GSoC 2015: Raspberry Pi 2 Support
Rohini Kulkarni
krohini1593 at gmail.com
Sat Jun 13 18:29:01 UTC 2015
Hi,
This is regarding Pi 2 SMP support. After powering on, the secondary
mailboxes read one of their four mailbox registers and wait for a non-zero
content to be written. This content is to be the physical address of the
location from where the cores are expected to start execution.
I am stuck at figuring out this address. How should I go about
understanding this?
Thanks!
On 3 Jun 2015 19:44, "Gedare Bloom" <gedare at gwu.edu> wrote:
> On Wed, Jun 3, 2015 at 2:39 AM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > But, I can't say cache configurations have a role here.
> > I'll push my code to my github project soon.
> > P.S. The Pi2 board I possess seems to have broken down. It just isn't
> > turning on. Unable to test further. Will order one immediately.
> Ouch. Make sure you put it in a safe space for development, clear of
> threats like moisture, static shock, and cats.
> > On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >> Hi,
> >> Alan, your suggestion has resulted in much improvement
> >> arm_control=0x1000
> >> This has simply worked! Looks like the other cores were taking up plenty
> >> of time.
> >> I was aware from references that the other cores run a WFI, but ya, did
> >> not get its impact.
> >> Time for each dhrystone has reduced to 7 from 13 and the no of
> dhrystones
> >> per second also increased.
> >> But this is a change only in the config.txt not actually in the boot
> code.
> >> Thanks
> >> Rohini
> >> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore <alan.cudmore at gmail.com>
> >> wrote:
> >>> The caches are being enabled on the RPI 1 BSP. The same code is being
> >>> executed by the RPI 2 BSP, but obviously it’s not sufficient for the
> cache
> >>> setup.
> >>> I have been reading through this long thread, and it is very
> informative:
> >>> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
> >>> I am starting to understand the setup that is required to enable caches
> >>> on the RPI 2. For example this message near the bottom of page 3 gives
> a
> >>> good indication of the speedup available by configuring the MMU and
> caches
> >>> correctly:
> >>> Quote from above thread
> >>> Enabling I/D caches and branch prediction, just like the julia demo
> uses,
> >>> it takes ~12 seconds, or ~21 fps. It's just one core but also a much
> smaller
> >>> loop than the julia demo has.
> >>> Enabling the MMU and mapping memory inner/outer write-back, write
> >>> allocate and the framebuffer inner write-through, no write allocate +
> outer
> >>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
> >>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater L2 cache
> >>> effect.
> >>> End of quote
> >>> The person who posted the above comment (mrvn) posted the code here:
> >>> https://github.com/mrvn/test/blob/master/mmu.cc
> >>> Also, it seems that when the Pi 2 starts up, cores 1-3 are put in a
> wait
> >>> loop always accessing the bus. By putting this option in the
> config.txt file
> >>> you can put the other cores to sleep, speeding up the code on core 1.
> >>> arm_control=0x1000
> >>> It would be worth trying that option to see if the benchmark speeds up.
> >>> Alan
> >>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary <heshamelmatary at gmail.com>
> >>> wrote:
> >>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <
> >>> wrote:
> >>> From what I saw, they have to be enabled separately. Cache/mmu are
> >>> disabled
> >>> upon reset.
> >>> For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
> >>> however I don't know about Pi2 and where its code is.
> >>> [1]
> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
> >>> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com>
> wrote:
> >>> Hi,
> >>> Aren't the MMU/Caches enabled by default for RPi [1]?
> >>> [1]
> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
> >>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
> >>> <joel.sherrill at oarcorp.com> wrote:
> >>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com
> >>> wrote:
> >>> Dr. Joel,
> >>> So we can't say something solely on the basis of this result?
> >>> I don't think so. If Linux performs the same, then what you did is as
> >>> good as it gets.
> >>> However, if Linux is faster then some setting still isn't right.
> >>> You need a reference measurement to have any confidence. It is possible
> >>> you did something but didn't actually turn the cache (or all the cache)
> >>> on.
> >>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >>> I have not run it under linux on pi2 yet. Will have to run and check
> >>> the result.
> >>> On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com>
> wrote:
> >>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com
> >>> wrote:
> >>> HI,
> >>> I tried running the dhrystone benchmark with some changes for
> >>> cache/mmu
> >>> set up.
> >>> However, the output shows a reduction in performance.
> >>> The time to run through the dhrystone has increased from 12 to 13 and
> >>> dhrystones run per second decreased.
> >>> According to this result, things were better with caches disabled.
> >>> I have been working on this since two days and could not figure out an
> >>> improvement. Any pointers?
> >>> How did it do under Linux on the Pi2?
> >>> Thanks.
> >>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
> >>> Hi All,
> >>> I have to implement the cache coherency support for Cortex A7. But for
> >>> A7 MPCore, unlike for A9, I am not able to find any register
> >>> description for the Snoop Control Unit from the TRM.
> >>> I need help here on how to proceed.
> >>> Additionally for A9 there is a single bit for A9 in the Auxiliary
> >>> Control Register which enables cache broadcast operations. The
> >>> register
> >>> format is different for A7 and again I am unable to find how to
> >>> achieve
> >>> the same for A7.
> >>> Thanks!
> >>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
> >>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
> >>> Hi,
> >>> I am working with the code for bsp hooks. I am referring to existing
> >>> ARM multicore bsp codes, zync mainly.
> >>> 1. There are existing hooks for the raspberry pi. Where should the
> >>> code
> >>> for the Pi2 hooks be added?
> >>> The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
> >>> the Pi BSP directory.
> >>> There is already a Pi2 variant of that code built. But we know
> >>> specific
> >>> places where there
> >>> are variances. Depending on the scope of what is different, it can be
> >>> as simple as
> >>> a cpp conditional in a .h to select a value or two implementations of
> >>> a
> >>> single method
> >>> and the Makefile.am picking the right file to build based on the board
> >>> variant.
> >>> The big question to always ask is: Is this specific to the Pi2 and
> >>> incompatible with the Pi?
> >>> Since the Pi BSP is still missing capabilities, it is likely code
> >>> common to both will
> >>> be added this summer. For example, did the mailbox interface change? I
> >>> don't know
> >>> but would guess that it didn't. Each new capability added needs that
> >>> added.
> >>> And any differences need to be analyzed to pick the least intrusive
> >>> way
> >>> to provide
> >>> alternate implementations. Or enable special code like the Pi2 SMP
> >>> support which
> >>> is dependent on --enable-smp and being a Pi2.
> >>> 2. Am I right in understanding that I will have to implement A7
> >>> specific functions as have been for A9? I am referring specifically to
> >>> the arm-a9mpcore-start.h
> >>> Yes.
> >>> If the code is very similar between the a7 and a9, then a discussion
> >>> on devel@ should occur to decide the best way to minimize duplication.
> >>> If you end up with a7 specific code, you should follow the location
> >>> and
> >>> naming patterns already established. That places it in
> >>> libbsp/arm/shared/...
> >>> so it can be used by any BSP with the right SMP core.
> >>> I am referring to existing codes to locate and get hold of what needs
> >>> to be done in the hooks. However, being new to such implementations, I
> >>> am taking longer to understand the details. Any suggestions that might
> >>> help here are welcome
> >>> The answer will depend on the factors listed above. When code can
> >>> be shared, we want to share it across as many BSPs as makes sense.
> >>> When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
> >>> you want to find the way to account for the variation in the least
> >>> intrusive code way possible.
> >>> Thanks!
> >>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >>> Hi,
> >>> Excited to be a part of this edition of GSoC! Thanks to everybody for
> >>> helping me get here and congratulations to all the participating
> >>> students!
> >>> So, now getting to work, firstly I wish to know, specifically from my
> >>> mentors, any changes that must be made to my proposed project or
> >>> schedule.
> >>> Secondly, are there any specifics for the development blog that we
> >>> need
> >>> to create for the project? Over time what is the blog expected to
> >>> convey.
> >>> Also, I have to create a new wiki page for my project as none exists.
> >>> I
> >>> want to know how to add one.
> >>> Rohini Kulkarni
> >>> -- Joel Sherrill, Ph.D. Director of Research & Development
> >>> joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
> >>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
> >>> 722-9985
> >>> Rohini Kulkarni
> >>> Rohini Kulkarni
> >>> --joel
> >>> --joel
> >>> _______________________________________________
> >>> devel mailing list
> >>> devel at rtems.org
> >>> http://lists.rtems.org/mailman/listinfo/devel
> >>> Hesham
> >>> Hesham
> >>> devel mailing list
> >>> devel at rtems.org
> >> Rohini Kulkarni
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150613/f07e4936/attachment-0001.html>
