[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni krohini1593 at gmail.com
Thu Jul 23 21:24:22 UTC 2015
On Tue, Jun 23, 2015 at 4:27 PM, Rohini Kulkarni <krohini1593 at gmail.com>
wrote:
> On Tue, Jun 23, 2015 at 1:44 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Please avoid unnecessary white-space changes and white-space at the end
>> of line.
>> Something went wrong with the whitespace. I couldn't see that change in
> my code. I'll rectify it.
>> On 22/06/15 22:59, Rohini Kulkarni wrote:
>>>  .../arm/raspberrypi/startup/mm_config_table.c      |   18
>>>  c/src/lib/libbsp/arm/shared/mminit.c               |   23
>>>  2 files changed, 32 insertions(+), 9 deletions(-)
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> index 8a6d37a..dd1941e 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/startup/mm_config_table.c
>>> @@ -31,39 +31,39 @@ const arm_cp15_start_section_config
>>> arm_cp15_start_mmu_config_table[] = {
>>>      .begin = (uint32_t) bsp_section_fast_data_begin,
>>>      .end = (uint32_t) bsp_section_fast_data_end,
>>> -    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
>>> +    .flags = ARMV7_MMU_DATA_READ_WRITE_CACHED
>>>      .begin = (uint32_t) bsp_section_start_begin,
>>>      .end = (uint32_t) bsp_section_start_end,
>>> -    .flags = ARMV7_MMU_CODE_CACHED
>>> +    .flags = ARMV7_MMU_CODE_CACHED
>>>      .begin = (uint32_t) bsp_section_vector_begin,
>>>      .end = (uint32_t) bsp_section_vector_end,
>>>      .begin = (uint32_t) bsp_section_text_begin,
>>>      .end = (uint32_t) bsp_section_text_end,
>>> -    .flags = ARMV7_MMU_READ_WRITE
>>> +    .flags = ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B
>> Why is this not ARMV7_MMU_CODE_CACHED?  Why can't this BSP use
>> ARMV7_CP15_START_DEFAULT_SECTIONS?
>> One question that came up when I figured out last night that this was the
> only required change. This was the only uncached normal memory section in
> the table. So there were many changes I tried before I made this cacheable.
> Why was it not made cacheable (MMU_CODE_CACHED is read only. But then yes,
> why is this made read write, differently from
> ARMV7_CP15_START_DEFAULT_SECTIONS)
I could finally get back to this issue. I used Pi 1 for debugging, but the
reason for this problem will apply to Pi 2 also.
With text section set to ARMV7_MMU_CODE_CACHED ( which implies read only) ,
a data abort exception occurs with memset() inside bsp_start_clear_bss()
function. An illegal write access to an address according to me.
Making this text section ARMV7_MMU_READ_WRITE causes no problem.
> The TEX bits 2 and 1 have been assigned the value for cacheable memory but
> are used in the defines for CACHED sections.
>>>      .begin = (uint32_t) bsp_section_rodata_begin,
>>>      .end = (uint32_t) bsp_section_rodata_end,
>>> -    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>>> +    .flags = ARMV7_MMU_DATA_READ_ONLY_CACHED
>>>      .begin = (uint32_t) bsp_section_data_begin,
>>>      .end = (uint32_t) bsp_section_data_end,
>>>      .begin = (uint32_t) bsp_section_bss_begin,
>>>      .end = (uint32_t) bsp_section_bss_end,
>>>      .begin = (uint32_t) bsp_section_work_begin,
>>>      .end = (uint32_t) bsp_section_work_end,
>>>      .begin = (uint32_t) bsp_section_stack_begin,
>>>      .end = (uint32_t) bsp_section_stack_end,
>>>      .begin = RPI_PERIPHERAL_BASE,
>>>      .end =   RPI_PERIPHERAL_BASE + RPI_PERIPHERAL_SIZE,
>>> diff --git a/c/src/lib/libbsp/arm/shared/mminit.c
>>> b/c/src/lib/libbsp/arm/shared/mminit.c
>>> index acfbfc0..96ca1ec 100644
>>> --- a/c/src/lib/libbsp/arm/shared/mminit.c
>>> +++ b/c/src/lib/libbsp/arm/shared/mminit.c
>>> @@ -13,6 +13,28 @@
>>>  #include <bsp/linker-symbols.h>
>>>  #include <bsp/mm.h>
>>> +#if (BSP_IS_RPI2 == 1)
>> Such a construct in a shared folder makes no sense.
> Thats right. Will change the integration for the two memory
> initializations
>>  +BSP_START_TEXT_SECTION void bsp_memory_management_initialize(void)
>>> +  /* Enable SMP in auxiliary control */
>>> +  uint32_t actlr = arm_cp15_get_auxiliary_control();
>>> +  actlr |= ARM_CORTEX_A9_ACTL_SMP;
>>> +  arm_cp15_set_auxiliary_control(actlr);
>>> +  uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
>>> +    ARM_CP15_CTRL_A,
>>> +    ARM_CP15_CTRL_AFE| ARM_CP15_CTRL_Z
>>> + arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>>> +    ctrl,
>>> +    (uint32_t *) bsp_translation_table_base,
>>> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>>> +    &arm_cp15_start_mmu_config_table[0],
>>> +    arm_cp15_start_mmu_config_table_size
>>> +#else
>>>    uint32_t ctrl = arm_cp15_get_control();
>>> @@ -27,3 +49,4 @@ BSP_START_TEXT_SECTION void
>>> +#endif
>>> \ No newline at end of file
>>> 1.7.9.5
>>> Rohini Kulkarni
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Rohini Kulkarni
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150724/8c6b5513/attachment.html>
