<sys/socket.h> POSIX Compliance Issue
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jan 23 00:37:40 UTC 2015
Hi
In running the Open Group FACE Conformance Test Suite on RTEMS, it
spotted that the old network stack's <sys/socket.h> does not include
the types.h (or sys/types.h) to get ssize_t. That means you get a type
undefined error if you followk
http://pubs.opengroup.org/onlinepubs/7908799/xns/syssocket.h.html
This impacts all the methods in <sys/socket.h> since the test suite assumes
that it only needs to include the .h file(s) specified by Open Group.
+ Does this occur with the new stack?
+ Is it OK to add the appropiate include file to old stack's socket.h?
Here is a test case.
#include <sys/socket.h>
void f(void)
ssize_t s;
int socket = 0;
void *buffer = 0;
size_t length = 0;
int flags = 0;
struct sockaddr *address = 0;
socklen_t *address_len = 0;
s = recvfrom(socket, buffer, length, flags, address, address_len);
