[PATCH 1/5] monitor: Remove notepad support
Sebastian Huber
Thu Jul 23 07:14:50 UTC 2015
cpukit/libmisc/monitor/mon-prmisc.c | 16 ----------------
cpukit/libmisc/monitor/mon-task.c | 23 +----------------------
cpukit/libmisc/monitor/monitor.h | 3 ---
3 files changed, 1 insertion(+), 41 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 9140f92..1b3a4df 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -248,19 +248,3 @@ rtems_monitor_dump_events(rtems_event_set events)
return fprintf(stdout,"%08" PRIx32, events);
-int
-rtems_monitor_dump_notepad(uint32_t *notepad)
- int length = 0;
- if (rtems_configuration_get_notepads_enabled()) {
- int i;
- for (i=0; i < RTEMS_NUMBER_NOTEPADS; i++)
- if (notepad[i])
- length += fprintf(stdout,"%d: 0x%" PRIx32, i, notepad[i]);
- return length;
diff --git a/cpukit/libmisc/monitor/mon-task.c b/cpukit/libmisc/monitor/mon-task.c
index c08f1d2..851c593 100644
--- a/cpukit/libmisc/monitor/mon-task.c
+++ b/cpukit/libmisc/monitor/mon-task.c
@@ -46,17 +46,6 @@ rtems_monitor_task_canonical(
canonical_task->modes = 0; /* XXX FIX ME.... rtems_thread->current_modes; */
canonical_task->attributes = 0 /* XXX FIX ME rtems_thread->API_Extensions[ THREAD_API_RTEMS ]->attribute_set */;
- * We know this is deprecated and don't want a warning on every BSP built.
- #pragma GCC diagnostic push
- #pragma GCC diagnostic ignored "-Wdeprecated-declarations"
- if ( rtems_configuration_get_notepads_enabled() ) {
- (void) memcpy(
- canonical_task->notepad, api ->Notepads, sizeof(canonical_task->notepad));
- #pragma GCC diagnostic pop
/* XXX more to fix */
(void) memcpy(&canonical_task->wait_args, &rtems_thread->Wait.Extra, sizeof(canonical_task->wait_args));
@@ -70,7 +59,7 @@ rtems_monitor_task_dump_header(
fprintf(stdout,"\
- ID NAME PRI STATE MODES EVENTS WAITID WAITARG NOTES\n\
+ ID NAME PRI STATE MODES EVENTS WAITID WAITARG\n\
/*23456789 123456789 123456789 123456789 123456789 123456789 123456789 123456789
0 1 2 3 4 5 6 7 */
@@ -108,15 +97,5 @@ rtems_monitor_task_dump(
length += rtems_monitor_dump_hex(monitor_task->wait_args);
- length += rtems_monitor_pad(72, length);
- length += rtems_monitor_dump_notepad(monitor_task->notepad);
fprintf(stdout,"\n");
diff --git a/cpukit/libmisc/monitor/monitor.h b/cpukit/libmisc/monitor/monitor.h
index 799df35..2f6cb71 100644
--- a/cpukit/libmisc/monitor/monitor.h
+++ b/cpukit/libmisc/monitor/monitor.h
@@ -104,8 +104,6 @@ typedef struct {
rtems_event_set events;
rtems_mode modes;
rtems_attribute attributes;
- uint32_t notepad[RTEMS_NUMBER_NOTEPADS]
- RTEMS_COMPILER_DEPRECATED_ATTRIBUTE;
rtems_id wait_id;
uint32_t wait_args;
uint32_t ticks;
@@ -413,7 +411,6 @@ int rtems_monitor_dump_state(States_Control state);
int rtems_monitor_dump_modes(rtems_mode modes);
int rtems_monitor_dump_attributes(rtems_attribute attributes);
int rtems_monitor_dump_events(rtems_event_set events);
-int rtems_monitor_dump_notepad(uint32_t *notepad);
/* object.c */
rtems_id rtems_monitor_id_fixup(rtems_id, uint32_t , rtems_monitor_object_type_t);
1.8.4.5
