[PATCH 3/6] RSB: add freetype2 bset
QIAO YANG yangqiao0505 at me.com
Sun Jul 19 20:48:22 UTC 2015
 rtems/config/4.11/graphics/freetype2.bset   | 20 ++++++++++
 rtems/config/graphics/freetype-2.4.10-1.cfg | 21 ++++++++++
 source-builder/config/freetype-1.cfg        | 62 +++++++++++++++++++++++++++++
 3 files changed, 103 insertions(+)
 create mode 100644 rtems/config/4.11/graphics/freetype2.bset
 create mode 100644 rtems/config/graphics/freetype-2.4.10-1.cfg
 create mode 100644 source-builder/config/freetype-1.cfg
diff --git a/rtems/config/4.11/graphics/freetype2.bset b/rtems/config/4.11/graphics/freetype2.bset
new file mode 100644
index 0000000..71971a0
--- /dev/null
+++ b/rtems/config/4.11/graphics/freetype2.bset
@@ -0,0 +1,20 @@
+# Build set for freetype
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build freetype.
+graphics/freetype-2.4.10-1.cfg
diff --git a/rtems/config/graphics/freetype-2.4.10-1.cfg b/rtems/config/graphics/freetype-2.4.10-1.cfg
index 0000000..524dc3a
--- /dev/null
+++ b/rtems/config/graphics/freetype-2.4.10-1.cfg
@@ -0,0 +1,21 @@
+# freetype 2.4.10
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# freetype Version
+%define freetype_version 2.4.10
+%hash md5 freetype-%{freetype_version}.tar.gz 4f255c6ee5d5cc2b5c3d423a07386fcb
+# freetype Build configuration
+%include %{_configdir}/freetype-1.cfg
diff --git a/source-builder/config/freetype-1.cfg b/source-builder/config/freetype-1.cfg
index 0000000..72fe1d3
--- /dev/null
+++ b/source-builder/config/freetype-1.cfg
@@ -0,0 +1,62 @@
+# freetype
+# This configuration file configure's, make's and install's freetype.
+%define release 1
+%endif
+Name:      freetype-v%{freetype_version}-%{_host}-%{release}
+Summary:   freetype is for producing high-quality output (glyph images) of most vector and bitmap font formats.
+Version:   %{freetype_version}
+Release:   %{release}
+URL:     http://www.freetype.org/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# freetype Source
+%source set freetype http://download.savannah.gnu.org/releases/freetype/freetype-%{freetype_version}.tar.gz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_freetype="freetype-%{freetype_version}"
+  %source setup freetype -q -n freetype-%{freetype_version}
+  %patch setup freetype -p1
+  cd ${build_top}
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+   ../${source_dir_freetype}/configure \
+    --host=%{_host} \
+    --prefix=%{_prefix} \
+    --includedir=%{_includedir} \
+    --libdir=%{_libdir} \
+    --disable-shared
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
2.1.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150719/5dc42b15/attachment-0001.html>
