[RSB Graphics Library] add patch for library source
Tue Jun 30 18:35:14 UTC 2015
On 6/30/2015 11:54 AM, Gedare Bloom wrote:
> Chris,
> Have we documented how to get custom patches working in RSB?
> I CC'ed Hesham too, since he has done this recently, he might have some advice.
I don't know if it is documented. But if the upstage doesn't have
a patch retrieval system, then it goes in rtems-tools on our side
as far as I understand.
For testing, you can manually place the patch in the RSB patches
directory.
FWIW I have a series of patches for 5 packages to add to the RSB.
> Gedare
> On Tue, Jun 30, 2015 at 3:24 AM, QIAO YANG <yangqiao0505 at me.com> wrote:
>> Hi,
>> I'm now working on moving the graphic libraries from rtems-graphic-tool-kits
>> into rsb, based on the existing work for libjpeg and the
>> rtems-graphic-tool-kits's buid script.
>> The port of libpng, libtiff, freetype2 can be review on my github:
>> https://github.com/yangqiao/rtems-source-builder/commits/graphics
>> While I've got some problems when trying to add patch for source code.
>> As what I've read from other cfg files, we should first "patch add" the
>> needed patches, then "patch setup" to apply them. When I try to add the
>> patch under source-builder/patches/,  it warned me that the path doesn't
>> have a proper protocl such as https, git .... And I've found that some
>> patches of gdb ..etc are in rtems-tools and the sb-build retrieve them from
>> the git server. How can I add a patch from source-builder/patches/ instead
>> of uploading to rtems-tools ? Or maybe I missed something?
>> Thanks in advance
> devel mailing list
> devel at rtems.org
