[RSB Graphics Library] add patch for library source
Gedare Bloom gedare at gwu.edu
Tue Jun 30 16:54:52 UTC 2015
Chris,
Have we documented how to get custom patches working in RSB?
I CC'ed Hesham too, since he has done this recently, he might have some advice.
Gedare
On Tue, Jun 30, 2015 at 3:24 AM, QIAO YANG <yangqiao0505 at me.com> wrote:
> Hi,
> I'm now working on moving the graphic libraries from rtems-graphic-tool-kits
> into rsb, based on the existing work for libjpeg and the
> rtems-graphic-tool-kits's buid script.
> The port of libpng, libtiff, freetype2 can be review on my github:
> https://github.com/yangqiao/rtems-source-builder/commits/graphics
> While I've got some problems when trying to add patch for source code.
> As what I've read from other cfg files, we should first "patch add" the
> needed patches, then "patch setup" to apply them. When I try to add the
> patch under source-builder/patches/,  it warned me that the path doesn't
> have a proper protocl such as https, git .... And I've found that some
> patches of gdb ..etc are in rtems-tools and the sb-build retrieve them from
> the git server. How can I add a patch from source-builder/patches/ instead
> of uploading to rtems-tools ? Or maybe I missed something?
> Thanks in advance
