USB Host and MMC/SD Card Stack
Tue Jun 9 07:16:40 UTC 2015
Hello Daniel,
the USB host and MMC/SD card stack is from FreeBSD 9. It works quite
well on our targets.
On 05/06/15 18:27, Daniel Gutson wrote:
> Hi Sebastian,
>     is this industrial-grade fully functional, or has known issues? If
> it has, we could fix them.
> Thanks,
>     Daniel.
> On Mon, May 18, 2015 at 4:01 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 16/05/15 20:53, Afshin Jamaali (Arian) wrote:
>>> Hi Sebastian,
>>> Sorry, it seems a problem exists. The link
>>> "http://git.rtems.org/rtems-libbsd.git/" says:
>>> "No repositories found"
>> Sorry, the right link is:
>> https://git.rtems.org/rtems-libbsd
>>> Best Regards,
>>> Afshin Jamaali
>>> -----Original Message-----
>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
>>> Sent: Friday, May 15, 2015 18:25
>>> To: devel at rtems.org
>>> Subject: Re: USB Host and MMC/SD Card Stack
>>> Hello,
>>> the USB host and MMC/SD card stack for RTEMS is now available via the
>>> libbsd:
>>> I will remove my libusb repository to avoid confusion.
>>> On 27/08/14 14:19, Sebastian Huber wrote:
>>>> Hello,
>>>> I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
>>>> repository area:
>>>> http://git.rtems.org/sebh/rtems-libusb.git/
>>>> It was previously only available as a snapshot:
>>>> https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
>>>> The USB host stack is a port from FreeBSD 8.  The MMC/SD card stack is
>>>> a port from FreeBSD 9.3.
>>>> The libusb is a subset an older version of the libbsd which contains
>>>> also the network stack from FreeBSD 9.3.  We use libusb on some boards
>>>> and projects.  I simply had no time to test the USB and MMC/SD parts
>>>> in libbsd.
>>>> http://git.rtems.org/rtems-libbsd/
>>>> Both libraries lack documentation.  The basic network stack in libbsd
>>>> works well, but more work is required to polish it.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
