SMP support for Raspberry Pi 2
Rohini Kulkarni
krohini1593 at gmail.com
Mon Jul 13 18:24:31 UTC 2015
I did change the configure file to add support for --enable-smp option.
Ok, I suppose that is the problem.
What is the sb option for?
On 13 Jul 2015 21:13, "Gedare Bloom" <gedare at gwu.edu> wrote:
> Did you change configure, or configure.ac?
> After you change configure.ac or Makefile.am files, you need to run
> sb-bootstrap again.
> On Sun, Jul 12, 2015 at 7:05 AM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > Hi,
> > I don't have #define RTEMS_SMP 1 in cpuopts.h.
> > Have made changes only to libbsp/arm/raspberrypi/configure .
> > On Sun, Jul 12, 2015 at 1:50 AM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> In the build tree, there are exactly two identical "cpuopts.h" files. In
> >> this file you must find a:
> >> /* if SMP is enabled */
> >> #define RTEMS_SMP 1
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > Rohini Kulkarni
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150713/7e3edc43/attachment-0002.html>
