Moxie BSP Build Failure
Fri Jan 2 16:33:21 UTC 2015
On 1/2/2015 10:31 AM, Joel Sherrill wrote:
> On 1/2/2015 12:10 AM, Anthony Green wrote:
>> Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>>> Hi
>>> This is with the binutils and gcc heads.
>> Change "sub.l" to "sub" and you're good.  I've been testing with this.  Sorry about the change!
> Thanks. Will this still work with the old tools?
And the answer is no. :(
Any suggestions on how to deal with switching between new and released
toolsets?
> --joel
>> AG
>>> moxie-rtems4.11-gcc --pipe -B../../../../../.././lib/
>>> -B../../../../../.././moxiesim/lib/ -specs bsp_specs -qrtems
>>> -DHAVE_CONFIG_H   -isystem ../../../../../.././moxiesim/lib/include
>>> -DASM -Os -g -ffunction-sections -fdata-sections -Wall
>>> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
>>> -Wnested-externs -MT start.o -MD -MP -MF .deps/start.Tpo -c -o start.o
>>> `test -f 'start/start.S' || echo
>>> '../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/'`start/start.S
>>> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:
>>> Assembler messages:
>>> ../../../../../../../../rtems/c/src/lib/libbsp/moxie/moxiesim/start/start.S:15:
>>> Error: unknown opcode sub.l $r2,$r0
