[PATCH] Temporary fix for ethernet rx intr hang issue and Disable cache
ragunath ragunath3252 at gmail.com
Sun Jun 28 09:54:09 UTC 2015
 c/src/lib/libbsp/arm/beagle/configure.ac          |  3 +++
 c/src/lib/libbsp/arm/beagle/irq.c                 |  5 +++--
 c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c | 17 +++++++++++++++++
 3 files changed, 23 insertions(+), 2 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/configure.ac b/c/src/lib/libbsp/arm/beagle/configure.ac
index b0c99a3..41cd939 100644
--- a/c/src/lib/libbsp/arm/beagle/configure.ac
+++ b/c/src/lib/libbsp/arm/beagle/configure.ac
@@ -33,6 +33,9 @@ RTEMS_BSPOPTS_HELP([CONSOLE_POLLED],[polled console i/o (e.g. to run testsuite)]
 RTEMS_BSPOPTS_SET([BBB_DEBUG],[beaglebone*],[0])
 RTEMS_BSPOPTS_HELP([BBB_DEBUG],[Enable BBB debug])
+RTEMS_BSPOPTS_SET([BBB_CACHE_DISABLE],[beaglebone*],[0])
+RTEMS_BSPOPTS_HELP([BBB_CACHE_DISABLE],[DISABLE CACHE IN BBB])
 RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
 RTEMS_BSP_LINKCMDS
diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
index c6485cd..9f2429c 100644
--- a/c/src/lib/libbsp/arm/beagle/irq.c
+++ b/c/src/lib/libbsp/arm/beagle/irq.c
@@ -73,7 +73,8 @@ void bsp_interrupt_dispatch(void)
     _ARMV4_Status_restore(psr);
-    bsp_interrupt_vector_enable(irq);
+    if ( ! ( irq == 40 || irq == 41 || irq == 42 || irq == 43 ) )
+      bsp_interrupt_vector_enable(irq);
@@ -94,11 +95,11 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
   uint32_t mask, cur;
   uint32_t mir_reg = get_mir_reg(vector, &mask);
+  irqs_enabled[vector] = 1;
   cur = mmio_read(omap_intr.base + mir_reg);
   mmio_write(omap_intr.base + mir_reg, cur & ~mask);
   flush_data_cache();
-  irqs_enabled[vector] = 1;
   return RTEMS_SUCCESSFUL;
diff --git a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
index 157edfa..c8d6526 100644
--- a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
+++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
@@ -44,10 +44,26 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
   /* turn mmu off first in case it's on */
   uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
+#if BBB_CACHE_DISABLE
+    /* clear - mmu off & disable cache */
+    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A | ARM_CP15_CTRL_I | ARM_CP15_CTRL_C,
+#else
     ARM_CP15_CTRL_M | ARM_CP15_CTRL_A,	/* clear - mmu off */
+#endif /* BBB_CACHE_DISABLE */
     ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
+  arm_cp15_start_setup_translation_table(
+    (uint32_t *) bsp_translation_table_base,
+    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
+    &beagle_mmu_config_table[0],
+    RTEMS_ARRAY_SIZE(beagle_mmu_config_table)
+  ctrl |= ARM_CP15_CTRL_M;
+  arm_cp15_set_control(ctrl);
+#else
   arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
     ctrl,
@@ -55,4 +71,5 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
1.9.1
