SMP support for Raspberry Pi 2
Mon Jul 20 06:12:03 UTC 2015
On 19/07/15 09:52, Rohini Kulkarni wrote:
> Do I have to just run the smp tests executables bare metal?
You should run the SMP tests like all the other tests.
> RTEMS kernel image runs fine, but the smp01 executable that I tried
> produces no output at all.
In case for example ticker.exe runs, and smp01.exe produces no output,
then something is wrong with the SMP startup. You can debug this problem
on Qemu. Without a debugger it will be very hard.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
