[PATCH] modified: waf_generator.py Fix incorrect encoding of NET_CFG_GATEWAY_IP and change _IP_IP ending to _IP. Remove _IP_IP ending from NET_TAP_INTERFACE.
Fri Jun 26 04:13:17 UTC 2015
On 24/06/2015 3:04 pm, Gene Smith wrote:
> modified:   wscript
> Re-generated from "./freebsd-to-rtems -m" based on
> waf_generator.py
Pushed.
Thanks.
