[PATCH] IMFS: Replace node union with individual struct
Sebastian Huber
Thu Jan 22 09:08:29 UTC 2015
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
cpukit/dev/i2c/i2c-bus.c | 16 +-
cpukit/dev/i2c/i2c-dev.c | 16 +-
cpukit/libblock/src/blkdev-imfs.c | 21 +-
cpukit/libfs/Makefile.am | 2 +-
cpukit/libfs/src/imfs/deviceio.c | 40 ++--
cpukit/libfs/src/imfs/imfs.h | 291 ++++++++++++++----------
cpukit/libfs/src/imfs/imfs_creat.c | 10 +-
cpukit/libfs/src/imfs/imfs_debug.c | 138 -----------
cpukit/libfs/src/imfs/imfs_directory.c | 55 +++--
cpukit/libfs/src/imfs/imfs_eval.c | 43 ++--
cpukit/libfs/src/imfs/imfs_fifo.c | 4 +-
cpukit/libfs/src/imfs/imfs_fsunmount.c | 2 +-
cpukit/libfs/src/imfs/imfs_handlers_device.c | 15 +-
cpukit/libfs/src/imfs/imfs_handlers_directory.c | 27 ++-
cpukit/libfs/src/imfs/imfs_handlers_link.c | 36 +--
cpukit/libfs/src/imfs/imfs_handlers_memfile.c | 30 ++-
cpukit/libfs/src/imfs/imfs_initsupp.c | 14 +-
cpukit/libfs/src/imfs/imfs_link.c | 10 +-
cpukit/libfs/src/imfs/imfs_load_tar.c | 25 +-
cpukit/libfs/src/imfs/imfs_make_generic_node.c | 63 +++--
cpukit/libfs/src/imfs/imfs_mknod.c | 25 +-
cpukit/libfs/src/imfs/imfs_mount.c | 6 +-
cpukit/libfs/src/imfs/imfs_readlink.c | 10 +-
cpukit/libfs/src/imfs/imfs_symlink.c | 12 +-
cpukit/libfs/src/imfs/imfs_unmount.c | 6 +-
cpukit/libfs/src/imfs/memfile.c | 244 ++++++++++----------
testsuites/fstests/fsimfsgeneric01/init.c | 37 +--
testsuites/libtests/newlib01/init.c | 12 +-
testsuites/libtests/tar02/init.c | 1 -
testsuites/libtests/tar02/tar02.scn | 14 +-
testsuites/psxtests/psxfile01/psxfile01.scn | 75 +-----
testsuites/psxtests/psxfile01/test.c | 14 +-
testsuites/psxtests/psximfs02/init.c | 3 -
testsuites/psxtests/psximfs02/psximfs02.scn | 32 +--
34 files changed, 563 insertions(+), 786 deletions(-)
delete mode 100644 cpukit/libfs/src/imfs/imfs_debug.c
diff --git a/cpukit/dev/i2c/i2c-bus.c b/cpukit/dev/i2c/i2c-bus.c
index dafd758..0f27d06 100644
--- a/cpukit/dev/i2c/i2c-bus.c
+++ b/cpukit/dev/i2c/i2c-bus.c
@@ -223,23 +223,21 @@ static const rtems_filesystem_file_handlers_r i2c_bus_handler = {
.writev_h = rtems_filesystem_default_writev
-static IMFS_jnode_t *i2c_bus_node_destroy(IMFS_jnode_t *node)
+static void i2c_bus_node_destroy(IMFS_jnode_t *node)
i2c_bus *bus;
bus = IMFS_generic_get_context_by_node(node);
(*bus->destroy)(bus);
- return node;
+ IMFS_node_destroy_default(node);
-static const IMFS_node_control i2c_bus_node_control = {
- .imfs_type = IMFS_GENERIC,
- .handlers = &i2c_bus_handler,
- .node_initialize = IMFS_node_initialize_generic,
- .node_remove = IMFS_node_remove_default,
- .node_destroy = i2c_bus_node_destroy
+static const IMFS_node_control i2c_bus_node_control = IMFS_GENERIC_INITIALIZER(
+ &i2c_bus_handler,
+ IMFS_node_initialize_generic,
+ i2c_bus_node_destroy
int i2c_bus_register(
i2c_bus *bus,
diff --git a/cpukit/dev/i2c/i2c-dev.c b/cpukit/dev/i2c/i2c-dev.c
index 76ae757..6710632 100644
--- a/cpukit/dev/i2c/i2c-dev.c
+++ b/cpukit/dev/i2c/i2c-dev.c
@@ -116,23 +116,21 @@ static const rtems_filesystem_file_handlers_r i2c_dev_handler = {
-static IMFS_jnode_t *i2c_dev_node_destroy(IMFS_jnode_t *node)
+static void i2c_dev_node_destroy(IMFS_jnode_t *node)
i2c_dev *dev;
dev = IMFS_generic_get_context_by_node(node);
(*dev->destroy)(dev);
- return node;
-static const IMFS_node_control i2c_dev_node_control = {
- .handlers = &i2c_dev_handler,
- .node_destroy = i2c_dev_node_destroy
+static const IMFS_node_control i2c_dev_node_control = IMFS_GENERIC_INITIALIZER(
+ &i2c_dev_handler,
+ i2c_dev_node_destroy
int i2c_dev_register(
i2c_dev *dev,
diff --git a/cpukit/libblock/src/blkdev-imfs.c b/cpukit/libblock/src/blkdev-imfs.c
index d6134f9..7a2d00b 100644
--- a/cpukit/libblock/src/blkdev-imfs.c
+++ b/cpukit/libblock/src/blkdev-imfs.c
@@ -229,13 +229,13 @@ static const rtems_filesystem_file_handlers_r rtems_blkdev_imfs_node = {
static IMFS_jnode_t *rtems_blkdev_imfs_initialize(
IMFS_jnode_t *node,
- const IMFS_types_union *info
+ void *arg
rtems_blkdev_imfs_context *ctx;
rtems_disk_device *dd;
- node = IMFS_node_initialize_generic(node, info);
+ node = IMFS_node_initialize_generic(node, arg);
ctx = IMFS_generic_get_context_by_node(node);
dd = &ctx->dd;
@@ -244,7 +244,7 @@ static IMFS_jnode_t *rtems_blkdev_imfs_initialize(
return node;
-static IMFS_jnode_t *rtems_blkdev_imfs_destroy(IMFS_jnode_t *node)
+static void rtems_blkdev_imfs_destroy(IMFS_jnode_t *node)
rtems_blkdev_imfs_context *ctx = IMFS_generic_get_context_by_node(node);
rtems_disk_device *dd = &ctx->dd;
@@ -260,16 +260,15 @@ static IMFS_jnode_t *rtems_blkdev_imfs_destroy(IMFS_jnode_t *node)
free(ctx);
- return node;
-static const IMFS_node_control rtems_blkdev_imfs_control = {
- .handlers = &rtems_blkdev_imfs_node,
- .node_initialize = rtems_blkdev_imfs_initialize,
- .node_destroy = rtems_blkdev_imfs_destroy
+static const IMFS_node_control rtems_blkdev_imfs_control =
+ IMFS_GENERIC_INITIALIZER(
+ &rtems_blkdev_imfs_node,
+ rtems_blkdev_imfs_initialize,
+ rtems_blkdev_imfs_destroy
rtems_status_code rtems_blkdev_create(
const char *device,
diff --git a/cpukit/libfs/Makefile.am b/cpukit/libfs/Makefile.am
index b255d1c..6427d69 100644
--- a/cpukit/libfs/Makefile.am
+++ b/cpukit/libfs/Makefile.am
@@ -42,7 +42,7 @@ libimfs_a_SOURCES =
libimfs_a_SOURCES += src/imfs/deviceio.c \
src/imfs/fifoimfs_init.c src/imfs/imfs_chown.c src/imfs/imfs_config.c \
- src/imfs/imfs_creat.c src/imfs/imfs_debug.c src/imfs/imfs_directory.c \
+ src/imfs/imfs_creat.c src/imfs/imfs_directory.c \
src/imfs/imfs_eval.c src/imfs/imfs_fchmod.c \
src/imfs/imfs_fifo.c \
src/imfs/imfs_make_generic_node.c \
diff --git a/cpukit/libfs/src/imfs/deviceio.c b/cpukit/libfs/src/imfs/deviceio.c
index cdb18ee..4819e80 100644
--- a/cpukit/libfs/src/imfs/deviceio.c
+++ b/cpukit/libfs/src/imfs/deviceio.c
@@ -29,17 +29,15 @@ int device_open(
mode_t mode
- IMFS_jnode_t *the_jnode;
- the_jnode = iop->pathinfo.node_access;
+ const IMFS_device_t *device = IMFS_iop_to_device( iop );
return rtems_deviceio_open(
iop,
pathname,
oflag,
mode,
- the_jnode->info.device.major,
- the_jnode->info.device.minor
+ device->major,
+ device->minor
@@ -47,14 +45,12 @@ int device_close(
rtems_libio_t *iop
return rtems_deviceio_close(
iop,
+ device->major,
+ device->minor
@@ -64,16 +60,14 @@ ssize_t device_read(
size_t count
return rtems_deviceio_read(
iop,
buffer,
count,
+ device->major,
+ device->minor
@@ -83,16 +77,14 @@ ssize_t device_write(
size_t count
return rtems_deviceio_write(
iop,
buffer,
count,
+ device->major,
+ device->minor
@@ -102,16 +94,14 @@ int device_ioctl(
void *buffer
return rtems_deviceio_control(
iop,
command,
buffer,
+ device->major,
+ device->minor
diff --git a/cpukit/libfs/src/imfs/imfs.h b/cpukit/libfs/src/imfs/imfs.h
index c34f89f..fe99493 100644
--- a/cpukit/libfs/src/imfs/imfs.h
+++ b/cpukit/libfs/src/imfs/imfs.h
@@ -41,32 +41,6 @@ extern "C" {
struct IMFS_jnode_tt;
typedef struct IMFS_jnode_tt IMFS_jnode_t;
-typedef struct {
- rtems_chain_control Entries;
- rtems_filesystem_mount_table_entry_t *mt_fs;
-} IMFS_directory_t;
-typedef struct {
- rtems_device_major_number major;
- rtems_device_minor_number minor;
-} IMFS_device_t;
-typedef struct {
- IMFS_jnode_t *link_node;
-} IMFS_link_t;
-typedef struct {
- char *name;
-} IMFS_sym_link_t;
-typedef struct {
- pipe_control_t *pipe;
-} IMFS_fifo_t;
-typedef struct {
- void *context;
-} IMFS_generic_t;
* IMFS "memfile" information
@@ -100,18 +74,6 @@ typedef struct {
typedef uint8_t *block_p;
typedef block_p *block_ptr;
-typedef struct {
- off_t size; /* size of file in bytes */
- block_ptr indirect; /* array of 128 data blocks pointers */
- block_ptr doubly_indirect; /* 128 indirect blocks */
- block_ptr triply_indirect; /* 128 doubly indirect blocks */
-} IMFS_memfile_t;
-typedef struct {
- block_p direct; /* pointer to file image */
-} IMFS_linearfile_t;
* Important block numbers for "memfiles"
@@ -142,25 +104,11 @@ typedef enum {
IMFS_SYM_LINK,
IMFS_MEMORY_FILE,
IMFS_LINEAR_FILE,
- IMFS_FIFO,
- IMFS_GENERIC,
- IMFS_INVALID_NODE
+ IMFS_FIFO
} IMFS_jnode_types_t;
-/* The IMFS_GENERIC does not count */
#define IMFS_TYPE_COUNT (IMFS_FIFO + 1)
-typedef union {
- IMFS_directory_t directory;
- IMFS_device_t device;
- IMFS_link_t hard_link;
- IMFS_sym_link_t sym_link;
- IMFS_memfile_t file;
- IMFS_linearfile_t linearfile;
- IMFS_fifo_t fifo;
- IMFS_generic_t generic;
-} IMFS_types_union;
@@ -171,8 +119,9 @@ typedef union {
* @brief Initializes an IMFS node.
- * @param[in,out] node The IMFS node.
- * @param[in] info The IMFS type information.
+ * @param[in] node The IMFS node.
+ * @param[in] arg The user provided argument pointer. It may contain node
+ * specific initialization information.
* @retval node Successful operation.
* @retval NULL An error occurred. The @c errno indicates the error. This
@@ -183,14 +132,14 @@ typedef union {
typedef IMFS_jnode_t *(*IMFS_node_control_initialize)(
IMFS_jnode_t *node,
+ void *arg
* @brief Returns the node and does nothing else.
+ * @param[in] arg The user provided argument pointer. It is not used.
* @retval node Returns always the node passed as parameter.
@@ -198,14 +147,15 @@ typedef IMFS_jnode_t *(*IMFS_node_control_initialize)(
IMFS_jnode_t *IMFS_node_initialize_default(
IMFS_jnode_t *node,
+ void *arg
* @brief Returns the node and sets the generic node context.
+ * @param[in] arg The user provided argument pointer. It must contain the
+ * generic context.
@@ -213,13 +163,13 @@ IMFS_jnode_t *IMFS_node_initialize_default(
IMFS_jnode_t *IMFS_node_initialize_generic(
IMFS_jnode_t *node,
+ void *arg
* @brief Prepares the removal of an IMFS node from its parent directory.
@@ -234,7 +184,7 @@ typedef IMFS_jnode_t *(*IMFS_node_control_remove)(
@@ -247,31 +197,27 @@ IMFS_jnode_t *IMFS_node_remove_default(
* @brief Destroys an IMFS node.
- * @retval node Returns always the node passed as parameter.
* @see IMFS_node_control and IMFS_node_destroy_default().
-typedef IMFS_jnode_t *(*IMFS_node_control_destroy)( IMFS_jnode_t *node );
+typedef void (*IMFS_node_control_destroy)( IMFS_jnode_t *node );
- * @brief Returns the node and does nothing else.
+ * @brief Frees the node.
* @see IMFS_node_control.
-IMFS_jnode_t *IMFS_node_destroy_default( IMFS_jnode_t *node );
+void IMFS_node_destroy_default( IMFS_jnode_t *node );
* @brief IMFS node control.
typedef struct {
- IMFS_jnode_types_t imfs_type;
const rtems_filesystem_file_handlers_r *handlers;
+ size_t node_size;
IMFS_node_control_initialize node_initialize;
IMFS_node_control_remove node_remove;
IMFS_node_control_destroy node_destroy;
@@ -323,9 +269,87 @@ struct IMFS_jnode_tt {
time_t stat_mtime; /* Time of last modification */
time_t stat_ctime; /* Time of last status change */
const IMFS_node_control *control;
- IMFS_types_union info;
+typedef struct {
+ IMFS_jnode_t Node;
+ rtems_chain_control Entries;
+ rtems_filesystem_mount_table_entry_t *mt_fs;
+} IMFS_directory_t;
+typedef struct {
+ rtems_device_major_number major;
+ rtems_device_minor_number minor;
+} IMFS_device_t;
+typedef struct {
+ IMFS_jnode_t *link_node;
+} IMFS_link_t;
+typedef struct {
+ char *name;
+} IMFS_sym_link_t;
+typedef struct {
+ size_t size; /* size of file in bytes */
+} IMFS_filebase_t;
+typedef struct {
+ IMFS_filebase_t File;
+ block_ptr indirect; /* array of 128 data blocks pointers */
+ block_ptr doubly_indirect; /* 128 indirect blocks */
+ block_ptr triply_indirect; /* 128 doubly indirect blocks */
+} IMFS_memfile_t;
+typedef struct {
+ block_p direct; /* pointer to file image */
+} IMFS_linearfile_t;
+/* Support copy on write for linear files */
+typedef union {
+ IMFS_memfile_t Memfile;
+ IMFS_linearfile_t Linearfile;
+} IMFS_file_t;
+typedef struct {
+ pipe_control_t *pipe;
+} IMFS_fifo_t;
+typedef struct {
+ void *context;
+} IMFS_generic_t;
+static inline IMFS_directory_t *IMFS_iop_to_directory(
+ const rtems_libio_t *iop
+ return (IMFS_directory_t *) iop->pathinfo.node_access;
+static inline IMFS_device_t *IMFS_iop_to_device( const rtems_libio_t *iop )
+ return (IMFS_device_t *) iop->pathinfo.node_access;
+static inline IMFS_file_t *IMFS_iop_to_file( const rtems_libio_t *iop )
+ return (IMFS_file_t *) iop->pathinfo.node_access;
+static inline IMFS_memfile_t *IMFS_iop_to_memfile( const rtems_libio_t *iop )
+ return (IMFS_memfile_t *) iop->pathinfo.node_access;
static inline void IMFS_update_atime( IMFS_jnode_t *jnode )
struct timeval now;
@@ -480,26 +504,6 @@ extern int rtems_tarfs_load(
- * @brief Dump the entire IMFS.
- * This routine dumps the entire IMFS that is mounted at the root
- * directory.
- * NOTE: Assuming the "/" directory is bad.
- * Not checking that the starting directory is in an IMFS is bad.
-extern void IMFS_dump( void );
- * @brief Get the size of the largest file which can be created
- * using the IMFS memory file type.
- * Return the size of the largest file which can be created
-extern int IMFS_memfile_maximum_size( void );
* @brief Destroy an IMFS node.
extern void IMFS_node_destroy( IMFS_jnode_t *node );
@@ -581,7 +585,7 @@ extern IMFS_jnode_t *IMFS_allocate_node(
const char *name,
size_t namelen,
mode_t mode,
+ void *arg
@@ -596,7 +600,7 @@ extern IMFS_jnode_t *IMFS_create_node_with_control(
const char *name,
size_t namelen,
mode_t mode,
+ void *arg
extern bool IMFS_is_imfs_instance(
@@ -617,8 +621,25 @@ extern bool IMFS_is_imfs_instance(
* more features like support for fsync() and fdatasync(). The generic nodes
* use the reference counting of the IMFS. This provides automatic node
* destruction when the last reference vanishes.
+ * @brief Initializer for a generic node control.
+ * @param[in] handlers The file system node handlers.
+ * @param[in] init The node initialization method.
+ * @param[in] destroy The node destruction method.
+#define IMFS_GENERIC_INITIALIZER( handlers, init, destroy ) \
+ ( handlers ), \
+ sizeof( IMFS_generic_t ), \
+ ( init ), \
+ IMFS_node_remove_default, \
+ ( destroy ) \
* @brief Makes a generic IMFS node.
@@ -638,14 +659,33 @@ extern bool IMFS_is_imfs_instance(
* #include <rtems/imfs.h>
- * static const IMFS_node_control some_node_control = {
- * .imfs_type = IMFS_GENERIC,
- * .handlers = &some_node_handlers,
- * .node_initialize = IMFS_node_initialize_generic,
- * .node_remove = IMFS_node_remove_default,
- * .node_destroy = some_node_destroy
+ * static const rtems_filesystem_file_handlers_r some_node_handlers = {
+ * static IMFS_jnode_t *some_node_init(IMFS_jnode_t *node, void *arg)
+ * void *context;
+ * node = IMFS_node_initialize_generic(node, arg);
+ * context = IMFS_generic_get_context_by_node(node);
+ * return node;
+ * static void some_node_destroy(IMFS_jnode_t *node)
+ * void *context = IMFS_generic_get_context_by_node(node);
+ * IMFS_node_destroy_default(node);
+ * static const IMFS_node_control some_node_control = IMFS_GENERIC_INITIALIZER(
+ * &some_node_handlers,
+ * some_node_init,
+ * some_node_destroy
* void example(void *some_node_context)
* int rv;
@@ -688,7 +728,7 @@ extern int IMFS_unmount(
rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
-extern IMFS_jnode_t *IMFS_memfile_remove(
+extern void IMFS_memfile_remove(
IMFS_jnode_t *the_jnode /* IN/OUT */
@@ -734,18 +774,23 @@ extern ssize_t imfs_dir_read(
- * @brief Open a memory file.
+ * @brief Open a linear file.
- * This routine processes the open() system call. Note that there is
- * nothing special to be done at open() time.
+ * Transforms the file into a memfile if opened for writing.
-extern int memfile_open(
+extern int IMFS_linfile_open(
rtems_libio_t *iop, /* IN */
const char *pathname, /* IN */
int oflag, /* IN */
mode_t mode /* IN */
+extern ssize_t IMFS_linfile_read(
+ rtems_libio_t *iop,
+ void *buffer,
+ size_t count
* @brief Read a memory file.
@@ -905,12 +950,14 @@ static inline void IMFS_Set_handlers( rtems_filesystem_location_info_t *loc )
static inline void IMFS_add_to_directory(
- IMFS_jnode_t *dir,
- IMFS_jnode_t *node
+ IMFS_jnode_t *dir_node,
+ IMFS_jnode_t *entry_node
- node->Parent = dir;
- rtems_chain_append_unprotected( &dir->info.directory.Entries, &node->Node );
+ IMFS_directory_t *dir = (IMFS_directory_t *) dir_node;
+ entry_node->Parent = dir_node;
+ rtems_chain_append_unprotected( &dir->Entries, &entry_node->Node );
static inline void IMFS_remove_from_directory( IMFS_jnode_t *node )
@@ -920,14 +967,16 @@ static inline void IMFS_remove_from_directory( IMFS_jnode_t *node )
rtems_chain_extract_unprotected( &node->Node );
-static inline IMFS_jnode_types_t IMFS_type( const IMFS_jnode_t *node )
+static inline bool IMFS_is_directory( const IMFS_jnode_t *node )
- return node->control->imfs_type;
+ return S_ISDIR( node->st_mode );
-static inline bool IMFS_is_directory( const IMFS_jnode_t *node )
+#define IMFS_STAT_FMT_HARD_LINK 0
+static inline bool IMFS_is_hard_link( mode_t mode )
- return node->control->imfs_type == IMFS_DIRECTORY;
+ return ( mode & S_IFMT ) == IMFS_STAT_FMT_HARD_LINK;
static inline IMFS_jnode_t *IMFS_create_node(
@@ -936,7 +985,7 @@ static inline IMFS_jnode_t *IMFS_create_node(
const char *name,
size_t namelen,
mode_t mode,
+ void *arg
const IMFS_fs_info_t *fs_info =
@@ -948,7 +997,7 @@ static inline IMFS_jnode_t *IMFS_create_node(
name,
namelen,
mode,
- info
+ arg
@@ -963,7 +1012,9 @@ static inline void *IMFS_generic_get_context_by_node(
- return node->info.generic.context;
+ const IMFS_generic_t *generic = (const IMFS_generic_t *) node;
+ return generic->context;
static inline void *IMFS_generic_get_context_by_location(
diff --git a/cpukit/libfs/src/imfs/imfs_creat.c b/cpukit/libfs/src/imfs/imfs_creat.c
index 4cea0c2..effb84b 100644
--- a/cpukit/libfs/src/imfs/imfs_creat.c
+++ b/cpukit/libfs/src/imfs/imfs_creat.c
@@ -28,7 +28,7 @@ IMFS_jnode_t *IMFS_allocate_node(
const char *name,
size_t namelen,
mode_t mode,
+ void *arg
IMFS_jnode_t *node;
@@ -46,7 +46,7 @@ IMFS_jnode_t *IMFS_allocate_node(
* Allocate an IMFS jnode
- node = calloc( 1, sizeof( IMFS_jnode_t ) );
+ node = calloc( 1, node_control->node_size );
if ( !node ) {
errno = ENOMEM;
@@ -78,7 +78,7 @@ IMFS_jnode_t *IMFS_allocate_node(
node->stat_ctime = (time_t) tv.tv_sec;
node->st_ino = ++fs_info->ino_count;
- initialized_node = (*node->control->node_initialize)( node, info );
+ initialized_node = (*node->control->node_initialize)( node, arg );
if ( initialized_node == NULL ) {
free( node );
@@ -92,7 +92,7 @@ IMFS_jnode_t *IMFS_create_node_with_control(
const char *name,
size_t namelen,
mode_t mode,
+ void *arg
IMFS_fs_info_t *fs_info = parentloc->mt_entry->fs_info;
@@ -102,7 +102,7 @@ IMFS_jnode_t *IMFS_create_node_with_control(
name,
namelen,
mode,
- info
+ arg
if ( node != NULL ) {
diff --git a/cpukit/libfs/src/imfs/imfs_debug.c b/cpukit/libfs/src/imfs/imfs_debug.c
deleted file mode 100644
index 9f56466..0000000
--- a/cpukit/libfs/src/imfs/imfs_debug.c
+++ /dev/null
@@ -1,138 +0,0 @@
- * @file
- * @brief IMFS Debug Support
- * @ingroup IMFS
- * COPYRIGHT (c) 1989-1999.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include "imfs.h"
-#include <inttypes.h>
-#include <unistd.h>
-#include <stdio.h>
- * IMFS_print_jnode
- * This routine prints the contents of the specified jnode.
-static void IMFS_print_jnode(
- IMFS_assert( the_jnode );
- fprintf(stdout, "%s", the_jnode->name );
- switch( IMFS_type( the_jnode ) ) {
- case IMFS_DIRECTORY:
- fprintf(stdout, "/" );
- break;
- case IMFS_DEVICE:
- fprintf(stdout, " (device %" PRId32 ", %" PRId32 ")",
- the_jnode->info.device.major, the_jnode->info.device.minor );
- break;
- case IMFS_LINEAR_FILE:
- fprintf(stdout, " (file %" PRId32 " %p)",
- (uint32_t)the_jnode->info.linearfile.size,
- the_jnode->info.linearfile.direct
- break;
- case IMFS_MEMORY_FILE:
- /* Useful when debugging .. varies between targets */
-#if 0
- fprintf(stdout, " (file %" PRId32 " %p %p %p)",
- (uint32_t)the_jnode->info.file.size,
- the_jnode->info.file.indirect,
- the_jnode->info.file.doubly_indirect,
- the_jnode->info.file.triply_indirect
-#else
- fprintf(stdout, " (file %" PRId32 ")",
- (uint32_t)the_jnode->info.file.size );
-#endif
- break;
- case IMFS_HARD_LINK:
- fprintf(stdout, " links not printed\n" );
- return;
- case IMFS_SYM_LINK:
- return;
- case IMFS_FIFO:
- fprintf(stdout, " FIFO not printed\n" );
- return;
- default:
- fprintf(stdout, " bad type %d\n", IMFS_type( the_jnode ) );
- return;
- puts("");
- * IMFS_dump_directory
- * This routine prints the contents of a directory in the IMFS. If a
- * directory is encountered, then this routine will recurse to process
- * the subdirectory.
-static void IMFS_dump_directory(
- IMFS_jnode_t *the_directory,
- int level
- rtems_chain_node *the_node;
- rtems_chain_control *the_chain;
- int i;
- IMFS_assert( the_directory );
- IMFS_assert( level >= 0 );
- IMFS_assert( IMFS_is_directory( the_directory ) );
- the_chain = &the_directory->info.directory.Entries;
- for ( the_node = rtems_chain_first( the_chain );
- !rtems_chain_is_tail( the_chain, the_node );
- the_node = the_node->next ) {
- the_jnode = (IMFS_jnode_t *) the_node;
- for ( i=0 ; i<=level ; i++ )
- fprintf(stdout, "...." );
- IMFS_print_jnode( the_jnode );
- if ( IMFS_is_directory( the_jnode ) )
- IMFS_dump_directory( the_jnode, level + 1 );
-void IMFS_dump( void )
- fprintf(stdout, "*************** Dump of Entire IMFS ***************\n" );
- fprintf(stdout, "/\n" );
- IMFS_dump_directory( rtems_filesystem_root->location.node_access, 0 );
- fprintf(stdout, "*************** End of Dump ***************\n" );
-int IMFS_memfile_maximum_size( void )
- return IMFS_MEMFILE_MAXIMUM_SIZE;
diff --git a/cpukit/libfs/src/imfs/imfs_directory.c b/cpukit/libfs/src/imfs/imfs_directory.c
index 8325a14..fc35b01 100644
--- a/cpukit/libfs/src/imfs/imfs_directory.c
+++ b/cpukit/libfs/src/imfs/imfs_directory.c
@@ -33,19 +33,19 @@ ssize_t imfs_dir_read(
* Read up to element iop->offset in the directory chain of the
* imfs_jnode_t struct for this file descriptor.
- int bytes_transferred;
- int current_entry;
- int first_entry;
- int last_entry;
- struct dirent tmp_dirent;
+ const IMFS_directory_t *dir;
+ const rtems_chain_node *node;
+ const rtems_chain_control *entries;
+ struct dirent *dir_ent;
+ ssize_t bytes_transferred;
+ off_t current_entry;
+ off_t first_entry;
+ off_t last_entry;
rtems_filesystem_instance_lock( &iop->pathinfo );
- the_jnode = (IMFS_jnode_t *)iop->pathinfo.node_access;
- the_chain = &the_jnode->info.directory.Entries;
+ dir = IMFS_iop_to_directory( iop );
+ entries = &dir->Entries;
/* Move to the first of the desired directory entries */
@@ -54,32 +54,31 @@ ssize_t imfs_dir_read(
/* protect against using sizes that are not exact multiples of the */
/* -dirent- size. These could result in unexpected results */
last_entry = first_entry
- + (count / sizeof( struct dirent )) * sizeof( struct dirent );
+ + (count / sizeof( *dir_ent )) * sizeof( *dir_ent );
/* The directory was not empty so try to move to the desired entry in chain*/
for (
current_entry = 0,
- the_node = rtems_chain_first( the_chain );
+ node = rtems_chain_immutable_first( entries );
current_entry < last_entry
- && !rtems_chain_is_tail( the_chain, the_node );
- current_entry += sizeof( struct dirent ),
- the_node = rtems_chain_next( the_node )
+ && !rtems_chain_is_tail( entries, node );
+ current_entry += sizeof( *dir_ent ),
+ node = rtems_chain_immutable_next( node )
if( current_entry >= first_entry ) {
+ const IMFS_jnode_t *imfs_node = (const IMFS_jnode_t *) node;
+ dir_ent = (struct dirent *) ((char *) buffer + bytes_transferred);
/* Move the entry to the return buffer */
- tmp_dirent.d_off = current_entry;
- tmp_dirent.d_reclen = sizeof( struct dirent );
- tmp_dirent.d_ino = the_jnode->st_ino;
- tmp_dirent.d_namlen = strlen( the_jnode->name );
- strcpy( tmp_dirent.d_name, the_jnode->name );
- memcpy(
- buffer + bytes_transferred,
- (void *)&tmp_dirent,
- sizeof( struct dirent )
- iop->offset += sizeof( struct dirent );
- bytes_transferred += sizeof( struct dirent );
+ dir_ent->d_off = current_entry;
+ dir_ent->d_reclen = sizeof( *dir_ent );
+ dir_ent->d_ino = imfs_node->st_ino;
+ dir_ent->d_namlen = strlen( imfs_node->name );
+ memcpy( dir_ent->d_name, imfs_node->name, dir_ent->d_namlen + 1 );
+ iop->offset += sizeof( *dir_ent );
+ bytes_transferred += (ssize_t) sizeof( *dir_ent );
diff --git a/cpukit/libfs/src/imfs/imfs_eval.c b/cpukit/libfs/src/imfs/imfs_eval.c
index 9bbfc83..9e2d6f5 100644
--- a/cpukit/libfs/src/imfs/imfs_eval.c
+++ b/cpukit/libfs/src/imfs/imfs_eval.c
@@ -38,18 +38,18 @@ static bool IMFS_eval_is_directory(
static IMFS_jnode_t *IMFS_search_in_directory(
+ IMFS_directory_t *dir,
const char *token,
size_t tokenlen
if ( rtems_filesystem_is_current_directory( token, tokenlen ) ) {
- return dir;
+ return &dir->Node;
} else {
if ( rtems_filesystem_is_parent_directory( token, tokenlen ) ) {
- return dir->Parent;
+ return dir->Node.Parent;
} else {
- rtems_chain_control *entries = &dir->info.directory.Entries;
+ rtems_chain_control *entries = &dir->Entries;
rtems_chain_node *current = rtems_chain_first( entries );
rtems_chain_node *tail = rtems_chain_tail( entries );
@@ -72,14 +72,16 @@ static IMFS_jnode_t *IMFS_search_in_directory(
static rtems_filesystem_global_location_t **IMFS_is_mount_point(
IMFS_jnode_t *node,
- IMFS_jnode_types_t type
+ mode_t mode
rtems_filesystem_global_location_t **fs_root_ptr = NULL;
- if ( type == IMFS_DIRECTORY ) {
- if ( node->info.directory.mt_fs != NULL ) {
- fs_root_ptr = &node->info.directory.mt_fs->mt_fs_root;
+ if ( S_ISDIR( mode ) ) {
+ IMFS_directory_t *dir = (IMFS_directory_t *) node;
+ if ( dir->mt_fs != NULL ) {
+ fs_root_ptr = &dir->mt_fs->mt_fs_root;
@@ -97,13 +99,13 @@ static rtems_filesystem_eval_path_generic_status IMFS_eval_token(
RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_DONE;
rtems_filesystem_location_info_t *currentloc =
rtems_filesystem_eval_path_get_currentloc( ctx );
- IMFS_jnode_t *dir = currentloc->node_access;
+ IMFS_directory_t *dir = currentloc->node_access;
bool access_ok = rtems_filesystem_eval_path_check_access(
ctx,
RTEMS_FS_PERMS_EXEC,
- dir->st_mode,
- dir->st_uid,
- dir->st_gid
+ dir->Node.st_mode,
+ dir->Node.st_uid,
+ dir->Node.st_gid
if ( access_ok ) {
@@ -114,24 +116,27 @@ static rtems_filesystem_eval_path_generic_status IMFS_eval_token(
int eval_flags = rtems_filesystem_eval_path_get_flags( ctx );
bool follow_hard_link = (eval_flags & RTEMS_FS_FOLLOW_HARD_LINK) != 0;
bool follow_sym_link = (eval_flags & RTEMS_FS_FOLLOW_SYM_LINK) != 0;
- IMFS_jnode_types_t type = IMFS_type( entry );
+ mode_t mode = entry->st_mode;
rtems_filesystem_eval_path_clear_token( ctx );
- if ( type == IMFS_HARD_LINK && (follow_hard_link || !terminal)) {
- entry = entry->info.hard_link.link_node;
+ if ( IMFS_is_hard_link( mode ) && ( follow_hard_link || !terminal ) ) {
+ const IMFS_link_t *hard_link = (const IMFS_link_t *) entry;
+ entry = hard_link->link_node;
- if ( type == IMFS_SYM_LINK && (follow_sym_link || !terminal)) {
- const char *target = entry->info.sym_link.name;
+ if ( S_ISLNK( mode ) && ( follow_sym_link || !terminal ) ) {
+ const IMFS_sym_link_t *sym_link = (const IMFS_sym_link_t *) entry;
+ const char *target = sym_link->name;
rtems_filesystem_eval_path_recursive( ctx, target, strlen( target ) );
} else {
- IMFS_is_mount_point( entry, type );
+ IMFS_is_mount_point( entry, mode );
if ( fs_root_ptr == NULL ) {
- --dir->reference_count;
+ --dir->Node.reference_count;
++entry->reference_count;
currentloc->node_access = entry;
currentloc->node_access_2 =
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index 72aa29f..36eab85 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -19,7 +19,7 @@
#include "imfs.h"
-#define JNODE2PIPE(_jnode) ( (_jnode)->info.fifo.pipe )
+#define JNODE2PIPE(_jnode) ( ((IMFS_fifo_t *)(_jnode))->pipe )
#define LIBIO2PIPE(_iop) ( JNODE2PIPE((IMFS_jnode_t *)(_iop)->pathinfo.node_access) )
@@ -131,8 +131,8 @@ static const rtems_filesystem_file_handlers_r IMFS_fifo_handlers = {
const IMFS_node_control IMFS_node_control_fifo = {
- .imfs_type = IMFS_FIFO,
.handlers = &IMFS_fifo_handlers,
+ .node_size = sizeof(IMFS_fifo_t),
.node_initialize = IMFS_node_initialize_default,
.node_destroy = IMFS_node_destroy_default
diff --git a/cpukit/libfs/src/imfs/imfs_fsunmount.c b/cpukit/libfs/src/imfs/imfs_fsunmount.c
index a2e676f..629818f 100644
--- a/cpukit/libfs/src/imfs/imfs_fsunmount.c
+++ b/cpukit/libfs/src/imfs/imfs_fsunmount.c
@@ -21,7 +21,7 @@
#include "imfs.h"
#define jnode_get_control( jnode ) \
- (&jnode->info.directory.Entries)
+ (&((IMFS_directory_t *) jnode)->Entries)
#define jnode_has_no_children( jnode ) \
rtems_chain_is_empty( jnode_get_control( jnode ) )
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index 95e8dea..f27511e 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -25,10 +25,9 @@ static int IMFS_stat_device(
struct stat *buf
- const IMFS_jnode_t *node = loc->node_access;
- const IMFS_device_t *io = &node->info.device;
+ const IMFS_device_t *device = loc->node_access;
- buf->st_rdev = rtems_filesystem_make_dev_t( io->major, io->minor );
+ buf->st_rdev = rtems_filesystem_make_dev_t( device->major, device->minor );
return IMFS_stat( loc, buf );
@@ -53,18 +52,20 @@ static const rtems_filesystem_file_handlers_r IMFS_device_handlers = {
static IMFS_jnode_t *IMFS_node_initialize_device(
IMFS_jnode_t *node,
+ void *arg
- node->info.device.major = info->device.major;
- node->info.device.minor = info->device.minor;
+ IMFS_device_t *device = (IMFS_device_t *) node;
+ dev_t *dev = arg;
+ rtems_filesystem_split_dev_t( *dev, device->major, device->minor );
return node;
const IMFS_node_control IMFS_node_control_device = {
- .imfs_type = IMFS_DEVICE,
.handlers = &IMFS_device_handlers,
+ .node_size = sizeof(IMFS_device_t),
.node_initialize = IMFS_node_initialize_device,
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_directory.c b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
index 4b5f133..1be399b 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_directory.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_directory.c
@@ -25,7 +25,8 @@
static size_t IMFS_directory_size( const IMFS_jnode_t *node )
size_t size = 0;
- const rtems_chain_control *chain = &node->info.directory.Entries;
+ const IMFS_directory_t *dir = (const IMFS_directory_t *) node;
+ const rtems_chain_control *chain = &dir->Entries;
const rtems_chain_node *current = rtems_chain_immutable_first( chain );
const rtems_chain_node *tail = rtems_chain_immutable_tail( chain );
@@ -69,37 +70,41 @@ static const rtems_filesystem_file_handlers_r IMFS_directory_handlers = {
static IMFS_jnode_t *IMFS_node_initialize_directory(
IMFS_jnode_t *node,
+ void *arg
- rtems_chain_initialize_empty( &node->info.directory.Entries );
+ rtems_chain_initialize_empty( &dir->Entries );
return node;
-static bool IMFS_is_mount_point( const IMFS_jnode_t *node )
+static bool IMFS_is_mount_point( const IMFS_directory_t *dir )
- return node->info.directory.mt_fs != NULL;
+ return dir->mt_fs != NULL;
static IMFS_jnode_t *IMFS_node_remove_directory(
IMFS_jnode_t *node
- if ( !rtems_chain_is_empty( &node->info.directory.Entries ) ) {
+ if ( !rtems_chain_is_empty( &dir->Entries ) ) {
errno = ENOTEMPTY;
- node = NULL;
- } else if ( IMFS_is_mount_point( node ) ) {
+ dir = NULL;
+ } else if ( IMFS_is_mount_point( dir ) ) {
errno = EBUSY;
- node = NULL;
+ dir = NULL;
- return node;
const IMFS_node_control IMFS_node_control_directory = {
- .imfs_type = IMFS_DIRECTORY,
.handlers = &IMFS_directory_handlers,
+ .node_size = sizeof(IMFS_directory_t),
.node_initialize = IMFS_node_initialize_directory,
.node_remove = IMFS_node_remove_directory,
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_link.c b/cpukit/libfs/src/imfs/imfs_handlers_link.c
index cd71f95..25848be 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_link.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_link.c
@@ -30,14 +30,17 @@ static int IMFS_stat_link(
- if ( IMFS_type( node ) != IMFS_HARD_LINK ) {
- buf->st_size = strlen( node->info.sym_link.name );
+ if ( !IMFS_is_hard_link( node->st_mode ) ) {
+ const IMFS_sym_link_t *sym_link = (const IMFS_sym_link_t *) node;
+ buf->st_size = strlen( sym_link->name );
} else {
+ const IMFS_link_t *hard_link = (const IMFS_link_t *) node;
rtems_filesystem_location_info_t targetloc = *loc;
- targetloc.node_access = node->info.hard_link.link_node;
+ targetloc.node_access = hard_link->link_node;
IMFS_Set_handlers( &targetloc );
return (targetloc.handlers->fstat_h)( &targetloc, buf );
@@ -64,10 +67,12 @@ static const rtems_filesystem_file_handlers_r IMFS_link_handlers = {
static IMFS_jnode_t *IMFS_node_initialize_hard_link(
IMFS_jnode_t *node,
+ void *arg
- node->info.hard_link.link_node = info->hard_link.link_node;
+ IMFS_link_t *hard_link = (IMFS_link_t *) node;
+ hard_link->link_node = arg;
return node;
@@ -76,7 +81,8 @@ static IMFS_jnode_t *IMFS_node_remove_hard_link(
IMFS_jnode_t *node
- IMFS_jnode_t *target = node->info.hard_link.link_node;
+ IMFS_jnode_t *target = hard_link->link_node;
_Assert( target != NULL );
@@ -94,8 +100,8 @@ static IMFS_jnode_t *IMFS_node_remove_hard_link(
const IMFS_node_control IMFS_node_control_hard_link = {
- .imfs_type = IMFS_HARD_LINK,
.handlers = &IMFS_link_handlers,
+ .node_size = sizeof(IMFS_link_t),
.node_initialize = IMFS_node_initialize_hard_link,
.node_remove = IMFS_node_remove_hard_link,
@@ -103,24 +109,28 @@ const IMFS_node_control IMFS_node_control_hard_link = {
static IMFS_jnode_t *IMFS_node_initialize_sym_link(
IMFS_jnode_t *node,
+ void *arg
- node->info.sym_link.name = info->sym_link.name;
+ IMFS_sym_link_t *sym_link = (IMFS_sym_link_t *) node;
+ sym_link->name = arg;
return node;
-static IMFS_jnode_t *IMFS_node_destroy_sym_link( IMFS_jnode_t *node )
+static void IMFS_node_destroy_sym_link( IMFS_jnode_t *node )
- free( node->info.sym_link.name );
- return node;
+ free( sym_link->name );
+ IMFS_node_destroy_default( node );
const IMFS_node_control IMFS_node_control_sym_link = {
- .imfs_type = IMFS_SYM_LINK,
+ .node_size = sizeof(IMFS_sym_link_t),
.node_initialize = IMFS_node_initialize_sym_link,
.node_destroy = IMFS_node_destroy_sym_link
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
index fbc3054..db682bb 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_memfile.c
@@ -25,16 +25,16 @@ static int IMFS_stat_file(
struct stat *buf
+ const IMFS_file_t *file = loc->node_access;
- buf->st_size = node->info.file.size;
+ buf->st_size = file->File.size;
buf->st_blksize = imfs_rq_memfile_bytes_per_block;
static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
- .open_h = memfile_open,
+ .open_h = rtems_filesystem_default_open,
.close_h = rtems_filesystem_default_close,
.read_h = memfile_read,
.write_h = memfile_write,
@@ -51,17 +51,35 @@ static const rtems_filesystem_file_handlers_r IMFS_memfile_handlers = {
+static const rtems_filesystem_file_handlers_r IMFS_linfile_handlers = {
+ .open_h = IMFS_linfile_open,
+ .close_h = rtems_filesystem_default_close,
+ .read_h = IMFS_linfile_read,
+ .write_h = rtems_filesystem_default_write,
+ .ioctl_h = rtems_filesystem_default_ioctl,
+ .lseek_h = rtems_filesystem_default_lseek_file,
+ .fstat_h = IMFS_stat_file,
+ .ftruncate_h = rtems_filesystem_default_ftruncate,
+ .fsync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
+ .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync_success,
+ .fcntl_h = rtems_filesystem_default_fcntl,
+ .kqfilter_h = rtems_filesystem_default_kqfilter,
+ .poll_h = rtems_filesystem_default_poll,
+ .readv_h = rtems_filesystem_default_readv,
+ .writev_h = rtems_filesystem_default_writev
const IMFS_node_control IMFS_node_control_memfile = {
- .imfs_type = IMFS_MEMORY_FILE,
.handlers = &IMFS_memfile_handlers,
+ .node_size = sizeof(IMFS_file_t),
.node_destroy = IMFS_memfile_remove
const IMFS_node_control IMFS_node_control_linfile = {
- .imfs_type = IMFS_LINEAR_FILE,
- .handlers = &IMFS_memfile_handlers,
+ .handlers = &IMFS_linfile_handlers,
diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c b/cpukit/libfs/src/imfs/imfs_initsupp.c
index 3c103ab..5f857d1 100644
--- a/cpukit/libfs/src/imfs/imfs_initsupp.c
+++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
@@ -124,9 +124,7 @@ void IMFS_node_destroy( IMFS_jnode_t *node )
IMFS_assert( node->reference_count == 0 );
- node = (*node->control->node_destroy)( node );
- free( node );
+ (*node->control->node_destroy)( node );
void IMFS_node_free( const rtems_filesystem_location_info_t *loc )
@@ -142,7 +140,7 @@ void IMFS_node_free( const rtems_filesystem_location_info_t *loc )
static IMFS_jnode_t *IMFS_node_initialize_enosys(
IMFS_jnode_t *node,
+ void *arg
errno = ENOSYS;
@@ -152,7 +150,7 @@ static IMFS_jnode_t *IMFS_node_initialize_enosys(
IMFS_jnode_t *node,
+ void *arg
return node;
@@ -165,14 +163,14 @@ IMFS_jnode_t *IMFS_node_remove_default(
return node;
- return node;
+ free( node );
const IMFS_node_control IMFS_node_control_enosys = {
- .imfs_type = IMFS_INVALID_NODE,
.handlers = &rtems_filesystem_handlers_default,
+ .node_size = sizeof(IMFS_jnode_t),
.node_initialize = IMFS_node_initialize_enosys,
diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
index cb9246a..61b9f43 100644
--- a/cpukit/libfs/src/imfs/imfs_link.c
+++ b/cpukit/libfs/src/imfs/imfs_link.c
@@ -27,12 +27,10 @@ int IMFS_link(
size_t namelen
- IMFS_jnode_t *new_node;
- IMFS_jnode_t *target;
+ IMFS_jnode_t *new_node;
+ IMFS_jnode_t *target;
target = targetloc->node_access;
- info.hard_link.link_node = target;
* Verify this node can be linked to.
@@ -48,8 +46,8 @@ int IMFS_link(
IMFS_HARD_LINK,
name,
namelen,
- ( S_IFLNK | ( S_IRWXU | S_IRWXG | S_IRWXO )),
- &info
+ IMFS_STAT_FMT_HARD_LINK | ( S_IRWXU | S_IRWXG | S_IRWXO ),
+ target
if ( !new_node )
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index 1ef0e0b..c775a10 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -45,7 +45,6 @@ int rtems_tarfs_load(
unsigned long file_mode;
int offset;
unsigned long nblocks;
- IMFS_jnode_t *node;
int rv = 0;
int eval_flags = RTEMS_FS_FOLLOW_LINK;
rtems_filesystem_eval_path_context_t ctx;
@@ -123,16 +122,20 @@ int rtems_tarfs_load(
rtems_filesystem_eval_path_continue( &ctx );
if ( !rtems_filesystem_location_is_null( currentloc ) ) {
- node = IMFS_create_node(
- currentloc,
- IMFS_LINEAR_FILE,
- rtems_filesystem_eval_path_get_token( &ctx ),
- rtems_filesystem_eval_path_get_tokenlen( &ctx ),
- (file_mode & (S_IRWXU | S_IRWXG | S_IRWXO)) | S_IFREG,
- NULL
- node->info.linearfile.size = file_size;
- node->info.linearfile.direct = &tar_image[offset];
+ IMFS_linearfile_t *linfile = (IMFS_linearfile_t *)
+ IMFS_create_node(
+ currentloc,
+ IMFS_LINEAR_FILE,
+ rtems_filesystem_eval_path_get_token( &ctx ),
+ rtems_filesystem_eval_path_get_tokenlen( &ctx ),
+ (file_mode & (S_IRWXU | S_IRWXG | S_IRWXO)) | S_IFREG,
+ NULL
+ if ( linfile != NULL ) {
+ linfile->File.size = file_size;
+ linfile->direct = &tar_image[offset];
nblocks = (((file_size) + 511) & ~511) / 512;
diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
index c054a48..1daef3e 100644
--- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
+++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
@@ -29,10 +29,12 @@
IMFS_jnode_t *node,
+ void *arg
- node->info.generic.context = info->generic.context;
+ IMFS_generic_t *generic = (IMFS_generic_t *) node;
+ generic->context = arg;
return node;
@@ -72,45 +74,36 @@ int IMFS_make_generic_node(
if ( rv == 0 ) {
- if ( node_control->imfs_type == IMFS_GENERIC ) {
- rtems_filesystem_eval_path_context_t ctx;
- int eval_flags = RTEMS_FS_FOLLOW_LINK
- | RTEMS_FS_MAKE
- | RTEMS_FS_EXCLUSIVE;
- const rtems_filesystem_location_info_t *currentloc =
- rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
- if ( IMFS_is_imfs_instance( currentloc ) ) {
- info.generic.context = context;
- new_node = IMFS_create_node_with_control(
- currentloc,
- node_control,
- mode,
- &info
- if ( new_node != NULL ) {
- IMFS_jnode_t *parent = currentloc->node_access;
- IMFS_mtime_ctime_update( parent );
- } else {
- rv = -1;
+ rtems_filesystem_eval_path_context_t ctx;
+ int eval_flags = RTEMS_FS_FOLLOW_LINK
+ | RTEMS_FS_MAKE
+ | RTEMS_FS_EXCLUSIVE;
+ const rtems_filesystem_location_info_t *currentloc =
+ rtems_filesystem_eval_path_start( &ctx, path, eval_flags );
+ if ( IMFS_is_imfs_instance( currentloc ) ) {
+ IMFS_jnode_t *new_node = IMFS_create_node_with_control(
+ currentloc,
+ node_control,
+ mode,
+ context
+ if ( new_node != NULL ) {
+ IMFS_jnode_t *parent = currentloc->node_access;
+ IMFS_mtime_ctime_update( parent );
} else {
- rtems_filesystem_eval_path_error( &ctx, ENOTSUP );
rv = -1;
- rtems_filesystem_eval_path_cleanup( &ctx );
} else {
- errno = EINVAL;
+ rtems_filesystem_eval_path_error( &ctx, ENOTSUP );
rv = -1;
+ rtems_filesystem_eval_path_cleanup( &ctx );
return rv;
diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c b/cpukit/libfs/src/imfs/imfs_mknod.c
index 5bb8c2d..9800642 100644
--- a/cpukit/libfs/src/imfs/imfs_mknod.c
+++ b/cpukit/libfs/src/imfs/imfs_mknod.c
@@ -23,27 +23,17 @@
#include "imfs.h"
-static void get_type_and_info_by_mode_and_dev(
- mode_t mode,
- dev_t dev,
- IMFS_jnode_types_t *type,
- IMFS_types_union *info
+static IMFS_jnode_types_t get_type( mode_t mode )
- *type = IMFS_DIRECTORY;
+ return IMFS_DIRECTORY;
} else if ( S_ISBLK( mode ) || S_ISCHR( mode ) ) {
- *type = IMFS_DEVICE;
- rtems_filesystem_split_dev_t(
- dev,
- info->device.major,
- info->device.minor
+ return IMFS_DEVICE;
} else if (S_ISFIFO( mode )) {
- *type = IMFS_FIFO;
+ return IMFS_FIFO;
} else {
IMFS_assert( S_ISREG( mode ) );
- *type = IMFS_MEMORY_FILE;
+ return IMFS_MEMORY_FILE;
@@ -57,12 +47,11 @@ int IMFS_mknod(
int rv = 0;
IMFS_jnode_types_t type;
- get_type_and_info_by_mode_and_dev( mode, dev, &type, &info );
+ type = get_type( mode );
- new_node = IMFS_create_node( parentloc, type, name, namelen, mode, &info );
+ new_node = IMFS_create_node( parentloc, type, name, namelen, mode, &dev );
IMFS_jnode_t *parent = parentloc->node_access;
diff --git a/cpukit/libfs/src/imfs/imfs_mount.c b/cpukit/libfs/src/imfs/imfs_mount.c
index 06227f6..56a3621 100644
--- a/cpukit/libfs/src/imfs/imfs_mount.c
+++ b/cpukit/libfs/src/imfs/imfs_mount.c
@@ -29,8 +29,10 @@ int IMFS_mount( rtems_filesystem_mount_table_entry_t *mt_entry )
IMFS_jnode_t *node = mt_entry->mt_point_node->location.node_access;
if ( IMFS_is_directory( node ) ) {
- if ( node->info.directory.mt_fs == NULL ) {
- node->info.directory.mt_fs = mt_entry;
+ if ( dir->mt_fs == NULL ) {
+ dir->mt_fs = mt_entry;
} else {
errno = EBUSY;
rv = -1;
diff --git a/cpukit/libfs/src/imfs/imfs_readlink.c b/cpukit/libfs/src/imfs/imfs_readlink.c
index 45ca4a1..2c26954 100644
--- a/cpukit/libfs/src/imfs/imfs_readlink.c
+++ b/cpukit/libfs/src/imfs/imfs_readlink.c
@@ -26,15 +26,13 @@ ssize_t IMFS_readlink(
size_t bufsize
+ IMFS_sym_link_t *sym_link;
ssize_t i;
- node = loc->node_access;
+ sym_link = loc->node_access;
- IMFS_assert( node->control->imfs_type == IMFS_SYM_LINK );
- for( i=0; ((i<bufsize) && (node->info.sym_link.name[i] != '\0')); i++ )
- buf[i] = node->info.sym_link.name[i];
+ for( i=0; ((i<bufsize) && (sym_link->name[i] != '\0')); i++ )
+ buf[i] = sym_link->name[i];
return i;
diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c b/cpukit/libfs/src/imfs/imfs_symlink.c
index 003b379..963cefc 100644
--- a/cpukit/libfs/src/imfs/imfs_symlink.c
+++ b/cpukit/libfs/src/imfs/imfs_symlink.c
@@ -30,14 +30,14 @@ int IMFS_symlink(
const char *target
+ char *dup_target;
* Duplicate link name
- info.sym_link.name = strdup(target);
- if (info.sym_link.name == NULL) {
+ dup_target = strdup(target);
+ if (dup_target == NULL) {
rtems_set_errno_and_return_minus_one(ENOMEM);
@@ -50,11 +50,11 @@ int IMFS_symlink(
name,
namelen,
- &info
+ dup_target
if (new_node == NULL) {
- free(info.sym_link.name);
+ free(dup_target);
diff --git a/cpukit/libfs/src/imfs/imfs_unmount.c b/cpukit/libfs/src/imfs/imfs_unmount.c
index 62fc4b4..13a3a14 100644
--- a/cpukit/libfs/src/imfs/imfs_unmount.c
+++ b/cpukit/libfs/src/imfs/imfs_unmount.c
@@ -29,8 +29,10 @@ int IMFS_unmount( rtems_filesystem_mount_table_entry_t *mt_entry )
- if ( node->info.directory.mt_fs == mt_entry ) {
- node->info.directory.mt_fs = NULL;
+ if ( dir->mt_fs == mt_entry ) {
+ dir->mt_fs = NULL;
} else {
errno = EINVAL;
rv = -1;
diff --git a/cpukit/libfs/src/imfs/memfile.c b/cpukit/libfs/src/imfs/memfile.c
index 1fdb741..563001a 100644
--- a/cpukit/libfs/src/imfs/memfile.c
+++ b/cpukit/libfs/src/imfs/memfile.c
@@ -29,36 +29,36 @@
* Prototypes of private routines
MEMFILE_STATIC int IMFS_memfile_extend(
- IMFS_jnode_t *the_jnode,
- bool zero_fill,
- off_t new_length
+ IMFS_memfile_t *memfile,
+ bool zero_fill,
+ off_t new_length
MEMFILE_STATIC int IMFS_memfile_addblock(
- unsigned int block
+ unsigned int block
MEMFILE_STATIC void IMFS_memfile_remove_block(
MEMFILE_STATIC block_p *IMFS_memfile_get_block_pointer(
unsigned int block,
int malloc_it
MEMFILE_STATIC ssize_t IMFS_memfile_read(
+ IMFS_file_t *file,
off_t start,
unsigned char *destination,
unsigned int length
ssize_t IMFS_memfile_write( /* cannot be static as used in imfs_fchmod.c */
off_t start,
const unsigned char *source,
unsigned int length
@@ -70,50 +70,68 @@ void memfile_free_block(
void *memory
-int memfile_open(
+int IMFS_linfile_open(
rtems_libio_t *iop,
int oflag,
mode_t mode
+ IMFS_file_t *file;
+ file = iop->pathinfo.node_access;
* Perform 'copy on write' for linear files
- if ((iop->flags & LIBIO_FLAGS_WRITE)
- && (IMFS_type( the_jnode ) == IMFS_LINEAR_FILE)) {
- uint32_t count = the_jnode->info.linearfile.size;
- const unsigned char *buffer = the_jnode->info.linearfile.direct;
+ if ((iop->flags & LIBIO_FLAGS_WRITE) != 0) {
+ uint32_t count = file->File.size;
+ const unsigned char *buffer = file->Linearfile.direct;
- the_jnode->control = &IMFS_node_control_memfile;
- the_jnode->info.file.size = 0;
- the_jnode->info.file.indirect = 0;
- the_jnode->info.file.doubly_indirect = 0;
- the_jnode->info.file.triply_indirect = 0;
+ file->Node.control = &IMFS_node_control_memfile;
+ file->File.size = 0;
+ file->Memfile.indirect = 0;
+ file->Memfile.doubly_indirect = 0;
+ file->Memfile.triply_indirect = 0;
if ((count != 0)
- && (IMFS_memfile_write(the_jnode, 0, buffer, count) == -1))
+ && (IMFS_memfile_write(&file->Memfile, 0, buffer, count) == -1))
return -1;
return 0;
-ssize_t memfile_read(
+ssize_t IMFS_linfile_read(
rtems_libio_t *iop,
void *buffer,
size_t count
- ssize_t status;
+ IMFS_file_t *file = IMFS_iop_to_file( iop );
+ off_t start = iop->offset;
+ size_t size = file->File.size;
+ const unsigned char *data = file->Linearfile.direct;
+ if (count > size - start)
+ count = size - start;
+ IMFS_update_atime( &file->Node );
+ iop->offset = start + count;
+ memcpy(buffer, &data[start], count);
+ return (ssize_t) count;
+ssize_t memfile_read(
+ void *buffer,
+ size_t count
+ ssize_t status;
- status = IMFS_memfile_read( the_jnode, iop->offset, buffer, count );
+ status = IMFS_memfile_read( file, iop->offset, buffer, count );
if ( status > 0 )
iop->offset += status;
@@ -127,15 +145,13 @@ ssize_t memfile_write(
size_t count
+ IMFS_memfile_t *memfile = IMFS_iop_to_memfile( iop );
ssize_t status;
if ((iop->flags & LIBIO_FLAGS_APPEND) != 0)
- iop->offset = the_jnode->info.file.size;
+ iop->offset = memfile->File.size;
- status = IMFS_memfile_write( the_jnode, iop->offset, buffer, count );
+ status = IMFS_memfile_write( memfile, iop->offset, buffer, count );
if ( status > 0 )
@@ -154,9 +170,7 @@ int memfile_ftruncate(
off_t length
* POSIX 1003.1b does not specify what happens if you truncate a file
@@ -164,17 +178,17 @@ int memfile_ftruncate(
* as an extend operation.
- if ( length > the_jnode->info.file.size )
- return IMFS_memfile_extend( the_jnode, true, length );
+ if ( length > memfile->File.size )
+ return IMFS_memfile_extend( memfile, true, length );
* The in-memory files do not currently reclaim memory until the file is
* deleted. So we leave the previously allocated blocks in place for
* future use and just set the length.
- the_jnode->info.file.size = length;
+ memfile->File.size = length;
- IMFS_mtime_ctime_update(the_jnode);
+ IMFS_mtime_ctime_update( &memfile->File.Node );
return 0;
@@ -187,9 +201,9 @@ int memfile_ftruncate(
* extend the file.
- bool zero_fill,
- off_t new_length
+ bool zero_fill,
+ off_t new_length
unsigned int block;
@@ -200,8 +214,7 @@ MEMFILE_STATIC int IMFS_memfile_extend(
* Perform internal consistency checks
- IMFS_assert( IMFS_type( the_jnode ) == IMFS_MEMORY_FILE );
+ IMFS_assert( memfile );
* Verify new file size is supported
@@ -212,32 +225,32 @@ MEMFILE_STATIC int IMFS_memfile_extend(
* Verify new file size is actually larger than current size
- if ( new_length <= the_jnode->info.file.size )
+ if ( new_length <= memfile->File.size )
return 0;
* Calculate the number of range of blocks to allocate
new_blocks = new_length / IMFS_MEMFILE_BYTES_PER_BLOCK;
- old_blocks = the_jnode->info.file.size / IMFS_MEMFILE_BYTES_PER_BLOCK;
- offset = the_jnode->info.file.size - old_blocks * IMFS_MEMFILE_BYTES_PER_BLOCK;
+ old_blocks = memfile->File.size / IMFS_MEMFILE_BYTES_PER_BLOCK;
+ offset = memfile->File.size - old_blocks * IMFS_MEMFILE_BYTES_PER_BLOCK;
* Now allocate each of those blocks.
for ( block=old_blocks ; block<=new_blocks ; block++ ) {
- if ( !IMFS_memfile_addblock( the_jnode, block ) ) {
+ if ( !IMFS_memfile_addblock( memfile, block ) ) {
if ( zero_fill ) {
size_t count = IMFS_MEMFILE_BYTES_PER_BLOCK - offset;
block_p *block_ptr =
- IMFS_memfile_get_block_pointer( the_jnode, block, 0 );
+ IMFS_memfile_get_block_pointer( memfile, block, 0 );
memset( &(*block_ptr) [offset], 0, count);
offset = 0;
} else {
for ( ; block>=old_blocks ; block-- ) {
- IMFS_memfile_remove_block( the_jnode, block );
+ IMFS_memfile_remove_block( memfile, block );
rtems_set_errno_and_return_minus_one( ENOSPC );
@@ -246,9 +259,10 @@ MEMFILE_STATIC int IMFS_memfile_extend(
* Set the new length of the file.
- the_jnode->info.file.size = new_length;
+ memfile->File.size = new_length;
return 0;
@@ -258,20 +272,19 @@ MEMFILE_STATIC int IMFS_memfile_extend(
* This routine adds a single block to the specified in-memory file.
block_p memory;
block_p *block_entry_ptr;
* Obtain the pointer for the specified block number
- block_entry_ptr = IMFS_memfile_get_block_pointer( the_jnode, block, 1 );
+ block_entry_ptr = IMFS_memfile_get_block_pointer( memfile, block, 1 );
if ( !block_entry_ptr )
return 1;
@@ -300,14 +313,14 @@ MEMFILE_STATIC int IMFS_memfile_addblock(
* dangerous and the results unpredictable.
block_p *block_ptr;
block_p ptr;
- block_ptr = IMFS_memfile_get_block_pointer( the_jnode, block, 0 );
+ block_ptr = IMFS_memfile_get_block_pointer( memfile, block, 0 );
if ( block_ptr ) {
ptr = *block_ptr;
*block_ptr = 0;
@@ -372,21 +385,22 @@ static void memfile_free_blocks_in_table(
* Regardless until the IMFS implementation is proven, it
* is better to stick to simple, easy to understand algorithms.
-IMFS_jnode_t *IMFS_memfile_remove(
+void IMFS_memfile_remove(
- IMFS_memfile_t *info;
+ IMFS_memfile_t *memfile;
int i;
int j;
unsigned int to_free;
block_p *p;
+ memfile = (IMFS_memfile_t *) the_jnode;
* Eventually this could be set smarter at each call to
@@ -400,26 +414,25 @@ IMFS_jnode_t *IMFS_memfile_remove(
* + doubly indirect
* + triply indirect
- info = &the_jnode->info.file;
- if ( info->indirect ) {
- memfile_free_blocks_in_table( &info->indirect, to_free );
+ if ( memfile->indirect ) {
+ memfile_free_blocks_in_table( &memfile->indirect, to_free );
- if ( info->doubly_indirect ) {
+ if ( memfile->doubly_indirect ) {
for ( i=0 ; i<IMFS_MEMFILE_BLOCK_SLOTS ; i++ ) {
- if ( info->doubly_indirect[i] ) {
+ if ( memfile->doubly_indirect[i] ) {
- (block_p **)&info->doubly_indirect[i], to_free );
+ (block_p **)&memfile->doubly_indirect[i], to_free );
- memfile_free_blocks_in_table( &info->doubly_indirect, to_free );
+ memfile_free_blocks_in_table( &memfile->doubly_indirect, to_free );
- if ( info->triply_indirect ) {
+ if ( memfile->triply_indirect ) {
- p = (block_p *) info->triply_indirect[i];
+ p = (block_p *) memfile->triply_indirect[i];
if ( !p ) /* ensure we have a valid pointer */
break;
for ( j=0 ; j<IMFS_MEMFILE_BLOCK_SLOTS ; j++ ) {
@@ -428,13 +441,13 @@ IMFS_jnode_t *IMFS_memfile_remove(
- (block_p **)&info->triply_indirect[i], to_free );
+ (block_p **)&memfile->triply_indirect[i], to_free );
- (block_p **)&info->triply_indirect, to_free );
+ (block_p **)&memfile->triply_indirect, to_free );
- return the_jnode;
+ IMFS_node_destroy_default( the_jnode );
@@ -449,7 +462,7 @@ IMFS_jnode_t *IMFS_memfile_remove(
* read).
off_t start,
unsigned int length
@@ -469,9 +482,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
- IMFS_assert( IMFS_type( the_jnode ) == IMFS_MEMORY_FILE ||
- IMFS_type( the_jnode ) == IMFS_LINEAR_FILE );
+ IMFS_assert( file );
IMFS_assert( dest );
@@ -480,28 +491,13 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
my_length = length;
- if ( IMFS_type( the_jnode ) == IMFS_LINEAR_FILE ) {
- unsigned char *file_ptr;
- file_ptr = (unsigned char *)the_jnode->info.linearfile.direct;
- if (my_length > (the_jnode->info.linearfile.size - start))
- my_length = the_jnode->info.linearfile.size - start;
- memcpy(dest, &file_ptr[start], my_length);
- IMFS_update_atime( the_jnode );
- return my_length;
* If the last byte we are supposed to read is past the end of this
* in memory file, then shorten the length to read.
last_byte = start + length;
- if ( last_byte > the_jnode->info.file.size )
- my_length = the_jnode->info.file.size - start;
+ if ( last_byte > file->Memfile.File.size )
+ my_length = file->Memfile.File.size - start;
copied = 0;
@@ -521,7 +517,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK - start_offset;
if ( to_copy > my_length )
to_copy = my_length;
+ block_ptr = IMFS_memfile_get_block_pointer( &file->Memfile, block, 0 );
if ( !block_ptr )
return copied;
memcpy( dest, &(*block_ptr)[ start_offset ], to_copy );
@@ -536,7 +532,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
to_copy = IMFS_MEMFILE_BYTES_PER_BLOCK;
while ( my_length >= IMFS_MEMFILE_BYTES_PER_BLOCK ) {
if ( !block_ptr )
return copied;
memcpy( dest, &(*block_ptr)[ 0 ], to_copy );
@@ -552,14 +548,14 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
IMFS_assert( my_length < IMFS_MEMFILE_BYTES_PER_BLOCK );
if ( my_length ) {
if ( !block_ptr )
return copied;
memcpy( dest, &(*block_ptr)[ 0 ], my_length );
copied += my_length;
return copied;
@@ -568,10 +564,10 @@ MEMFILE_STATIC ssize_t IMFS_memfile_read(
* IMFS_memfile_write
* This routine writes the specified data buffer into the in memory
- * file pointed to by the_jnode. The file is extended as needed.
+ * file pointed to by memfile. The file is extended as needed.
MEMFILE_STATIC ssize_t IMFS_memfile_write(
off_t start,
unsigned int length
@@ -593,8 +589,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
IMFS_assert( source );
my_length = length;
@@ -603,10 +598,10 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
last_byte = start + my_length;
- if ( last_byte > the_jnode->info.file.size ) {
- bool zero_fill = start > the_jnode->info.file.size;
+ if ( last_byte > memfile->File.size ) {
+ bool zero_fill = start > memfile->File.size;
- status = IMFS_memfile_extend( the_jnode, zero_fill, last_byte );
+ status = IMFS_memfile_extend( memfile, zero_fill, last_byte );
if ( status )
return status;
@@ -629,7 +624,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
if ( !block_ptr )
return copied;
#if 0
@@ -656,7 +651,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
if ( !block_ptr )
return copied;
#if 0
@@ -676,7 +671,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
if ( my_length ) {
if ( !block_ptr )
return copied;
#if 0
@@ -687,7 +682,7 @@ MEMFILE_STATIC ssize_t IMFS_memfile_write(
copied += to_copy;
- IMFS_mtime_ctime_update( the_jnode );
return copied;
@@ -723,13 +718,12 @@ block_p *IMFS_memfile_get_block_pointer_DEBUG(
#else
#endif
unsigned int block,
int malloc_it
unsigned int my_block;
unsigned int singly;
unsigned int doubly;
unsigned int triply;
@@ -740,17 +734,15 @@ block_p *IMFS_memfile_get_block_pointer(
my_block = block;
* Is the block number in the simple indirect portion?
if ( my_block <= LAST_INDIRECT ) {
- p = info->indirect;
+ p = memfile->indirect;
if ( malloc_it ) {
@@ -758,15 +750,15 @@ block_p *IMFS_memfile_get_block_pointer(
p = memfile_alloc_block();
if ( !p )
return 0;
- info->indirect = p;
+ memfile->indirect = p;
- return &info->indirect[ my_block ];
+ return &memfile->indirect[ my_block ];
if ( !p )
return 0;
@@ -779,14 +771,14 @@ block_p *IMFS_memfile_get_block_pointer(
singly = my_block % IMFS_MEMFILE_BLOCK_SLOTS;
doubly = my_block / IMFS_MEMFILE_BLOCK_SLOTS;
- p = info->doubly_indirect;
+ p = memfile->doubly_indirect;
if ( malloc_it ) {
if ( !p ) {
if ( !p )
return 0;
- info->doubly_indirect = p;
+ memfile->doubly_indirect = p;
p1 = (block_p *)p[ doubly ];
@@ -821,14 +813,14 @@ block_p *IMFS_memfile_get_block_pointer(
triply = doubly / IMFS_MEMFILE_BLOCK_SLOTS;
doubly %= IMFS_MEMFILE_BLOCK_SLOTS;
- p = info->triply_indirect;
+ p = memfile->triply_indirect;
if ( malloc_it ) {
if ( !p ) {
if ( !p )
return 0;
- info->triply_indirect = p;
+ memfile->triply_indirect = p;
p1 = (block_p *) p[ triply ];
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index 03e4c19..671ad14 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -262,12 +262,12 @@ static const rtems_filesystem_file_handlers_r node_handlers = {
static IMFS_jnode_t *node_initialize(
IMFS_jnode_t *node,
+ void *arg
test_state *state = NULL;
state = IMFS_generic_get_context_by_node(node);
rtems_test_assert(*state == TEST_NEW);
@@ -286,19 +286,19 @@ static IMFS_jnode_t *node_remove(IMFS_jnode_t *node)
return node;
-static IMFS_jnode_t *node_destroy(IMFS_jnode_t *node)
+static void node_destroy(IMFS_jnode_t *node)
test_state *state = IMFS_generic_get_context_by_node(node);
rtems_test_assert(*state == TEST_REMOVED);
*state = TEST_DESTROYED;
- return node;
static const IMFS_node_control node_control = {
.handlers = &node_handlers,
+ .node_size = sizeof(IMFS_generic_t),
.node_initialize = node_initialize,
.node_remove = node_remove,
.node_destroy = node_destroy
@@ -370,7 +370,7 @@ static void test_imfs_make_generic_node(void)
static IMFS_jnode_t *node_initialize_error(
IMFS_jnode_t *node,
+ void *arg
errno = EIO;
@@ -385,24 +385,14 @@ static IMFS_jnode_t *node_remove_inhibited(IMFS_jnode_t *node)
return node;
-static IMFS_jnode_t *node_destroy_inhibited(IMFS_jnode_t *node)
+static void node_destroy_inhibited(IMFS_jnode_t *node)
rtems_test_assert(false);
- return node;
-static const IMFS_node_control node_invalid_control = {
- .handlers = &node_handlers,
- .node_initialize = node_initialize_error,
- .node_remove = node_remove_inhibited,
- .node_destroy = node_destroy_inhibited
static const IMFS_node_control node_initialization_error_control = {
@@ -424,17 +414,6 @@ static void test_imfs_make_generic_node_errors(void)
errno = 0;
rv = IMFS_make_generic_node(
path,
- S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
- &node_invalid_control,
- NULL
- rtems_test_assert(rv == -1);
- rtems_test_assert(errno == EINVAL);
- rtems_test_assert(rtems_resource_snapshot_check(&before));
- errno = 0;
- rv = IMFS_make_generic_node(
- path,
S_IFDIR | S_IRWXU | S_IRWXG | S_IRWXO,
&node_control,
NULL
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index 0361607..f9d3936 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -232,13 +232,11 @@ static const rtems_filesystem_file_handlers_r node_handlers = {
.writev_h = handler_writev
-static const IMFS_node_control node_control = {
- .node_initialize = IMFS_node_initialize_default,
- .node_destroy = IMFS_node_destroy_default
+static const IMFS_node_control node_control = IMFS_GENERIC_INITIALIZER(
+ &node_handlers,
+ IMFS_node_initialize_default,
static void test(void)
diff --git a/testsuites/libtests/tar02/init.c b/testsuites/libtests/tar02/init.c
index ebf87f8..8d790f6 100644
--- a/testsuites/libtests/tar02/init.c
+++ b/testsuites/libtests/tar02/init.c
@@ -68,7 +68,6 @@ rtems_task Init(
TEST_BEGIN();
test_tarfs_load();
- IMFS_dump();
TEST_END();
exit( 0 );
diff --git a/testsuites/libtests/tar02/tar02.scn b/testsuites/libtests/tar02/tar02.scn
index f4ba9ce..e7a9165 100644
--- a/testsuites/libtests/tar02/tar02.scn
+++ b/testsuites/libtests/tar02/tar02.scn
@@ -1,4 +1,4 @@
-*** TAR02 TEST ***
+*** BEGIN OF TEST TAR 2 ***
Loading tarfs image ... successful
========= /home/test_file =========
(0)This is a test of loading an RTEMS filesystem from an
@@ -8,14 +8,4 @@ initial tar image.
initial tar image.
-*************** Dump of Entire IMFS ***************
-....dev/
-........ttyS0 (device 0, 0)
-........console (device 0, 0)
-........ttyS1 (device 0, 1)
-....home/
-........test_file (file 73 0x390f8)
-....symlink links not printed
-*************** End of Dump ***************
-*** END OF TAR02 TEST ***
+*** END OF TEST TAR 2 ***
diff --git a/testsuites/psxtests/psxfile01/psxfile01.scn b/testsuites/psxtests/psxfile01/psxfile01.scn
index 5cdd609..605fef1 100644
--- a/testsuites/psxtests/psxfile01/psxfile01.scn
+++ b/testsuites/psxtests/psxfile01/psxfile01.scn
@@ -1,11 +1,4 @@
-*** FILE TEST 1 ***
-....dev/
-........console_a (device 0, 0)
-........console_b (device 0, 1)
+*** BEGIN OF TEST PSXFILE 1 ***
stat of /dev/console
....st_dev (0xfffe:0x0)
....st_rdev (0x0:0x0)
@@ -181,26 +174,6 @@ This is call 5 to fprintf
....ctime = Sat Dec 31 09:00:00 1988
....st_blksize 80
....st_blocks 0
-....dev/
-........tty/
-............S3 (device 255, 128)
-........test_console (device 0, 0)
-....etc/
-........passwd (file 0)
-....tmp/
-........my_dir/
-........tom (file 0)
-........john (file 0)
-........joel (file 533)
-........j (file 130)
-....imfs/
-........hidden_on_mount/
truncate /tmp/j to length of 40
@@ -209,53 +182,15 @@ truncate /tmp/j to length of 40
....nlink = 1
....uid = 0
....gid = 0
-....atime = Sat Dec 31 09:00:02 1988
-....mtime = Sat Dec 31 09:00:00 1988
-....ctime = Sat Dec 31 09:00:00 1988
+....atime = Sat Dec 31 09:00:01 1988
+....mtime = Sat Dec 31 09:00:02 1988
+....ctime = Sat Dec 31 09:00:02 1988
....st_blksize 80
....st_blocks 0
-....dev/
-........tty/
-....etc/
-....tmp/
-........my_dir/
-........j (file 40)
-....imfs/
truncate /tmp/j to length of 0
truncate /tmp to length of 0 should fail with EISDIR
21: Is a directory
-....dev/
-........tty/
-....etc/
-....tmp/
-........my_dir/
-........j (file 0)
-....imfs/
Writing First File
Writing Second File
(0)this is a test line
@@ -264,4 +199,4 @@ this is a test line
this is a test line
-*** END OF FILE TEST 1 ***
+*** END OF TEST PSXFILE 1 ***
diff --git a/testsuites/psxtests/psxfile01/test.c b/testsuites/psxtests/psxfile01/test.c
index 94f80c8..abc9295 100644
--- a/testsuites/psxtests/psxfile01/test.c
+++ b/testsuites/psxtests/psxfile01/test.c
@@ -166,19 +166,13 @@ int main(
* Grab the maximum size of an in-memory file.
- max_size = IMFS_memfile_maximum_size();
+ max_size = IMFS_MEMFILE_MAXIMUM_SIZE;
build_time( &time, 12, 31, 1988, 9, 0, 0, 0 );
rtems_status = rtems_clock_set( &time );
directive_failed( rtems_status, "clock set" );
- * Dump an empty file system
- IMFS_dump();
* Simple stat() of /dev/console.
@@ -605,8 +599,6 @@ since new path is not valid");
rtems_test_assert( mtime1 == mtime2);
rtems_test_assert( ctime1 == ctime2);
- IMFS_dump();
unlink( "/tmp/joel" );
@@ -631,8 +623,6 @@ since new path is not valid");
rtems_test_assert( mtime1 != mtime2);
rtems_test_assert( ctime1 != ctime2);
- IMFS_dump();
/* try to truncate the console and see what happens */
status = truncate( "/dev/console", 40 );
rtems_test_assert( status == 0 );
@@ -647,8 +637,6 @@ since new path is not valid");
printf( "%d: %s\n", errno, strerror( errno ) );
rtems_test_assert( errno == EISDIR );
- IMFS_dump();
status = truncate( "/tmp/fred", 10 );
rtems_test_assert( status == -1);
diff --git a/testsuites/psxtests/psximfs02/init.c b/testsuites/psxtests/psximfs02/init.c
index 9d45b75..c7e2d3c 100644
--- a/testsuites/psxtests/psximfs02/init.c
+++ b/testsuites/psxtests/psximfs02/init.c
@@ -31,7 +31,6 @@ extern int seteuid(uid_t euid);
/* forward declarations to avoid warnings */
rtems_task Init(rtems_task_argument argument);
-void IMFS_dump(void);
rtems_task Init(
@@ -183,8 +182,6 @@ rtems_task Init(
puts( "Creating a fifo -- OK" );
status = mkfifo( "/fifo", S_IRWXU );
- IMFS_dump();
puts( "chown /fifo to 10 -- OK" );
status = chown( "/fifo", 10, 10 );
diff --git a/testsuites/psxtests/psximfs02/psximfs02.scn b/testsuites/psxtests/psximfs02/psximfs02.scn
index f86e975..930a0fa 100644
--- a/testsuites/psxtests/psximfs02/psximfs02.scn
+++ b/testsuites/psxtests/psximfs02/psximfs02.scn
@@ -1,4 +1,4 @@
-*** TEST IMFS 02 ***
+*** BEGIN OF TEST PSXIMFS 2 ***
Creating directory /dir00
Creating directory /dir00/dir01
Changing directory to /dir00
@@ -24,42 +24,22 @@ Opening /node-link in WRONLY mode -- expect EACCES
Creating a symlink /node-slink for /node
Opening /node-slink in WRONLY mode -- expect EACCES
Allocate most of heap
-Attempt to mount a fs at /dir01 -- expect ENOMEM
-Freeing allocated memory
-Allocate most of heap
+Attempt to mount a fs at dir01 -- expect ENOMEMFreeing allocated memory
+Allocate most of heap
Attempt to create /node-link-2 for /node -- expect ENOMEM
Attempt to create /node-slink-2 for /node -- expect ENOMEM
-Attempt to create /node-slink-2 for /node -- expect ENOMEM
-Attempt to stat a hardlink -- expect ENOTSUP
+Attempt to create node-slink-2 for /node -- expect ENOMEMFreeing allocated memory
+Attempt to stat a hardlink
Changing euid to 10
Attempt chmod on /node -- expect EPERM
Attempt chown on /node -- expect EPERM
Changing euid back to 0 [root]
-....dev/
-....dir00/
-........dir01/
-........dir01-link0 links not printed
-........dir01-link1 links not printed
-........dir01-link2 links not printed
-........dir01-link3 links not printed
-........dir01-link4 links not printed
-........dir01-link5 links not printed
-........dir01-link6 links not printed
-....node (file 0)
-....node-link links not printed
-....node-slink links not printed
-....fifo FIFO not printed
Changing euid to 10
chmod /fifo -- OK
chown /fifo to 0 -- OK
-*** END OF TEST IMFS 02 ***
+*** END OF TEST PSXIMFS 2 ***
1.8.4.5
