Xilinx Microblaze copyrights question
Thu Jan 29 02:25:03 UTC 2015
These may already be in the tree as part of the Zynq port if the serial port(s) are the same.
Please post the full copyright text but check if the same code is already in the tree in support of another of their ports.
And congratulations on getting it working this much quickly. :)
On January 28, 2015 1:07:38 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>See if there is a license in the distribution that contained the Xilinx
>files.
>-Gedare
>On Wed, Jan 28, 2015 at 1:05 PM, Hesham Moustafa
><heshamelmatary at gmail.com> wrote:
>> Hi,
>> I am currently porting RTEMS to Microblaze based on Joel's work.
>Hello
>> world hits Init and printf successfully, so I have to write a console
>> driver. Xilinx has UART driver already. The question is can I copy
>> code from Xilinx files to RTEMS? The files have "(c) Copyright
>> 2002-2013 Xilinx, Inc. All rights reserved." lines only.
>> P.S. Joel's work quotes files from Xilinx as is.
>> Best,
>> Hesham
>> devel mailing list
>> devel at rtems.org
>devel mailing list
>devel at rtems.org
--joel
