[PATCH 7/7] score: Hide SMP lock profiling impl if disabled
Fri Jun 26 07:07:32 UTC 2015
On 26/06/2015 5:01 pm, Sebastian Huber wrote:
> On 26/06/15 01:45, Chris Johns wrote:
>> On 25/06/2015 11:17 pm, Sebastian Huber wrote:
>>> The problem is that empty structures have a different size in C and C++.
>>>   cpukit/score/include/rtems/score/percpu.h  |  17 ++-
>>>   cpukit/score/include/rtems/score/smplock.h | 167
>>>   cpukit/score/src/profilingsmplock.c        |  18 ++--
>>>   cpukit/score/src/smp.c                     |   5 +-
>>>   4 files changed, 127 insertions(+), 80 deletions(-)
>>> diff --git a/cpukit/score/include/rtems/score/percpu.h
>>> b/cpukit/score/include/rtems/score/percpu.h
>>> index a6f7a25..088c31f 100644
>>> --- a/cpukit/score/include/rtems/score/percpu.h
>>> +++ b/cpukit/score/include/rtems/score/percpu.h
>>> @@ -319,10 +319,17 @@ typedef struct Per_CPU_Control {
>>>       SMP_ticket_lock_Control Lock;
>>> -     * @brief Lock statistics context for the per-CPU lock.
>>> -    SMP_lock_Stats_context Lock_stats_context;
>>> +    #if defined( RTEMS_PROFILING )
>>> +       * @brief Lock statistics for the per-CPU lock.
>>> +      SMP_lock_Stats Lock_stats;
>>> +       * @brief Lock statistics context for the per-CPU lock.
>>> +      SMP_lock_Stats_context Lock_stats_context;
>>> +    #endif
>> My only comment is the ability to get any SMP status is difficult. It is
>> either all on or you get nothing. Moving all stats related defines
>> inside #ifdefs and into the global RTEMS_PROFILING define make this
>> harder to do. This is not specifically addressing this lock stats change
>> but on a more general level and this change reminded me.
> This patch changes nothing in terms of functionality.  It just avoids
> zero size structures which unfortunately are implementation-defined in C
> (size is zero with GCC) and C++ (size must be non-zero and is 1 in GCC).
I understand the purpose of the patch and it is fine.
>> I looked into adding some SMP stats to top not long ago I found there
>> was nothing I report on unless profiling was on and if I turned on
>> profiling I got too much such as timing and other nice features.
>> I could not see how to show how many context switches each core had, how
>> many interrupts each core serviced.
> We can enable such things individually.
Then may I suggest we default them to always so code that references
these values can avoid the condition compile options to get at them.
>> I understand the desire to push the limits and not waste a single cycle
>> if we can help it but I actually found it difficult to know if I had SMP
>> built correctly and if it was working from a shell command line. I feel
>> we need some standard stats users can depend on that help us know things
>> are basically working.
>> Chris
> Is this not something that can be done with the linker based tracing?
It is about working production system with an issue. Being able to run
top and see things are happy is a real bonus.
