[SPAM] Re: Self-contained one purpose objects
Thu Jul 23 11:59:35 UTC 2015
On 23/07/15 13:51, Joel Sherrill wrote:
> On 7/23/2015 6:36 AM, Sebastian Huber wrote:
>> On 23/07/15 12:29, Chris Johns wrote:
>>> I feel this needs to be a real API not a pseudo-internal API. Making
>>> this an API means the project agrees to support the API, it has tests
>>> and we have to make sure it is working for a release. Oh and it has
>>> documentation.
>> For an API I suggest to use C11/C++11:
>> http://en.cppreference.com/w/c/thread
>> For GCC this is done via this API:
>> https://gcc.gnu.org/viewcvs/gcc/trunk/libgcc/gthr.h?revision=219188&view=markup
> So to parrot back a simple version of what you are proposing.
> + Add simple, self-contained objects for use in supporting
>   performance critical support components (e.g. FreeBSD,
>   gcc, newlib, OpenMP).
> + I assume that other language run-time layers may benefit
>   from this.
> + Use these lighter objects to reimplement gxx wrappers.
> One question is how much of the C11/C++11 threading and synchronization
> will be covered by self-contained objects.
Covered by self-contained objects would be:
* mutexes
* semaphores
* condition variables
* general futex support
NOT covered would be:
* threads
* POSIX keys
I theory we could also do this for threads as well, but this is quite
labour intensive. For POSIX keys, thread-local storage (TLS) could be
used instead.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
