libbsd Makefile issues
Ric Claus
claus at slac.stanford.edu
Thu Jul 23 17:20:08 UTC 2015
On Jun 23, 2015, at 8:30 PM, Gene Smith <gds at chartertn.net> wrote:
> On 06/23/2015 02:18 PM, Joel Sherrill wrote:
>> On 6/23/2015 1:09 PM, Gene Smith wrote:
>>> Here's the things I did to fix the Makefile. I think you added the
>>> quotes (item 1) and maybe item 2. I think the error you are seeing is
>>> due to item 3 since it can't find pcap.h.
>>> 1) Everywhere the string "-D_U_=__attribute__((unused))" appears in the
>>> rules it needs to be quoted. It appears in almost every rule so there
>>> are maybe 100s of them. (I used single quotes, FWIW.)
>>> 2) Everywhere sting "freebsd/usr.sbin/tcpdump/tcpdump-D__FreeBSD__=1"
>>> appears it needs have a space inserted:
>>> "freebsd/usr.sbin/tcpdump/tcpdump -D__FreeBSD__=1"
>>> Quotes aren't required. Again, there a many of these.
>>> 3) Several include paths need to be added:
>>> COMMON_FLAGS += -Ifreebsd/contrib/libpcap
>>> COMMON_FLAGS += -Irtemsbsd/sys
>>> COMMON_FLAGS += -Ifreebsd/usr.sbin/tcpdump/tcpdump
>>> COMMON_FLAGS += -Ifreebsd/contrib/tcpdump
>>> COMMON_FLAGS +=
>>> -Ibuild/arm-rtems4.11-realview_pbx_a9_qemu/testsuite/include
>>> (The last one contains the bsp name so probably needs to be more
>>> general, but seems to work ok as an ad hoc fix.)
A git pull of rtems-libbsd this morning still has the above problems, so I’ve generated the attached patch.
This last -I seems odd. Before I tried building with waf, I could not find a build/ directory anywhere. As mentioned in another e-mail, rtems-libbsd doesn’t currently build for the realview example for me, but for as far as it got, there is only one file that could get picked up by this -I and that is build/arm-rtems4.11-realview_pbx_a9_qemu/testsuite/include/rtems/bsd/test/network-config.h.
I don’t find network-config.h anywhere else in either the rtems-libbsd or rtems trees, nor in those created by make and make install of an RTEMS BSP, so I’m not sure what the proper -I option would be. At any rate, in the attached patch I included it (commented out) as -Ibuild/$(TARGET)-$(BSP)/testsuite/include. With this, both make and waf get to the same place before crashing.
Ric
>> I could repeat those steps but if you have a patch, I am
>> happy to push it.
>> Please.. patch. :)
>> Is it working for you on some target?
> It basically works on realview with qemu but the last COMMON_FLAGS addition for include paths will break it for other bsp's I suspect. But I will send the patch via private email since it is quite large.
> -gene
> devel mailing list
> devel at rtems.org
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150723/b3a76f13/attachment-0001.obj>
