[PATCH] Temporary fix for ethernet rx intr hang issue and Disable cache
Ben Gras beng at shrike-systems.com
Sun Jun 28 21:27:54 UTC 2015
All,
I really don't want to merge a line like:
+    if ( ! ( irq == 40 || irq == 41 || irq == 42 || irq == 43 ) )
in the generic interrupt dispatch function.
At minimum, replace the IRQ numbers with descriptive macro names and
comment on why it's needed and that it's temporary.
On Sun, Jun 28, 2015 at 11:54 AM, ragunath <ragunath3252 at gmail.com> wrote:
>  c/src/lib/libbsp/arm/beagle/configure.ac          |  3 +++
>  c/src/lib/libbsp/arm/beagle/irq.c                 |  5 +++--
>  c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c | 17 +++++++++++++++++
>  3 files changed, 23 insertions(+), 2 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/configure.ac b/c/src/lib/libbsp/arm/beagle/configure.ac
> index b0c99a3..41cd939 100644
> --- a/c/src/lib/libbsp/arm/beagle/configure.ac
> +++ b/c/src/lib/libbsp/arm/beagle/configure.ac
> @@ -33,6 +33,9 @@ RTEMS_BSPOPTS_HELP([CONSOLE_POLLED],[polled console i/o (e.g. to run testsuite)]
>  RTEMS_BSPOPTS_SET([BBB_DEBUG],[beaglebone*],[0])
>  RTEMS_BSPOPTS_HELP([BBB_DEBUG],[Enable BBB debug])
> +RTEMS_BSPOPTS_SET([BBB_CACHE_DISABLE],[beaglebone*],[0])
> +RTEMS_BSPOPTS_HELP([BBB_CACHE_DISABLE],[DISABLE CACHE IN BBB])
>  RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
>  RTEMS_BSP_LINKCMDS
> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
> index c6485cd..9f2429c 100644
> --- a/c/src/lib/libbsp/arm/beagle/irq.c
> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> @@ -73,7 +73,8 @@ void bsp_interrupt_dispatch(void)
>      _ARMV4_Status_restore(psr);
> -    bsp_interrupt_vector_enable(irq);
> +      bsp_interrupt_vector_enable(irq);
> @@ -94,11 +95,11 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
>    uint32_t mir_reg = get_mir_reg(vector, &mask);
> +  irqs_enabled[vector] = 1;
>    cur = mmio_read(omap_intr.base + mir_reg);
>    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
>    flush_data_cache();
> -  irqs_enabled[vector] = 1;
>    return RTEMS_SUCCESSFUL;
> diff --git a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> index 157edfa..c8d6526 100644
> --- a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> +++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
> @@ -44,10 +44,26 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
>    /* turn mmu off first in case it's on */
>    uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
> +#if BBB_CACHE_DISABLE
> +    /* clear - mmu off & disable cache */
> +    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A | ARM_CP15_CTRL_I | ARM_CP15_CTRL_C,
> +#else
>      ARM_CP15_CTRL_M | ARM_CP15_CTRL_A, /* clear - mmu off */
> +#endif /* BBB_CACHE_DISABLE */
>      ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
> +  arm_cp15_start_setup_translation_table(
> +    (uint32_t *) bsp_translation_table_base,
> +    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
> +    &beagle_mmu_config_table[0],
> +    RTEMS_ARRAY_SIZE(beagle_mmu_config_table)
> +  ctrl |= ARM_CP15_CTRL_M;
> +  arm_cp15_set_control(ctrl);
> +#else
>    arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
>      ctrl,
> @@ -55,4 +71,5 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
> 1.9.1
> devel mailing list
> devel at rtems.org
