[PATCH] qemu: Bump git version and disable stack protection
Thu Jun 25 23:27:32 UTC 2015
On 26/06/2015 4:29 am, Joel Sherrill wrote:
> Stack protection must be disabled (--disable-stack-protection) must
> be disabled to avoid bugs in older toolsets. If this can be made
> conditional somehow, it is supposed to be needed on CentOS 5 and 6.
> There are at least two patches in Qemu Patchworks which are supposed
> to fix this but they do not fix it.
> http://patchwork.ozlabs.org/patch/394826/
> https://patchwork.ozlabs.org/patch/410493/
> The bump in the git version is an update to ensure all patches
> that might be related to this issue which have been committed
> were used. But apparently none were. The bump also avoids a period
> where "make install" did not work on CentOS 7 due to a missing BIOS
> file. This was likely a failure in all host environments.
Ok. Please push.
Thanks for sorting this out.
