[PATCH 093/111] SPICTRL: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:35 UTC 2015
c/src/lib/libbsp/sparc/shared/spi/spictrl.c | 29 +++++++++++++++++---------
1 files changed, 19 insertions(+), 10 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/spi/spictrl.c b/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
index b149a95..dab478d 100644
--- a/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
+++ b/c/src/lib/libbsp/sparc/shared/spi/spictrl.c
@@ -297,10 +297,10 @@ STATIC rtems_status_code spictrl_libi2c_send_addr(rtems_libi2c_bus_t *bushdl,
/* Set as high frequency of SCK as possible but not higher than
* requested frequency (freq).
-int spictrl_set_freq(struct spictrl_priv *priv, unsigned int freq)
+static int spictrl_set_freq(struct spictrl_priv *priv, unsigned int freq)
unsigned int core_freq_hz = priv->core_freq_hz;
- unsigned int lowest_freq_possible, result;
+ unsigned int lowest_freq_possible;
unsigned int div, div16, pm, fact;
/* Lowest possible when DIV16 is set and PM is 0xf */
@@ -338,14 +338,15 @@ int spictrl_set_freq(struct spictrl_priv *priv, unsigned int freq)
(pm << SPICTRL_MODE_PM_BIT) | (div16 << SPICTRL_MODE_DIV16_BIT) |
(fact << SPICTRL_MODE_FACT_BIT);
- result = core_freq_hz / (2 * (fact ? 1 : 2) * (div) * (div16 ? 16 : 1) );
- DBG("SPICTRL: Effective bit rate %u (requested %u), PM: %x, FACT: %d, div16: %x, core_freq: %u\n", result, freq, pm, fact, div16, core_freq_hz);
+ DBG("SPICTRL: Effective bit rate %u (requested %u), PM: %x, FACT: %d, div16: %x, core_freq: %u\n",
+ core_freq_hz / (2 * (fact ? 1 : 2) * (div) * (div16 ? 16 : 1)),
+ freq, pm, fact, div16, core_freq_hz);
return 0;
/* Start Automated Periodic transfers, after this call read can be done */
-int spictrl_start_periodic(struct spictrl_priv *priv)
+static int spictrl_start_periodic(struct spictrl_priv *priv)
struct spictrl_ioctl_config *cfg = &priv->periodic_cfg;
unsigned int am_cfg;
@@ -376,7 +377,7 @@ int spictrl_start_periodic(struct spictrl_priv *priv)
/* Stop Automated Periodic transfers */
-void spictrl_stop_periodic(struct spictrl_priv *priv)
+static void spictrl_stop_periodic(struct spictrl_priv *priv)
priv->regs->am_cfg = 0;
@@ -385,12 +386,14 @@ void spictrl_stop_periodic(struct spictrl_priv *priv)
* it may be needed in periodic mode to look at the Not Full bit (NF)
* in order not to hang in an infinte loop when read is called.
-unsigned int spictrl_status(struct spictrl_priv *priv)
+static inline unsigned int spictrl_status(struct spictrl_priv *priv)
return priv->regs->event;
-int spictrl_read_periodic(struct spictrl_priv *priv, struct spictrl_period_io *rarg)
+static int spictrl_read_periodic(
+ struct spictrl_priv *priv,
+ struct spictrl_period_io *rarg)
int i, rxi, rxshift, bits_per_char, reg;
unsigned int rx_word, mask;
@@ -455,7 +458,9 @@ int spictrl_read_periodic(struct spictrl_priv *priv, struct spictrl_period_io *r
return 0;
-int spictrl_write_periodic(struct spictrl_priv *priv, struct spictrl_period_io *warg)
+static int spictrl_write_periodic(
+ struct spictrl_period_io *warg)
int i, txi, txshift, bits_per_char, reg;
unsigned int tx_word, mask;
@@ -522,7 +527,11 @@ int spictrl_write_periodic(struct spictrl_priv *priv, struct spictrl_period_io *
return 0;
-int spictrl_read_write(struct spictrl_priv *priv, void *rxbuf, void *txbuf, int len)
+static int spictrl_read_write(
+ void *rxbuf,
+ void *txbuf,
+ int len)
unsigned int tx_word, rx_word, tmp;
int txshift = priv->txshift;
1.7.0.4
