[PATCH 2/6] RSB: add tiff-4.0.2 bset
QIAO YANG yangqiao0505 at me.com
Sun Jul 19 20:47:43 UTC 2015
 rtems/config/4.11/graphics/libtiff.bset   | 20 ++++++++++
 rtems/config/graphics/libtiff-4.0.2-1.cfg | 21 +++++++++++
 source-builder/config/libtiff-1.cfg       | 62 +++++++++++++++++++++++++++++++
 3 files changed, 103 insertions(+)
 create mode 100644 rtems/config/4.11/graphics/libtiff.bset
 create mode 100644 rtems/config/graphics/libtiff-4.0.2-1.cfg
 create mode 100644 source-builder/config/libtiff-1.cfg
diff --git a/rtems/config/4.11/graphics/libtiff.bset b/rtems/config/4.11/graphics/libtiff.bset
new file mode 100644
index 0000000..d4a9165
--- /dev/null
+++ b/rtems/config/4.11/graphics/libtiff.bset
@@ -0,0 +1,20 @@
+# Build set for libtiff
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build libtiff.
+graphics/libtiff-4.0.2-1.cfg
diff --git a/rtems/config/graphics/libtiff-4.0.2-1.cfg b/rtems/config/graphics/libtiff-4.0.2-1.cfg
index 0000000..e0b708e
--- /dev/null
+++ b/rtems/config/graphics/libtiff-4.0.2-1.cfg
@@ -0,0 +1,21 @@
+# libtiff 4.0.2
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# tiff Version
+%define tiff_version 4.0.2
+%hash md5 tiff-%{tiff_version}.tar.gz 04a08fa1e07e696e820a0c3f32465a13
+# tiff Build configuration
+%include %{_configdir}/libtiff-1.cfg
diff --git a/source-builder/config/libtiff-1.cfg b/source-builder/config/libtiff-1.cfg
index 0000000..bebc1ce
--- /dev/null
+++ b/source-builder/config/libtiff-1.cfg
@@ -0,0 +1,62 @@
+# libtiff
+# This configuration file configure's, make's and install's libtiff.
+%define release 1
+%endif
+Name:      libtiff-v%{tiff_version}-%{_host}-%{release}
+Summary:   libtiff provides support for the Tag Image File Format (TIFF), a widely used format for storing image data.
+Version:   %{tiff_version}
+Release:   %{release}
+URL:     http://www.libtiff.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# libtiff Source
+%source set libtiff ftp://ftp.remotesensing.org/pub/libtiff/tiff-%{tiff_version}.tar.gz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_tiff="tiff-%{tiff_version}"
+  %source setup libtiff -q -n tiff-%{tiff_version}
+  %patch setup libtiff -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  CFLAGS= CXXFLAGS= ../${source_dir_tiff}/configure \
+    --host=%{_host} \
+    --prefix=%{_prefix} \
+    --includedir=%{_prefix}/lib/include \
+    --disable-shared
+#  %{__make} %{?_smp_mflags} all
+  %{__make}
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.1.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150719/948522d3/attachment.html>
