address from HARDWARE (REMOTE) to CPU-LOCAL */
-		priv->bds_hw = (unsigned int)priv->cfg.bd_buffer & ~0x1;
+		priv->bds_hw = (struct gr1553rt_bd *)
+			((unsigned int)priv->cfg.bd_buffer & ~0x1);
 		priv->bd_buffer = priv->cfg.bd_buffer;
 		drvmgr_translate_check(
 			*priv->pdev,
@@ -906,7 +911,8 @@ int gr1553rt_sw_alloc(struct gr1553rt_priv *priv)
 	/* Allocate Sub address table */
 	if ((unsigned int)priv->cfg.satab_buffer & 1) {
-		priv->sas_hw = (unsigned int)priv->cfg.satab_buffer & ~0x1;
+		priv->sas_hw = (struct gr1553rt_sa *)
+			((unsigned int)priv->cfg.satab_buffer & ~0x1);
 		priv->satab_buffer = priv->cfg.satab_buffer;
 			*priv->pdev,
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr1553b.h b/c/src/lib/libbsp/sparc/shared/include/gr1553b.h
index 33a79bf..12a4704 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr1553b.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr1553b.h
@@ -23,6 +23,8 @@
 #ifndef __GR1553B_H__
 #define __GR1553B_H__
+#include <stdint.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
@@ -30,57 +32,57 @@ extern "C" {
 /* The GR1553B registers */
 struct gr1553b_regs {
 	/* Common Registers */
-	volatile unsigned int irq; /* 0x00 IRQ register */
-	volatile unsigned int imask;	/* 0x04 IRQ enable mask */
+	volatile uint32_t irq;		/* 0x00 IRQ register */
+	volatile uint32_t imask;	/* 0x04 IRQ enable mask */
 	int unused0[(0x10-0x08)/4];
-	volatile unsigned int hwcfg;	/* 0x10 HW config register */
+	volatile uint32_t hwcfg;	/* 0x10 HW config register */
 	int unused1[(0x40-0x14)/4];	/* Padding */
 	/* BC Registers */
-	volatile unsigned int bc_stat;	/* 0x40 BC status */
-	volatile unsigned int bc_ctrl;	/* 0x44 BC Action register */
-	volatile unsigned int bc_bd;	/* 0x48 BC transfer list pointer */
-	volatile unsigned int bc_abd;	/* 0x4c BC async list pointer */
-	volatile unsigned int bc_timer;	/* 0x50 BC timer register */
-	volatile unsigned int bc_wake;	/* 0x54 BC wakeup control register */
-	volatile unsigned int bc_irqptr;/* 0x58 BC transfer IRQ pointer */
-	volatile unsigned int bc_busmsk;/* 0x5C BC per-RT bus mask register */
+	volatile uint32_t bc_stat;	/* 0x40 BC status */
+	volatile uint32_t bc_ctrl;	/* 0x44 BC Action register */
+	volatile uint32_t bc_bd;	/* 0x48 BC transfer list pointer */
+	volatile uint32_t bc_abd;	/* 0x4c BC async list pointer */
+	volatile uint32_t bc_timer;	/* 0x50 BC timer register */
+	volatile uint32_t bc_wake;	/* 0x54 BC wakeup control register */
+	volatile uint32_t bc_irqptr;	/* 0x58 BC transfer IRQ pointer */
+	volatile uint32_t bc_busmsk;	/* 0x5C BC per-RT bus mask register */
 	int unused2[(0x68-0x60)/4];	/* Padding */
-	volatile unsigned int bc_slot;	/* 0x48 BC Current BD pointer */
-	volatile unsigned int bc_aslot;	/* 0x4c BC Current async BD pointer */
+	volatile uint32_t bc_slot;	/* 0x48 BC Current BD pointer */
+	volatile uint32_t bc_aslot;	/* 0x4c BC Current async BD pointer */
 	int unused3[(0x80-0x70)/4];	/* Padding */
 	/* RT Registers */
-	volatile unsigned int rt_stat;	/* 0x80 RT status */
-	volatile unsigned int rt_cfg;	/* 0x84 RT config register */
-	volatile unsigned int rt_stat2;	/* 0x88 RT bus status bits */
-	volatile unsigned int rt_statw;	/* 0x8c RT status words */
-	volatile unsigned int rt_sync;	/* 0x90 RT bus synchronize */
-	volatile unsigned int rt_tab;	/* 0x94 RT subaddress table base */
-	volatile unsigned int rt_mcctrl;/* 0x98 RT valid mode code mask */
+	volatile uint32_t rt_stat;	/* 0x80 RT status */
+	volatile uint32_t rt_cfg;	/* 0x84 RT config register */
+	volatile uint32_t rt_stat2;	/* 0x88 RT bus status bits */
+	volatile uint32_t rt_statw;	/* 0x8c RT status words */
+	volatile uint32_t rt_sync;	/* 0x90 RT bus synchronize */
+	volatile uint32_t rt_tab;	/* 0x94 RT subaddress table base */
+	volatile uint32_t rt_mcctrl;	/* 0x98 RT valid mode code mask */
 	int unused4[(0xa4-0x9c)/4];
-	volatile unsigned int rt_ttag;	/* 0xa4 RT time tag register */
+	volatile uint32_t rt_ttag;	/* 0xa4 RT time tag register */
 	int unused5;			/* 0xa8 RESERVED */
-	volatile unsigned int rt_evsz;	/* 0xac RT event log end pointer */
-	volatile unsigned int rt_evlog;	/* 0xb0 RT event log position */
-	volatile unsigned int rt_evirq;	/* 0xb4 RT event log IRQ position */
+	volatile uint32_t rt_evsz;	/* 0xac RT event log end pointer */
+	volatile uint32_t rt_evlog;	/* 0xb0 RT event log position */
+	volatile uint32_t rt_evirq;	/* 0xb4 RT event log IRQ position */
 	int unused6[(0xc0-0xb8)/4];	/* Padding */
 	/* BM Registers */
-	volatile unsigned int bm_stat;	/* 0xc0 BM status */
-	volatile unsigned int bm_ctrl;	/* 0xc4 BM control register */
-	volatile unsigned int bm_adr;	/* 0xc8 BM address filter */
-	volatile unsigned int bm_subadr;/* 0xcc BM subaddress filter */
-	volatile unsigned int bm_mc;	/* 0xd0 BM mode code filter */
-	volatile unsigned int bm_start;	/* 0xd4 BM log start address */
-	volatile unsigned int bm_end;	/* 0xd8 BM log size/alignment mask */
-	volatile unsigned int bm_pos;	/* 0xdc BM log position */
-	volatile unsigned int bm_ttag;	/* 0xe0 BM time tag register */
+	volatile uint32_t bm_stat;	/* 0xc0 BM status */
+	volatile uint32_t bm_ctrl;	/* 0xc4 BM control register */
+	volatile uint32_t bm_adr;	/* 0xc8 BM address filter */
+	volatile uint32_t bm_subadr;	/* 0xcc BM subaddress filter */
+	volatile uint32_t bm_mc;	/* 0xd0 BM mode code filter */
+	volatile uint32_t bm_start;	/* 0xd4 BM log start address */
+	volatile uint32_t bm_end;	/* 0xd8 BM log size/alignment mask */
+	volatile uint32_t bm_pos;	/* 0xdc BM log position */
+	volatile uint32_t bm_ttag;	/* 0xe0 BM time tag register */
 #define GR1553BC_KEY 0x15520000
1.7.0.4
