[PATCH 104/111] GR-RASTA-SPW-ROUTER: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:46 UTC 2015
.../sparc/shared/include/gr_rasta_spw_router.h | 5 ++++-
.../libbsp/sparc/shared/pci/gr_rasta_spw_router.c | 17 +++++++----------
2 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h
index ba98957..2b9833a 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_spw_router.h
@@ -32,9 +32,12 @@ extern struct drvmgr_bus_res *gr_rasta_spw_router_resources[];
#define RASTA_SPW_ROUTER_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
#define RASTA_SPW_ROUTER_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
-/* Print information about GR-CPCI-LEON4-N2X PCI board */
+/* Print information about all GR-CPCI-LEON4-N2X PCI boards */
void gr_rasta_spw_router_print(int options);
+/* Print information about one GR-CPCI-LEON4-N2X PCI board */
+void gr_rasta_spw_router_print_dev(struct drvmgr_dev *dev, int options);
/* Register GR-RASTA-SPW-ROUTER driver to Driver Manager */
void gr_rasta_spw_router_register_drv(void);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
index 3b40993..92e6b4a 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_spw_router.c
@@ -28,6 +28,7 @@
#include <drvmgr/drvmgr.h>
#include <drvmgr/ambapp_bus.h>
#include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
#include <genirq.h>
#include <gr_rasta_spw_router.h>
@@ -196,7 +197,6 @@ struct drvmgr_bus_res *gr_rasta_spw_router_resources[] __attribute__((weak)) =
NULL
-int gr_rasta_spw_router_resources_cnt = 0;
@@ -239,7 +239,6 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
unsigned int ctrl;
uint8_t tmp2;
struct ambapp_dev *tmp;
- int status;
struct ambapp_ahb_info *ahb;
uint8_t cap_ptr;
pci_dev_t pcidev = priv->pcidev;
@@ -307,7 +306,7 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
ambapp_freq_init(&priv->abus, NULL, priv->version->amba_freq_hz);
/* Find IRQ controller, Clear all current IRQs */
- tmp = ambapp_for_each(&priv->abus,
+ tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
(OPTIONS_ALL|OPTIONS_APB_SLVS),
VENDOR_GAISLER, GAISLER_IRQMP,
ambapp_find_by_idx, NULL);
@@ -327,7 +326,7 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
priv->bus_maps_down[1].size = 0;
/* Find GRPCI2 controller AHB Slave interface */
- tmp = (void *)ambapp_for_each(&priv->abus,
(OPTIONS_ALL|OPTIONS_AHB_SLVS),
VENDOR_GAISLER, GAISLER_GRPCI2,
@@ -343,7 +342,7 @@ static int gr_rasta_spw_router_hw_init(struct gr_rasta_spw_router_priv *priv)
priv->bus_maps_up[1].size = 0;
/* Find GRPCI2 controller APB Slave interface */
@@ -387,6 +386,7 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
int status;
uint32_t bar0, bar0_size;
union drvmgr_key_value *value;
+ int resources_cnt;
priv = dev->priv;
if (!priv)
@@ -397,10 +397,7 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
priv->dev = dev;
/* Determine number of configurations */
- if ( gr_rasta_spw_router_resources_cnt == 0 ) {
- while ( gr_rasta_spw_router_resources[gr_rasta_spw_router_resources_cnt] )
- gr_rasta_spw_router_resources_cnt++;
+ resources_cnt = get_resarray_count(gr_rasta_spw_router_resources);
/* Generate Device prefix */
@@ -454,7 +451,7 @@ int gr_rasta_spw_router_init1(struct drvmgr_dev *dev)
priv->config.ops = &ambapp_rasta_spw_router_ops;
priv->config.maps_up = &priv->bus_maps_up[0];
priv->config.maps_down = &priv->bus_maps_down[0];
- if ( priv->dev->minor_drv < gr_rasta_spw_router_resources_cnt ) {
+ if ( priv->dev->minor_drv < resources_cnt ) {
priv->config.resources = gr_rasta_spw_router_resources[priv->dev->minor_drv];
} else {
priv->config.resources = NULL;
1.7.0.4
