SMP support for Raspberry Pi 2
Tue Jul 28 06:54:33 UTC 2015
Hello Rohini,
please use the devel list.
On 28/07/15 07:41, Rohini Kulkarni wrote:
> Hi,
> I wish to understand where the interprocessor interrupts are used
> during the boot process. During final initialization of SMP I can see
> rtems_interrupt_handler_install(
>       ARM_GIC_IRQ_SGI_0,
>       "IPI",
>       RTEMS_INTERRUPT_UNIQUE,
>       bsp_inter_processor_interrupt,
>       NULL
> Raspberry Pi 2 does not have the generic interrupt controller.
> Interrupt routing will have to be handled differently. So I wish to
> understand how/ where it is used. I suppose this might be the problem.
Sorry, that the documentation is so scattered.  I think we should move
everything into the CPU Architecture Supplement. It would be nice if you
can help to improve the documentation since you have a different view point.
You must install the IPI during the system initialization. It is raised
via the _CPU_SMP_Send_interrupt() function, for an example see
arm-a9mpcore-smp.c.
> Thanks.
> On Wed, Jul 22, 2015 at 7:08 PM, Rohini Kulkarni
> <krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>> wrote:
>     Ok. Qemu suggestion seems helpful for the cache configuration
>     issue though. I am trying with Pi 1.
>     Thanks.
>     On 22 Jul 2015 18:59, "Sebastian Huber"
>     <sebastian.huber at embedded-brains.de
>     <mailto:sebastian.huber at embedded-brains.de>> wrote:
>         Sorry, I cannot help you here since I never worked with a
>         Raspberry Pi.
>         Sebastian Huber, embedded brains GmbH
>         Address : Dornierstr. 4, D-82178 Puchheim, Germany
>         Phone   : +49 89 189 47 41-16
>         Fax     : +49 89 189 47 41-09
>         E-Mail  : sebastian.huber at embedded-brains.de
>         PGP     : Public key available on request.
>         Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>         des EHUG.
> Rohini Kulkarni
