[PATCH 106/111] GR-TMTC-1553: fix build warnings
Daniel Hellstrom
daniel at gaisler.com
Thu Feb 26 16:39:48 UTC 2015
.../lib/libbsp/sparc/shared/include/gr_tmtc_1553.h | 8 +++++++-
c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c | 20 +++++++++-----------
2 files changed, 16 insertions(+), 12 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h b/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
index 4df89f7..61cd0b1 100644
--- a/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
+++ b/c/src/lib/libbsp/sparc/shared/include/gr_tmtc_1553.h
@@ -28,7 +28,7 @@ extern "C" {
* used by the drivers controlling the cores on the GR-TMTC-1553 target AMBA bus.
* The gr_rasta_io_resources is declared weak so that the user can override the
- * default configuration.
+ * default configuration. The array must be terminated with a NULL resource.
extern struct drvmgr_bus_res *gr_tmtc_1553_resources[];
@@ -42,6 +42,12 @@ void gr_tmtc_1553_print(int options);
/* Register GR-RASTA-IO driver */
void gr_tmtc_1553_register_drv(void);
+/* Print information about all GR-TMTC-1553 devices registered to this driver */
+void gr_tmtc_1553_print(int options);
+/* Print information about one GR-TMTC-1553 device */
+void gr_tmtc_1553_print_dev(struct drvmgr_dev *dev, int options);
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c b/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
index 6b512a9..c2bd8eb 100644
--- a/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
+++ b/c/src/lib/libbsp/sparc/shared/pci/gr_tmtc_1553.c
@@ -31,6 +31,7 @@
#include <drvmgr/drvmgr.h>
#include <drvmgr/ambapp_bus.h>
#include <drvmgr/pci_bus.h>
+#include <drvmgr/bspcommon.h>
#include <genirq.h>
#include <gr_tmtc_1553.h>
@@ -49,6 +50,7 @@
int gr_tmtc_1553_init1(struct drvmgr_dev *dev);
int gr_tmtc_1553_init2(struct drvmgr_dev *dev);
+void gr_tmtc_1553_isr (void *arg);
struct gr_tmtc_1553_ver {
const unsigned int amba_freq_hz; /* The frequency */
@@ -160,7 +162,6 @@ struct drvmgr_bus_res *gr_tmtc_1553_resources[] __attribute__((weak)) =
NULL
-int gr_tmtc_1553_resources_cnt = 0;
@@ -194,11 +195,10 @@ void gr_tmtc_1553_isr (void *arg)
DBG("GR-TMTC-1553-IRQ: 0x%x\n", tmp);
-int gr_tmtc_1553_hw_init(struct gr_tmtc_1553_priv *priv)
+static int gr_tmtc_1553_hw_init(struct gr_tmtc_1553_priv *priv)
unsigned int *page0 = NULL;
struct ambapp_dev *tmp;
- int status;
unsigned int pci_freq_hz;
struct pci_dev_info *devinfo = priv->devinfo;
uint32_t bar0, bar0_size;
@@ -243,12 +243,12 @@ int gr_tmtc_1553_hw_init(struct gr_tmtc_1553_priv *priv)
NULL, &priv->amba_maps[0]);
/* Frequency is the hsame as the PCI bus frequency */
- drvmgr_freq_get(priv->dev, NULL, &pci_freq_hz);
+ drvmgr_freq_get(priv->dev, 0, &pci_freq_hz);
ambapp_freq_init(&priv->abus, NULL, pci_freq_hz);
/* Find IRQ controller */
- tmp = (void *)ambapp_for_each(&priv->abus,
+ tmp = (struct ambapp_dev *)ambapp_for_each(&priv->abus,
(OPTIONS_ALL|OPTIONS_APB_SLVS),
VENDOR_GAISLER, GAISLER_IRQMP,
ambapp_find_by_idx, NULL);
@@ -283,6 +283,7 @@ int gr_tmtc_1553_init1(struct drvmgr_dev *dev)
struct pci_dev_info *devinfo;
int status;
+ int resources_cnt;
/* PCI device does not have the IRQ line register, when PCI autoconf configures it the configuration
* is forgotten. We take the IRQ number from the PCI Host device (AMBA device), this works as long
@@ -291,7 +292,7 @@ int gr_tmtc_1553_init1(struct drvmgr_dev *dev)
* Note that this only works on LEON.
((struct pci_dev_info *)dev->businfo)->irq = ((struct amba_dev_info *)dev->parent->dev->businfo)->info.irq;
priv = malloc(sizeof(struct gr_tmtc_1553_priv));
if ( !priv )
return DRVMGR_NOMEM;
@@ -301,10 +302,7 @@ int gr_tmtc_1553_init1(struct drvmgr_dev *dev)
priv->dev = dev;
/* Determine number of configurations */
- if ( gr_tmtc_1553_resources_cnt == 0 ) {
- while ( gr_tmtc_1553_resources[gr_tmtc_1553_resources_cnt] )
- gr_tmtc_1553_resources_cnt++;
+ resources_cnt = get_resarray_count(gr_tmtc_1553_resources);
/* Generate Device prefix */
@@ -354,7 +352,7 @@ int gr_tmtc_1553_init1(struct drvmgr_dev *dev)
* which means that translation from AMBA->PCI should fail if attempted.
priv->config.maps_up = DRVMGR_TRANSLATE_NO_BRIDGE;
- if ( priv->dev->minor_drv < gr_tmtc_1553_resources_cnt ) {
+ if ( priv->dev->minor_drv < resources_cnt ) {
priv->config.resources = gr_tmtc_1553_resources[priv->dev->minor_drv];
} else {
priv->config.resources = NULL;
1.7.0.4
