pc386 libbsd test failures
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Jun 23 16:24:08 UTC 2015
Hi
Things are looking a better if I build with waf but there
is still one failure. I built and ran all these:
unix01 rwlock01 selectpollkqueue01 sleep01 syscalls01
commands01 loopback01 swi01 timeout01 init01 thread01 mutex01
commands01 failed with this. But it also has run to completion.
Looks about a 1/3 failure rate.
=================================== commands01
--- ::1 ping6 statistics ---
1 packets transmitted, 1 packets received, 0.0% packet loss
round-trip min/avg/max/std-dev = 11.330/11.330/11.330/nan ms
PING6(56=40+8+8 bytes) ::1 --> ::1
16 bytes from ::1, icmp_seq=0 hlim=64 time=0.414 ms
round-trip min/avg/max/std-dev = 0.414/0.414/0.414/0.000 ms
assertion "rtems_resource_snapshot_check(&snapshot)" failed: file "../../testsuite/commands01/test_main.c", line 216, function: test_ping6
