Possible generic RSB issue
Joel Sherrill
joel.sherrill at oarcorp.com
Thu Jan 15 19:38:04 UTC 2015
Hi
I am trying to update the moxie tools and the previous version
of binutils used is incapable of building a current toolset.
Even when I take the install point out of my PATH, it appears that
that is used internally by the RSB and thus the as used to build
gcc is the one from the previous install.
I think generically this means that once you have a binutils installed,
the next tool build will use the old binutils and thus we are possibly
never building the updated toolset with the updated binutils. In other
words, if binutils installed, then that is used instead of the one about
to be installed.
