GSoC 2015: Raspberry Pi 2 Support
Rohini Kulkarni krohini1593 at gmail.com
Sun Jun 21 19:27:55 UTC 2015
There is very little code that had to be added.
I need to clean the code and add conditional call for Pi 2. Then I would be
ready to submit a patch.
 On 22 Jun 2015 00:52, "Gedare Bloom" <gedare at gwu.edu> wrote:
> On Sun, Jun 21, 2015 at 3:04 PM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > I missed mentioning the number of dhrystones in the previous mail.
> > Originally it was 1 million.
> > The new number of dhrystones I executed is 100 million.
> The next thing to do is to figure out what changes are contributing to
> the performance improvement, and then prepare patches. :) Great work
> > On Mon, Jun 22, 2015 at 12:29 AM, Rohini Kulkarni <krohini1593 at gmail.com
> > wrote:
> >> Hi all,
> >> I have managed to get a significant performance improvement with some
> >> changes in configurations.
> >> The measured time was for dhrystones reduced from 12 to "too small to be
> >> measured "
> >> For dhrystones the time was 0.4.
> >> The number of dhrystones per second increased from approximately 83333
> to
> >> 2500000 :)
> >> Thanks!
> >> On Sun, Jun 21, 2015 at 1:32 AM, Rohini Kulkarni <krohini1593 at gmail.com
> >> wrote:
> >>> Hi,
> >>> I have added an SMP related post to my blog to define where exactly in
> >>> the code I need to work. Some feedback to indicate if I am identifying
> the
> >>> work area correctly would be very helpful!
> >>> Thanks!
> >>> On 18 Jun 2015 03:37, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> >>>> Hi all,
> >>>> I have updated my blog to reflect my understanding and attempts for
> >>>> cache performance issue.
> >>>> Lately I have been trying around memory attributes for the
> >>>> mm_config_table. One set of configurations for cacheable memory
> (inner and
> >>>> outer levels)ended up reducing performance further ( which I really
> thought
> >>>> would improve). So this table set up certainly controls performance.
> >>>> The results are not improving after turning on cache. So memory
> sections
> >>>> are perhaps not even getting cached.
> >>>> I get a feeling it has got to do with this mm_config_table.
> >>>> Updates from the github code and blog might help in further
> discussion.
> >>>> Link to github code:https://github.com/krohini1593/rtems/tree/rohini
> >>>> Link to Blog
> >>>> Thanks!
> >>>> On Mon, Jun 15, 2015 at 8:29 PM, Alan Cudmore <alan.cudmore at gmail.com
> >>>> wrote:
> >>>>> Hi,
> >>>>> Some of the code examples may give you some clues. Like this one:
> >>>>> https://github.com/mrvn/test/blob/master/smp.cc
> >>>>> Or this:
> >>>>> https://github.com/PeterLemon/RaspberryPi/tree/master/SMP/SMPINIT
> >>>>> If you still can't figure it out, you can always join the
> >>>>> raspberrypi.org forums and ask on this thread:
> >>>>> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
> >>>>> When it comes to the Pi 2 and SMP, you are our RTEMS expert :)
> >>>>> Thanks,
> >>>>> Alan
> >>>>> On Sat, Jun 13, 2015 at 2:29 PM, Rohini Kulkarni
> >>>>>> Hi,
> >>>>>> This is regarding Pi 2 SMP support. After powering on, the secondary
> >>>>>> mailboxes read one of their four mailbox registers and wait for a
> non-zero
> >>>>>> content to be written. This content is to be the physical address
> of the
> >>>>>> location from where the cores are expected to start execution.
> >>>>>> I am stuck at figuring out this address. How should I go about
> >>>>>> understanding this?
> >>>>>> Thanks!
> >>>>>> On 3 Jun 2015 19:44, "Gedare Bloom" <gedare at gwu.edu> wrote:
> >>>>>>> On Wed, Jun 3, 2015 at 2:39 AM, Rohini Kulkarni
> >>>>>>> > But, I can't say cache configurations have a role here.
> >>>>>>> > I'll push my code to my github project soon.
> >>>>>>> > P.S. The Pi2 board I possess seems to have broken down. It just
> >>>>>>> > isn't
> >>>>>>> > turning on. Unable to test further. Will order one immediately.
> >>>>>>> Ouch. Make sure you put it in a safe space for development, clear
> of
> >>>>>>> threats like moisture, static shock, and cats.
> >>>>>>> > On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com>
> >>>>>>> > wrote:
> >>>>>>> >> Hi,
> >>>>>>> >> Alan, your suggestion has resulted in much improvement
> >>>>>>> >> arm_control=0x1000
> >>>>>>> >> This has simply worked! Looks like the other cores were taking
> up
> >>>>>>> >> plenty
> >>>>>>> >> of time.
> >>>>>>> >> I was aware from references that the other cores run a WFI, but
> >>>>>>> >> ya, did
> >>>>>>> >> not get its impact.
> >>>>>>> >> Time for each dhrystone has reduced to 7 from 13 and the no of
> >>>>>>> >> dhrystones
> >>>>>>> >> per second also increased.
> >>>>>>> >> But this is a change only in the config.txt not actually in the
> >>>>>>> >> boot code.
> >>>>>>> >> Thanks
> >>>>>>> >> Rohini
> >>>>>>> >> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore
> >>>>>>> >> <alan.cudmore at gmail.com>
> >>>>>>> >> wrote:
> >>>>>>> >>> The caches are being enabled on the RPI 1 BSP. The same code is
> >>>>>>> >>> being
> >>>>>>> >>> executed by the RPI 2 BSP, but obviously it’s not sufficient
> for
> >>>>>>> >>> the cache
> >>>>>>> >>> setup.
> >>>>>>> >>> I have been reading through this long thread, and it is very
> >>>>>>> >>> informative:
> >>>>>>> >>> I am starting to understand the setup that is required to
> enable
> >>>>>>> >>> caches
> >>>>>>> >>> on the RPI 2. For example this message near the bottom of page
> 3
> >>>>>>> >>> gives a
> >>>>>>> >>> good indication of the speedup available by configuring the MMU
> >>>>>>> >>> and caches
> >>>>>>> >>> correctly:
> >>>>>>> >>> Quote from above thread
> >>>>>>> >>> Enabling I/D caches and branch prediction, just like the julia
> >>>>>>> >>> demo uses,
> >>>>>>> >>> it takes ~12 seconds, or ~21 fps. It's just one core but also a
> >>>>>>> >>> much smaller
> >>>>>>> >>> loop than the julia demo has.
> >>>>>>> >>> Enabling the MMU and mapping memory inner/outer write-back,
> write
> >>>>>>> >>> allocate and the framebuffer inner write-through, no write
> >>>>>>> >>> allocate + outer
> >>>>>>> >>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
> >>>>>>> >>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater
> L2
> >>>>>>> >>> cache
> >>>>>>> >>> effect.
> >>>>>>> >>> End of quote
> >>>>>>> >>> The person who posted the above comment (mrvn) posted the code
> >>>>>>> >>> here:
> >>>>>>> >>> https://github.com/mrvn/test/blob/master/mmu.cc
> >>>>>>> >>> Also, it seems that when the Pi 2 starts up, cores 1-3 are put
> in
> >>>>>>> >>> a wait
> >>>>>>> >>> loop always accessing the bus. By putting this option in the
> >>>>>>> >>> config.txt file
> >>>>>>> >>> you can put the other cores to sleep, speeding up the code on
> >>>>>>> >>> core 1.
> >>>>>>> >>>  arm_control=0x1000
> >>>>>>> >>> It would be worth trying that option to see if the benchmark
> >>>>>>> >>> speeds up.
> >>>>>>> >>> Alan
> >>>>>>> >>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary
> >>>>>>> >>> <heshamelmatary at gmail.com>
> >>>>>>> >>> wrote:
> >>>>>>> >>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni
> >>>>>>> >>> wrote:
> >>>>>>> >>> From what I saw, they have to be enabled separately. Cache/mmu
> >>>>>>> >>> are
> >>>>>>> >>> disabled
> >>>>>>> >>> upon reset.
> >>>>>>> >>> For the existing Raspberry BSP [1] there's a code for MMU/Cache
> >>>>>>> >>> init,
> >>>>>>> >>> however I don't know about Pi2 and where its code is.
> >>>>>>> >>> [1]
> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
> >>>>>>> >>> On 2 Jun 2015 16:59, "Hesham ALMatary" <
> >>>>>>> >>> wrote:
> >>>>>>> >>> Hi,
> >>>>>>> >>> Aren't the MMU/Caches enabled by default for RPi [1]?
> >>>>>>> >>> [1]
> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
> >>>>>>> >>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
> >>>>>>> >>> <joel.sherrill at oarcorp.com> wrote:
> >>>>>>> >>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni
> >>>>>>> >>> wrote:
> >>>>>>> >>> Dr. Joel,
> >>>>>>> >>> So we can't say something solely on the basis of this result?
> >>>>>>> >>> I don't think so. If Linux performs the same, then what you did
> >>>>>>> >>> is as
> >>>>>>> >>> good as it gets.
> >>>>>>> >>> However, if Linux is faster then some setting still isn't
> right.
> >>>>>>> >>> You need a reference measurement to have any confidence. It is
> >>>>>>> >>> possible
> >>>>>>> >>> you did something but didn't actually turn the cache (or all
> the
> >>>>>>> >>> cache)
> >>>>>>> >>> on.
> >>>>>>> >>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com>
> >>>>>>> >>> wrote:
> >>>>>>> >>> I have not run it under linux on pi2 yet. Will have to run and
> >>>>>>> >>> check
> >>>>>>> >>> the result.
> >>>>>>> >>> On 2 Jun 2015 16:16, "Joel Sherrill" <
> >>>>>>> >>> wrote:
> >>>>>>> >>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni
> >>>>>>> >>> wrote:
> >>>>>>> >>> HI,
> >>>>>>> >>> I tried running the dhrystone benchmark with some changes for
> >>>>>>> >>> cache/mmu
> >>>>>>> >>> set up.
> >>>>>>> >>> However, the output shows a reduction in performance.
> >>>>>>> >>> The time to run through the dhrystone has increased from 12 to
> 13
> >>>>>>> >>> and
> >>>>>>> >>> dhrystones run per second decreased.
> >>>>>>> >>> According to this result, things were better with caches
> >>>>>>> >>> disabled.
> >>>>>>> >>> I have been working on this since two days and could not figure
> >>>>>>> >>> out an
> >>>>>>> >>> improvement. Any pointers?
> >>>>>>> >>> How did it do under Linux on the Pi2?
> >>>>>>> >>> Thanks.
> >>>>>>> >>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
> >>>>>>> >>> Hi All,
> >>>>>>> >>> I have to implement the cache coherency support for Cortex A7.
> >>>>>>> >>> But for
> >>>>>>> >>> A7 MPCore, unlike for A9, I am not able to find any register
> >>>>>>> >>> description for the Snoop Control Unit from the TRM.
> >>>>>>> >>> I need help here on how to proceed.
> >>>>>>> >>> Additionally for A9 there is a single bit for A9 in the
> Auxiliary
> >>>>>>> >>> Control Register which enables cache broadcast operations. The
> >>>>>>> >>> register
> >>>>>>> >>> format is different for A7 and again I am unable to find how to
> >>>>>>> >>> achieve
> >>>>>>> >>> the same for A7.
> >>>>>>> >>> Thanks!
> >>>>>>> >>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
> >>>>>>> >>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
> >>>>>>> >>> Hi,
> >>>>>>> >>> I am working with the code for bsp hooks. I am referring to
> >>>>>>> >>> existing
> >>>>>>> >>> ARM multicore bsp codes, zync mainly.
> >>>>>>> >>> 1. There are existing hooks for the raspberry pi. Where should
> >>>>>>> >>> the
> >>>>>>> >>> code
> >>>>>>> >>> for the  Pi2 hooks be added?
> >>>>>>> >>> The Pi and Pi2 are remarkably similar so Pi2 should be placed
> >>>>>>> >>> inside
> >>>>>>> >>> the Pi BSP directory.
> >>>>>>> >>> There is already a Pi2 variant of that code built. But we know
> >>>>>>> >>> specific
> >>>>>>> >>> places where there
> >>>>>>> >>> are variances. Depending on the scope of what is different, it
> >>>>>>> >>> can be
> >>>>>>> >>> as simple as
> >>>>>>> >>> a cpp conditional in a .h to select a value or two
> >>>>>>> >>> implementations of
> >>>>>>> >>> a
> >>>>>>> >>> single method
> >>>>>>> >>> and the Makefile.am picking the right file to build based on
> the
> >>>>>>> >>> board
> >>>>>>> >>> variant.
> >>>>>>> >>> The big question to always ask is: Is this specific to the Pi2
> >>>>>>> >>> and
> >>>>>>> >>> incompatible with the Pi?
> >>>>>>> >>> Since the Pi BSP is still missing capabilities, it is likely
> code
> >>>>>>> >>> common to both will
> >>>>>>> >>> be added this summer. For example, did the mailbox interface
> >>>>>>> >>> change? I
> >>>>>>> >>> don't know
> >>>>>>> >>> but would guess that it didn't.  Each new capability added
> needs
> >>>>>>> >>> that
> >>>>>>> >>> added.
> >>>>>>> >>> And any differences need to be analyzed to pick the least
> >>>>>>> >>> intrusive
> >>>>>>> >>> way
> >>>>>>> >>> to provide
> >>>>>>> >>> alternate implementations. Or enable special code like the Pi2
> >>>>>>> >>> SMP
> >>>>>>> >>> support which
> >>>>>>> >>> is dependent on --enable-smp and being a Pi2.
> >>>>>>> >>> 2. Am I right in understanding that I will have to implement A7
> >>>>>>> >>> specific functions as have been for A9? I am referring
> >>>>>>> >>> specifically to
> >>>>>>> >>> the arm-a9mpcore-start.h
> >>>>>>> >>> Yes.
> >>>>>>> >>> If the code is very similar between the a7 and a9, then a
> >>>>>>> >>> discussion
> >>>>>>> >>> on devel@ should occur to decide the best way to minimize
> >>>>>>> >>> duplication.
> >>>>>>> >>> If you end up with a7 specific code, you should follow the
> >>>>>>> >>> location
> >>>>>>> >>> and
> >>>>>>> >>> naming patterns already established. That places it in
> >>>>>>> >>> libbsp/arm/shared/...
> >>>>>>> >>> so it can be used by any BSP with the right SMP core.
> >>>>>>> >>> I am referring to existing codes to locate and get hold of what
> >>>>>>> >>> needs
> >>>>>>> >>> to be done in the hooks. However, being new to such
> >>>>>>> >>> implementations, I
> >>>>>>> >>> am taking longer to understand the details. Any suggestions
> that
> >>>>>>> >>> might
> >>>>>>> >>> help here are welcome
> >>>>>>> >>> The answer will depend on the factors listed above. When code
> can
> >>>>>>> >>> be shared, we want to share it across as many BSPs as makes
> >>>>>>> >>> sense.
> >>>>>>> >>> When it is unique to a specific BSP **variant** (e.g. Pi vs
> Pi2),
> >>>>>>> >>> then
> >>>>>>> >>> you want to find the way to account for the variation in the
> >>>>>>> >>> least
> >>>>>>> >>> intrusive code way possible.
> >>>>>>> >>> Thanks!
> >>>>>>> >>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com>
> >>>>>>> >>> wrote:
> >>>>>>> >>> Hi,
> >>>>>>> >>> Excited to be a part of  this edition of GSoC! Thanks to
> >>>>>>> >>> everybody for
> >>>>>>> >>> helping me get here and congratulations to all the
> participating
> >>>>>>> >>> students!
> >>>>>>> >>> So, now getting to work, firstly I wish to know, specifically
> >>>>>>> >>> from my
> >>>>>>> >>> mentors, any changes that must be made to my proposed project
> or
> >>>>>>> >>> schedule.
> >>>>>>> >>> Secondly, are there any specifics for the development blog that
> >>>>>>> >>> we
> >>>>>>> >>> need
> >>>>>>> >>> to create for the project? Over time what is the blog expected
> to
> >>>>>>> >>> convey.
> >>>>>>> >>> Also, I have to create a new wiki page for my project as none
> >>>>>>> >>> exists.
> >>>>>>> >>> I
> >>>>>>> >>> want to know how to add one.
> >>>>>>> >>> Rohini Kulkarni
> >>>>>>> >>> -- Joel Sherrill, Ph.D. Director of Research & Development
> >>>>>>> >>> joel.sherrill at OARcorp.com On-Line Applications Research Ask me
> >>>>>>> >>> about
> >>>>>>> >>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
> >>>>>>> >>> 722-9985
> >>>>>>> >>> Rohini Kulkarni
> >>>>>>> >>> Rohini Kulkarni
> >>>>>>> >>> --joel
> >>>>>>> >>> --joel
> >>>>>>> >>> _______________________________________________
> >>>>>>> >>> devel mailing list
> >>>>>>> >>> devel at rtems.org
> >>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
> >>>>>>> >>> Hesham
> >>>>>>> >>> Hesham
> >>>>>>> >>> devel mailing list
> >>>>>>> >>> devel at rtems.org
> >>>>>>> >> Rohini Kulkarni
> >>>>>>> > devel mailing list
> >>>>>>> > devel at rtems.org
> >>>>>> devel mailing list
> >>>>>> devel at rtems.org
> >>>> Rohini Kulkarni
> >> Rohini Kulkarni
> > Rohini Kulkarni
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150622/dfee7663/attachment-0002.html>
