Patch: RaspberryPi clock driver
Tue Jul 7 21:06:11 UTC 2015
Thanks!
That applied perfectly and I just pushed it.
Hopefully it corrected the anomalies you saw.
FWIW I just noticed the Pi clock driver does not have support
for getting the nanoseconds since the last tick so timestamps
will have the granularity of the clock tick.
On 7/7/2015 3:52 PM, Jan Sommer wrote:
> Hi,
> I hope that's how this works. Here is a patch for the raspberrypi clock driver to use the correct value for the timer counter based on rtems_configuration_get_microseconds_per_tick() as discussed in the user-list.
> Cheers,
>     Jan
