SMP support for Raspberry Pi 2
Rohini Kulkarni
krohini1593 at gmail.com
Wed Jul 29 09:52:42 UTC 2015
On Tue, Jul 28, 2015 at 12:24 PM, Sebastian Huber <
> Hello Rohini,
> please use the devel list.
> On 28/07/15 07:41, Rohini Kulkarni wrote:
>> Hi,
>> I wish to understand where the interprocessor interrupts are used during
>> the boot process. During final initialization of SMP I can see
>> rtems_interrupt_handler_install(
>> ARM_GIC_IRQ_SGI_0,
>> "IPI",
>> RTEMS_INTERRUPT_UNIQUE,
>> bsp_inter_processor_interrupt,
>> NULL
>> Raspberry Pi 2 does not have the generic interrupt controller. Interrupt
>> routing will have to be handled differently. So I wish to understand how/
>> where it is used. I suppose this might be the problem.
> Sorry, that the documentation is so scattered. I think we should move
> everything into the CPU Architecture Supplement. It would be nice if you
> can help to improve the documentation since you have a different view point.
> You must install the IPI during the system initialization. It is raised
> via the _CPU_SMP_Send_interrupt() function, for an example see
> arm-a9mpcore-smp.c.
I could locate the function in arm-a9mpcore-smp.c. but it would be helpful
if I can know where this being called from, a deeper call hierarchy, so
that I can ascertain this is a problem. I can see a Send_messgae function
call this. But don't know where the send message is being called from.
>> Thanks.
>> On Wed, Jul 22, 2015 at 7:08 PM, Rohini Kulkarni <krohini1593 at gmail.com
>> <mailto:krohini1593 at gmail.com>> wrote:
>> Ok. Qemu suggestion seems helpful for the cache configuration
>> issue though. I am trying with Pi 1.
>> Thanks.
>> On 22 Jul 2015 18:59, "Sebastian Huber"
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> Sorry, I cannot help you here since I never worked with a
>> Raspberry Pi.
>> -- Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
>> des EHUG.
>> Rohini Kulkarni
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150729/b99bcc6d/attachment.html>
