[PATCH 105/111] GR-RASTA-TMTC: fix build warnings
Daniel Hellstrom daniel at gaisler.com
Thu Feb 26 16:39:47 UTC 2015
 .../libbsp/sparc/shared/include/gr_rasta_tmtc.h    |    8 ++++-
 c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c  |   29 +++++++++----------
 2 files changed, 20 insertions(+), 17 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
index 28b6ea0..c6f1036 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_rasta_tmtc.h
@@ -78,7 +78,8 @@ extern "C" {
  * used by the device drivers controlling the cores on the GR-RASTA-IO target
  * AMBA bus.
- * The array is defined weak, and defualts to no resources.
+ * The array is defined weak, and defaults to no resources. The array must be
+ * terminated with a NULL resource.
 extern struct drvmgr_bus_res *gr_rasta_tmtc_resources[];
@@ -86,9 +87,12 @@ extern struct drvmgr_bus_res *gr_rasta_tmtc_resources[];
 #define RASTA_TMTC_OPTIONS_AMBA   0x01 /* Print AMBA bus devices */
 #define RASTA_TMTC_OPTIONS_IRQ    0x02 /* Print current IRQ setup */
-/* Print information about GR-RASTA-TMTC PCI board */
+/* Print information about GR-RASTA-TMTC PCI boards */
 void gr_rasta_tmtc_print(int options);
+/* Print information about a GR-RASTA-TMTC PCI boards */
+void gr_rasta_tmtc_print_dev(struct drvmgr_dev *dev, int options);
 /* Register GR-RASTA-TMTC driver */
 void gr_rasta_tmtc_register_drv(void);
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
index faefa4d..7714a00 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_rasta_tmtc.c
@@ -30,6 +30,7 @@
 #include <drvmgr/drvmgr.h>
 #include <drvmgr/ambapp_bus.h>
 #include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
 #include <genirq.h>
 #include <gr_rasta_tmtc.h>
@@ -61,6 +62,7 @@ extern unsigned int _RAM_START;
 int gr_rasta_tmtc_init1(struct drvmgr_dev *dev);
 int gr_rasta_tmtc_init2(struct drvmgr_dev *dev);
+void gr_rasta_tmtc_isr (void *arg);
 struct grpci_regs {
 	volatile unsigned int cfg_stat;
@@ -210,7 +212,6 @@ struct drvmgr_bus_res *gr_rasta_tmtc_resources[] __attribute__((weak)) =
 	NULL,
-int gr_rasta_tmtc_resources_cnt = 0;
@@ -247,7 +248,7 @@ void gr_rasta_tmtc_isr (void *arg)
 /* Init AMBA bus frequency, IRQ controller, GPIO register, bus maps and other
  * common stuff between rev0 and rev1.
-int gr_rasta_tmtc_hw_init_common(struct gr_rasta_tmtc_priv *priv)
+static int gr_rasta_tmtc_hw_init_common(struct gr_rasta_tmtc_priv *priv)
 	struct ambapp_dev *tmp;
 	unsigned int pci_freq_hz;
@@ -259,7 +260,7 @@ int gr_rasta_tmtc_hw_init_common(struct gr_rasta_tmtc_priv *priv)
 	ambapp_freq_init(&priv->abus, NULL, pci_freq_hz);
 	/* Find IRQ controller, Clear all current IRQs */
-	tmp = (void *)ambapp_for_each(&priv->abus,
+	tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
 					(OPTIONS_ALL|OPTIONS_APB_SLVS),
 					VENDOR_GAISLER, GAISLER_IRQMP,
 					ambapp_find_by_idx, NULL);
@@ -273,7 +274,7 @@ int gr_rasta_tmtc_hw_init_common(struct gr_rasta_tmtc_priv *priv)
 	priv->irq->ilevel = 0;
 	/* Find First GPIO controller */
 					VENDOR_GAISLER, GAISLER_GPIO,
@@ -309,7 +310,7 @@ int gr_rasta_tmtc_hw_init_common(struct gr_rasta_tmtc_priv *priv)
 /* PCI Hardware (Revision 0) initialization */
-int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
+static int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
 	unsigned int *page0 = NULL;
@@ -381,7 +382,7 @@ int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
 	*page0 = AHB1_BASE_ADDR;
 	/* Find GRPCI controller */
 					VENDOR_GAISLER, GAISLER_PCIFBRG,
@@ -427,7 +428,7 @@ int gr_rasta_tmtc0_hw_init(struct gr_rasta_tmtc_priv *priv)
 /* PCI Hardware (Revision 1) initialization */
-int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
+static int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
 	int i;
 	uint32_t data;
@@ -507,7 +508,7 @@ int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
 		return status;
 	/* Find GRPCI2 controller AHB Slave interface */
 					(OPTIONS_ALL|OPTIONS_AHB_SLVS),
 					VENDOR_GAISLER, GAISLER_GRPCI2,
@@ -523,7 +524,7 @@ int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
 	priv->bus_maps_up[1].size = 0;
 	/* Find GRPCI2 controller APB Slave interface */
@@ -548,7 +549,7 @@ int gr_rasta_tmtc1_hw_init(struct gr_rasta_tmtc_priv *priv)
 	return 0;
-void gr_rasta_tmtc_hw_init2(struct gr_rasta_tmtc_priv *priv)
+static void gr_rasta_tmtc_hw_init2(struct gr_rasta_tmtc_priv *priv)
 	/* Enable DMA by enabling PCI target as master */
 	pci_master_enable(priv->pcidev);
@@ -564,6 +565,7 @@ int gr_rasta_tmtc_init1(struct drvmgr_dev *dev)
 	int status;
 	uint32_t bar0, bar1, bar0_size, bar1_size;
 	union drvmgr_key_value *value;
+	int resources_cnt;
 	priv = dev->priv;
 	if (!priv)
@@ -571,10 +573,7 @@ int gr_rasta_tmtc_init1(struct drvmgr_dev *dev)
 	priv->dev = dev;
 	/* Determine number of configurations */
-	if ( gr_rasta_tmtc_resources_cnt == 0 ) {
-		while ( gr_rasta_tmtc_resources[gr_rasta_tmtc_resources_cnt] )
-			gr_rasta_tmtc_resources_cnt++;
+	resources_cnt = get_resarray_count(gr_rasta_tmtc_resources);
 	/* Generate Device prefix */
@@ -645,7 +644,7 @@ int gr_rasta_tmtc_init1(struct drvmgr_dev *dev)
 	priv->config.ops = &ambapp_rasta_tmtc_ops;
 	priv->config.maps_up = &priv->bus_maps_up[0];
 	priv->config.maps_down = &priv->bus_maps_down[0];
-	if ( priv->dev->minor_drv < gr_rasta_tmtc_resources_cnt ) {
+	if ( priv->dev->minor_drv < resources_cnt ) {
 		priv->config.resources = gr_rasta_tmtc_resources[priv->dev->minor_drv];
 	} else {
 		priv->config.resources = NULL;
1.7.0.4
