[PATCH 092/111] GRSPW router: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:34 UTC 2015
.../lib/libbsp/sparc/shared/include/grspw_router.h | 3 ++
c/src/lib/libbsp/sparc/shared/spw/grspw_router.c | 38 +++++++++++++-------
2 files changed, 28 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/grspw_router.h b/c/src/lib/libbsp/sparc/shared/include/grspw_router.h
index c3b186f..2b57a2b 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grspw_router.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grspw_router.h
@@ -101,4 +101,7 @@ struct router_port {
/* Get Current Time-Code Register */
#define GRSPWR_IOCTL_TC_GET 0x0c /* OUT: unsigned int */
+/* Register GRSPW Router driver to Driver Manager */
+void router_register_drv (void);
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw_router.c b/c/src/lib/libbsp/sparc/shared/spw/grspw_router.c
index f33ad37..b0d0c61 100644
--- a/c/src/lib/libbsp/sparc/shared/spw/grspw_router.c
+++ b/c/src/lib/libbsp/sparc/shared/spw/grspw_router.c
@@ -88,7 +88,9 @@ static rtems_device_driver router_control(
NULL, \
router_control }
-void router_hwinfo(struct router_priv *priv, struct router_hw_info *hwinfo);
+static void router_hwinfo(
+ struct router_priv *priv,
+ struct router_hw_info *hwinfo);
static rtems_driver_address_table router_driver = ROUTER_DRIVER_TABLE_ENTRY;
static int router_driver_io_registered = 0;
@@ -277,7 +279,9 @@ static rtems_device_driver router_close(
return RTEMS_SUCCESSFUL;
unsigned int tmp;
@@ -295,7 +299,9 @@ void router_hwinfo(struct router_priv *priv, struct router_hw_info *hwinfo)
hwinfo->iid = (tmp >> 0) & 0xff;
-int router_config_set(struct router_priv *priv, struct router_config *cfg)
+static int router_config_set(
+ struct router_config *cfg)
int i;
@@ -333,7 +339,9 @@ int router_config_set(struct router_priv *priv, struct router_config *cfg)
return 0;
-int router_config_read(struct router_priv *priv, struct router_config *cfg)
+static int router_config_read(
int i;
@@ -347,7 +355,9 @@ int router_config_read(struct router_priv *priv, struct router_config *cfg)
return 0;
-int router_routes_set(struct router_priv *priv, struct router_routes *routes)
+static int router_routes_set(
+ struct router_routes *routes)
int i;
for (i=0; i<224; i++)
@@ -355,7 +365,9 @@ int router_routes_set(struct router_priv *priv, struct router_routes *routes)
return 0;
-int router_routes_read(struct router_priv *priv, struct router_routes *routes)
+static int router_routes_read(
int i;
@@ -363,7 +375,7 @@ int router_routes_read(struct router_priv *priv, struct router_routes *routes)
return 0;
-int router_ps_set(struct router_priv *priv, struct router_ps *ps)
+static int router_ps_set(struct router_priv *priv, struct router_ps *ps)
int i;
unsigned int *p = &ps->ps[0];
@@ -372,7 +384,7 @@ int router_ps_set(struct router_priv *priv, struct router_ps *ps)
return 0;
-int router_ps_read(struct router_priv *priv, struct router_ps *ps)
+static int router_ps_read(struct router_priv *priv, struct router_ps *ps)
int i;
@@ -381,13 +393,13 @@ int router_ps_read(struct router_priv *priv, struct router_ps *ps)
return 0;
-int router_we_set(struct router_priv *priv, int we)
+static int router_we_set(struct router_priv *priv, int we)
REG_WRITE(&priv->regs->cfgwe, we & 0x1);
return 0;
-int router_port_ctrl(struct router_priv *priv, struct router_port *port)
+static int router_port_ctrl(struct router_priv *priv, struct router_port *port)
unsigned int ctrl, sts;
@@ -415,19 +427,19 @@ int router_port_ctrl(struct router_priv *priv, struct router_port *port)
return 0;
-int router_cfgsts_set(struct router_priv *priv, unsigned int cfgsts)
+static int router_cfgsts_set(struct router_priv *priv, unsigned int cfgsts)
REG_WRITE(&priv->regs->cfgsts, cfgsts);
return 0;
-int router_cfgsts_read(struct router_priv *priv, unsigned int *cfgsts)
+static int router_cfgsts_read(struct router_priv *priv, unsigned int *cfgsts)
*cfgsts = REG_READ(&priv->regs->cfgsts);
return 0;
-int router_tc_read(struct router_priv *priv, unsigned int *tc)
+static int router_tc_read(struct router_priv *priv, unsigned int *tc)
*tc = REG_READ(&priv->regs->timecode);
return 0;
1.7.0.4
