Fwd: [PR 66854 powerpc regression] Fix RTEMS powerpc build issue
Gedare Bloom
gedare at rtems.org
Wed Jul 15 13:36:37 UTC 2015
in case anyone else hit this..
---------- Forwarded message ----------
From: Michael Meissner <meissner at linux.vnet.ibm.com>
Date: Tue, Jul 14, 2015 at 8:09 PM
Subject: [PR 66854 powerpc regression] Fix RTEMS powerpc build issue
To: gcc-patches at gcc.gnu.org, dje.gcc at gmail.com
My IEEE 128-bit floating point infrastructure patches resulted in a
segmentation violation on RTEMS when building libgcc. I had put a test using a
type tree variable before the test whether it was NULL or not.
This patch bootstraps on 64-bit Linux, and it also fixes the problem in
question when building a RTEMS compiler. Can this patch be installed if it
causes no further regressions for RTEMS?
2015-07-14 Michael Meissner <meissner at linux.vnet.ibm.com>
PR target/66854
* config/rs6000/rs6000.c (rs6000_pass_by_reference): Move test for
null before IEEE 128-bit floating point support patch.
Michael Meissner, IBM
IBM, M/S 2506R, 550 King Street, Littleton, MA 01460-6245, USA
email: meissner at linux.vnet.ibm.com, phone: +1 (978) 899-4797
Index: gcc/config/rs6000/rs6000.c
--- gcc/config/rs6000/rs6000.c (revision 225780)
+++ gcc/config/rs6000/rs6000.c (working copy)
@@ -10832,6 +10832,9 @@
machine_mode mode, const_tree type,
bool named ATTRIBUTE_UNUSED)
+ if (!type)
+ return 0;
if (DEFAULT_ABI == ABI_V4 && TARGET_IEEEQUAD
&& FLOAT128_IEEE_P (TYPE_MODE (type)))
@@ -10840,9 +10843,6 @@
return 1;
- if (!type)
- return 0;
if (DEFAULT_ABI == ABI_V4 && AGGREGATE_TYPE_P (type))
if (TARGET_DEBUG_ARG)
