[PATCH] Temporary fix for ethernet rx intr hang issue and Disable cache
Gedare Bloom gedare at gwu.edu
Thu Jun 25 17:03:39 UTC 2015
On Thu, Jun 25, 2015 at 12:20 PM, ragunath <ragunath3252 at gmail.com> wrote:
> This patch has two changes that are needed for networking to work in BBB.
> We disable cache as it is causing random values to be learned in the cpsw Address
> Lookup Engine(ALE) causing tx to fail. Vector enable is done after handler is called by the server task.
>  c/src/lib/libbsp/arm/beagle/irq.c                 | 2 ++
>  c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c | 8 +++++---
>  2 files changed, 7 insertions(+), 3 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
> index c6485cd..64e7756 100644
> --- a/c/src/lib/libbsp/arm/beagle/irq.c
> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> @@ -73,6 +73,7 @@ void bsp_interrupt_dispatch(void)
>      _ARMV4_Status_restore(psr);
> +    if(!(irq == 40 || irq == 41 || irq == 42 || irq == 43))
>      bsp_interrupt_vector_enable(irq);
Please follow the RTEMS style conventions. Add spaces in the if, and
bracket/indent the conditional block.
> @@ -94,6 +95,7 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
>    uint32_t mir_reg = get_mir_reg(vector, &mask);
> +  irqs_enabled[vector] = 1;
Was this being done somewhere else?
>    cur = mmio_read(omap_intr.base + mir_reg);
>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>    flush_data_cache();
> diff --git a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> index 157edfa..6cd0f38 100644
> --- a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> +++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> @@ -44,15 +44,17 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
>    /* turn mmu off first in case it's on */
>    uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
> -    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A, /* clear - mmu off */
> +    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A | ARM_CP15_CTRL_I | ARM_CP15_CTRL_C,     /* clear - mmu off */
And break lines > 80 characters.
We should probably make it flexible to control whether to disable the
cache or not. We used to have an ifdef for NETWORKING, but that no
longer applies when using libbsd, so I'm not sure if there is a
suitable option for the CPP. perhaps you should add a BSP_OPT to
control the cache behavior though.
>      ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> -  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
> -    ctrl,
> +  arm_cp15_start_setup_translation_table(
>      (uint32_t *) bsp_translation_table_base,
>      ARM_MMU_DEFAULT_CLIENT_DOMAIN,
>      &beagle_mmu_config_table[0],
>      RTEMS_ARRAY_SIZE(beagle_mmu_config_table)
> +  ctrl |= ARM_CP15_CTRL_M;
> +  arm_cp15_set_control(ctrl);
> 1.9.1
> devel mailing list
> devel at rtems.org
