SMP support for Raspberry Pi 2
Rohini Kulkarni
krohini1593 at gmail.com
Sat Jul 4 10:37:40 UTC 2015
On Fri, Jul 3, 2015 at 10:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On July 3, 2015 11:53:07 AM CDT, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> >Any help that I can with this?
> >On 1 Jul 2015 16:59, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >Hi all,
> >I wish to know where the maximum number of processors for a variant are
> >configured. I took a look at some configure scripts. I could see the
> >processor count defined for xilinx-zynq in its configuration file as
> >ZYNQ_CPUS=2.
This looks to be BSP specific and could originate in configure.ac or a .h
file.
I found this under ~/libbsp/arm/xilinx-zynq/configure
# Check whether --enable-smp was given.
if test "$rtems_cv_HAS_SMP" = "yes"; then :
ZYNQ_CPUS="2"
fi
> It is likely that each BSP has an underlying hardware limit.
Yes
> >rtems_configuration_get_maximum_processors() called in gets this
> >configured number. But I don't know from where.
> This is set initially based on the confdefs.h parameter
> CONFIGURE_SMP_MAXIMUM_PROCESSORS or something close to that (on phone).
Ya, I found this piece of code in confdefs.h
#if defined(RTEMS_SMP)
* If configured for SMP, then we need to know the maximum CPU cores.
#if !defined(CONFIGURE_SMP_APPLICATION)
#if !defined(CONFIGURE_SMP_MAXIMUM_PROCESSORS)
#define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
#endif
#else
#error "CONFIGURE_SMP_MAXIMUM_PROCESSORS not specified for SMP
Application"
#endif
#endif
#endif
This piece of code gets the configured number of CPUs. I suppose this
number is not specified and will have to be specified by me somewhere in
the configurations. But I am unable to find out where.
> Ultimately the maximum CPUs for an application is the lower of those
> available or RTEMS is configured for.
Yes.
> >Also where is RTEMS_SMP defined for a bsp?
> A side-effect of building with --enable-smp.
Oh,alright.
> >Thanks.
> >Rohini Kulkarni
> --joel
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150704/93bd0eb6/attachment-0002.html>
